![]() Join Date: Jul 2010 Location: Austin, TX
Rep Power: 877 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 200
(Thread Starter) | Not Ranked : 0 score So right now, I have an AP, SRI, and TIP. Future plans (eventually) are an upgraded TMIC, DP, and TP. I don't see this car going BT and all that jazz. So, with that being said. What am I looking at for doing a meth/water injection kit? Devil's Own has the universal and the progressive controller. Labonte seems to have all sorts of stuff on his site. What kit are you guys running? Are you even buying kits or just piecing together parts? What is needed to have a safe, efficient, and reliable meth injection? Thanks for your input. Are there any drawbacks to doing meth injection other than the monthly Meth bill?
__________________ 2009 CWP MS3 SportBuilt Motor and Twinscroll T3 35r - 415WHP/400WTQ - 93 Pump Gas, No Meth - Mustang Dyno Custom Tubular Manifold - HTP 3.5" Intake - 3" V-Band TBE - Custom COBB FMIC - COBB EBCS - COBB 44mm WG - KW V2 Coilovers SOLD! 2008 Toyota Tacoma TRD Sport 4x4 |
| The Following User Says Thank You to XLT_66 For This Useful Post: | rfinkle2 (04-08-2011) |
Groans: 224
| Not Ranked : 0 score I've got a snow performance kit in my car. It runs off of a MAF based controller that tells it when to spray. So when the MAF hits a certain voltage it has a boost equivalent, then the meth sprays. Meth is fucking magic plain and simple, I've never seen a drawback to it unless a car had been tuned for meth and then run out during a WOT pull. My recommendation is to use it as a safety net and just use a bit of it to lay over your existing tune
| The Following User Says Thank You to MS3-a(sore)ASS-rex For This Useful Post: | rfinkle2 (04-08-2011) |
![]() Join Date: Jul 2009 Location: Keene, NH
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 53
Groaned at 68 Times in 44 Posts
| Not Ranked : 0 score What I wonder is how meth affects the ECU's ability to regulate AFR...
__________________ 08.5 Mazdaspeed 3 - Cobb AP w/ Boost Targetting at 17psi, CP-E Nano SRI, ETS 3.25" TMIC, SU Test Pipe, CP-E RMM, Bilstein Sports, Cobb Springs, Progress RSB, Short Shift Plate, SU Solid Shifter Bushings, Dashhawk, Gold 18x8.5 Rota G-Force's, 235/40/18 Hankook Ventus V12's 253WHP/274WTQ on a Mustang Dyno before tune, 282WHP/318WTQ in VD after tune 97 Suzuki TL1000S Naked - LeoVince Slip-Ons, K&N Filter, PCII, fully custom naked setup 89 Kawasaki 650SX Stand-Up Jetski |
| The Following User Says Thank You to SRTie4k For This Useful Post: | MS3-a(sore)ASS-rex (04-08-2011) |
Groans: 224
| Not Ranked : 0 score To regulate or to read? I know adding meth, depending on nozzle size could move the AFR anywhere from .5 to over 1.x
| Banned ![]() Join Date: Jun 2008 Location: misery
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 11,510
Groans: 1,940
| Not Ranked : 0 score these threads are the new "which bov" and "which intake" threads do stg 1 for stock turbo. if i were a moderator, i'd lock this thread and tell you to search search search |
| Not Ranked : 0 score Subscribed for info. on brand recommendations, failsafe recommendations etc. |
Groans: 224
| Not Ranked : 0 score I say fuck a failsafe. Don't have one in this car and didnt have one in my 700whp talon. I would recommend a checkvalve to stop meth drip however.
Also, will that effect LTFT's, and therefore cause you to run lean if you run out of meth? Actually now that I think about it, the ECU doesn't make changes in OL anyways, so maybe it's a moot point...
__________________ 08.5 Mazdaspeed 3 - Cobb AP w/ Boost Targetting at 17psi, CP-E Nano SRI, ETS 3.25" TMIC, SU Test Pipe, CP-E RMM, Bilstein Sports, Cobb Springs, Progress RSB, Short Shift Plate, SU Solid Shifter Bushings, Dashhawk, Gold 18x8.5 Rota G-Force's, 235/40/18 Hankook Ventus V12's 253WHP/274WTQ on a Mustang Dyno before tune, 282WHP/318WTQ in VD after tune 97 Suzuki TL1000S Naked - LeoVince Slip-Ons, K&N Filter, PCII, fully custom naked setup 89 Kawasaki 650SX Stand-Up Jetski | |
(Thread Starter) | Not Ranked : 0 score I've been searching and I've been reading the "I'm bored...ask me meth questions" thread. I would think injecting a foreign combustible into your intake is a bit more complicated than choosing which BPV to choose. Can someone point me to a guide on how to actually set up and tune for meth injection?
Groans: 1,940
| Not Ranked : 0 score this was from april 2nd - What Meth/Alcohol systems are you running? this is from yesterday - Meth Install |
| Not Ranked : 0 score I see @FORZDA 1 below, and I would wait to hear his answer. |
Groans: 224
Excellent example of meth drip:
__________________ MS3 has been retired to daily duty Project 1G; 1991 Eagle Talon TSi. 63MM Borg Warner Powered, Corn-Fed, 2.4L Long Rod Monster Under Construction Stock Turbo-Stock Engine Grand Champion of the World! 501WHP & 569WTQ (PERM Tuned, 93 OCTANE PUMP GAS K04 W/N2O!!) NATOR PA Last edited by MS3-a(sore)ASS-rex; 04-08-2011 at 08:43 AM. Reason: MSF Database - Automerged Doublepost | |
| Not Ranked : 0 score I can add one thing. I noticed that the Devil's own kits have the same type of connections that Synapse is using on their BPV's. I had to go "old school" tubing on my Synapse (not using @ the moment), to get it to stop hissing @ the connections. Many people use Devils Own kits w/out a problem, but I, personally am apprehensive to use their connections. |
(Thread Starter) | Not Ranked : 0 score Also, what's the deal with all the failsafe stuff that places like Snow Performance offer. The list seems endless. Snow Performance: Products I'm looking to use something like a 50/50 mix to use to help keep temps down and keep things clean. A Stage 1 is all I need, huh? Are there any recommend additions to a stage 1 kit that I should consider?
Groans: 224
| Not Ranked : 0 score I always end up having trouble with quick connect fittings. I recommend using compression fittings. They're dirt cheap so a couple extra bucks won't break the bank
| Not Ranked : 0 score italics from snow performance... i think their stage 1 kit is n/a only. I know @phillyb used Devils own, so his stage 1 recommendation is for Devil's own. Stage 1 Boost Cooler N/A™ The gasoline Stage 1 Boost Cooler N/A™ kit is available for naturally aspirated applications that don't utilize a MAF sensor. Operation is very simple, the system starts injecting when the vacuum switch reaches the user-adjustable point and it injects a fixed amount of fluid through the nozzle until the switch opens again. This makes it a good choice for naturally aspirated cars looking for an octane enhancement and cooler intake charge. Activation can also be set up through any other user-chosen switch, such as a full throttle switch, etc. |
| The Following User Says Thank You to rfinkle2 For This Useful Post: | XLT_66 (04-08-2011) |
![]() Join Date: Nov 2008 Location: Edmonton, Alberta
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,648
(Thread Starter) | Not Ranked : 0 score I was referring to the DO kit. My bad.
![]() | | #19 | ![]() |
![]() | | #20 | ![]() |
Granted, we usually don't run much over 100 psi in anything... Do you have problems with leaks? It is critical that the tubing is the correct size for the fitting though. A 6mm tube will fit with a 1/4" fitting...but not always and it's usually not a good idea. However, 5/32" and 4mm as well as 5/16" and 8mm are interchangeable. What size lines are you guys running?
__________________ 2009 CWP MS3 SportBuilt Motor and Twinscroll T3 35r - 415WHP/400WTQ - 93 Pump Gas, No Meth - Mustang Dyno Custom Tubular Manifold - HTP 3.5" Intake - 3" V-Band TBE - Custom COBB FMIC - COBB EBCS - COBB 44mm WG - KW V2 Coilovers SOLD! 2008 Toyota Tacoma TRD Sport 4x4 | |
| The Following User Says Thank You to XLT_66 For This Useful Post: | MS3-a(sore)ASS-rex (04-08-2011) |
![]() | | #21 | ![]() |
I'm going to add links to related info. http://www.mazdaspeedforum.org/forum/foru...-w-pics-72851/ Methanol Mixing Calculator (EXCEL) Pre-turbo methanol injection Last edited by rfinkle2; 04-08-2011 at 09:18 AM. | |
![]() | | #22 | ![]() |
Groans: 224
| Not Ranked : 0 score 3/8" refrigeration line. My issues usually stem from the meth tank fitting with leaks. Which is why I go with a compression fitting. I don't want my trunk to ever fill up with a pool o meth again
![]() | | #23 | ![]() |
| [MSF STIG] ![]() Join Date: Apr 2008 Location: Gloucester, VA
Rep Power: 2121 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,476
| Not Ranked : 0 score I have the Labonte VC-100 kit as I think it is the "best" with a positive solenoid for the meth on/off and is manifold pressure(boost) controlled. I've attached a cell photo of my Speed6trunk install w/4qt tank. I ran the hose along the brake/fuel line route under the car and the wiring through the kick panels. I mounted the controller behind the battery and made a bracket to mount the solenoid within 1" of the spray nozzle. I wasn't a fan of WMI until I actually tried it out. I never ran it in the "old" days. I installed it with a very small #3 nozzle to keep the intake/valves clean, but it made a significant difference in how much air the engine could pull in, even with the small nozzle. I start the spray at 10 psi and max it at ~20psi. When I go back with my basically new motor, I will switch to a #4 nozzle. I now believe that meth is REQUIRED for the big power the DISI is capable of. I also added the optional level sensor in the tank and wired it to the washer fluid low light, so the light tells me I'm low on meth as I don't use the washer much..... Oh, and NO leaks...
__________________ `07 Speed6 Sport Tit Gray Sleeper Express... SOLD `11 Ducati 1198SP SBK Duc Red w/Termi exh; Redline flash-tune + PC-5; Sargent; Shift-tech, CDT, & EVR Carbon; 14F/39R gear w/FBF QC; Speedymoto; R&G; ProGrip; Custom LED; Antigravity; Ducabike; Duc Perf, etc... a 182whp/105wtq The BIG DOG `12 Ducati 1100SP EVO Hyper Duc CORSE w/Termi exh; Redline flash-tune + PC-5; Ducshop Hyperstacks; 14F/41R gear w/FBF QC; Shift-tech, CDT, & BST(wheels) Carbon; R&G; ProGrip; Antigravity; Ducabike; Duc Perf, etc... a 95whp/75wtq The Hooligan `12 Aprilia RSV4 "Factory" SBK w/Akra Tit exh & race map; 15/42 gear; R&G; ProGrip; Gilles; CompWerkes; LightWerkes; Lightech; LSL Pegs; Antigravity; Zero Gravity; AF1 Flat Carbon, etc... the 181whp/83wtq The Land Rocket `17 Ford Focus RS Nitrous Blue w/Cobb V3/AT; OZ Ultraleggera; Schroth harness The Super Fun Toy Last edited by FORZDA 1; 04-08-2011 at 09:34 AM. Reason: mo info |
| The Following 10 Users Say Thank You to FORZDA 1 For This Useful Post: | Docnox (06-08-2011), IMASA (06-25-2011), JacksonMS30 (04-08-2011), laxplayermjd (06-07-2011), magicka (06-07-2011), mghtymouse380 (04-13-2011), Monotonous ONE (04-13-2011), Nataphen (04-08-2011), rfinkle2 (04-08-2011), XLT_66 (04-08-2011) |
![]() | | #24 | ![]() |
![]() Join Date: Jul 2010 Location: Bayonne, NJ
Rep Power: 1439 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,348
Groans: 267
| Not Ranked : 0 score can you give a brief description of how you did this?
__________________ 2006 LPM MS6 GT (totaled) 0-60 mph : 4.2 second (as per DH) 12.83 @ ???MPH 1.67 60ft 2002 Miata Se (convertible whore) |
![]() | | #25 | ![]() |
![]() Join Date: Jan 2010 Location: Rosemount, MN
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 946
Groans: 53
Groaned at 31 Times in 22 Posts
| Not Ranked : 0 score So are you guys with Meth just noting your WOT AFRs and adjusting your target? Let's say you're targeting 11.8:1 but because of the meth you're actually seeing 11.1:1. Are you then setting your targets to 12.5:1 to compensate and hit your desired 11.8:1 target?
__________________ You know.... Moose stuff |
![]() | | #26 | ![]() |
| Bob Ross Fanclub ![]() Join Date: Jan 2009 Location: SEFL
Rep Power: 4333 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,534
__________________ |
| The Following 2 Users Say Thank You to Tomas For This Useful Post: | i8urgti (06-03-2011), YokiMazoku (06-07-2011) |
![]() | | #27 | ![]() |
| 2zz mr-s ![]() Join Date: Nov 2010 Location: katy, tx
Rep Power: 3483 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
Groans: 239
__________________ [07:25 PM] Pu Manchu: the second rule is "don't tell anyone" [07:25 PM] Pu Manchu: the first rule of tranny fucking is "don't do it" |
![]() | | #28 | ![]() |
![]() Join Date: Dec 2008 Location: Toledo OH
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 324
| Not Ranked : 0 score Subbed for reference
__________________ | CP-E 75 Duro RMM/TMM + TBE | Corksport SR/TI | Forge BPV | Cobb AP- DJ Tuned | NGK Plugs | Hotchkis RSB @ 140% | PTP IM Gasket/TB Coolant Delete + BSD | Autotech FPi | AEM Meth Injection | SU TMIC | JBR SSP + Stage2 OCC |PG Oil Filter Conversion | Toyota Injector Seals | Bizzerko PnP IM | Grimmspeed EBCS | Ingalls ETD | Sonic Tuning S3 Coilovers |Fluids Rotella T6 A lot Rislone Engine Treatment Motorcraft XT-M5-QS(trans) VP Methanol ~Splash of E85~ |
![]() | | #29 | ![]() |
| Not Ranked : 0 score Thats correct. |
| The Following User Says Thank You to speed23 For This Useful Post: | amoosenamedhank (06-04-2011) |
![]() | | #30 | ![]() |
![]() Join Date: Apr 2009 Location: LOUISIANA!! Football, Guns, Cars, Crawfish, and Beer
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 735
| Not Ranked : 0 score I added this as well. You just drill 7/8, hand tighten it in, make sure the sensor floats up in the tank, ground one lead, and solder the other to the controller yellow wire. Works like a champ. I'm excited about the whole system in general.
__________________ Traded |
![]() | | #31 | ![]() |
| Not Ranked : 0 score Here is my write up: How to install an Alkycontrol kit with PAC controller. The newer alkycontrol kits have a pressure switch to indicate the pump is active instead of mine which indicates off of power supplied to the pump. I have had this kit for 6 years on 2 cars and it is just awesome.
__________________ 08 MS3: ATP GTX3071 at 26PSI , AEM Dryflow 21-2147DK, CP-E 3.25'' MAF, CP-E Nviscid TIP, PG FMIC piping with Treadstone TR11 core, Cobb BPV, Ported IM, PG v1 manifold, CP-E catted DP, CNT CBE, KMD v2, Grimspeed EBCS, Alkycontrol Meth injection (M10 with 100% meth), E40 fuel, Cobb AP (ATR= WIN), ACT ZX4-HDSS, 3-Bar MAP, JBR RSB, and CP-E 60 Duro Engine Mount Set. (297.3WHP/366.9WTQ - on K04, 469.2WHP/420.7WTQ - on GTX3071) |
| The Following User Says Thank You to cld12pk2go For This Useful Post: | rfinkle2 (06-07-2011) |
![]() | | #32 | ![]() |
![]() Join Date: Mar 2010
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 895
![]() | | #33 | ![]() |
![]() Join Date: Sep 2009 Location: salem oregon
Rep Power: 187 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 58
| Not Ranked : 0 score Lots of useful info thanks everyone im ordering my meth kit this week so thanks for the helpful post.
__________________ Boobs.....because you can't motorboat a personality. |
![]() | | #34 | ![]() |
![]() Join Date: Mar 2010 Location: Memphis, TN
Rep Power: 315 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 621
| Not Ranked : 0 score subbed. i just cleaned my intake valves the other day, they new looking now and i want meth. 100 degree weather makes my boost temps way too hot
__________________ 2007 Speed 6 Liquid Platinum Metallic, DIY Duplicolor Graphite Wheel Paint, Clutchmasters FX100, Stock again with 91 ots tune |
| The Following User Says Thank You to laxplayermjd For This Useful Post: | Abilor (06-07-2011) |
![]() | | #35 | ![]() |
| Not Ranked : 0 score I also struggle with the ridiculous nature of early June in the 100's. Meth has seemed to help so far.
![]() | | #36 | ![]() |
| Not Ranked : 0 score Hey guys i posted this in another thread but maybe someone here knows. Where can i find a remote filler for the meth tanks? And how is everything connecting the hose to the lid of the tank without it leaking?
![]() | | #37 | ![]() |
| Not Ranked : 0 score I'd like to comment on compression fittings; I used to use them all the time in my paintball guns running unregulated CO2 (in AZ summers). 800+ PSI with a hot tank was no problem and never had leaks.
![]() | | #38 | ![]() |
Groans: 239
| Not Ranked : 0 score howd you clean yer valves?
![]() | | #39 | ![]() |
| Not Ranked : 0 score i cleaned basically a abrasive blaster using walnut shell media with the blaster set to 6bar. good as new. even that didnt take it all off. did some scraping with a pick. seafoam will do very minimal to clean any of this when run through the intake. if anything youd be better off letting it soak on the valves with them closed all the way. using some tool to scrape at them. Its very hard to do it with anything well that why walnut shells blasting is the way to go.
![]() | | #40 | ![]() |
![]() Join Date: Jun 2011 Location: Vermont
Rep Power: 0 ![]() ![]() Thanks: 18
| Not Ranked : 0 score Hey guys, I'm a bit of a noob here and not exactly a car expert. I have an 07 speed 3 with CP-E catback, SRI, TIP, BOV, and Hypertech programming. The next things on my list are FMIC, DP, Denso spark plugs, and Meth/Water injection. I'm struggling with this hot weather too and within the past few days the temps here (Vermont) have gone from low 70's to high 90's and I've noticed a serious decrease in power, so the meth/water injection seems really tempting. What I don't know is how much a stock turbo/internals with bolt-ons and Hypertech tune would benefit from a meth kit. What would need to be done to get the most out of it, and would I have to get rid of Hypertech and tune with something else? I was reading somewhere that you can actually lose power with meth if you don't adjust boost and timing... ![]() Thanks to anybody who can answer these questions or comment on my mods and what you think. All input will be appreciated |
| Devils Own Meth Injection | 11cruzito11 | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 28 | 10-17-2009 07:40 PM |
| meth injection problem. | 1quik3 | MazdaSpeed 3/6 - Turbo Induction | 3 | 08-10-2009 02:06 PM |
| Meth Injection accessories | wassup61 | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 4 | 05-14-2009 05:10 PM |
| Meth Injection Question | Element | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 6 | 02-03-2009 12:11 PM |
