Like Tree13Likes
 Old 01-30-2017, 09:23 AM   #41
wes3id's Avatar
Posts: 611   (View Stats)
wes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the world
Originally Posted by BLKspd5 View Post
I lubed them all with a little petroleum jelly.
IDK man. You could take the pump back apart and inspect all the rings for flat spots or unusual wear. if you do find something that suggests a defect or just doesn't work, i will refund your money.
You did reprime the pump when you reinstalled it right?
07 SPEED 6 W/ GEN PU MOTOR SWAP/BNR S3/ K27 OIL FEED LINE/CUSTOM OIL DRAIN LINE/COBB INJECTOR SEALS/COBB XLE/CX RACING FMIC/CORKSPORT POWER SERIES 3" EXHAUST (CATLESS)/M2 3" DOWNPIPE (CATLESS)/COBB AP V3/GRIMMSPEED EBCS/JBR 3.5" WIDE PATH INTAKE/XS POWER V3 TURBO MANIFOLD/PNP INTAKE MANIFOLD/AUTOTECH INTERNALS/3 BAR MAP SENSOR/VTCS DELETE/KOZMIC MOTORSPORTS EGR DELETE/JBR BSD & BAFFLE TRAY/JBR OCC/NGK PLUGS/SURE TORQUE R6 RMM/AWR TRANSMISSION & PASSENGER MOUNTS/SURE JUGGERNAUGHT REAR DIFF MOUNT/CORKSPORT REAR DIFF MOUNT/FIDANZA FLYWHEEL W/ LUK CLUTCH/TWM SHORT SHIFTER/SURE COUNTER SHIFT/SURE SHORTCUT/H&R LOWERING SPRINGS/KONI YELLOWS/ WHITELINE RSB/ AWR END LINKS FRONT&REAR/ CORKSPORT FRONT & REAR STRUT BARS/SPC FRONT CAMBER BALL JOINTS/BRAIDED STEEL BRAKE & CLUTCH LINES/FIBER IMAGES VENTED HOOD/CORKSPORT FRONT PLATE RELOCATE/PC VALVE COVER/TRUNK MOUNTED RED TOP/INTERIOR MODS
K04 93 FREEKTUNED 271 AWHP/296TQ
K04 E85 FREEKTUNED 309 AWHP/360TQ
BNR S3 93 FREEKTUNED 336 AWHP/360TQ
BNR S3 E85 FREEKTUNED 375 AWHP/376TQ
wes3id is offline   Reply With Quote
 Old 01-30-2017, 10:37 PM   #42
Fstrnyou's Avatar
Posts: 2,498   (View Stats)
Take it all back apart and check for torn or knicked rings. Might have cut something during assembly. It's happened before.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
 Old 02-10-2017, 07:22 AM   #43
BurlyTheUnicorn's Avatar
Posts: 2   (View Stats)
BurlyTheUnicorn is an unknown quantity at this point
I was wondering if these kits solve the problem of full e85 gumming up the pump. I would like to take out my pump, rebuild it with these o rings, then not have to clean it every few months like people on full e85 have issues with. If so I would like to purchase one.
BurlyTheUnicorn is offline   Reply With Quote
 Old 02-10-2017, 09:57 AM   #44
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
No, that's a result of a reaction between inappropriate oil and the ethanol in the fuel.
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
 Old 02-10-2017, 10:02 AM   #45
Would it be beneficial for running full e85 then? Then run MM oil in my e85? I'm looking for anyway possible to run full e85 instead of a mix. (And yes I understand that there are other threads about this but I'm asking about the o rings)
 Old 02-10-2017, 10:52 PM   #46
wes3id's Avatar
the only way you will be able to run full e85 is either with a stock ko4 turbo or with aux fuel. Otherwise you will require more fuel than our shitty injectors can provide.
As for the gunked up hpfp (black death) i used Royal Purple 5w30 w/ dexros and also did the Redline SI-1 treatment to the hpfp internals.
The o-ring rebuild kit i sell does not mean you can run full e85 and meth! it just means the o-rings are actually e85 and methanol safe opposed to the factory o-rings. most people only replace 1 particular o-ring in the pump, however; i thought if you are taking it apart to replace one...why not replace them all and have complete confidence that your hpfp is good to go (granted your internals are good of course)
 Old 03-01-2017, 07:41 AM   #47
Texasgunslinger9's Avatar
Posts: 15   (View Stats)
Texasgunslinger9 is an unknown quantity at this point
Are there any kits still available?
Texasgunslinger9 is offline   Reply With Quote
 Old 03-01-2017, 05:27 PM   #48
wes3id's Avatar
yes, plenty...pm me for details
The Following User Says Thank You to wes3id For This Useful Post:
PHB (11-20-2017)
 Old 04-28-2017, 11:20 PM   #49
ms3steeez's Avatar
Posts: 312   (View Stats)
ms3steeez is the leader of the worldms3steeez is the leader of the worldms3steeez is the leader of the worldms3steeez is the leader of the worldms3steeez is the leader of the worldms3steeez is the leader of the worldms3steeez is the leader of the worldms3steeez is the leader of the worldms3steeez is the leader of the worldms3steeez is the leader of the worldms3steeez is the leader of the world
Originally Posted by wes3id View Post
ok gents or ladies, it's been a while....but i'm now done with school and have some spare time between odd hours at work to get other shit done. Here is the kit i've been sitting on for a little while now. I saw that somebody had tried to take my idea the other day on FB, but with a far lesser half assed attitude....so i figured i should get this shit done. I have already posted on a few mazdaspeed sites. I have 24 kits with new hex head screws ready to ship out for $30 shipped, $25 local pickup. I have another 20 or so kits without replacement screws (for the time being) ready to ship out for $25 shipped or $20 local pickup. I will be adding replacement screws to the rest of the kits very soon, so if you just want to save $5 because you're a cheap piece of shit....better get a kit soon.
I took a lot of time making sure that the o-rings sizes i chose fit correctly for the application. All o-rings are Buna-n (methanol and ethanol safe) Superior to the standard Viton o-rings.
That was me on fb selling some. I wasn't trying to steal your idea, or potential buyers. I needed a set, and could only order in packs of 10 so I sold the rest of the sets to save others from having to buy so many, and to recoup the cost.
Just wanted to clear that up so you know I didn't do it to steal your idea (even though it is a great idea lol)
FreekTuned GT3076R, M2 catless DP, CS HPFP internals, Custom 3.5" intake, Custom 51R battery box, Grimmspeed 3 port EBCS, CS shifter bushings, RA mudflaps, TurboXS core w/ custom piping, Devils Own 100% meth injection, JBR 88 RMM, Denso ITV22, CPE Safeseals, JBR EGR delete, Forge V1, Hawk HPS pads, VCTS Delete, 3 bar map sensor, kozmic primary EGR delete (391 whp on Vdyno, ZZB 12-17-14)
Build in progress
.020 over block, pinned and keyed, wiseco pistons, manley H beams, SP63 head w/ intake and exhaust ports, and mild bowl work. DM TB spacer, L19 studs, XSpower V1 mani, CNT catback, ACT 6 puck w/ streetlight flywheel, CS injector seals, Clevite main and King rod bearings, redefined performance PCV plate, PTP oil pan baffle w/ JBR BSD, 4 bar map sensor
ms3steeez is offline   Reply With Quote
The Following User Says Thank You to ms3steeez For This Useful Post:
wes3id (04-29-2017)
 Old 03-06-2018, 08:01 AM   #50
wes3id's Avatar
Sorry that it has been so long that i have been on here guys, so long in fact..that i have turned brownie again. Well to those that are interested, I have created a Facebook page for my HPFP rebuild kits and have added a few services. I am continuing to try and add other products, Like MAF sensor O-rings for $5.00 shipped. check out my page if you need help with your HPFP
https://www.facebook.com/wes3id/
TRBLSM likes this.
Db09ms3 (03-06-2018)
 Old 03-06-2018, 01:21 PM   #51
GroceryGtr's Avatar
Posts: 472   (View Stats)
FYI I'm very please with my kit purchase from wes3id. I bought the 'all inclusive' kit just incase and wasn't disappointed with the included items or the quality of said items. Even if you dont need it its nice to buy and have on the shelf for later. Price is peanuts when you look at what it would cost to source this correctly on your own.
wes3id likes this.
 Old 03-06-2018, 01:51 PM   #52
Db09ms3's Avatar
Posts: 536   (View Stats)
I saw your FB page. I liked it. May use your services in the future. Maybe not. In any case. Thank you.
wes3id likes this.
 Old 03-06-2018, 05:38 PM   #53
wes3id's Avatar
If you have purchased a kit from me in the past, I have made some slight changes...such as pictured instructions/ o-ring spec sheet. Also please visit my Facebook page and leave feedback, I would greatly appreciate it. Other services offered, MAF Sensor O-rings now sold and included in each kit.
 Old 03-06-2018, 06:05 PM   #54
Fstrnyou's Avatar
You had me at "other services". Sign me up!!
wes3id, Db09ms3 and kTaLgsTo like this.
Other rides:
History:
 Old 03-07-2018, 08:40 PM   #55
wes3id's Avatar
Tee hee, not quite back page "other services" buddy!
 Old 03-07-2018, 09:58 PM   #56
Fstrnyou's Avatar
Sorry. BackPage Charlotte is my home page.
Other rides:
History:
 Old 05-08-2019, 03:47 PM   #57
Amnesia's Avatar
Posts: 13   (View Stats)
Amnesia will become famous soon enough
Curious if this HPFP O-ring kit is still available. or where id be able to get them all!
Thanks!
Amnesia is offline   Reply With Quote
 Old 05-08-2019, 06:08 PM   #58
Mack_Sant's Avatar
Posts: 75   (View Stats)
Mack_Sant is a splendid one to beholdMack_Sant is a splendid one to beholdMack_Sant is a splendid one to beholdMack_Sant is a splendid one to beholdMack_Sant is a splendid one to beholdMack_Sant is a splendid one to beholdMack_Sant is a splendid one to behold
Thanks!
IIRC this guy stopped supplying the kits. If you’re on Facebook look on the mazdaspeed6 pages for a guy named Michael Rey. He now sells HPFP rebuild kits. For sure check out the California Mazdaspeeds page. I’m not sure if he’s on here.
My inner vagina tells me not to pull harder.
^ For the love of all that's tight and moist, if you cannot figure out something so simple, find some locals to help you.
Mack_Sant is offline   Reply With Quote
Oil leak - Please help identify - HPFP O-ring? qkrthnu2 MazdaSpeed 6 - Engine, Transmission & Driveline 15 11-16-2015 12:26 PM
HPFP O-Ring Part Number? csharp 2010 MS3 - Fuel, Nitrous & Water Injection 33 06-28-2015 05:01 PM
hpfp leaking o-ring muggs Mazdaspeed3/6 General Discussion 3 03-29-2014 10:21 PM
hpfp o-ring question muggs Mazdaspeed3/6 General Discussion 2 03-26-2014 08:29 PM
Page generated in 0.39236 seconds with 30 queries
