 Old 09-02-2011, 12:09 AM   #1
JAGspeed6's Avatar
Posts: 138   (View Stats)
JAGspeed6 has much to be proud ofJAGspeed6 has much to be proud ofJAGspeed6 has much to be proud ofJAGspeed6 has much to be proud ofJAGspeed6 has much to be proud ofJAGspeed6 has much to be proud ofJAGspeed6 has much to be proud ofJAGspeed6 has much to be proud ofJAGspeed6 has much to be proud ofJAGspeed6 has much to be proud of
Groaned at 20 Times in 6 Posts
Default HPFP internals or new HPFP?
Okay this is prob a nube question and I have searched and havent found my answer so...do I need to replace my entire fuel pump or can I just get the internals replaced and be fine? Are replacing the internals basically the same as getting a new fuel pump minus a few hundred dollars? Thanks.
JAGspeed6 is offline   Reply With Quote
 Old 09-02-2011, 12:14 AM   #2
SWAY's Avatar
Posts: 2,517   (View Stats)
Groans: 190
ok ill be easy on you fellow Texan, just replace internals go to namotorsports.com when kmds are back in stock later this month get those
TEAM LBN BEERS -- FYCN
TEAM MUMFORD -- FYCN
 Old 09-02-2011, 12:14 AM   #3
emag remrofni's Avatar
Posts: 1,594   (View Stats)
emag remrofni is the leader of the worldemag remrofni is the leader of the worldemag remrofni is the leader of the worldemag remrofni is the leader of the worldemag remrofni is the leader of the worldemag remrofni is the leader of the worldemag remrofni is the leader of the worldemag remrofni is the leader of the worldemag remrofni is the leader of the worldemag remrofni is the leader of the worldemag remrofni is the leader of the world
Groans: 209
Groaned at 92 Times in 38 Posts
Will you donate if I give you the answer? You clearly haven't searched, because this has been covered ad nauseum.
Basically, do internals if you know how to operate a wrench and a table vice. Buy the whole thing from CP-E if you are a full retard.
/thread
please lock @doubleflusher
// 09 CWP // Cobb SRI // SURE Race RMM // eBay double penetration DP // SU BPV // ITV22's // JBR SSP // KMD Internals // VTAK GAUGE // Cobb FMIC V.1 //
4 Gallon E85 by Stratified
My Photography - DarkSidePhotoshoot.com
it was a mexican
whoever said they are lazy is a stupid dumb fucking idiot
and they can do ANYTHING...they prolly got the wheels off with a branch and some hedge clippers
The dick bone is not connected to the asshole... Mind over matter, learn to control them both.
emag remrofni is offline   Reply With Quote
The Following User Says Thank You to emag remrofni For This Useful Post:
86AmishMs3 (09-02-2011)
 Old 09-02-2011, 12:14 AM   #4
86AmishMs3's Avatar
Posts: 3,639   (View Stats)
Groans: 338
Neutral  +1 score
cp-e offers full pumps with upgraded internals. But you can buy upgraded internals and put them in yourself ie. kmd, autotech...
Current: N54 135i
DCI, DP's, Exhaust, FMIC
12.3@122
2009 Mazdaspeed 3:
GT3076 - Corkey tuned
390whp/400wtq
12.8@114
Sold
 Old 09-02-2011, 12:15 AM   #5
SleeperHatch's Avatar
Posts: 3,138   (View Stats)
You can do either replacing internals is a helluva lot cheaper and there's a group buy going on that I think ends tomorrow or something..and with internals u take ur pump out switch internals back in when u switch pumps you have to send ur pump into cp-e and you get there entire replacement pump...just go with internals
Sent from my PG86100 using Tapatalk
2009 CWP Speed3
 Old 09-02-2011, 12:16 AM   #6
urbansurfer's Avatar
Posts: 213   (View Stats)
urbansurfer has a reputation beyond reputeurbansurfer has a reputation beyond reputeurbansurfer has a reputation beyond reputeurbansurfer has a reputation beyond reputeurbansurfer has a reputation beyond reputeurbansurfer has a reputation beyond reputeurbansurfer has a reputation beyond reputeurbansurfer has a reputation beyond reputeurbansurfer has a reputation beyond reputeurbansurfer has a reputation beyond reputeurbansurfer has a reputation beyond repute
Yup. You're right. Pump = internals + labor. Internals = DIY
If you can do it yourself you might as well and save some money. Or do what I did and enlist someone who's done it before :p. Best if you have an ap or other monitoring device so you can watch your pressure in case you fucked your shit.
2006 Mazdaspeed 6 GT w/ Nav - Black Cherry Mica
Cobb SRI / Cobb TIP / Cobb AP / PTP FP internals /IVT 22 / Turbosmart BPV / ETS TMIC / SURE TP / Flex-Innovations grounding kit / Stage 2 TWM SS / Corksport strut tower brace / Corksport SS Brake lines / SU Rear interior brace / SU Stiff Diff / TT Top Diff Mount / Morimoto projectors / 3000k HID Fogs
urbansurfer is offline   Reply With Quote
 Old 09-02-2011, 12:26 AM   #7
JAGspeed6's Avatar
Alright thanks for the help. Internals it is. Shouldnt be hard to install at all.
 Old 11-18-2011, 01:49 PM   #8
beavanjb's Avatar
Posts: 49   (View Stats)
beavanjb is a splendid one to beholdbeavanjb is a splendid one to beholdbeavanjb is a splendid one to beholdbeavanjb is a splendid one to beholdbeavanjb is a splendid one to beholdbeavanjb is a splendid one to beholdbeavanjb is a splendid one to behold
So, did you get the internals (Brand?) and how did it turn out? I'm in the same debate, $350 or so for internals vs $640 or so for the pump after core return. I guess if the only difference is the labor then yes DIY is right. BTW, what is the lifespan of CDFP upgrade? It seems a few people need replacements after only 10K.
beavanjb is offline   Reply With Quote
 Old 11-18-2011, 01:54 PM   #9
COCKSTRONG
SofaKingAwesome's Avatar
Posts: 8,447   (View Stats)
Groans: 890
@JAGspeed6
Holler if you need help, a bunch of MS3 guys in the area to help. Now donate fucker
 Old 11-21-2011, 07:14 AM   #10
JAGspeed6's Avatar
No I havent gotten them yet. Im in college, so money has been a little tight. Im saving up tho.
Cobb SRI, Cobb TIP, Forge V2, JBR RMM, AWR PMM, Cobb AP, CP-E downpipe, CP-E dual cat-back exhaust, CP-E TMIC, JBR EGR delete kit, JBR T.I.G., Sure shortcut and counterweight, Autotech internals, ACT 6-Puck clutch, Megan Racing springs, Enkei Imola rims 18x7.5, 235/40/18 Continental DWS Extreme Contact
 Old 11-26-2011, 11:54 AM   #11
MSpeedzilla's Avatar
Posts: 121   (View Stats)
MSpeedzilla is the leader of the worldMSpeedzilla is the leader of the worldMSpeedzilla is the leader of the worldMSpeedzilla is the leader of the worldMSpeedzilla is the leader of the worldMSpeedzilla is the leader of the worldMSpeedzilla is the leader of the worldMSpeedzilla is the leader of the worldMSpeedzilla is the leader of the worldMSpeedzilla is the leader of the worldMSpeedzilla is the leader of the world
internals any one know where i can find some cheap ones right now ish
_____________________________________________
2008 Silver Gen 1, MS3 MSCAI, Cobb TIP, Full Catless Race/Downpipe, Cobb XLE Bpv, MAPerformance rmm, Cobb AP, HPFP, xt-m5-qs, Shift bushings(washers), denso ITV22, Torque Android app, .
MSpeedzilla is offline   Reply With Quote
 Old 11-26-2011, 02:34 PM   #12
Sid3wayS's Avatar
Posts: 6,790   (View Stats)
Groans: 97
jp at edge auto sports 349 for autotechs there is also a group buy goin on for kmd
TEAM LUXURY
Which HPFP Internals drewsifer86 MazdaSpeed 3 - Engine, Transmission & Driveline 14 12-02-2010 09:24 PM
Page generated in 0.32925 seconds with 29 queries
