![]() Join Date: Nov 2010 Location: Columbus, GA
Rep Power: 4253 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,493
Groans: 307
(Thread Starter) | Neutral : +1 score First I am starting with the 2.25 gallon tank and will soon swap it out with something bigger depending on how quick I am having to refill the tank. Made two 7/8 holes for the bulkhead fitting and the level sensor. I think I'm going to end up adding some epoxy or something similar to secure them to the tank a little better. For the pump, I purchased the "Upper Housing Assembly" with the 3/8 FPT and swapped it with the pre-installed "push to connect" For the Upper Housing on the pump I used one of the 3/8's to -4AN that came with the Devil's Own SS Kit and purchased the 90* from Jegs.com. Next is the actual SS Line Set purchased from DO. Now since I am doing a Dual Nozzle setup I needed more line. So I added an extra 14" line and an additional nozzle holder. Also didn't like the t-fitting that DO sold so I purchased a NOS brand y-splitter. Probably not necessary but oh well... At this point I am not quite sure how much line I will actually need so I purchased 4' of PTFE SS Line from Jegs.com. With that I also purchased 4 PTFE specific fittings. So once I measure everything out and get it ran in the car I will update with all the exact lengths of all the lines. Next is this little guy I got today. This is JMF's version of the throttle spacer. It came with the 4 bolts and 3 plugs. Here is the configuration I plan to test out tomorrow. I'm not expecting an easy fit so we'll see how it goes. I also purchased DM version of the throttle spacer, so once they ship that I will add to the thread. Here's a list of the things that I got to to work with so far. I probably went overboard but screw it. I will update more tomorrow. Prices, links and more install pics... Any recommendations or face palming are welcome. UPDATE DAY 2 Started the day with running the main 15' line from the trunk into the down through the opening where the ITFP is. Drilled a 7/8 hole and stuffed a grommet to protect the line. I ran the line down along side the rest of them. Worked out pretty good. After everything was in place I zip tied for added measure (not depicted). The 15' line ended right at the fuse box. (Circled in red). Added the DO solenoid and the DO 8" line Added the NOS Y-Splitter and made a 24" and a 28" line with the P.T.F.E. fittings and line I got from Jegs.com. You can see here that the NOS Y-Spliiter worked out better than the DO T-Splitter would have. Now, on to the foreseen problem of getting the JMF throttle body spacer to fit with the stock Intake Manifold. I knew this was going to be an issue with fitment but I was determined to make something work. This is the issue I found. The seam on the Mani and the uneven portion was preventing a good seal, as the DO nozzle holder was too bulky and hitting the portion of the mani circled in red. My fix to this was to spend some time grinding the area down. Made everything nice and flush and with the help of a JBR Thermal Gasket, I had enough clearance to get everything in there after I flattened the DO nozzle holders on the grinder just a bit. Any nozzle holder similar in height but more narrow than the Devils Own rounded ones should work just fine. If the JMF or even DM spacer was/is about 3-4mm wider, would solve the issue. Another potential fix which I believe DM is doing is adding an option for more throttle body gaskets with the spacer. I recommend anyone trying these on the stock Intake Manifold add two TIG's to the TB. There was plenty of bite left on the 4 bolts supplied to allow for the spacer and the TIG I have on my setup. So everything but the controller is in and ready to go. I will wrap it up tomorrow with a test (vids & pics), then the tuning process begins. Adios e85! Did some testing on the Dual DO7's with the JMF. Everything looks good. Leak Test, pump priming and functionality complete. Solenoid and the two check valves are doing their job. No drip coming from the nozzle. Going to finish up the electrical in a bit. More to follow..... UPDATE DAY 3 So I took yesterday off to pick up the motor for the upcoming build. I finished the install today. Because of my OCD and more specifically OCD in regards to electronics and wiring things in my car, it too longer than it really should have. I ran the blue and yellow wires for the pump and level sensor along the side of the car under the door trim, and just found a spot in the trunk for ground to complete that portion of the job I just ran a red 16ga fused power to the battery. For the controller I wasn't very creative so just put decided to put it into the change compartment. The MAP inlet is said to require a 1/16th hose. First problem is I couldn't find one in town. I went to 3 autoparts stores with no luck. Second problem I found a cheap 1/16 hose at Lowes and its honestly too small and flimsy and I didn't feel comfortable pursuing that size. I ended up using 3/32 hose but as you can see it crimps and bend so easy, I think the 1/16th would have been worse. I also purchased about 6 feet of 7/64 hose.. This is what I ended up doing With the combination of Posi-taps and other wire crimping pieces I got everything wrapped up and put the car back together. Priming it was tricky because of limited space everything being all connected and ready to go I ended up setting the controller to its lowest setting on the injection start and highest setting on the full injection dial. Then feathered the throttle while watching BATs and the green LED on the controller. Probably not the best way to do it but it worked. A little blind faith involved but it worked out. I did find a leak so had to disconnect one of the lines at the Y-Splitter, applied some more thread sealer and tightened everything down. Re-primed and leak free. Prices: From Summit Racing... $70.47 Jegs.com $65.94 X's 4 Devil's Own $369 from Edge. Because I didn't get the FPT Upper Assembly, and SS lines initially... Plus all the odds and ends It was a little pricey. Plus its a Dual Setup. Total price without all the extra crap I bought.... $968.52... yeah... I know. I took the car out for a quick test... I set the injection start at around 10psi and full at 18ish.. and grabbed a log. I still have e85 left in tank so I will do some work over the next few days.. Cool to see the BAT's drop from 90's to 50's and IDC's back down to double digits. The pucker factor was definitely high but I will be more responsible with the tuning moving forward. Logs and failsafe install (pending delivery) coming soon... UPDATE: 20 Oct 2014 Today I received the DM version of the throttle spacer. Here are a few pic's of what came in the box. minus the nozzles obviously.... I will be putting this in probably this weekend when the 6 gallon tank comes in. Not sure if there is a benefit at this point to run the bigger nozzles (DO10's). What say you?
__________________ "Here am I. Send me!" ____________________________________________ Columbus, GA 2006 MazdaSpeed 6 EBTEC Motor ¤ PTE 5862 ¤ Custom 3" Exhaust ¤ Bosch 3.5 Bar ¤ Custom 4" Intake ¤ CS Seals ¤ JBR EBCS ¤ Kozmic DP ¤ TurboSmart BOV ¤ Treadstone TR10 FMIC ¤ NGK's ¤ AT Internals ¤ 6th Port ¤ DO Meth ¤ CPE Exh Manifold ¤ Tial 44mm EWG ¤ JMF Manifold ¤ COBB AP ¤ 18x8 Tenzo Cuzco's ¤ H&R Coilovers ¤ Dual OCC ¤ Guardian Angel GT3076 - 393/380 3/9 e85 GT3076 - 426/400 E85/DO10 Meth PTE5862 - TBD ![]() Last edited by ms6mil; 10-20-2014 at 08:53 PM. |
| The Following 26 Users Say Thank You to ms6mil For This Useful Post: | Agent_Orange (10-12-2014), AshFromCan (10-14-2014), bigspender (05-25-2015), chaser27 (10-13-2014), CrawlingMS3 (10-21-2014), cshunter (10-12-2014), Dano (10-20-2014), Goodrich27 (05-07-2015), googlebutt (10-21-2014), Hammology (10-13-2014), impossible (02-05-2016), ItsNox (10-11-2014), Jansi (10-13-2014), kbz0129 (10-11-2014), Mauro_Penguin (10-11-2014), Micha (10-14-2014), Mistersix (10-12-2014), NRBt (09-15-2015), OverBoosted (10-13-2014), PL ENDO (10-21-2014), Plimmer (10-13-2014), Poohster (10-11-2014), rfinkle2 (10-18-2014), Scare Dem (10-11-2014), smoogs12 (10-12-2014), WetzMS3 (10-13-2014) |
![]() Join Date: Apr 2012
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 64
| Not Ranked : 0 score Good idea to turn the pump up the other way. Inlet needs to be as low as possible. If you dont when your tank gets low it will become a problem.
__________________ 2012 Black Mazda 3 MPS ![]() CP-E Stage 2 Pistons - Manley Rods - BNR S3 - HTP 3" TIP + 3" BTM - Corksport Airbox - Cobb FMIC 2XS Exhaust Manifold - Snow Performance Meth Kit - HKS SSQIV - HPFP Internals - CPE Catted Downpipe - Perm PCV Plate OBX Catback - CPE Stage 2 RMM - JBR Side Mounts - SURE AGS Shiftknob + Shortcut + Anchors Cobb Accessport V3 - Saikou Michi OCC - Damond OCC - Corksport Springs - Bilstein B8 Shocks Versus Eurolace 19 x 8 +45 - Hankook RS3 Built & Tuned by Rob Track Setup - 18 x 8.5 Lenso Spec E - Nitto NT-01 245/40/18 DBA T3 Rotors - Carbotech XP10 Brake Pads |
| The Following User Says Thank You to ledfootrob For This Useful Post: | ms6mil (10-11-2014) |
Groans: 307
(Thread Starter) | Not Ranked : 0 score I tried to fit it that way and the upper assembly hangs lower than the tank. I would need to prop it up for it to fit. Plus from what I'm being told by the guys at DO the pump will be functional in any position. For these tanks and the larger ones that I will be upgrading to all mount on top. I would like to hear and read about pump flow failure because the pump wasn't put upside down. I'm open to it, just seems to be one of those things that people say because everyone else does. I shouldn't be running low... Again I'm open to (the whole putting the pump lower than the tank)it if the manufacturer or more importantly the MSF community that has insight or experience with this tank or the like, and a pump not being put upside down at which point flow became issue.
__________________ "Here am I. Send me!" ____________________________________________ Columbus, GA 2006 MazdaSpeed 6 EBTEC Motor ¤ PTE 5862 ¤ Custom 3" Exhaust ¤ Bosch 3.5 Bar ¤ Custom 4" Intake ¤ CS Seals ¤ JBR EBCS ¤ Kozmic DP ¤ TurboSmart BOV ¤ Treadstone TR10 FMIC ¤ NGK's ¤ AT Internals ¤ 6th Port ¤ DO Meth ¤ CPE Exh Manifold ¤ Tial 44mm EWG ¤ JMF Manifold ¤ COBB AP ¤ 18x8 Tenzo Cuzco's ¤ H&R Coilovers ¤ Dual OCC ¤ Guardian Angel GT3076 - 393/380 3/9 e85 GT3076 - 426/400 E85/DO10 Meth PTE5862 - TBD ![]() |
| Not Ranked : 0 score Once the tank gets low and sloshes around air will get into the hose and the pump will run dry. If the inlet is at the bottom of the tank it will self prime itself.
Groans: 307
(Thread Starter) | Not Ranked : 0 score This tank has a built in sump and fluid baffle to prevent such an issue, unlike the 2-4qt tanks. My Fluid level sensor is remarkably higher than the tank tap. As long as the sump and baffle work like they should, there should be no air pickup. Also will have a flow fail safe connected to the Guardian Angel
| The Following 3 Users Say Thank You to ms6mil For This Useful Post: |
![]() Join Date: Sep 2013 Location: Grapevine, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 373
| Not Ranked : 0 score Nice! What did you end up spending on all those little AN fittings? This is on my long list of to do's lol
__________________ 2010 Ms3 PD Tuned GTX3076 EWG Forged Engine Built By Yours Truly 2006 Ms6 GT-Stock |
| The Following 2 Users Say Thank You to kbz0129 For This Useful Post: | ms6mil (10-11-2014), richardms3 (08-10-2015) |
Groans: 307
(Thread Starter) | Not Ranked : 0 score Gonna consolidate all the prices tomorrow, and trim it to the essentials. I used jegs.com and summitracing for the fittings. Definitely spent more than I should have.
| The Following User Says Thank You to ms6mil For This Useful Post: | impossible (02-05-2016) |
| Not Ranked : 0 score You should ask someone at Devil's Own. I thought the point was the pump was a pusher style. Doesn't like to suck very much. With the low tank, you will be sucking uphill. My impression was the inlet to the pump should be lower than the tank and the lowest point in the system |
| The Following User Says Thank You to sheston For This Useful Post: | ms6mil (10-11-2014) |
Groans: 307
I already did speak with the DO guys. If anyone has substantive evidence/experience with this 2.25 gallon tank with the sump and baffle or similar types I would love some input. (specifically of its baffle & sump failure)
__________________ "Here am I. Send me!" ____________________________________________ Columbus, GA 2006 MazdaSpeed 6 EBTEC Motor ¤ PTE 5862 ¤ Custom 3" Exhaust ¤ Bosch 3.5 Bar ¤ Custom 4" Intake ¤ CS Seals ¤ JBR EBCS ¤ Kozmic DP ¤ TurboSmart BOV ¤ Treadstone TR10 FMIC ¤ NGK's ¤ AT Internals ¤ 6th Port ¤ DO Meth ¤ CPE Exh Manifold ¤ Tial 44mm EWG ¤ JMF Manifold ¤ COBB AP ¤ 18x8 Tenzo Cuzco's ¤ H&R Coilovers ¤ Dual OCC ¤ Guardian Angel GT3076 - 393/380 3/9 e85 GT3076 - 426/400 E85/DO10 Meth PTE5862 - TBD ![]() | |
| The Following User Says Thank You to ms6mil For This Useful Post: | Poohster (10-12-2014) |
Groans: 307
(Thread Starter) | Not Ranked : 0 score Updated OP.
![]() Join Date: Jan 2013 Location: South Boston, MA
Rep Power: 1402 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,475
| Not Ranked : 0 score Damn @ms6mil; that is a legit write up of your setup. It has definitely been noted for the future. Good to see what's workin, functioning and what's not between great minds collaborating and pushing the platform on meth.
__________________ 07 BLACK MICA MS3 PATTY/JEFF BUILT MOTOR BNRS3V2 349/344 VD 93 FREEKTUNE E25 382/375 GSD DynoJet 141020 STOCK BLOCK FREEK KORN TUNE 335whp/356wtq ENM 14 K04 ~ Ordnance, Droppn' Warheads of Foreheads Since 1922 ~ BOSTON STRONG |
| The Following User Says Thank You to King Scumbag For This Useful Post: | ms6mil (10-12-2014) |
Groans: 307
(Thread Starter) | Not Ranked : 0 score Leak Test, pump priming and functionality complete. Solenoid and the two check valves are doing their job. No drip coming from the nozzles. Video added to OP
__________________ "Here am I. Send me!" ____________________________________________ Columbus, GA 2006 MazdaSpeed 6 EBTEC Motor ¤ PTE 5862 ¤ Custom 3" Exhaust ¤ Bosch 3.5 Bar ¤ Custom 4" Intake ¤ CS Seals ¤ JBR EBCS ¤ Kozmic DP ¤ TurboSmart BOV ¤ Treadstone TR10 FMIC ¤ NGK's ¤ AT Internals ¤ 6th Port ¤ DO Meth ¤ CPE Exh Manifold ¤ Tial 44mm EWG ¤ JMF Manifold ¤ COBB AP ¤ 18x8 Tenzo Cuzco's ¤ H&R Coilovers ¤ Dual OCC ¤ Guardian Angel GT3076 - 393/380 3/9 e85 GT3076 - 426/400 E85/DO10 Meth PTE5862 - TBD ![]() Last edited by ms6mil; 10-12-2014 at 10:02 AM. |
![]() Join Date: Jan 2014 Location: Winnipeg, Manitoba
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 212
| Not Ranked : 0 score You mentioned possibly upgrading to a bigger tank depending on how often you have to refill. How long do you expect that volume of meth to last? I know it will depend on your goals, setup, etc. but what are your ballpark expectations? Thinking of doing this in the future at some point and just trying to get ideas on what to expect. Great writeup btw.
__________________ 2013 White MS3 Power |Cobb V3 AccessPort| |Ultimate Racing TBE w/ V2 DP| |Cobb FMIC| |Cobb SRI/TIP| |Autotech HPFP Internals| Supporting |Cobb RMM| |Cobb Shift Weight| |
| The Following User Says Thank You to AshFromCan For This Useful Post: | ms6mil (10-12-2014) |
| Not Ranked : 0 score I would be interested in how fast you go thru the Meth as well. That video is very impressive, lots of Meth. With my driving style, (D03 and D07) coming on at 10ish psi and full by 18 psi, I go thru a gallon and a half to 2 gallons every gas tank. How much horsepower are you running? |
| The Following 2 Users Say Thank You to sheston For This Useful Post: | AshFromCan (10-13-2014), ms6mil (10-12-2014) |
Groans: 307
I will be upgrading to the 6 gallon at some point.
__________________ "Here am I. Send me!" ____________________________________________ Columbus, GA 2006 MazdaSpeed 6 EBTEC Motor ¤ PTE 5862 ¤ Custom 3" Exhaust ¤ Bosch 3.5 Bar ¤ Custom 4" Intake ¤ CS Seals ¤ JBR EBCS ¤ Kozmic DP ¤ TurboSmart BOV ¤ Treadstone TR10 FMIC ¤ NGK's ¤ AT Internals ¤ 6th Port ¤ DO Meth ¤ CPE Exh Manifold ¤ Tial 44mm EWG ¤ JMF Manifold ¤ COBB AP ¤ 18x8 Tenzo Cuzco's ¤ H&R Coilovers ¤ Dual OCC ¤ Guardian Angel GT3076 - 393/380 3/9 e85 GT3076 - 426/400 E85/DO10 Meth PTE5862 - TBD ![]() Last edited by ms6mil; 10-12-2014 at 08:00 PM. | ||
| The Following 7 Users Say Thank You to ms6mil For This Useful Post: | AshFromCan (10-13-2014), cshunter (10-12-2014), Hammology (10-13-2014), impossible (02-05-2016), ItsNox (10-12-2014), Mauro_Penguin (10-19-2014), Plimmer (10-13-2014) |
![]() Join Date: Mar 2013 Location: San Antonio, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 683
| Not Ranked : 0 score Awesome thread. Thanks for the R&D, and VD looks great.
__________________ Was: 2012 with GTX3071 and BF Goodrich g-Force Rivals Now: 2015 Mustang GT 5.0, soon to be track toy |
| The Following User Says Thank You to Plimmer For This Useful Post: | ms6mil (10-13-2014) |
Groans: 307
(Thread Starter) | Not Ranked : 0 score OP updated.. Thanks Rob, Let me know when we're gonna pitch in for more meth. I am gonna be going through alot of this stuff.
| The Following User Says Thank You to ms6mil For This Useful Post: | ItsNox (10-13-2014) |
Groans: 307
| The Following 2 Users Say Thank You to ms6mil For This Useful Post: | AshFromCan (10-14-2014), Mauro_Penguin (10-19-2014) |
![]() | | #19 | ![]() |
| Not Ranked : 0 score Great update. I have a question for you. You made a comment about have E still in the tank. Are you trying to replace E with this set-up? I'm toying with using Meth in the gas tank instead of Eth, really using that for the knock protection, with the Meth spray for the extra fuel and BAT cooling (I'm hoping this gives me protection if my WMI fails at some point). Is this your plans as well? |
| The Following User Says Thank You to sheston For This Useful Post: | ms6mil (10-14-2014) |
![]() | | #20 | ![]() |
Groans: 307
The more I read about the various fails with meth, the more anxious I get. Check valves, pump failure, leaks, clogged lines... it all could go very wrong, besides the flow meter/fail safe and my OCD to check and re check everything and ensuring I installed to the best of my ability is all i can do.
| The Following 2 Users Say Thank You to ms6mil For This Useful Post: | ItsNox (10-14-2014), Mauro_Penguin (10-19-2014) |
![]() | | #21 | ![]() |
| Not Ranked : 0 score Looks like you did a great job making it as robust as possible. Good luck continuing. I just didn't like having to keep jugs of Eth and jugs of Meth. I used to put 4.5 gallons of Eth in every tank. Now I'm putting 2 gallons of Meth. Seems fairly equivalent as far as knock protection and timing, and now I only have to go to one drug dealer :-) |
| The Following 2 Users Say Thank You to sheston For This Useful Post: | Mauro_Penguin (10-19-2014), ms6mil (10-14-2014) |
![]() | | #22 | ![]() |
Groans: 307
![]() | | #23 | ![]() |
![]() Join Date: Sep 2013 Location: Heflin, AL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 803
| Not Ranked : 0 score well now I know who is going to help me with my install when the day comes... Good stuff! Glad to see you moving along with this build. Sending the motor out? I pegged you for a DIY'er. you know you wanna try it lol
| V2 Pre-amp | | |
![]() | | #24 | ![]() |
Groans: 307
I am going to start purchasing the supporting upgrades for it soon, ie JMF mani, new exhaust mani and a bigger turblow!
| The Following 2 Users Say Thank You to ms6mil For This Useful Post: | BLKSTIG (10-15-2014), Mauro_Penguin (10-19-2014) |
![]() | | #25 | ![]() |
Groans: 307
(Thread Starter) | Not Ranked : 0 score I got a few revisions in, this progressive controller will take some getting used to. I still have to smooth out the AFR's a bit. I am seeing a common issue from what I have read in other threads with enrichment after I let off the throttle. Also overshot my boost at spool up a little so will make corrections on the next map. I am continuing to track my meth usage, # of WOT logs, etc... I will continue to clean up the tune and report back.. Tips, recommendations, all welcome.
![]() | | #26 | ![]() |
| Not Ranked : 0 score Man, that is some write-up. Thanks for taking the time to do that. |
| The Following 3 Users Say Thank You to rfinkle2 For This Useful Post: |
![]() | | #27 | ![]() |
| Not Ranked : 0 score Ditto Rob, ditto, I agree this thread is win. @ms6mil; good shit dood. I'm sitting, watching and waiting. Nothing better then seeing such a great setup come together so well. I thank you for this as if and when I do run meth this is a great reference. Let the dick reading continue ![]() Edit: riding not reading..I'm drunk but I love reading it too. Hahahaba
![]() | | #28 | ![]() |
Groans: 307
(Thread Starter) | Not Ranked : 0 score Much appreciated. For now I am just continuing to log and tweak. So far I just finished my first tank of gas and have over half the 2.25 gallon tank of meth left. I have driven over 350 miles of mixed driving and about 57 WOT logs and a few races this evening with a befuddled Stang 5.0 owner. The 2.25 galllon DO meth tank would be perfect for a single nozzle trunk setup but I am ordering the 6 gallon tank this weekend. I figure once I swap the DO10's and test out the DM throttle body spacer it would be a perfect opportunity to swap out for a bigger meth tank. I will post up some logs tomorrow.
| The Following 4 Users Say Thank You to ms6mil For This Useful Post: |
![]() | | #29 | ![]() |
| Not Ranked : 0 score off topic: how many miles are on your motor and how many miles at this power level?
| V2 Pre-amp | | |
![]() | | #30 | ![]() |
Groans: 307
(Thread Starter) | Not Ranked : 0 score Currently around 94k miles on the motor. As far as how long at this power level, I would say it's been about a year and half and about 20-25k miles since the turbo install. Our last Dyno day was this last May and I was at 393 and have been there pretty consistently since then on e85. I would guess about 10k miles since then.
| The Following User Says Thank You to ms6mil For This Useful Post: | BLKSTIG (10-19-2014) |
![]() | | #31 | ![]() |
Groans: 307
(Thread Starter) | Not Ranked : 0 score Here's a couple of pulls from this morning. About time to top off the meth tank.
__________________ "Here am I. Send me!" ____________________________________________ Columbus, GA 2006 MazdaSpeed 6 EBTEC Motor ¤ PTE 5862 ¤ Custom 3" Exhaust ¤ Bosch 3.5 Bar ¤ Custom 4" Intake ¤ CS Seals ¤ JBR EBCS ¤ Kozmic DP ¤ TurboSmart BOV ¤ Treadstone TR10 FMIC ¤ NGK's ¤ AT Internals ¤ 6th Port ¤ DO Meth ¤ CPE Exh Manifold ¤ Tial 44mm EWG ¤ JMF Manifold ¤ COBB AP ¤ 18x8 Tenzo Cuzco's ¤ H&R Coilovers ¤ Dual OCC ¤ Guardian Angel GT3076 - 393/380 3/9 e85 GT3076 - 426/400 E85/DO10 Meth PTE5862 - TBD ![]() Last edited by ms6mil; 10-19-2014 at 04:48 PM. |
| The Following 7 Users Say Thank You to ms6mil For This Useful Post: | 09TrueRedGTX (10-20-2014), BLKSTIG (10-19-2014), chaser27 (10-19-2014), King Scumbag (10-19-2014), Mauro_Penguin (10-19-2014), rfinkle2 (10-20-2014), rymanmazda (10-19-2014) |
![]() | | #32 | ![]() |
__________________ 2013 White MS3 Power |Cobb V3 AccessPort| |Ultimate Racing TBE w/ V2 DP| |Cobb FMIC| |Cobb SRI/TIP| |Autotech HPFP Internals| Supporting |Cobb RMM| |Cobb Shift Weight| | |
| The Following User Says Thank You to AshFromCan For This Useful Post: | ms6mil (10-19-2014) |
![]() | | #33 | ![]() |
| Not Ranked : 0 score Man, I need to go BT! Nice stuff |
| The Following User Says Thank You to sheston For This Useful Post: | ms6mil (10-19-2014) |
![]() | | #34 | ![]() |
Groans: 307
(Thread Starter) | Not Ranked : 0 score 100% on dual DO7's
![]() | | #35 | ![]() |
Groans: 307
| The Following User Says Thank You to ms6mil For This Useful Post: | Mauro_Penguin (10-20-2014) |
![]() | | #36 | ![]() |
| Not Ranked : 0 score | |
![]() | | #37 | ![]() |
Groans: 307
(Thread Starter) | Not Ranked : 0 score Yeah I saw it, I'll adjust, thanks again.
| The Following User Says Thank You to ms6mil For This Useful Post: | rfinkle2 (10-20-2014) |
![]() | | #38 | ![]() |
Groans: 307
(Thread Starter) | Not Ranked : 0 score Today I received the DM version of the throttle spacer. Here are a few pic's of what came in the box. minus the nozzles obviously.... I will be putting this in probably this weekend when the 6 gallon tank comes in. Not sure if there is a benefit at this point to run the bigger nozzles (DO10's). What say you?
| The Following 2 Users Say Thank You to ms6mil For This Useful Post: | ItsNox (10-21-2014), Mauro_Penguin (10-23-2014) |
![]() | | #39 | ![]() |
Groans: 307
| The Following 2 Users Say Thank You to ms6mil For This Useful Post: | Mauro_Penguin (10-23-2014), OverBoosted (10-23-2014) |
![]() | | #40 | ![]() |
![]() Join Date: Oct 2012 Location: Colorado Springs, CO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 757
__________________ mods: \\// AT HPFP // AccessPort // CS S2 TIP, SRI and TMIC // CPe S2 RMM // Synapse BPV // Mazda gutted secondary cat // S-OTS+ 91S2 // HKS TP DLi II // Wilwood DP6 13” brakes // TCE 2 piece rear rotors // Maxwell SuperCap/LiFePO4 cell \\// waiting for install: \\// CPE Catted DP // CS Battery Box // Devils Own Meth kit // H&R Coilovers \\// | |
| Meth nozzle install location?? | Darthspeed3 | 2010 MS3 - Fuel, Nitrous & Water Injection | 5 | 06-16-2014 12:13 PM |
| Dual meth tank install how-to | Matrix311 | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 11 | 02-11-2013 05:55 PM |
