 Old 11-07-2017, 12:17 PM   #1
KhalidBiary's Avatar
Posts: 36   (View Stats)
KhalidBiary is on a distinguished road
Default ITFP very quiet occasional whine
The title pretty much says it all , occasionally if I listen very closely I hear a quiet whine from my fuel tank. I am thinking it's the ITFP however I'm not having problems with power cutting under WOT. Should I worry ? Should I go through the hassle of replacing or is my pump fine. Thank you in advance !
KhalidBiary is offline   Reply With Quote
 Old 11-08-2017, 08:26 AM   #2
Varomnia's Avatar
Posts: 459   (View Stats)
Pump is fine. If you ever get the point of tearing out all your interior, you'll hear it all the time. Pumps make noise, you're just listening too closely for it.
 Old 11-08-2017, 10:32 AM   #3
ChaunceyM's Avatar
Posts: 948   (View Stats)
ChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the world
Truth. I stripped mine and can hear it fire up every time I turn the key to on. It was surprising how loud that pump is with the seats out.
Corksport: SRI & TIP, Strut Tower Brace, Coilovers
CP-e: RMM
JBR: Rear Sway Bar (with Moog End Links)
TWM: Full Replacement Shifter
Cobb: AP
AutoTech: HPFP Internals
Ebay: Test Pipe
ChaunceyM is offline   Reply With Quote
Occasional Pulsy feel with DSC/TC MIL lights meicalnissyen MazdaSpeed 6 - Engine, Transmission & Driveline 2 03-21-2017 12:57 PM
Occasional knock slowspd MazdaSpeed 3/6 - ECU Computer Tuning 6 08-03-2012 09:37 AM
Occasional Loss of RPM and Stall mirage 2010 MS3 - Troubleshoot/Diagnostics 2 07-19-2012 10:39 AM
occasional KR Axel907 MazdaSpeed 3/6 - ECU Computer Tuning 42 07-15-2012 06:36 PM
occasional CEL p2187 jax ms3gt MazdaSpeed 3/6 - Troubleshoot/Diagnostics 30 02-17-2011 09:39 AM
Page generated in 0.23338 seconds with 22 queries
