Closed Thread
 Old 05-28-2013, 09:56 AM   #1
Boo5ted's Avatar
Posts: 54   (View Stats)
Boo5ted is a jewel in the roughBoo5ted is a jewel in the roughBoo5ted is a jewel in the roughBoo5ted is a jewel in the rough
Default Meth injection ?'s
Hello I'm new to the forum
I have a 07 MS6 with a sure CAI Sure TIP and the Cobb passport
I will be doing a FMIC AND I custom cat back
I'm interested in meth injection for it, I'm familiar with it on a previous boosted vehicle
My question is how are these kits for a DD have you guys heard of coolingmist.com here's the kit I used on my turbo charged ranger. Would this work on our cars? And at what pound of boost do you have the kits activate at?
Coolingmist Stage 1 (solenoid, s/a injector)
I'm sorry if this is a repost being a noob but I really couldn't find info
Thanks
Dominic
Boo5ted is offline
 Old 05-28-2013, 09:59 AM   #2
Colin1337's Avatar
Posts: 1,330   (View Stats)
Colin1337 is the leader of the worldColin1337 is the leader of the worldColin1337 is the leader of the worldColin1337 is the leader of the worldColin1337 is the leader of the worldColin1337 is the leader of the worldColin1337 is the leader of the worldColin1337 is the leader of the worldColin1337 is the leader of the worldColin1337 is the leader of the worldColin1337 is the leader of the world
First and foremost you need to donate.
Secondly, you need HPFP internals so you dont pop your motor.
Third, you need to use the search function.
GATDAYUM
2005 CTS-V
KCCO
2006 Mazdaspeed6 SOLD
COBB AP /|\ 3' Magnaflow CBE /|\ Autotech FPI /|\ COBB SF Intake /|\ NGK plugs /|\ RMM /|\ Megan springs /|\ GReddy RS BOV /|\ Strapped diff /|\ eGay catless DP /|\ BSD 'kit" /|\ PTP oil pan baffle /|\ Custom FMIC /|\ Spin on oil filter conversion
1995 Miata SOLD
Tokiko Illumina Adjustables | FM springs | HardDog M2 rollbar w/Single diagonal | GV rep front lip | Flyin' Miata rear shock mounts.
Colin1337 is offline
The Following 3 Users Say Thank You to Colin1337 For This Useful Post:
gigliotti175 (05-28-2013), kritz (05-28-2013), Kyle Undefined (05-28-2013)
 Old 05-28-2013, 10:03 AM   #3
speed23's Avatar
Posts: 1,480   (View Stats)
Lots of people run meth on daily driven mazdaspeeds and everyone knows coolingmist (although snow, devils own and AEM are more common). Activate at roughly half your max boost. Play with the search function to learn it better, otherwise other members will tear you to shreds for not finding the info yourself in the future. I'd also suggest donating to the forum as it will open up lots of good info/sale threads etc.
speed23 is offline
 Old 05-28-2013, 10:21 AM   #4
Boo5ted's Avatar
Ok I'll donate ASAP why do I need to upgrade the hpfp internals?
Boo5ted is offline
The Following User Says NO Thank You to Boo5ted For This Un-useful Post:
Chimmike (05-28-2013)
 Old 05-28-2013, 10:26 AM   #5
MS3-a(sore)ASS-rex's Avatar
Posts: 7,012   (View Stats)
Groans: 224
As you begin to request more boost and timing you increase the need for more fuel to avoid a lean situation for your AFR.
With these cars on a stock pump/internals, as you request more fuel to keep your AFR's consitent the pump cannot keep up and fuel pressure begins to drop off. Upgrading the pump/internals ensures your pump can keep up.
Although meth can be used as a bandaid to make up for a pump that hasn't been upgraded by adding additional fuel.
NATOR PA
MS3-a(sore)ASS-rex is offline
Payne Racing 67 (05-28-2013)
 Old 05-28-2013, 10:27 AM   #6
kritz's Avatar
Posts: 7,290   (View Stats)
Groans: 95
Yes, and get a Cobb AP before a catback<[not a power mod] Down pipe before Catback. Search using the google function.
Nator is what it does.
kritz is offline
 Old 05-28-2013, 10:36 AM   #7
Payne Racing 67's Avatar
Posts: 4,483   (View Stats)
Payne Racing 67 is the leader of the worldPayne Racing 67 is the leader of the worldPayne Racing 67 is the leader of the worldPayne Racing 67 is the leader of the worldPayne Racing 67 is the leader of the worldPayne Racing 67 is the leader of the worldPayne Racing 67 is the leader of the worldPayne Racing 67 is the leader of the worldPayne Racing 67 is the leader of the worldPayne Racing 67 is the leader of the worldPayne Racing 67 is the leader of the world
Groaned at 64 Times in 49 Posts
Stick with either Devil's Own or Snow. Aquamist is best if you can afford it.
Badsnake 2003 Cobra: Ported Eaton, 2.93 upper, 4lb lower, Steeda intake, fuel system, LF Heat Excg, MGW Shifter, MM Coilovers, Billet Flow IRS Brace, Magnaflow O/R X Pipe/CBE, Fiore Clutch Quadrant/Adjuster, MT ET Street Radials 515rwhp/525rwtq.
#HAR Hidden Agendas Racing
Payne Racing 67 is offline
 Old 05-28-2013, 10:44 AM   #8
Boo5ted's Avatar
So by the sounds of it I need upgraded HPFP before I get a meth kit
Boo5ted is offline
 Old 05-28-2013, 10:45 AM   #9
kritz's Avatar
Groans: 95
You need to do a lot of reading Sir. But yes.
kritz is offline
The Following 3 Users Say Thank You to kritz For This Useful Post:
Colin1337 (05-28-2013), gigliotti175 (05-28-2013), Kyle Undefined (05-28-2013)
 Old 05-28-2013, 11:15 AM   #10
chuckms6's Avatar
Posts: 1,618   (View Stats)
If your car came with an access port and some other mods you might already have a hpfp. Search on here how to tell if you have internals or if you need internals.
Sent from my SAMSUNG-SGH-I727
Megan Racing Coilovers
13.7@ 96 w/1.8 60ft (SRI, AP)
chuckms6 is offline
The Following User Says Thank You to chuckms6 For This Useful Post:
speed23 (05-28-2013)
 Old 05-28-2013, 11:48 AM   #11
Boo5ted's Avatar
Ok
Boo5ted is offline
 Old 05-28-2013, 01:00 PM   #12
Boo5ted's Avatar
My apologies to everybody I just read up on the HPFP internals and I'm up to speed
Boo5ted is offline
The Following User Says Thank You to Boo5ted For This Useful Post:
 Old 05-28-2013, 01:06 PM   #13
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
This is the point where you need to stop posting and start researching the platform more.
I'm closing this thread to save you some trouble.
07 MS3
The original Genpoo Hater
Chimmike is offline
chuckms6 (05-28-2013), Colin1337 (05-28-2013)
Closed Thread
Meth Injection info atvfreek MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 67 05-02-2017 06:07 PM
Meth injection explanation qweedqwag 2010 MS3 - Fuel, Nitrous & Water Injection 7 01-14-2013 02:11 AM
Map wire for meth injection NJSPEED3 MSF KB - Mazdaspeed 3/6 - Fuel 20 09-19-2012 02:07 PM
Map wire for meth injection NJSPEED3 2010 MS3 - Fuel, Nitrous & Water Injection 19 04-19-2012 12:05 PM
Page generated in 0.33886 seconds with 28 queries
