Like Tree13Likes
 Old 10-14-2016, 09:04 AM   #1
wes3id's Avatar
Posts: 611   (View Stats)
wes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the world
Default HPFP o-ring rebuild kit
So, i was getting together the info to buy all 6 o-rings that go in our HPFP and noticed that there is not a kit available. Oem o-rings from mazda cost $8 a piece and up. Since most places only sell in quantities , i have ordered enough o-rings to make 50 complete HPFP rebuild kits. I have chosen Multipurpose Buna-N as it methanol and ethanol safe. Specifications below.
Each o-ring will be packaged separately in a labeled bag. A printed document providing what each o-ring goes to in HPFP and specifications below will be provided. Everything should be here in a few days, and i will start putting them together. I will then provide proper signage and such. I am not actually selling anything right now until i post signage with pics of product.
Just gauging interest, I was thinking $25 a kit shipped.
For Use With
Acetic Acid
Ammonium Hydroxide
Animal Oil
Bases
Boric Acid
Butyl Alcohol
Calcium Hydroxide
Citric Acid
Diluted Salt Solutions
Ethanol
Ethylene Glycol
Glycerin
Grease
Hydraulic Oil
Isopropyl Alcohol
Methanol
Mineral Oil
Motor Oil
Petroleum Fluids
Phosphoric Acid
Potassium Hydroxide
Sodium Bicarbonate
Vegetable Oil
Note Chemical compatibility must be determined by the customer based on the conditions in which the product is being used, including the presence of other chemicals, temperature, and consistency.
Specifications Met ASTM D2000/SAE J200
Temperature Range -20° to 250° F
Color Black
RoHS Compliant
All O-rings meet ASTM D2000.
Oil-Resistant Buna-N—The most widely used O-ring material, Buna-N also resists grease, hydraulic fluids, and abrasion. They meet SAE J200. Temperature range is -20° to 250° F. Durometer is A70 (medium). Color is black.
07 SPEED 6 W/ GEN PU MOTOR SWAP/BNR S3/ K27 OIL FEED LINE/CUSTOM OIL DRAIN LINE/COBB INJECTOR SEALS/COBB XLE/CX RACING FMIC/CORKSPORT POWER SERIES 3" EXHAUST (CATLESS)/M2 3" DOWNPIPE (CATLESS)/COBB AP V3/GRIMMSPEED EBCS/JBR 3.5" WIDE PATH INTAKE/XS POWER V3 TURBO MANIFOLD/PNP INTAKE MANIFOLD/AUTOTECH INTERNALS/3 BAR MAP SENSOR/VTCS DELETE/KOZMIC MOTORSPORTS EGR DELETE/JBR BSD & BAFFLE TRAY/JBR OCC/NGK PLUGS/SURE TORQUE R6 RMM/AWR TRANSMISSION & PASSENGER MOUNTS/SURE JUGGERNAUGHT REAR DIFF MOUNT/CORKSPORT REAR DIFF MOUNT/FIDANZA FLYWHEEL W/ LUK CLUTCH/TWM SHORT SHIFTER/SURE COUNTER SHIFT/SURE SHORTCUT/H&R LOWERING SPRINGS/KONI YELLOWS/ WHITELINE RSB/ AWR END LINKS FRONT&REAR/ CORKSPORT FRONT & REAR STRUT BARS/SPC FRONT CAMBER BALL JOINTS/BRAIDED STEEL BRAKE & CLUTCH LINES/FIBER IMAGES VENTED HOOD/CORKSPORT FRONT PLATE RELOCATE/PC VALVE COVER/TRUNK MOUNTED RED TOP/INTERIOR MODS
K04 93 FREEKTUNED 271 AWHP/296TQ
K04 E85 FREEKTUNED 309 AWHP/360TQ
BNR S3 93 FREEKTUNED 336 AWHP/360TQ
BNR S3 E85 FREEKTUNED 375 AWHP/376TQ
wes3id is offline   Reply With Quote
The Following 2 Users Say Thank You to wes3id For This Useful Post:
BMC (04-26-2017), impossible (12-23-2016)
 Old 10-14-2016, 09:17 AM   #2
Bingo's Avatar
Posts: 740   (View Stats)
Groaned at 9 Times in 7 Posts
What all comes with the kit? I'm familiar with the o-ring, but I'm wondering what all you're putting together. When I did mine, all it took was the ring itself.
Things that matter: CS "Stage 2" SRI/TIP, CS TMIC, AT HPFP, JBR 70 duro RMM, Stratified OTS +, Koni FSD's, Whiteline endlinks.
Things that don't: Gen Pu wheels, CPE center pod with Prosport boost, OP, and OT gauges, Eonon G9151A.
 Old 10-14-2016, 09:39 AM   #3
wes3id's Avatar
The kit would consist of all 6 of the o-rings that are needed in your HPFP, better quality upgraded o-rings (withstands more chemicals than oem)
1x HPFP housing o-ring
1x Piston housing o-ring
1x Internal piston housing (double seal "x-ring") o-ring
1x Spill valve o-ring
1x inlet/bypass tube assembly o-ring
1x diaphragm cover o-ring
The Following User Says Thank You to wes3id For This Useful Post:
Yatta (10-14-2016)
 Old 10-14-2016, 11:51 AM   #4
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
I may want to get a set. How much will it cost?
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
 Old 10-14-2016, 12:20 PM   #5
wes3id's Avatar
Not sure what shipping would cost to Romania, but being so light and can fit in an envelope...should not be much
$25 shipped. depending on demand, that price could go down. If i can find a metric o-ring that will fit the MAF sensor from the same supplier, i will be trying to include one of those in the kit as well.
Cheapspeed likes this.
Cheapspeed (10-22-2016)
 Old 10-14-2016, 12:32 PM   #6
Thor Hammer's Avatar
Posts: 1,847   (View Stats)
Groans: 211
What is the elastomer of the stock ones? I would assume also Buna-N. its very common.
 Old 10-14-2016, 12:55 PM   #7
wes3id's Avatar
I am not sure what stock is, i can't find any info pertaining to it's elastomer. Being that out cars were never made to run Meth or E, they could very well be Viton seals. Keep in mind that while the Buna-N has it's advantages, my main selling point was the cost. OEM 0-rings cost anywhere from $8-$22 a piece.
I know most people only need to replace one seal/o-ring, but if you are in there replacing one..would you not rather have peace of mind knowing all your seals/o-rings are good and fresh...at a low cost?
Thor Hammer (10-14-2016)
 Old 10-14-2016, 01:04 PM   #8
I get my MAF and other o-rings from McMaster Carr. I imagine they'd have the sizes for this hpfp rebuild kit as well.
I dont have the MAF size on hand at the moment, but can post up later if need be.
wes3id likes this.
 Old 10-14-2016, 01:39 PM   #9
wes3id's Avatar
exactly where i'm getting them! unfortunately i need to find some with a 2.8mm thickness, but are only offered in increments of .5mm
 Old 10-14-2016, 02:18 PM   #10
wes3id's Avatar
ya, let me know what measurement you have for the MAF sensor when you get it.
If anybody else has any suggestions for other o-rings they would like to see included in the kit, please let me know...keep in mind price may fluctuate a few bucks.
Last edited by wes3id; 10-14-2016 at 02:18 PM. Reason: MSF Database - Automerged Doublepost
 Old 10-15-2016, 03:51 PM   #11
wes3id's Avatar
Found out today what a pain in the ass the 4x security bolts are for the diaphragm cover and inlet tube assembly. I have the special bits for removing them, but still ended up stripping 2 of the heads. With that being said, I have ordered some stainless steel allen key screws. If they work well, i will be inluding 4x in the kit.
David_Cudd likes this.
 Old 10-16-2016, 09:03 AM   #12
David_Cudd's Avatar
Posts: 23   (View Stats)
David_Cudd has a spectacular aura aboutDavid_Cudd has a spectacular aura about
Is it common enough for you to need to change these o rings? Have there been issues in the past with the o rings failing and letting oil into the fuel pump and into the motor?
David_Cudd is offline   Reply With Quote
 Old 10-16-2016, 09:26 AM   #13
Bingo's Avatar
To my knowledge it's not too common, but I believe it depends on how you install your internals. Don't douse yours in brake cleaner.
 Old 10-21-2016, 05:36 PM   #14
wes3id's Avatar
Finally got all the proper fitting o-rings and screws in. Here is a pic of what the kit will look like so far. I will be installing and testing this spare test pump on my car before i offer these for sale. I will be adding a UV fuel additive and , take it for a hard run (while monitoring fuel pressure, and inspect the pump with a UV light for any leaks.
Cheapspeed (10-22-2016), mituc (10-22-2016)
 Old 10-22-2016, 10:25 AM   #15
SpeedyTurd's Avatar
Posts: 35   (View Stats)
SpeedyTurd has a spectacular aura aboutSpeedyTurd has a spectacular aura aboutSpeedyTurd has a spectacular aura about
Nice kit. Some might say it pointless, but this just gives you peace of mind everything has been serviced and freshened up.
It may have been said before but what's the final price of the kit with the screws. And what's the info needed so we can order this?
Couple questions though.
Why Buna-N and not Viton?
Viton has a temperature rating up 400f while Buna-n is 250? And the durometer is a little more for viton.
SpeedyTurd is offline   Reply With Quote
 Old 10-22-2016, 01:45 PM   #16
frothy's Avatar
Posts: 1,067   (View Stats)
O-Ring Fluid Compatibility Guide
The Following 2 Users Say Thank You to frothy For This Useful Post:
SpeedyTurd (10-23-2016), WetzMS3 (01-30-2017)
 Old 10-22-2016, 02:06 PM   #17
wes3id's Avatar
Price will still be $25 shipped including screws. Once i test it on my own car, i will take orders. The last thing i want to do, is sell untested product and destroy somebody's car.
blackms3_71 likes this.
mituc (10-23-2016), SpeedyTurd (10-23-2016)
 Old 11-29-2016, 12:05 PM   #18
Fstrnyou's Avatar
Posts: 2,498   (View Stats)
update?
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
 Old 11-29-2016, 03:06 PM   #19
blackms3_71's Avatar
Posts: 2,250   (View Stats)
Hmm i would buy a kit for that one day my shit messes up
 Old 11-29-2016, 04:20 PM   #20
East0352's Avatar
Posts: 11   (View Stats)
East0352 is an unknown quantity at this point
Just curious, hate to throw a monkey wrench in, but the list does not show Gasoline to be compatible. I haven't pulled apart an HPFP, yet, but I would think that Gas would make contact with the O-rings. Gas is probably one of the worst chemicals when it comes to contact with rubber type components. Just making sure that base was covered before you started sending these out to everyone. I really hope it works. I just didn't see anything that reassured me.
East0352 is offline   Reply With Quote
 Old 11-29-2016, 04:24 PM   #21
connor_cwp's Avatar
Posts: 119   (View Stats)
connor_cwp has a reputation beyond reputeconnor_cwp has a reputation beyond reputeconnor_cwp has a reputation beyond reputeconnor_cwp has a reputation beyond reputeconnor_cwp has a reputation beyond reputeconnor_cwp has a reputation beyond reputeconnor_cwp has a reputation beyond reputeconnor_cwp has a reputation beyond reputeconnor_cwp has a reputation beyond reputeconnor_cwp has a reputation beyond reputeconnor_cwp has a reputation beyond repute
From Nitrile (Buna-N) Rubber Polymer
Gasoline:
RECOMMENDED: Little or Minor Effect
2009 CWP MS3 Sport
DM EGR Delete, TMM, and PMM. JBR RMM, BSD, Oil Baffle, Shift Weight. HTP 3.5" intake, Under Route IC Piping. Treadstone TR8. AEM gauges. CPE Gauge Pod. Progress RSB. Evo X Enkei. 245 Pilot Super Sport. Rally Armor Mudflaps. Custom test pipe, catback, and MAC EBCS in 3 port.
connor_cwp is offline   Reply With Quote
 Old 12-22-2016, 02:03 AM   #22
wes3id's Avatar
ok gents or ladies, it's been a while....but i'm now done with school and have some spare time between odd hours at work to get other shit done. Here is the kit i've been sitting on for a little while now. I saw that somebody had tried to take my idea the other day on FB, but with a far lesser half assed attitude....so i figured i should get this shit done. I have already posted on a few mazdaspeed sites. I have 24 kits with new hex head screws ready to ship out for $30 shipped, $25 local pickup. I have another 20 or so kits without replacement screws (for the time being) ready to ship out for $25 shipped or $20 local pickup. I will be adding replacement screws to the rest of the kits very soon, so if you just want to save $5 because you're a cheap piece of shit....better get a kit soon.
I took a lot of time making sure that the o-rings sizes i chose fit correctly for the application. All o-rings are Buna-n (methanol and ethanol safe) Superior to the standard Viton o-rings.
impossible (12-23-2016), WetzMS3 (01-30-2017)
 Old 12-22-2016, 03:56 AM   #23
l0stperfecti0n's Avatar
Posts: 16   (View Stats)
l0stperfecti0n will become famous soon enough
Can I get one of those $30 kits?
AP V2, Autotech Internals, Devils Own V2 WMI, CX Racing FMIC, 3 Bar MAP, JBR 3 Inch Intake, CNT Racing Turbo Back, Exhuast, Carolina Panthers Sticker, Denso ITV22, Ebay OCC, XS Power V3 Exhaust Mani, Stratified e30 Tune, Some other shit
l0stperfecti0n is offline   Reply With Quote
 Old 12-22-2016, 02:27 PM   #24
wes3id's Avatar
PM me for paypal info
 Old 12-22-2016, 03:39 PM   #25
PM sent
 Old 12-22-2016, 05:42 PM   #26
mazda62006's Avatar
Posts: 65   (View Stats)
mazda62006 is a splendid one to beholdmazda62006 is a splendid one to beholdmazda62006 is a splendid one to beholdmazda62006 is a splendid one to beholdmazda62006 is a splendid one to beholdmazda62006 is a splendid one to behold
Are you running these now? I know I saw where you said you were going to test them. Did you test them?
mazda62006 is offline   Reply With Quote
 Old 12-22-2016, 05:56 PM   #27
wes3id's Avatar
Yes tested was done successfully. I am running them in my car now
 Old 12-23-2016, 07:33 PM   #28
wes3id's Avatar
22 kits ready to ship out!
 Old 12-23-2016, 10:54 PM   #29
impossible's Avatar
Posts: 733   (View Stats)
Groans: 30
Might want to update the OP with the version that includes the Allen bolts for those interested. I saw your posts on FB and will definitely be grabbing a set but I'm pulling my longblock right now so I have no use until it's time to go back together and hopefully you're still selling at that time.
wes3id (12-24-2016)
 Old 12-23-2016, 11:00 PM   #30
Fstrnyou's Avatar
I could have used a kit a few weeks ago when I did my internals. Maybe next time.
Other rides:
History:
 Old 12-29-2016, 09:04 AM   #31
BLKspd5's Avatar
BLKspd5 is just really niceBLKspd5 is just really niceBLKspd5 is just really niceBLKspd5 is just really nice
PM sent. Also which special bit is required? I'd like to know before I rip into it and realize I don't have all the tools.
Engine/Exhaust/Intake
Corksport:Injector Seals, OCC, EBCS, HPFP Internals, Long Catted DP||Magnaflow:CBE||HTP:3.5" Intake & 51r Tray||JBR:Boost Tubes, Recirc. Hose||CP-E:TMIC||Cobb:Accessport V3(Freektune)||Forge:V2 BPV(Blue Spring)||Damond Motorsports:Full EGR Delete||NGK 6510
Suspension/Chassis
Corksport:Camber Plates, FSB/RSB, Endlinks, Short Shifter||JBR:Rear Camber Arms||CP-E:RMM||H&R:Street Performance Coilovers||Damond Motorsports:PMM, TMM
BLKspd5 is offline   Reply With Quote
 Old 12-29-2016, 09:20 AM   #32
frothy's Avatar
Torx security bit... T25
BLKspd5 (12-29-2016)
 Old 12-29-2016, 10:03 AM   #33
BLKspd5's Avatar
Awesome thanks.
Suspension/Chassis
 Old 01-15-2017, 03:41 PM   #34
BLKspd5's Avatar
Is the piston housing 28mm OD x 23mm ID x 2.5mm thick?
Suspension/Chassis
 Old 01-15-2017, 05:51 PM   #35
TXGenPu's Avatar
Posts: 14   (View Stats)
TXGenPu will become famous soon enough
Any kits left for sale?
TXGenPu is offline   Reply With Quote
 Old 01-15-2017, 07:20 PM   #36
SpeedyTurd's Avatar
How do we purchase?
 Old 01-16-2017, 10:38 PM   #37
wes3id's Avatar
yes i have plenty kits left ready to ship. pm me for payment info
How do we purchase?
Last edited by wes3id; 01-16-2017 at 10:38 PM. Reason: MSF Database - Automerged Doublepost
 Old 01-27-2017, 02:53 PM   #38
BLKspd5's Avatar
Before using this kit my HPFP Act. would be between 1700 and 1830ish. Now I'm hitting 1650-1810 area. Is this concerning? I know you should be above 1600, but I lost some PSI after changing the O-rings. I also just checked and my oil is above the "max" by a bit and I know last time I changed my oil it was just under the max. My catch can also fills quite fast, every 400 miles of a beer colored liquid that smells like gas.
Edit: And in no way am I blaming you, I appreciate your work making these kits, just wondering if you experienced this? Or maybe I did something wrong.
Suspension/Chassis
 Old 01-29-2017, 12:31 PM   #39
wes3id's Avatar
I did not experience any of those issues with mine. Did you lightly lube the o-rings when installing to get a good seal?
 Old 01-29-2017, 02:29 PM   #40
BLKspd5's Avatar
I lubed them all with a little petroleum jelly.
Suspension/Chassis
Oil leak - Please help identify - HPFP O-ring? qkrthnu2 MazdaSpeed 6 - Engine, Transmission & Driveline 15 11-16-2015 12:26 PM
HPFP O-Ring Part Number? csharp 2010 MS3 - Fuel, Nitrous & Water Injection 33 06-28-2015 05:01 PM
hpfp leaking o-ring muggs Mazdaspeed3/6 General Discussion 3 03-29-2014 10:21 PM
hpfp o-ring question muggs Mazdaspeed3/6 General Discussion 2 03-26-2014 08:29 PM
Page generated in 0.57529 seconds with 37 queries
