 Old 10-11-2009, 11:12 AM   #1
The spark actually happens at the end of the pink trace (falling edge). When the signal is high, it is charging the coil. When the edge falls, the spark happens. I counted about 18 crank pulses from the missing tooth to the end of the spark event in this picture. Every crank pulse is 6 degrees. So 6*18 = 108 degrees. Since spark happens at 10 degrees before TDC, that means it is 108+10 = around 118 degrees from the missing tooth to TDC. Which is correct. Nice capture!
As for logging the injectors, nice video! That shows me the command from the ECU is enough to look at.
I can't tell from the video if the ECU moves WHEN it injects around. As you see, when you rev it, the crank pulses become faster. So this might be tricky, but keeping the missing tooth on the screen will give us the reference needed (as long as we can still count teeth). Are you logging on the scope itself or taking a video of it? If taking a video, vary load very slowly with a passenger and change the timescale as RPM and load increases so that you can still see the missing tooth.
Great stuff so far! We're getting somewhere!
djuosnteisn (10-11-2009), MarkyMark (10-11-2009)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f303/have-you-measured-when-injectors-39696/
PERM's MS6 This thread Refback 09-10-2012 05:17 PM
General Speed 6 Build & Product Thread This thread Refback 01-27-2012 01:45 PM
Measured the injectors - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Refback 10-13-2011 12:16 AM
Which meth kit to get - Page 3 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Refback 06-18-2011 10:14 AM
What's new for the MZR 2.3L DISI engine? This thread Refback 03-23-2011 07:33 PM
Injectors - Mazda 6 Forums : Mazda 6 / Mazda Atenza Forum This thread Refback 03-28-2010 02:50 PM
Fuel Pressure Tuning - Page 3 - Mazda 6 Forums : Mazda 6 / Mazda Atenza Forum This thread Refback 03-08-2010 07:58 PM
Ported intake hp - Page 2 - Mazda 6 Forums : Mazda 6 / Mazda Atenza Forum This thread Refback 02-25-2010 05:15 AM
E85 with COBB TUNE - Mazda6 / Atenza This thread Refback 02-02-2010 05:27 PM
Mazda6 / Atenza > Ported intake hp This thread Refback 11-27-2009 04:02 PM
Fuel Pressure Tuning - Mazda6 / Atenza This thread Refback 11-15-2009 02:14 PM
Injectors - Mazda6 / Atenza This thread Refback 11-13-2009 07:46 AM
Exhaust caming??? - Mazda6 / Atenza This thread Refback 11-04-2009 05:41 AM
North American Mazdaspeed club This thread Refback 10-28-2009 03:04 PM
Which meth kit to get - Mazda6 / Atenza This thread Refback 10-26-2009 11:10 AM
Ported intake hp - Mazda6 / Atenza This thread Refback 10-21-2009 08:47 PM
Measured the injectors - Mazda6 / Atenza This thread Refback 10-10-2009 10:33 PM
Mazdaspeed owners are smrt. - Carolina Mazdas This thread Refback 10-10-2009 06:24 PM
Who makes our injectors? cbspeed3 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 45 11-04-2009 10:19 AM
Injectors speeddemon MazdaSpeed 3 - Engine, Transmission & Driveline 17 10-28-2009 11:49 PM
Review: 2010 Ford Taurus SHO gets measured against the original Haltech Automotive News 0 09-14-2009 10:30 AM
What size are the stock injectors on the MS3? Haltech MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 15 05-16-2008 01:57 AM
Page generated in 0.33692 seconds with 22 queries
