Like Tree15Likes
 Old 01-04-2012, 03:25 PM   #1
2zz mr-s
dooderek's Avatar
Posts: 5,119   (View Stats)
Groans: 239
Default going pre turbo meth injection
thats right bitches
pre
turbo
meth
injection
dont think anyone is actually running this setup on the ms platform so ill go ahead and do something useful for once and break the ice.
if come into interesting observations. when i log during the day my g/s drop roughly ~30 grams compared to night. IAT's are maybe 20-10 degree's of difference. and we all know that turbos lose their efficiency when the air its compressing gets to hot right? aka moving to the right side of teh island. this should help some of those e85 dudes maxing out injectors on the stock turblows.
ill be using DO shit. ive used parts from labonte/coolingmist/snowperformance/DO and i have to say DO's the only product that has yet to fail. i dont vouch for products i dont use, but ive been running their check valve and fittings for months now no hiccups whatsoever. ill vouch for labonte controllers but they went under sooo poo.
parts should be in shortly i already had a meth kit so all i needed was a d01 nozzle holder (i bought 2 cuz i ghetto fabed my other one) and Y fitting. so we shall see gents we shall fucking see
@phate
Hamilton69 likes this.
The Following 22 Users Say Thank You to dooderek For This Useful Post:
BigjohnB20 (01-11-2012), BlueStreak (01-11-2012), charlesfist (01-04-2012), djuosnteisn (01-11-2012), El_Diablo (05-10-2013), GLORIFIEDBOZO (01-07-2012), Hamilton69 (01-07-2012), JTMS3 (01-07-2012), kmac (01-04-2012), mayer (01-12-2012), MS3-a(sore)ASS-rex (01-06-2012), phate (01-04-2012), RayRay (01-07-2012), rfinkle2 (01-04-2012), Roddiy (05-23-2013), silvapain (01-07-2012), SLOWHATCH (01-04-2012), speed23 (01-06-2012), tddvrrn (04-23-2012), TiGraySpeed6 (01-05-2012), TWOptSL0W (01-04-2012), wolly6973 (01-11-2012)
 Old 01-04-2012, 03:29 PM   #2
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
Thanks for the mention. I've now talked to a few companies about doing this, but I'm not ready to take the plunge, just yet. Hopefully, you pick up some airflow by doing this
-06 MS6
-Corn fed 07 MS3 - Sold
GLORIFIEDBOZO (01-07-2012), rfinkle2 (01-07-2012)
 Old 01-04-2012, 03:35 PM   #3
2zz mr-s
dooderek's Avatar
Groans: 239
its ok clint ill fuck up my car first, plus my turbo cost bout the same as a smokey k04
The Following 3 Users Say Thank You to dooderek For This Useful Post:
djuosnteisn (01-11-2012), GLORIFIEDBOZO (01-07-2012), phate (01-04-2012)
 Old 01-04-2012, 03:40 PM   #4
UnknownSuperhero's Avatar
Posts: 2,462   (View Stats)
The Internet Approves!
Where Do I Position My Water Injection Nozzles
The Following User Says Thank You to UnknownSuperhero For This Useful Post:
kaprikorn (05-10-2013)
 Old 01-04-2012, 03:44 PM   #5
2zz mr-s
dooderek's Avatar
Groans: 239
this may also allievate some surging issue as well. we shall see
 Old 01-04-2012, 04:07 PM   #6
Dust's Avatar
Posts: 192   (View Stats)
Dust is the leader of the worldDust is the leader of the worldDust is the leader of the worldDust is the leader of the worldDust is the leader of the worldDust is the leader of the worldDust is the leader of the worldDust is the leader of the worldDust is the leader of the worldDust is the leader of the worldDust is the leader of the world
Check valve or solenoid for the pre-turbo nozzle?
Dust is offline   Reply With Quote
 Old 01-04-2012, 04:12 PM   #7
2zz mr-s
dooderek's Avatar
Groans: 239
i run both, solenoid pre pump and check valve before the Y according to physics i shouldnt leak, if the solenoid and check valve are closed itll be like holding your finger over a straw, no water should leak out if any, plus vaccum from the car shouldnt be strong enough to pull that much fluid
 Old 01-04-2012, 04:28 PM   #8
Dust's Avatar
Can I recommend that you use the solenoid after the Y and before the preturbo nozzle, and stick the check valve before the post turbo nozzle? I had what you are currently suggesting, without the solenoid pre-pump, and vacuum, and gravity, would suck all of the fluid out of the hose after the check valve. It caused stumbling, and the car to die a few times. Not to mention how bad it must have been on the turbo. I know it will take more work, but I think that your turbo will thank you. I understand your straw analogy, but you will still have 2 openings, at different pressures.
 Old 01-04-2012, 04:32 PM   #9
2zz mr-s
dooderek's Avatar
Groans: 239
ive been running this setup before. i may consider buying another CV and putting them before each nozzle but the solenoid stays pre pump!
 Old 01-04-2012, 09:59 PM   #10
SLOWHATCH's Avatar
Posts: 2,461   (View Stats)
Groans: 274
In for results. Good luck. Seems promising.
 Old 01-06-2012, 08:12 PM   #11
2zz mr-s
dooderek's Avatar
Groans: 239
lewk what we haz here
The Following User Says Thank You to dooderek For This Useful Post:
SLOWHATCH (01-06-2012)
 Old 01-06-2012, 09:21 PM   #12
SLOWHATCH's Avatar
Groans: 274
Can't this be simplified and install the nozzle into the tih?
 Old 01-06-2012, 11:05 PM   #13
Bob Ross Fanclub
Tomas's Avatar
Posts: 3,811   (View Stats)
Wrong.
Been running a 0.75 nozzle pre terboh for a while now.
Sorry to spoil your glory.
The Following 15 Users Say Thank You to Tomas For This Useful Post:
ABolewski (02-15-2013), BlueStreak (01-11-2012), Chimmike (01-07-2012), cld12pk2go (01-08-2012), djuosnteisn (01-11-2012), EdgeAutosport.com (01-11-2012), El_Diablo (05-10-2013), helmetface (09-20-2012), IshiKage (01-11-2012), Mchart (01-07-2012), Micha (03-13-2014), MS3-a(sore)ASS-rex (01-06-2012), NJSPEED3 (01-12-2012), rfinkle2 (09-20-2012), SLOWHATCH (01-07-2012)
 Old 01-06-2012, 11:35 PM   #14
2zz mr-s
dooderek's Avatar
Groans: 239
keyword "think"
and also. fuck you, i wanted that glory!!!!!1111
please share your results
The Following 4 Users Say Thank You to dooderek For This Useful Post:
Bucker (01-15-2012), djuosnteisn (01-11-2012), mr.speedy3 (09-07-2013), SLOWHATCH (01-07-2012)
 Old 01-06-2012, 11:45 PM   #15
YZF-R6's Avatar
Posts: 189   (View Stats)
YZF-R6 is the leader of the worldYZF-R6 is the leader of the worldYZF-R6 is the leader of the worldYZF-R6 is the leader of the worldYZF-R6 is the leader of the worldYZF-R6 is the leader of the worldYZF-R6 is the leader of the worldYZF-R6 is the leader of the worldYZF-R6 is the leader of the worldYZF-R6 is the leader of the worldYZF-R6 is the leader of the world
Im not trying to sound like a smartass but am I seriously curious... Isnt this going to be very hard on the compressor wheel?
2010 MS3 Liquid Silver: TRZ Poly RMM, Cobb AP, PERM (Load-Based FTW), CP-E HPFP, SURE Aeros, HTP TIP, Corksport TMIC, SURE Boost Tubes, Magnaflow CBE, Corksport T/P, JBR LE Shift Knob & Weight, Redline MTL, Swift Spec-R, TSW Nurburgring 18x8.5, Nitto NT555 235/40/18.
If You Don't Like The Pu, Don't Play In The Pu.
YZF-R6 is offline   Reply With Quote
 Old 01-07-2012, 12:11 AM   #16
2zz mr-s
dooderek's Avatar
Groans: 239
potentially good sir, potentially. however especially with full meth and the fine spray from small nozzle there should a decreased chance of impeller damage.
 Old 01-07-2012, 12:21 AM   #17
TRex's Avatar
Posts: 3,139   (View Stats)
tiny little droplets hitting the turbine at high speed.......sounds.....unwise.....
 Old 01-07-2012, 12:23 AM   #18
2zz mr-s
dooderek's Avatar
Groans: 239
SHUN THE NONBELIEVER
The Following 10 Users Say Thank You to dooderek For This Useful Post:
ABolewski (02-15-2013), GLORIFIEDBOZO (01-07-2012), helmetface (09-20-2012), kmac (01-11-2012), phate (01-07-2012), Roddiy (05-23-2013), ScarMS3 (01-11-2012), SLOWHATCH (01-07-2012), thanox2 (01-12-2012), TRex (01-07-2012)
 Old 01-07-2012, 12:26 AM   #19
Eth Fiend
phate's Avatar
SSHHHHHHHHHUUUUUUUUUUNNNNNNNNNNNNNN!!!!!!!!!!
-06 MS6
The Following 7 Users Say Thank You to phate For This Useful Post:
ABolewski (02-15-2013), derek13p (05-06-2013), GLORIFIEDBOZO (01-07-2012), helmetface (09-20-2012), Roddiy (05-23-2013), ScarMS3 (01-11-2012), TRex (01-07-2012)
 Old 01-07-2012, 12:27 AM   #20
2zz mr-s
dooderek's Avatar
Groans: 239
if your still awake you must be drunk!!!
 Old 01-07-2012, 12:39 AM   #21
COOL STORY BRO
Hamilton69's Avatar
Posts: 2,418   (View Stats)
Hamilton69 is the leader of the worldHamilton69 is the leader of the worldHamilton69 is the leader of the worldHamilton69 is the leader of the worldHamilton69 is the leader of the worldHamilton69 is the leader of the worldHamilton69 is the leader of the worldHamilton69 is the leader of the worldHamilton69 is the leader of the worldHamilton69 is the leader of the worldHamilton69 is the leader of the world
Groans: 179
Groaned at 179 Times in 30 Posts
cant wait to see how this goes, nator socal is bringin the shit....twin turbo's, pre turbo meth (who doesnt like meth?) sounds like more fun than a one legged hooker
JBR 3.5" WHALE PENIS-su tmic- sure track urethane rmm- corksport catless 3" downpipe- ultimate racing tp-OBX 3" cat back -rally armor urethane flaps-Cobb Accessport FINKLE TUNED-sure shift anchors-autotech hpfp internals-HKS BOV VTA -jbr heavy shift knob- 245-40-r18 Falken 329's-paint matched uber smiley
ZOOM ZOOM BOOM
Hamilton69 is offline   Reply With Quote
The Following User Says Thank You to Hamilton69 For This Useful Post:
thehead (02-27-2012)
 Old 01-07-2012, 05:48 AM   #22
Bob Ross Fanclub
Tomas's Avatar
keyword "think"
Except for ridiculously low IAT's there is really not much to it.
I use it mainly to keep everything running cool during road racing. For street driving it is disconnected. That's why you see that stud sticking out of the push lock. It's a blind piece of hose.
I do not use it to increase power output via higher timing / boost.
I am sure you mean the compressor wheel. Not turbine. The pic I posted is my intake. Not exhaust manifold. Lol.
And no. It's not unwise.
All large bore diesel engine turbochargers have water injection pre turbo for cleaning purposes. It's usually engaged every 48 to 72 after continuous operation by dumping water a few inches before the compressor wheel . Although there is wear to the leading edge of the impeller veins after about 40K to 50K running hours, the creep and fatigue damage to the alloy due to regular operation is of more concern than the wear from the water. Wear is minimal.
The Following 9 Users Say Thank You to Tomas For This Useful Post:
ABolewski (02-15-2013), El_Diablo (05-10-2013), follman8r (11-07-2016), helmetface (09-20-2012), kmac (01-11-2012), phate (01-07-2012), redboat (05-01-2013), TRex (01-07-2012), wolly6973 (01-11-2012)
 Old 01-07-2012, 06:03 AM   #23
Mchart's Avatar
Posts: 980   (View Stats)
Mchart is the leader of the worldMchart is the leader of the worldMchart is the leader of the worldMchart is the leader of the worldMchart is the leader of the worldMchart is the leader of the worldMchart is the leader of the worldMchart is the leader of the worldMchart is the leader of the worldMchart is the leader of the worldMchart is the leader of the world
Groans: 54
Groaned at 42 Times in 32 Posts
I'm not quite sure why more people aren't running it this way to begin with. It seems like it is easier to install then post turbo, and it makes more sense to me to do it pre-turbo side to begin with.
Mods - Six (6) Kenny Loggins albums in each position in my 6 disc changer.
HOW-TO Tune a car - http://youtu.be/5ET9YXP1M04
Mchart is offline   Reply With Quote
 Old 01-07-2012, 06:04 AM   #24
Tomas,
When you posted in the e85 thread that you were knocking, even with e85, were you using this set-up?
Also how did your safe seals work out?
Did it stop your kr?
 Old 01-07-2012, 06:10 AM   #25
Bob Ross Fanclub
Tomas's Avatar
Tomas,
Hey Rob,
Sorry to report that I haven't installed the seals yet. When I took out the IM, after porting it, I did not have the time to also do the seals.
I did not have the pre-turbo nozzle hooked up when reporting the KR in the E85 thread. It was installed but not hooked up.
I have other issues to deal with at the moment with the car so I can't say whether the KR is still there or not.
 Old 01-07-2012, 08:47 AM   #26
Eth Fiend
phate's Avatar
Hey Rob,
@Tomas - Would you be able to do some testing for this setup? We aren't looking to turn up boost or increase timing because of it, or lower BAT's. We are looking to make the turbo "grow" just a bit. Could you grab some runs with the pre-turbo injection on and off, so we can get an idea if there is an increase in airflow because of it?
-06 MS6
GLORIFIEDBOZO (01-07-2012), JTMS3 (01-07-2012), rfinkle2 (01-07-2012), wolly6973 (01-11-2012)
 Old 01-07-2012, 09:04 AM   #27
GLORIFIEDBOZO's Avatar
Posts: 1,928   (View Stats)
GLORIFIEDBOZO is the leader of the worldGLORIFIEDBOZO is the leader of the worldGLORIFIEDBOZO is the leader of the worldGLORIFIEDBOZO is the leader of the worldGLORIFIEDBOZO is the leader of the worldGLORIFIEDBOZO is the leader of the worldGLORIFIEDBOZO is the leader of the worldGLORIFIEDBOZO is the leader of the worldGLORIFIEDBOZO is the leader of the worldGLORIFIEDBOZO is the leader of the worldGLORIFIEDBOZO is the leader of the world
In for win! Very interested in doing this myself.
"Intelligence isn't the ability to store information, but to find it" - Albert Einstein
"When I read about the evils of drinking, I quit reading" - Henry Youngman
GLORIFIEDBOZO is offline   Reply With Quote
 Old 01-07-2012, 09:42 AM   #28
2zz mr-s
dooderek's Avatar
Groans: 239
Another threads thunder stolen
The Following 9 Users Say Thank You to dooderek For This Useful Post:
djuosnteisn (01-11-2012), kmac (01-11-2012), phate (01-07-2012), rfinkle2 (01-07-2012), Roddiy (05-23-2013), ScarMS3 (01-11-2012), silvapain (01-07-2012), SLOWHATCH (01-07-2012), Tomas (01-07-2012)
 Old 01-07-2012, 10:35 AM   #29
Bob Ross Fanclub
Tomas's Avatar
HAHAHA. didn't mean to steal your thunder.
What nozzle size are you going to use? You said D01 nozzle holder?
I am having issues calibrating my MAF curve with the 4" intake. I also have a boost leak somewhere I can't find. In addition to this, I took off my crankshaft position sensor due to a code I threw thinking it was kapputt when it wasnt. So now I have to get a timing peg and align the sensor. Not sure when I'll be able to run some tests but if I am done before Derigo hooks up his China charger + meth cooler mod I'll post a couple of pulls with and sans pre terboh juicer.
Oh btw. Now that I remember. I am on a load based map so cooler IATs won't mean I will flow more. IIRC it just ran less boost to get to the same load / g/s.
The Following 4 Users Say Thank You to Tomas For This Useful Post:
helmetface (09-20-2012), kmac (01-11-2012), rfinkle2 (01-07-2012), wolly6973 (01-11-2012)
 Old 01-11-2012, 01:44 AM   #30
2zz mr-s
dooderek's Avatar
Groans: 239
got the meth installed with the help of good ol jordan (keefover)
intake out, staring at the whale penis
OT, but my valve cover filter catching all that nasty shit (sitting in meth)
compressor inspection prior to install
one day when you become baller as me, youll have an rx7 as your work bench too
my old nozzle (chinkus rigged)
meth flowing along the charge pipe, in this pic its actually going away from the engine (surge time)
flowing towards the engine
solenoid
testing this shit out
pre turbo nozzle, sanded down to where it meets the pipe and some liquid thread sealant
pre tb
__________________________________________________ ________________________
after a run, took the intake apart for some inspections
hard to tell from the pic but you can almost see the spiral pattern from the left over dye as it sucked into the turbo. pretty cool
turbo after
results
Log 102 is no pre turbo meth
Log 103 is with pre turbo meth
if you look you can see that the 102 "without meth" flowed slightly more than 103 "with meth" even though on 103 i left off a few rpms quicker.
heres my theory. the lower "recorded" flow i believe is attributed to the higher intake temps from 103. notice there is a 8 degree difference from 103 and 102.
if anyone can enlighten me on how the ecu calc's maf g/s i would be most appreciative. most certain intake temps defitnatly play a factor and considering how theres no IAT post turbo if i was infact flowing more there wouldnt be a way of me knowing unless i mounted the maf somewhere to make post turbo.
and finally here are my vd dyno results. now before anyone says shit this is only ONE run. i am NOT making a conclusive statement. this is just data that has been currently collected. VD is known to have alot of different variables effecting the graph. these 3 graphs were done on the same road. 103 and 102 are the same map but 103 with pre turbo meth. the last one was a previous map with slightly lower timing.
update yall as soon as i gets moar data!
The Following 15 Users Say Thank You to dooderek For This Useful Post:
86AmishMs3 (01-11-2012), Adam is so pro (04-26-2012), BlueStreak (01-11-2012), cocoanton (03-31-2013), djuosnteisn (01-11-2012), El_Diablo (05-10-2013), helmetface (09-20-2012), JacksonMS30 (01-11-2012), kmac (01-11-2012), rghispanic88 (01-11-2012), SLOWHATCH (01-11-2012), tddvrrn (04-23-2012), thehead (02-27-2012), TRex (01-11-2012), wolly6973 (01-11-2012)
 Old 01-11-2012, 06:56 AM   #31
wolly6973's Avatar
Posts: 2,364   (View Stats)
Groans: 386
That was with 100% meth, right?
 Old 01-11-2012, 07:13 AM   #32
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
your engine bay looks like shit.
good numbers gain though
07 MS3
The original Genpoo Hater
IshiKage (01-11-2012), rghispanic88 (01-11-2012)
 Old 01-11-2012, 08:13 AM   #33
Ziggo's Avatar
Posts: 3,843   (View Stats)
BATs are what you need to pay attention to. g/s is calculated directly from the MAF sensor, which is also where the IAT is read from.
Zigatapatalka
Ask Me About My:
 Old 01-11-2012, 09:23 AM   #34
Eth Fiend
phate's Avatar
Zigatapatalka
We aren't doing this to lower BAT's. We're doing this to watch the change in airflow by evaporating meth before the compressor.
I'll take a look at the logs later on my other computer!
-06 MS6
 Old 01-11-2012, 09:35 AM   #35
IshiKage's Avatar
Posts: 6,231   (View Stats)
Groans: 278
Props OP for making a thread and for being 2nd to go pre ign meth. oh, and @Tomas is the fuckin Man
2015 Mazda 6
 Old 01-11-2012, 10:03 AM   #36
2zz mr-s
dooderek's Avatar
Groans: 239
Screw you tomas!!!!a
 Old 01-11-2012, 10:20 AM   #37
2zz mr-s
dooderek's Avatar
Groans: 239
yes 100%
mike can i have your dick
anyone got a good idea how to test for increased g/s? i suppose mounting the maf sensor 1 foot post turbo would show the change in air temps and possibly reflect a better g/s.
only other thing is just get on a roller dyno and do a couple with and without pre turbo wmi.
haha didnt expect you to reply early clint, still thought youd be in your drunken stupor
 Old 01-11-2012, 10:36 AM   #38
Will fuck up ur day
Chimmike's Avatar
Groans: 433
y
I'm not so sure the increased g/s really matters if there's more power being made. g/s isn't totally definining power.
What you're doing is making the turbo more efficient with the BAT's as mentioned before.
Shit....................................this brings up a potentially better point:
What if a d.05 pre-turbo is more effective than, say, a d03-04 pre-throttle body for decreasing BATs? You'd end up consuming less methanol for the same drop in BAT's.............hmmmmmm
07 MS3
 Old 01-11-2012, 11:07 AM   #39
2zz mr-s
dooderek's Avatar
Groans: 239
but in this equation i am more concerned about "flow" than power. also running pre turbo nozzles will not make a charge cooler than a large one pre tb at the same time too much meth pre compressor will make an intercooler obsolete or even make it heat up the charge
 Old 01-11-2012, 11:30 AM   #40
Eth Fiend
phate's Avatar
yes 100%
You'll be able to see a change in flow, if there is one, simply by looking at MAF g/s between the runs. That g/s figure is extremely important, as it is how fueling is calculated. Any change will be seen there.
What's the difference between say 300g/s @ 75° post turbo meth vs 300g/s @ 75° pre-turbo meth? I'll venture a guess and say nothing except the amount of methanol it took to get there.
Now, if we see a change in hp, but no change in airflow or BAT's, what can we attribute it to? The extra meth we are injecting? IDK but that initial result looks promising.
@Derigo, can you grab like 5 or 10 runs with each set up (pre-turbo vs no pre-turbo)? We can average the runs and get a better idea in vd if there actually was power gained. Like you said, lots of variables in vd, but an average over 10 runs should give us a very good idea what is going on.
-06 MS6
Meth Injection without a tune? nynhex 2010 MS3 - Fuel, Nitrous & Water Injection 7 03-27-2010 01:59 PM
Meth injection installs sleeper329 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 16 03-08-2010 01:12 AM
Devils Own Meth Injection 11cruzito11 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 28 10-17-2009 07:40 PM
meth injection problem. 1quik3 MazdaSpeed 3/6 - Turbo Induction 3 08-10-2009 02:06 PM
Page generated in 0.62989 seconds with 36 queries
