 Old 07-14-2019, 06:42 PM   #1
The_big_dill's Avatar
Posts: 38   (View Stats)
The_big_dill has a spectacular aura aboutThe_big_dill has a spectacular aura about
Default High fuel pressure concern
Hi all,
Recently rebuilt an engine that had a burnt valve.
Engine starts great, but:
- Issues idling
- Lean AFR
- Fuel pressure too high (over 10K PSI)
During rebuild:
- Injectors cleaned (filters replaced)
- Used Autotech HPFP internals installed
- CS Injector seals with all new OEM upper seals
My searching has led me to issues with low pressure, but haven't found anyone with this problem.
I uploaded a log.
There may be more than 1 issue at play here. The O2 sensor grounds that were bolted to brackets have not been secured because all those brackets rusted away.
On a side note, engine sounds like a diesel once its warm. I thought it was the HPFP, but it doesn't sound right:
https://www.youtube.com/watch?v=h14Xu2gsw24
Disclaimer: I have never been in a properly running speed3, so I have no reference.
The_big_dill is offline   Reply With Quote
 Old 07-15-2019, 07:26 AM   #2
Fstrnyou's Avatar
Posts: 2,498   (View Stats)
Even if the ECU got 0 volts form the rail pressure sensor, the highest pressure possible is about 2199psi or something like that.
I'm not sure if the ECU would recognise or interpret a negative voltage to read higher pressures.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
 Old 07-15-2019, 07:31 AM   #3
Police - Grammarhead
Vansquish's Avatar
Originally Posted by The_big_dill View Post
Hi all,
- Issues idling
- Lean AFR
During rebuild:
I uploaded a log.
So...you both need to read more carefully. The OP's AP is reading in kPa, not in PSI. 13,000kPa of fuel pressure is 1885psi, which is fine for that vehicle. You can change the scale to PSI in the AP's settings menu, if memory serves.
The lean AFRs are interesting, because the ECU appears to be trying to pull additional fuel (make the mixture even leaner) despite already being very lean at idle. To me, that suggests that you've got one or more of the following:
- a bad MAF calibration (more generally, a bad tune, or a tune that isn't appropriate for your modifications - in particular the ID of the MAF housing)
- a failing or incorrect MAF sensor (seems unlikely, as the car is running and seems to be reading reasonable numbers)
- one or more bad O2 sensors (seems unlikely, as the AFR numbers and fuel trims aren't pegged at specific values)
The rattling doesn't sound good though. It sounds way too loud to be injectors, and it appears to be coming from all four cylinders rather than just the driver's side or just the passenger's side of the motor. If it was the former, I would suspect the HPFP and/or a failing HPRV, and if it was only the latter, I would suspect the timing chain.
 Old 07-15-2019, 07:36 AM   #4
Fstrnyou's Avatar
My reading is top notch. He said PSI so I responded in kind. My claims that 2199PSI is about the max the ECU can interpret is, for the sake of arguement, correct.
Other rides:
History:
Vansquish (07-15-2019)
 Old 07-15-2019, 07:41 AM   #5
Vansquish's Avatar
That may be, but the OP's video clearly shows kPa. Operating under the presumption that you had watched the video, there was only one conclusion to make: neither you nor he had recognized the units being used.
Fstrnyou (07-15-2019)
 Old 07-15-2019, 07:44 AM   #6
Fstrnyou's Avatar
Perhaps my reading is bad then. I thought he posted a datalog, which I am not able to open on my phone, so I didn't click it.
You win.
Other rides:
History:
 Old 07-15-2019, 08:49 AM   #7
No need for a flame war haha.
I appreciate both of your inputs, admire the attention to detail, and learned something new. And to pay attention better.
I am glad it's all good with the fuel pressure.
Regarding the timing, I have been doing some thinking and reading and I'm pretty positive I messed up one step in timing the engine.
All timing components are new and OEM, but I believe I tightened the cam sprockets before I released the tensioner. Sound like a possible cause to this?
Next steps, I would like to retime without removing the timing cover.
- could I loosen the exhaust sprocket, reapply the chain tensioner and retighten, or do I have to do this on the intake side?
- If I loosen the cam bolt, I must replace the friction washer, correct? If so, can I remove the sprocket without removing the timing cover?
The only other thing is that the crank position sensor was installed without any marking or positioning. Do you think my symptoms could be a cause of the ckp position?
Thanks again!!
 Old 07-15-2019, 09:06 AM   #8
Vansquish's Avatar
There's no flaming going on here at all, and if there are any hurt feelings, I don't think any of us intended that to be the outcome.
In any case, if you do retime the motor, you definitely need new friction washers, as they are single-use items which will fail if you try to reuse them.
Having not messed with the physical timing components on my car, I don't know if your tensioner-theory makes sense. I'll happily defer to someone with more knowledge than I have.
In any case, what is the internal diameter of your MAF housing? Does the MAF housing have an air-straightener? What tune are you running?
 Old 07-15-2019, 09:59 AM   #9
Fstrnyou's Avatar
What are these friction washers you speak of? Lol
Call me crazy, but I never have to worry about that garbage ever again with pinned cams.
Other rides:
History:
 Old 07-15-2019, 10:00 AM   #10
Thanks for the quick reply.
I did read that lean running could be a result of MAF calibration being required. It is the Cobb intake, from filter to the turbo. ( I believe it's called TIH and SF). I am running the Cobb stage 1 tune, iirc.
Should the tune have the maf calibration already set?
 Old 07-15-2019, 10:20 AM   #11
Vansquish's Avatar
You should definitely be running a map with the MAF calibration for that particular intake. I believe that COBB offers an off-the-shelf (OTS) map that includes the SF and TIH/TIP as part of the calibration. That said, you really should regard the COBB OTS maps as a stopgap measure and nothing more. They are really pretty piss-poor calibrations for this platform.
https://www.cobbtuning.com/maps/2007...stage-1-sf-map
Edit:
Please note that if you have an aftermarket downpipe, you need to be running a map that accounts for that fact as well.
https://www.cobbtuning.com/maps/2007...dm-stage-2-map
 Old 07-15-2019, 11:34 AM   #12
Jeff23spl's Avatar
Posts: 2,233   (View Stats)
Usually the last step after a timing job is to give it few turns in the right direction (clockwise in this case) and re check if everything is still ok....This let the tensioner set properly and let you see if the play was taken on the right side.
you can still check this prior to loosen any bolts. Just put back the crank pin to set TDC when the first cams lobes are facing and check if the cams are timed ok with the rear end flat surface aligned horizontally....(As explained in the ''how to vvt'' )
I don't think you could replace a washer or bolt without removing the cover to release the tensioner.
Trying to just loosen it and tight it back at the correct place is a risk that could bend valves if oil drop on the old washer and it slip later...
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
 Old 07-15-2019, 09:14 PM   #13
Thanks for all the great replies, this community is awesome!
I tore into it this evening and found the recirc valve hose was no longer attached to the TIP... nice and hidden under the intake. I attached it and the car runs so much better, I still need to check AFRs.
As for the knocking/ticking coming from the valve cover, it only happens when the engine is warm... When the engine is cold, the engine runs smooth and sounds right. The warmer it gets the worse the sound is.
Is this Valve lash or a defective VVT? I will re-check valve lash, but I am not sure how long the VVT has been sitting on the dealers shelf, will also check part number of the VVT when I check lash.
 Old 07-16-2019, 10:10 AM   #14
Jeff23spl's Avatar
nice find ! this is something the usual boost leak test would have showed very quick.
You can still look at your timing for peace of mind....but a new vvt should be fine, it needs to wear out first before going bad even if you didn't get the updated unit (And i would be surprised if Mazda had stocks of the original bad units on shelf for sale...)
Wife drive 2010 CX7
 Old 07-16-2019, 06:58 PM   #15
I do not know if it is anything to do with the timing really, as the sound sounds like its coming from the center of the valve cover, not the timing chain tunnel or the timing cover. But that is the only thing I believe I made a mistake assembling.
I started a new thread for the chain problem as it seems like this is the wrong forum section for this discussion.
Fuel pressure too high after WOT SlamChop 2010 MS3 - Fuel, Nitrous & Water Injection 12 02-14-2018 12:24 PM
High Pressure Fuel Line CorkSport CorkSport 14 12-30-2016 02:34 PM
Opinion On High RPM High Pressure Fuel Pump Spring ms3brendan MazdaSpeed 3 - Engine, Transmission & Driveline 1 07-13-2010 01:04 PM
Page generated in 0.35459 seconds with 24 queries
