Like Tree3Likes
 Old 02-10-2012, 01:17 AM   #1
paveltol's Avatar
Posts: 520   (View Stats)
paveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the world
Groaned at 23 Times in 2 Posts
Exclamation Injector seals solution. Version B
Hello everyone!
So here is a new tip for all those who face the problem of blown OEM injector seals and don't want to spend hundreds of dollars on OEM or some reinforced seals, there's a solution: The Toyota diesel injector seals. These seals come for every diesel Toyota engine and are proven to be of good quality.
These seals have been tested for more than a year on a number of modified Mazda 2.3 DISI Turbo engines, with different power level (from stock to 400hp) running on awful Russian fuel. None of the seals failed so far. Installation does not require any machining or trimming. They fit perfectly.
Now, the price. It is USD 7.8 per kit. USD 1.9 each.
P/N: 11177-64010
Enjoy.
UPDATE: See the pic attached. There is a comparison of OEM Mazda seals (left) and Toyota diesel seals (right). Mazda seals have rubber-like coating, Toyota seals do look like they are made of brass alloy. Surely they do not look as beefy as CP-E seals, but they are proven to be working on a number of modified cars. Two of them are 370hp and 405hp.
Different alloys have different properties and as you know diesel engines have extreme pressure spikes in the cam. Still it would actually be useful to find out the limit of these seals' tolerance on Mazda DISI engines.
Varomnia likes this.
Mazda 6 MPS Velocity Red, cp-e nano, cp-e TIP, BNR Stg3, Custom FMIC, cp-e HPFP, HKS Twin Power DLI2 ignition, HKS M35LF spark plugs, EGR block-off, catless 3" dp with welded in resonator, AutoExe Grounding Earth System, Grimmspeed BCS, AWR competition radiator, JBR SSP, 355mm 4-piston JBT Big Brake Kit, Rays RE30 wheels, Advan v103 tires, etc..
paveltol is offline   Reply With Quote
The Following 7 Users Say Thank You to paveltol For This Useful Post:
ABolewski (11-20-2012), atvfreek (11-23-2012), cocoanton (03-30-2013), Constantin (09-03-2012), ESB Jiu JItsu (10-17-2012), Speed3eak (09-21-2012), Varomnia (11-12-2016)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f303/injector-seals-solution-version-b-119326/
100% DI Failure with Nurburgring rentals - Page 6 - Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB This thread Refback 07-08-2013 06:54 AM
I just did my injector seal. Mine are dirtier than yours! - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 08-04-2012 02:09 PM
Injector seals solution. Version A paveltol MazdaSpeed 6 - Engine, Transmission & Driveline 756 05-23-2017 10:38 AM
Injector seals solution. paveltol 2010 MS3 - Fuel, Nitrous & Water Injection 404 11-22-2016 03:39 AM
Injector seals solution. paveltol 2010 MS3 - Engine, Transmission & Driveline 397 07-25-2014 08:34 PM
Injector seals solution - Gen 2 paveltol MSF KB - Mazdaspeed 3/6 - Engine, Transmission & Driveline 397 09-19-2012 02:50 PM
Injector seals solution. paveltol MSF KB - Mazdaspeed 3/6 - Fuel 401 09-19-2012 01:49 PM
Page generated in 0.75223 seconds with 53 queries
