Like Tree62Likes
 Old 05-20-2012, 07:09 PM   #1
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
Default Methanol Direct Injection
We all know that running water/meth injection (WMI) kits is beneficial for increasing octane and decreasing BAT's. We also know that direct injection (DI) is ridiculously awesome, because all of the heat is absorbed in the cylinder. We have found that running even small mixes of ethanol in our fuel system gives us enough effective octane to hit MBT without knock (Ethanol direct injection - EDI). The amount of heat ethanol absorbs is significantly higher than gas.
So the next logical step, of course, is the venture towards methanol direct injection (MDI).
The issue with running ethanol and methanol has always been their corrosive nature. Congress has mandated that vehicles be able to handle ethanol as a fuel, and we know we can run E85 in our cars without the seals and lines being eaten away or swelling. There has been no extensive testing of methanol with our OE fuel system.
PHASE 1 - Fuel Line Testing
I had an extra fuel line from my early E85 stages. This is the line that goes from the hard line at the firewall to the HPFP - it's the one with round, blue clips. I thought this would be a good candidate for testing methanol on the seals and lines, without running methanol in my car. [Ethanol didn't worry me, methanol does.] I pulled this line apart, and pulled the seals out and took measurements of everything so we can track the effects of methanol.
This is the line I'm talking about:
The line actually has split wire loom and a rubbery cover over it:
Here's what's on the actual line, itself. Maybe we can track down what this stuff is if we ever need to:
The ends have what seem to be 4 important pieces. Red is hard plastic, and seems to be a spacer to hold the seals in place. Green is an actual seal. Blue is another spacer between the Green and Black seal. Black is an actual seal. If you were to look into the end of the line, the order would go red/green/blue/black. Meaning black is on the line side, and red is on the connection side.
Measurements from each of these:
Red:
.050-.055" Thick - these got a little marred when I pulled them
.222-.225" Tall
Green:
.065" Width O-Ring
Blue:
.069-.070" Tall
.035-.037" Thick
Black:
.065" Width O-Ring
Fuel Line:
.032" Wall Thickness
.310" OD
I didn't get ID/OD's of the O-rings, because I cut these in half for the testing. That gave me 4 test vessels
The setup:
1) 100% Shell 93 octane - Control
2) 10% Methanol/90% 93
3) 25% Methanol/75% 93
4) 50% Methanol/50% 93
I will check these periodically. I was thinking every 2 weeks or so I could take a measurement. I'll give them a good swirl whenever I'm out in the garage and just keep an eye on them for any apparent changes. I was really hoping to see something blow up like those capsule animals, but that just didn't happen.
I didn't see any sense in testing E85 with these, as we already know the seals and lines hold up to ethanol. This isn't a comprehensive test, of course. We don't know if our fuel tank and fuel pump will hold up to methanol. This was just a simple test that may move us forward to testing the other components.
This idea originally came from here with @802MS3's question: M85 anyone?
UPDATES (phase 1)
5/20 - Around 7pm CST - pieces dropped into solution for testing.
5/21 - ~14 hours in: The black seal in the 50% solution looks to be swelling. This is the only change I see so far.
5/22 - ~48 hours in: 50% Methanol Solution: Black O-Ring - .076" Width (compared to .065" original) - kept in same solution to watch further changes
5/28 - 6 Days in: No further changes. 50% solution's black O-Ring still swelled to .076". All parts removed from solutions. Waiting to see if black O-Ring returns to normal size.
5/29 - 1 Day out of solution: Black O-Ring is back to original .065".
PHASE 2 - Injector O-Ring/Spacer Testing
I received the injector O-Rings and phenolic spacers from Ziggo yesterday, so I measured them and dropped them into solution.
Blue O-Ring:
.212-.215" Tall (Diameter not measured due to O-Ring damage)
Black Spacer:
.038-.041" Tall
Red Spacer:
.028-.032" Tall
These were dropped into the same solution setup:
UPDATES (phase 2)
5/31 - Around 7pm CST - Seals and Spacers dropped into solutions.
6/1 - ~12 Hours in - Blue O-Ring looks to be swelled in the 50% solution.
6/5 - 5 Days in:
00% Methanol - Blue O-Ring measured .218-.222"
10% Methanol - Blue O-Ring measured .220-.222"
25% Methanol -Blue O-Ring measured .229-.230"
50% Methanol - Blue O-Ring measured .247-.248" & Red Spacer measured .032-.034"
6/5 Results are possibly skewed for Blue O-Rings. All Blue O-Ring measurements (including the control) changed from original. Black and Red spacer measurements remained consistent, so I don't think my measuring skills or caliper are off. It is possibly they were still expanding from their slightly crushed state when I received them. The difference between solutions is still telling, though...
-06 MS6
-Corn fed 07 MS3 - Sold
The Following 117 Users Say Thank You to phate For This Useful Post:
802MS3 (05-20-2012), 86AmishMs3 (05-21-2012), ABolewski (12-05-2012), ABSpeed3 (05-25-2012), Addikted To Boost (07-25-2015), adlpb (05-21-2012), Alpha (05-22-2012), atvfreek (05-20-2012), AZSPEED3 (05-22-2012), BigRedSpecial (05-20-2012), bmfms3 (08-02-2012), Boost_creep (05-25-2012), brandonf (09-25-2013), breakfasteatre (05-21-2012), Broxer (05-20-2012), Bucker (05-20-2012), bwspeed (05-20-2012), charlesfist (05-31-2012), ckMS3 (05-20-2012), cld12pk2go (05-20-2012), Code Monkey (05-13-2014), daafisch (05-21-2012), Dano (12-05-2012), dantes5823 (05-20-2012), darkcherry (06-10-2012), derek13p (05-26-2013), djuosnteisn (05-21-2012), Dmurray06 (05-20-2012), doubleflusher (05-21-2012), dpolseno41 (05-20-2012), duappleganger (05-20-2012), eljefe62 (12-31-2012), Enki (05-31-2012), Fatguy729 (05-20-2012), Fobio (06-05-2012), forcedinduktion (12-08-2012), ganque (06-24-2012), GLORIFIEDBOZO (05-21-2012), h0ckeyman (12-05-2012), Hamilton69 (05-29-2012), harryclay (06-20-2013), helmetface (05-22-2012), i8urgti (05-28-2012), IMASA (05-20-2012), Ingle (05-21-2012), IshiKage (05-29-2012), ItsNox (12-29-2013), J-Liss (05-22-2012), JacksonMS30 (05-22-2012), jack_hammer (05-22-2012), JgamB (06-01-2015), jman46 (05-20-2012), JmkC (06-15-2012), josurr (05-21-2012), jracer (07-03-2012), JSmith (04-17-2013), JTMS3 (05-22-2012), kritz (05-20-2012), Lex (05-20-2012), m249saw (05-24-2012), Mauro_Penguin (08-30-2013), mazdafreak (05-28-2012), McGee (05-21-2012), MD1032 (10-19-2015), Meder (05-20-2012), meicalnissyen (08-16-2015), Mizzle (05-31-2012), Monotonous ONE (05-20-2012), Mortose (05-20-2012), MrPrime (06-03-2013), Ms3_Miami (08-01-2012), Nitr0EngiE (12-08-2012), outshined (05-21-2012), paveltol (05-29-2012), Pointless (05-25-2012), RayRay (05-29-2012), rfinkle2 (05-20-2012), rghispanic88 (05-20-2012), RichieRichness (05-29-2012), rigor (05-29-2012), Roddiy (05-21-2012), Seatime3 (05-20-2012), shawn. (05-22-2012), Sid3wayS (05-20-2012), silvapain (05-20-2012), skeurton (05-21-2012), skiptowncat (08-01-2012), sleepyspeed6 (06-12-2012), SLOWHATCH (05-20-2012), Snappy (10-27-2013), Snyeed (05-28-2012), speed14 (05-20-2012), speed23 (05-20-2012), SPEEDRAC3R (08-02-2012), SpeedRebirth (06-19-2013), Speed_j23 (05-20-2012), StayBroke (05-22-2012), stp (05-21-2012), superskaterxes (05-22-2012), surebOOst (05-21-2012), taf0422 (05-20-2012), TexasSpeed3 (05-29-2012), thehead (05-20-2012), themytb (05-21-2012), Tokay444 (05-20-2012), Twofer (01-09-2013), TWOptSL0W (05-20-2012), uncorked11 (05-20-2012), Vader (05-22-2012), Vinnie (05-24-2012), Voltron (05-31-2012), vrspeed10 (05-21-2012), wolly6973 (05-20-2012), xfeejayx (05-22-2012), xhymer (06-14-2012), xI Leveler Ix (05-29-2012), xxdjfate76xx (05-20-2012)
 Old 05-20-2012, 07:18 PM   #2
Eth Fiend
phate's Avatar
No more double merge, post away
I'll update this one with some articles I have found over the past year or so about EDI/MDI.
Effective Octane And Efficiency Advantages Of Direct Injection Alcohol Engines - MIT - http://web.mit.edu/mitei/lfee/progra...2008-01-rp.pdf
-06 MS6
The Following 6 Users Say Thank You to phate For This Useful Post:
AZSPEED3 (05-22-2012), Dmurray06 (05-20-2012), ItsNox (12-29-2013), rfinkle2 (05-20-2012), SLOWHATCH (05-20-2012), Speed_j23 (05-20-2012)
 Old 05-20-2012, 07:20 PM   #3
Dmurray06's Avatar
Posts: 3,279   (View Stats)
In first. For results. No e85 in Canada. Meth FTW. Thx @phate .
The Following 2 Users Say Thank You to Dmurray06 For This Useful Post:
phate (05-20-2012), Speed_j23 (05-20-2012)
 Old 05-20-2012, 07:30 PM   #4
Eth/Meth Junkie
cld12pk2go's Avatar
Posts: 2,998   (View Stats)
Much win in this thread I sense...
The Following 9 Users Say Thank You to cld12pk2go For This Useful Post:
atvfreek (05-20-2012), ckMS3 (05-20-2012), Dmurray06 (05-20-2012), ItsNox (12-29-2013), Ms3_Miami (08-01-2012), phate (05-20-2012), rfinkle2 (05-20-2012), SLOWHATCH (05-20-2012), Speed_j23 (05-20-2012)
 Old 05-20-2012, 07:32 PM   #5
ckMS3's Avatar
Posts: 1,112   (View Stats)
Subba dub dubbed in the tub
Give me your brain.
rfinkle2 and atvfreek like this.
348tq/367whp -21.5 psi
The Following 5 Users Say Thank You to ckMS3 For This Useful Post:
ABolewski (12-05-2012), atvfreek (05-20-2012), Dmurray06 (05-20-2012), phate (05-20-2012), rfinkle2 (05-20-2012)
 Old 05-20-2012, 07:35 PM   #6
jman46's Avatar
Posts: 3,169   (View Stats)
jman46 is the leader of the worldjman46 is the leader of the worldjman46 is the leader of the worldjman46 is the leader of the worldjman46 is the leader of the worldjman46 is the leader of the worldjman46 is the leader of the worldjman46 is the leader of the worldjman46 is the leader of the worldjman46 is the leader of the worldjman46 is the leader of the world
Groaned at 26 Times in 20 Posts
Damn phate, E85 AND meth? Maybe NASA will be able to copy your setup since you'll be able to get to the moon now lol. Nice work, waiting on results now.
'06 F350 Lariat PSD - 458whp/818wtq
'07 MS3 - 313hp/323tq - sold - the FIRST EVER FREEKPerm.
'06 F150 SCrew 4x4 5.4l - sold
'03 Marauder - Vortech on only 8psi 485whp/435wtq - sold
'95 Mustang GT - sold
'95 SHO MTX - sold
jman46 is offline   Reply With Quote
The Following 11 Users Say Thank You to jman46 For This Useful Post:
ABolewski (12-05-2012), atvfreek (05-20-2012), bmfms3 (08-02-2012), Bucker (05-20-2012), ckMS3 (05-20-2012), Dmurray06 (05-20-2012), IshiKage (05-29-2012), ItsNox (12-29-2013), phate (05-20-2012), rfinkle2 (05-20-2012), Speed_j23 (05-20-2012)
 Old 05-20-2012, 07:37 PM   #7
atvfreek's Avatar
Posts: 7,787   (View Stats)
Time to buy stock in heet. Can't wait to see how those o-rings and plastic hold up!
2010 Speed3-PTE5858
Freek built/Freektuned
510hp420tq
11.321@129.93
The Following 7 Users Say Thank You to atvfreek For This Useful Post:
bwspeed (05-20-2012), ckMS3 (05-20-2012), InFeXIoN (06-06-2012), jman46 (05-20-2012), phate (05-20-2012), rfinkle2 (05-20-2012), Speed_j23 (05-20-2012)
 Old 05-20-2012, 08:06 PM   #8
rabble rabble
802MS3's Avatar
Posts: 5,318   (View Stats)
Groans: 221
@xxdjfate76xx why you being a fag and groaning this man's awesome post?
'08 CWP MS3 w/ T3 3071r
The Following 9 Users Say Thank You to 802MS3 For This Useful Post:
Broxer (05-20-2012), JmkC (05-20-2012), phate (05-20-2012), rfinkle2 (05-20-2012), ryno077 (05-20-2012), silvapain (05-20-2012), SLOWHATCH (05-20-2012), Speed_j23 (05-20-2012), xxdjfate76xx (05-20-2012)
 Old 05-20-2012, 08:15 PM   #9
jman46's Avatar
You know why he did?
'95 SHO MTX - sold
The Following 4 Users Say Thank You to jman46 For This Useful Post:
bmfms3 (08-02-2012), phate (05-20-2012), Speed_j23 (05-20-2012), Voltron (05-31-2012)
 Old 05-20-2012, 08:16 PM   #10
ryno077's Avatar
Posts: 58   (View Stats)
ryno077 has a reputation beyond reputeryno077 has a reputation beyond reputeryno077 has a reputation beyond reputeryno077 has a reputation beyond reputeryno077 has a reputation beyond reputeryno077 has a reputation beyond reputeryno077 has a reputation beyond reputeryno077 has a reputation beyond reputeryno077 has a reputation beyond reputeryno077 has a reputation beyond reputeryno077 has a reputation beyond repute
Awesomeness. Subbed for results
07 MS3 GT
CPE catted DP & CBE // CPE HPFP // Corksport interior LEDs // Cobb AP // JBR Trilogy 88 Mounts // JBR OCC // Sensen Shocks // Centric Rotors // EBC Red Pads // JBR Intake // JBR Battery Tray
ryno077 is offline   Reply With Quote
The Following User Says Thank You to ryno077 For This Useful Post:
phate (05-20-2012)
 Old 05-20-2012, 08:21 PM   #11
dantes5823's Avatar
Posts: 6,576   (View Stats)
Subbed.
The Following User Says Thank You to dantes5823 For This Useful Post:
phate (05-20-2012)
 Old 05-20-2012, 08:24 PM   #12
SLOWHATCH's Avatar
Posts: 2,461   (View Stats)
Groans: 274
Guys please don't crap up the thread posting "subbed"
Use the thread tools box at top of page.
The Following 10 Users Say Thank You to SLOWHATCH For This Useful Post:
Alpha (05-22-2012), kunfu (05-21-2012), Mizzle (05-31-2012), Nliiitend1 (05-21-2012), phate (05-20-2012), Speed_j23 (05-20-2012), thehead (05-21-2012), Wicked (12-05-2012), wolly6973 (05-20-2012), xfeejayx (05-22-2012)
 Old 05-20-2012, 08:31 PM   #13
f-castrillo's Avatar
Posts: 1,342   (View Stats)
f-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the world
Subbed for results! Taking our platform to a new level
Sent from my Galaxy Nexus
(310whp, 341 ft/lb wtq) 91 octane + 100% methanol
JBR RSB, Stage2 OCC, Stage 2 SSP, IM TIG, 70D RMM, 70D PMM // DevilsOwn Stage 2 WMI kit + DO7 nozzle (MSF-prize) // COBB AP (Self-tune), XLE BPV // Corksport TMIC, SRI, TIP // Racing Beat Cat-back Exhaust // Denso Iridium ITV22 Spark Plugs // SURE TB TIG // Ultimate Racing Test Pipe // KMD HPFP Internals // TSW Nurburgring 18x7.5 ET45 Matte Black // SWIFT Spec-R Lowering Springs //
f-castrillo is offline   Reply With Quote
The Following User Says Thank You to f-castrillo For This Useful Post:
phate (05-20-2012)
 Old 05-20-2012, 09:10 PM   #14
xxdjfate76xx's Avatar
Posts: 1,446   (View Stats)
xxdjfate76xx is the leader of the worldxxdjfate76xx is the leader of the worldxxdjfate76xx is the leader of the worldxxdjfate76xx is the leader of the worldxxdjfate76xx is the leader of the worldxxdjfate76xx is the leader of the worldxxdjfate76xx is the leader of the worldxxdjfate76xx is the leader of the worldxxdjfate76xx is the leader of the worldxxdjfate76xx is the leader of the worldxxdjfate76xx is the leader of the world
Groans: 31
Fat finger iPhone fail
.. Anyway, this is a great experiment. Maybe try incorporating operating temps??
Project Gen1 MS3 coming thoon
xxdjfate76xx is offline   Reply With Quote
The Following User Says Thank You to xxdjfate76xx For This Useful Post:
phate (05-20-2012)
 Old 05-20-2012, 10:06 PM   #15
I'm going to venture that 10-20% is probably fine. This was an old trick to pass emissions people did on much older cars.
The Following 12 Users Say Thank You to Lex For This Useful Post:
Alpha (05-22-2012), atvfreek (05-21-2012), dantes5823 (05-20-2012), Dmurray06 (05-21-2012), Nliiitend1 (05-21-2012), phate (05-20-2012), rfinkle2 (05-21-2012), SLOWHATCH (05-21-2012), Speed_j23 (05-20-2012), Tokay444 (05-22-2012), Vader (05-22-2012), xI Leveler Ix (05-29-2012)
 Old 05-20-2012, 11:10 PM   #16
Speed_j23's Avatar
Posts: 611   (View Stats)
Speed_j23 is the leader of the worldSpeed_j23 is the leader of the worldSpeed_j23 is the leader of the worldSpeed_j23 is the leader of the worldSpeed_j23 is the leader of the worldSpeed_j23 is the leader of the worldSpeed_j23 is the leader of the worldSpeed_j23 is the leader of the worldSpeed_j23 is the leader of the worldSpeed_j23 is the leader of the worldSpeed_j23 is the leader of the world
Can't wait to see the results! Hopefully it'll be possible to run it with out any problems.
New: 06 WWP MS6
Old: 06 LPM MS6
Speed_j23 is offline   Reply With Quote
The Following User Says Thank You to Speed_j23 For This Useful Post:
phate (05-21-2012)
 Old 05-21-2012, 07:52 AM   #17
GLORIFIEDBOZO's Avatar
Posts: 1,928   (View Stats)
GLORIFIEDBOZO is the leader of the worldGLORIFIEDBOZO is the leader of the worldGLORIFIEDBOZO is the leader of the worldGLORIFIEDBOZO is the leader of the worldGLORIFIEDBOZO is the leader of the worldGLORIFIEDBOZO is the leader of the worldGLORIFIEDBOZO is the leader of the worldGLORIFIEDBOZO is the leader of the worldGLORIFIEDBOZO is the leader of the worldGLORIFIEDBOZO is the leader of the worldGLORIFIEDBOZO is the leader of the world
Personally I do that for the ones I'm really interested in so I get tapatalk notifications, which don't show up when you use the suscribe tool.
Have you started a thread on your current dealings with this?
"Intelligence isn't the ability to store information, but to find it" - Albert Einstein
"When I read about the evils of drinking, I quit reading" - Henry Youngman
GLORIFIEDBOZO is offline   Reply With Quote
The Following 2 Users Say Thank You to GLORIFIEDBOZO For This Useful Post:
phate (05-21-2012), SLOWHATCH (05-21-2012)
 Old 05-21-2012, 09:04 AM   #18
Eth Fiend
phate's Avatar
OP Updated. I'll keep updating the OP with any info about changes, as well as posting in here to let you guys know what is going on.
Went out to the garage this morning to take a look at any progress. The black O-Ring in the 50% solution looks to be swelled. I think I'll take everything out tonight and measure.
-06 MS6
Nliiitend1 (05-21-2012), silvapain (05-21-2012), SLOWHATCH (05-21-2012), Speed_j23 (05-21-2012), Tokay444 (05-22-2012), wolly6973 (05-21-2012)
 Old 05-21-2012, 09:16 AM   #19
SLOWHATCH's Avatar
Groans: 274
Fair enough.
I have only posted butt dyno, initial impressions and vd plot on the other M85 thread. At this point I don't think another thread is needed, at least not from me. If I find anything new ill likely just post here or the other thread to keep everything together.
The Following 3 Users Say Thank You to SLOWHATCH For This Useful Post:
GLORIFIEDBOZO (05-21-2012), phate (05-21-2012), Speed_j23 (05-21-2012)
 Old 05-21-2012, 09:23 AM   #20
Eth Fiend
phate's Avatar
You guys can shit in this thread all you want. I'm going to keep all of the information I collect in the first two posts.
-06 MS6
The Following 7 Users Say Thank You to phate For This Useful Post:
djuosnteisn (05-21-2012), GLORIFIEDBOZO (05-21-2012), silvapain (05-21-2012), SLOWHATCH (05-21-2012), Speed_j23 (05-21-2012), thehead (05-21-2012), wolly6973 (05-21-2012)
 Old 05-21-2012, 09:28 AM   #21
Ok great! I'll start shitting it up now!
J/k. Hey Clint, have you wondered about how the new injector tables (specific gravity ... easy enough) but the scalar will work with a substantial concentation of M?
The Following 6 Users Say Thank You to rfinkle2 For This Useful Post:
GLORIFIEDBOZO (05-21-2012), phate (05-21-2012), SLOWHATCH (05-21-2012), Speed_j23 (05-21-2012), Tokay444 (05-22-2012), wolly6973 (05-21-2012)
 Old 05-21-2012, 10:40 AM   #22
Ziggo's Avatar
Posts: 3,843   (View Stats)
You want some of my trashed fuel line spacers and orings?
Zigatapatalka
Ask Me About My:
The Following 6 Users Say Thank You to Ziggo For This Useful Post:
GLORIFIEDBOZO (05-21-2012), Nliiitend1 (05-21-2012), phate (05-21-2012), rfinkle2 (05-21-2012), Speed_j23 (05-21-2012), Tokay444 (05-22-2012)
 Old 05-21-2012, 10:46 AM   #23
Eth Fiend
phate's Avatar
Zigatapatalka
Sure, the more we can test outside of the car the better. I'll PM you when I'm back on my PC, and not on my phone.
-06 MS6
GLORIFIEDBOZO (05-21-2012), SLOWHATCH (05-21-2012), Speed_j23 (05-21-2012)
 Old 05-21-2012, 10:56 AM   #24
Fair enough.
Just want to make sure I don't miss anything
Aaaahhhh, no more 63 pages of posts containing valuable information sporadically spread through it? I'm gonna miss all the "I just spent 10hrs a day for the past 3 days reading this! Thanks for all the information @phate!" posts.
The Following 5 Users Say Thank You to GLORIFIEDBOZO For This Useful Post:
Boosted Beluga (05-22-2012), phate (05-21-2012), SLOWHATCH (05-21-2012), Speed_j23 (05-21-2012), wolly6973 (05-21-2012)
 Old 05-21-2012, 11:23 AM   #25
Eth Fiend
phate's Avatar
Looks like we have a scalar limit of 2.48 and Specific Gravity limit of 1.00. Should be plenty for even 100% methanol.
Aaaahhhh, no more 63 pages of posts containing valuable information sporadically spread through it? I'm gonna miss all the "I just spent 10hrs a day for the past 3 days reading this! Thanks for all the information phate!" posts.
Yeah, that thread got a little out of control. Great information, throughout, but I sure as hell don't want to read through 60+ pages of it.
-06 MS6
The Following 5 Users Say Thank You to phate For This Useful Post:
GLORIFIEDBOZO (05-21-2012), rfinkle2 (05-21-2012), SLOWHATCH (05-21-2012), Speed_j23 (05-21-2012), wolly6973 (05-21-2012)
 Old 05-21-2012, 11:38 AM   #26
vrspeed10's Avatar
Posts: 1,035   (View Stats)
vrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the world
Groaned at 25 Times in 10 Posts
in for results.. this is why dizzy rocks!!!
If your not first your last.
03 Speed Protege.. SOLD
10 Speed3 BT and getting my DRANK on!!!
vrspeed10 is offline   Reply With Quote
The Following 2 Users Say Thank You to vrspeed10 For This Useful Post:
 Old 05-21-2012, 11:50 AM   #27
Roddiy's Avatar
Posts: 5,388   (View Stats)
Groans: 279
@phate
What's the price of Methanol / Gal compared to Ethanol?
Would the power gains (theoretically) be worth it?
2010 LSM Speed3
#BakeryTuned
The Following User Says Thank You to Roddiy For This Useful Post:
phate (05-21-2012)
 Old 05-21-2012, 11:51 AM   #28
BigRedSpecial's Avatar
Posts: 1,436   (View Stats)
Groans: 56
Have you given any thought to throwing some bits of aluminum in there to check for corrosion? Effects on seals is only half the concern.
Needed: Driver mod
The Following 6 Users Say Thank You to BigRedSpecial For This Useful Post:
Alpha (05-22-2012), Lex (05-21-2012), Mizzle (05-31-2012), phate (05-21-2012), SLOWHATCH (05-21-2012), wolly6973 (05-21-2012)
 Old 05-21-2012, 11:57 AM   #29
Eth Fiend
phate's Avatar
Originally Posted by Roddiy View Post
@phate
Methanol ranges anywhere from a few bucks a gallon to $10+/gallon. It depends on where and what form you get it in. Race fuel distributors and chemical companies are probably the cheapest. You can get it in the form of HEET, or as methyl hydrate (paint thinner of sorts), but that's where it gets expensive.
This is more for the guys who don't have E85 available. I doubt there will be much (if any) power gain over E85 on the K04 (or on a give amount of air mass, in general). Ethanol has an effective octane of ~160 in DI engines, and methanol around 180. So, small amounts have a huge benefit, as we have seen with ethanol.
Originally Posted by BigRedSpecial View Post
Have you given any thought to throwing some pits of aluminum in there to check for corrosion? Effects on seals is only half the concern.
Yep, but I don't have an extra fuel rail or any hard lines, lol. Like I mentioned, this is definitely not a comprehensive test. Just something to get the ball rolling.
-06 MS6
Last edited by phate; 05-21-2012 at 11:57 AM. Reason: MSF Database - Automerged Doublepost
Bucker (05-22-2012), mazdafreak (05-28-2012), Pointless (06-18-2013), Speed_j23 (05-21-2012)
 Old 05-21-2012, 12:05 PM   #30
Groans: 56
Gotcha, I was just thinking anything at all, scraps of metal or whatever... just to show if there was a cutoff concentration for accelerated corrosion. Definitely wouldn't be comprehensive but could give some idea of when metal parts will start to be at risk.
Needed: Driver mod
The Following 2 Users Say Thank You to BigRedSpecial For This Useful Post:
phate (05-21-2012), wolly6973 (05-21-2012)
 Old 05-21-2012, 12:53 PM   #31
Ingle's Avatar
Posts: 421   (View Stats)
If you can get a hold of another set of the O-Rings and spacers, you should try an E85/Methanol mix which my belief would be the next logical progression to colonizing space.
The Following User Says Thank You to Ingle For This Useful Post:
phate (05-21-2012)
 Old 05-21-2012, 01:10 PM   #32
Aluminum will for sure become corroded by methanol.
What materials are compatible with methanol?
Pure methanol is non-corrosive to most metals (not including lead, magnesium and platinum) at ambient temperatures. However, coatings of copper (or copper alloys), zinc (including galvanized steel) or aluminum are attacked at high temperatures and more slowly at ambient temperatures. Stainless steel and carbon steel are typically used in Methanex plants.
Plastics are generally not recommended for storage purposes due to long-term deterioration of the material and the subsequent risk of methanol contamination.
Many resins, nylons and rubbers, particularly nitrile (Buna-N), ethylene-propylene, teflon and neoprene are used satisfactorily as components of equipment in methanol service.
Source: http://www.methanex.com/products/faqs.html
Concerns with methanol's corrosivity have been addressed by using methanol-compatible materials, and fuel additives that serve as corrosion inhibitors.
Low levels of methanol can be used in existing vehicles, with the use of proper cosolvents and corrosion inhibitors. The European Fuel Quality Directive allows up to 3% methanol with an equal amount of cosolvent to be blending in gasoline sold in Europe.
Source: Wikipedia
Corrosion inhibitors:
Brine Anti Corrosion Chemicals - Methanol Brine Corrosion Inhibitor
Some of you may notice that the aluminum bodies of your meth/WMI pumps get pitting and aluminum corrosion - this is due to the methanol running through these and I don't think they are expected to have an infinite shelf life. Again, it's all about concentrations here.
Last edited by Lex; 05-21-2012 at 01:13 PM. Reason: MSF Database - Automerged Doublepost
The Following 20 Users Say Thank You to Lex For This Useful Post:
802MS3 (05-21-2012), atvfreek (05-23-2012), BigRedSpecial (05-21-2012), bmfms3 (08-02-2012), CosmicArkie (05-21-2012), Dano (06-15-2012), eljefe62 (12-31-2012), GLORIFIEDBOZO (05-21-2012), IMASA (05-21-2012), jman46 (05-21-2012), josurr (05-21-2012), Mizzle (05-31-2012), p057 (05-22-2012), phate (05-21-2012), rfinkle2 (05-21-2012), SLOWHATCH (05-21-2012), Speed_j23 (05-21-2012), surebOOst (05-21-2012), Vader (06-03-2012), wolly6973 (05-21-2012)
 Old 05-21-2012, 03:38 PM   #33
Groans: 56
I'm excited to try this out as soon as I get back home; anxious to see the results from your testing.
Needed: Driver mod
 Old 05-21-2012, 08:38 PM   #34
rabble rabble
802MS3's Avatar
Groans: 221
would really love to run meth in my fuel. no e85 in all of NH, ME, or VT, and no plans to bring it here. really pumped to get some thoughts together.
The Following 5 Users Say Thank You to 802MS3 For This Useful Post:
atvfreek (05-23-2012), GLORIFIEDBOZO (05-21-2012), phate (05-22-2012), rfinkle2 (05-22-2012), SLOWHATCH (05-21-2012)
 Old 05-22-2012, 12:42 PM   #35
v8 convert
p057's Avatar
Posts: 1,782   (View Stats)
p057 has disabled reputation
Groans: 220
e85 would be at minimum 22 miles away from me (one way) to just get a little bit added to my tank. It would be pretty cost prohibitive.
Whereas if I could get my own generic supply of methanol and add as I please to my existing tank, it would greatly help with this florida heat!
p057 is offline   Reply With Quote
The Following 2 Users Say Thank You to p057 For This Useful Post:
 Old 05-22-2012, 01:17 PM   #36
Eth Fiend
phate's Avatar
I know of a lot of guys that grab 5-10 gallons of E85 at a time, and add 2-3 gallons to each fill up. Might be cost effective, since methanol will likely be a bit more expensive per gallon.
-06 MS6
atvfreek (05-23-2012), Bucker (05-22-2012), djuosnteisn (05-22-2012)
 Old 05-22-2012, 01:19 PM   #37
shawn.'s Avatar
Posts: 541   (View Stats)
shawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the world
Groaned at 22 Times in 16 Posts
this. i use a 5 gallon mix, and drive 20 minutes one way for e85. just pick up around 10 gallons or so when you go and it's not that big of a deal. i drive out every 1.5-2 weeks and usually enjoy the drive anyways lol
ATP GTX3071r// Cobb 3 Port EBCS // 3 Bar MAP // Cobb Accessport Freek Tuned // E85 Mix // JBR 3.5" Intake/TIP // Treadstone TR8C FMIC // Autotech HPFP Internals // Ported IM //C-pe Catted Downpipe // TRZ RMM // Corksport CBE // ISC Coilovers // EBC Slotted Rotors--Redstuff Pads // TWM shifter bushings // Dashhawk v2 // 6000k HIDs
Built engine--Manley H Beam Rods--Wiseco Pistons
shawn. is offline   Reply With Quote
The Following 3 Users Say Thank You to shawn. For This Useful Post:
phate (05-22-2012), rfinkle2 (05-22-2012), Speed_j23 (05-22-2012)
 Old 05-22-2012, 01:51 PM   #38
Eth/Meth Junkie
cld12pk2go's Avatar
Last guy I tuned I added about 5-6° by only using 2 gal E85 per tank over pump gas. Epic benefit and he just purchased 15-20 gal from the E85 station like 30 min from his house every few months.
Not a bad setup.
The Following 2 Users Say Thank You to cld12pk2go For This Useful Post:
 Old 05-22-2012, 02:25 PM   #39
Boosted Beluga's Avatar
Posts: 4,859   (View Stats)
Groans: 50
I use a 3 gal e85 mix and drive 20-25 mins one way. (10 miles mostly streets tho) I fill up a total of 15 gals plus put 3 gals in the car. Lasts about 5 weeks.
08 Mazdaspeed 3
Fucking FREEK TUNED and shit
The Following 2 Users Say Thank You to Boosted Beluga For This Useful Post:
atvfreek (05-23-2012), phate (05-22-2012)
 Old 05-22-2012, 02:52 PM   #40
J-Liss's Avatar
Posts: 1,949   (View Stats)
J-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the world
Groans: 81
Groaned at 30 Times in 25 Posts
nice one
2004 mazda 3-Daily
2008 mazda 6-Wife
2008.5 Mazdaspeed 3 totaled
1983- FB Rx-7 Soon to be boosted Carb epicness
Exedy Clutch/Tokico shocks/racing beat Springs/2.5 Custom exhaust/Short shifter/Solid Motor Mounts/custom 3 point harness bar/Full MSD ignition/T2 Oil cooler
J-Liss is offline   Reply With Quote
The Following User Says Thank You to J-Liss For This Useful Post:
phate (05-22-2012)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f303/methanol-direct-injection-114220/
Random thoughts for the day This thread Refback 03-25-2015 12:46 PM
Methanol Injection - Install Suggestions? AntiStock MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 4 12-07-2010 06:54 PM
Pre-turbo methanol injection KoukiS14 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 26 10-19-2009 04:20 PM
Page generated in 0.63473 seconds with 45 queries
