Like Tree31Likes
 Old 08-09-2012, 01:47 PM   #41
Jerd2189's Avatar
Posts: 7   (View Stats)
Jerd2189 will become famous soon enough
Figured out lean code, diameter of intake tubing I used is larger than factory so there was unmonitored air. Currently I have switched to a K&N intake short ram instead and it has been running better even though power band seems less responsive than my original intake.
Jerd2189 is offline   Reply With Quote
 Old 08-30-2012, 09:05 AM   #42
Jasbo's Avatar
Posts: 364   (View Stats)
Jasbo is the leader of the worldJasbo is the leader of the worldJasbo is the leader of the worldJasbo is the leader of the worldJasbo is the leader of the worldJasbo is the leader of the worldJasbo is the leader of the worldJasbo is the leader of the worldJasbo is the leader of the worldJasbo is the leader of the worldJasbo is the leader of the world
Originally Posted by shawn19 View Post
Sorry if this a stupid question but would a walboro 255 be enough fuel pump for full bolt-on through stage 2?
I see what your saying.. If the CDFP is having trouble keeping up, then your thinking its because the supply is dwindling? Perhaps the answer to that isnt about the feed rate to the CDFP as much as it is the amount of fuel the CDFP is taking in per cycle. In this case you wouldnt fix the high pressure problem without upgraded internals.
Jasbo is offline   Reply With Quote
 Old 09-06-2012, 03:37 PM   #43
Triz187's Avatar
Posts: 2   (View Stats)
Triz187 is an unknown quantity at this point
Default Fuel Pump Failing!
Went to get Dyno'd at Cobb last week. Running stg 2 with Auto Tech internals. Tuner said my FP failed while tuning. He tuned for my intake before the pump gave out so he built me a baseline map and said for me to put the stock internals back in and to investigate the Autotech ones for scoring or defects. I went home took the pump appart and found the Autotech internals ok with No sign of scoring or damage. While I had the pump out I investigated the housing and found a four-digit number on the high pressure line out of the pump. After research I found that the number which was 7215 was the manufacturing date of that pump and there was a service bulletin online from mazda stating that any pump manufactured before march 2007 should be replaced. When opening the pump with the 18mm socket to reinstall the OEM internals the stainless steel cylinder where the piston comes through was loose enough that I didnt have to place the pump in a vice to unscrew the stainless steel cylinder.Went ahead and put the stock internals back in.This time I took my torque wrench and tightened the 18mm stainless steel cylinder to about 35lb/ft, to ensure it would unscrew. Now running that base map, I keep throwing P2187 over and over again. Does this mean I need to purchase a brand new pump. I do have they Autotech internals cleaned and ready to install again. Did my pump fail on the dyno becuase the stainless steel cylinder started to back it self out, or did it fail because it was a faulty pump assembly from the factory( new internals were installed) Knowledgable people please help as I dont want to have to spend 400$ on a brand new pump if I dont have too. I want me car to run good again so I can get it back on the dyno for a protune.
Triz187 is offline   Reply With Quote
 Old 09-16-2012, 09:37 PM   #44
Resident Baus
duappleganger's Avatar
Posts: 504   (View Stats)
duappleganger is the leader of the worldduappleganger is the leader of the worldduappleganger is the leader of the worldduappleganger is the leader of the worldduappleganger is the leader of the worldduappleganger is the leader of the worldduappleganger is the leader of the worldduappleganger is the leader of the worldduappleganger is the leader of the worldduappleganger is the leader of the worldduappleganger is the leader of the world
Groans: 34
Groaned at 56 Times in 18 Posts
Hey sorry if this has been covered but I searched and didn't find a definitive answer. I understand that ~400 is good for idle and ~1750+ is good for WOT. I'm good on both those counts. I was cruising on the highway today and noticed my FP dropped to 280 while using cruise control and coasting down a hill at about 75mph. Is this acceptable? I've got autotech internals.
2011 Black Mica MS3
FREEKTUNE (On hold 'til EWG) ATP GTX3071R IWG (soon to be EWG) Full Race exhaust manifold CP-e whale peen + 3.25 in. intake
COBB EBCS + Downpipe + BPV + AP Stage 2 Corksport CBE + Brake Pads Ultimate FMIC NGK Iridium IX @ .28 DDM HID 6000k
Autotech CDFP Internals JBarone EGR delete, TB + IM gaskets, SSP + Shift Anchors, 88D RMM, 70D passenger + tranny mount, RSB, and OCC
HTP battery box TSW Nurburgrings 18x8.5 MBR w/ Michelin Pilot Super Sports 235x40x18 +45 Goodridge SS Brake Lines
Installation TBD: H&R springs + Koni yellow shocks + struts
duappleganger is offline   Reply With Quote
 Old 09-23-2012, 08:51 PM   #45
mhebert2001's Avatar
Posts: 491   (View Stats)
mhebert2001 has a reputation beyond reputemhebert2001 has a reputation beyond reputemhebert2001 has a reputation beyond reputemhebert2001 has a reputation beyond reputemhebert2001 has a reputation beyond reputemhebert2001 has a reputation beyond reputemhebert2001 has a reputation beyond reputemhebert2001 has a reputation beyond reputemhebert2001 has a reputation beyond reputemhebert2001 has a reputation beyond reputemhebert2001 has a reputation beyond repute
Groaned at 6 Times in 4 Posts
I seldom use cruse control, but I have seen mine drop down to the 200s during engine breaking. Not sure if that is good for both of us, or bad for both of us.
2012 MAZDASPEED3 BLACK MICA (Stage 1, Cobb AP, Autotechs, Cobb SF, TIP & Airbox)
Coming soon: 2nd etune
2013 MAZDASPEED3 Liquid Silver (Stock and not allowed to touch!)
mhebert2001 is offline   Reply With Quote
 Old 09-23-2012, 09:33 PM   #46
CamSpeed360's Avatar
Posts: 793   (View Stats)
CamSpeed360 is the leader of the worldCamSpeed360 is the leader of the worldCamSpeed360 is the leader of the worldCamSpeed360 is the leader of the worldCamSpeed360 is the leader of the worldCamSpeed360 is the leader of the worldCamSpeed360 is the leader of the worldCamSpeed360 is the leader of the worldCamSpeed360 is the leader of the worldCamSpeed360 is the leader of the worldCamSpeed360 is the leader of the world
Groaned at 31 Times in 13 Posts
Mine does the same. Of I can remember correctly, the desired pressure dropped that low too so it shouldn't be a problem. But I would ask someone else to confirm this.
2007 Black Mica MS3
JBR 3.5 Whale Penis Intake = Cobb V2/Treadstone FMIC = PTP HPFP internals
Snow Meth Injection, AIS 5GPH = TurboXS Downpipe/Racepipe = SSP-OCC
Road Magnet Springs = Bilstien B8 shocks = Cobb RSB = SURE RMM
Tuned by the FREEK
CamSpeed360 is offline   Reply With Quote
 Old 09-24-2012, 06:46 AM   #47
POWERED BY POLSKA
themytb's Avatar
Posts: 762   (View Stats)
Groans: 38
During coast/ engine braking the ecu cuts fuel, there is no demand for fuel so the commanded pressure most likely drops- I have not paid attention to my pressure while coasting, but I would not worry about it.
25%E85FREEKPERMED
 Old 10-07-2012, 09:30 PM   #48
agentgordon27's Avatar
Posts: 560   (View Stats)
So I noticed the OP jumps straight to the importance of the CDFP upgrade, so is the in-tank not a limiting factor for bolt on performance? I'm guessing because it only has to flow into the single point to the high pressure pump vs. maintaining pressure to a rail and four injectors?
 Old 10-08-2012, 09:13 AM   #49
POWERED BY POLSKA
themytb's Avatar
Groans: 38
In tank flows plenty until you get into an extra injectors(s) situation. The stock(non upgradeable) injectors will hold you back before a properly working ITP, and this occurs a bit past the 400 whp mark(on ms3's)
25%E85FREEKPERMED
 Old 10-11-2012, 07:28 AM   #50
chimneybear's Avatar
Posts: 29   (View Stats)
chimneybear has a spectacular aura aboutchimneybear has a spectacular aura about
Got a K&N SRI on '11 speed3 and was planning for a FMIC. Was rather disturbed to find out that fp upgrade should be done FIRST as talked here. I am currently, however, logging 1650-1750 psi consistently on WOT, peaking at 1800-ish. Should I still prioritize fp upgrade if I were to do AP stage 1 for now?
Power
Autotech upgraded fuel pump internals, K&N Typhoon SRI, Cobb Turbo inlet pipe, Cobb XLE BPV, NGK LTR7IX-11 1 step colder sparks, Cobb FMIC v2, JBR oil catch kit stage 2, ATP 3" catless upper down pipe, ATP 3" catless lower down pipe
Handling
CP-e engine mounts (rear, transmission, driver) 75A duro, JBR rear sway bar, Corksport coilovers, Corksport adjustable front camber plates, Megan adjustable rear toe arms, SPC adjustable rear camber arms, Goodyear Asymmetric 2 - 235/40/18
ECU
Cobb accessport v2 - self tuned
chimneybear is offline   Reply With Quote
 Old 10-11-2012, 07:48 AM   #51
jack_hammer's Avatar
Posts: 6,822   (View Stats)
Groans: 549
the genpus are known kill a fp with anything more than an intake.
it's fun to do bad things
 Old 10-12-2012, 01:19 PM   #52
MSpeed3013's Avatar
Posts: 136   (View Stats)
MSpeed3013 has much to be proud ofMSpeed3013 has much to be proud ofMSpeed3013 has much to be proud ofMSpeed3013 has much to be proud ofMSpeed3013 has much to be proud ofMSpeed3013 has much to be proud ofMSpeed3013 has much to be proud ofMSpeed3013 has much to be proud ofMSpeed3013 has much to be proud ofMSpeed3013 has much to be proud of
Now, do you mean driving at a constant speed/rpm, when you say coast? If not, Is there an acceptable FP pressure while at "cruising speed"? Noticed a pressure drop while at crusing speed with cruise control on, and i was curious. I have AT internals installed.
Cobb Access Port V2--Stratified Stage 2 S-OTS--Custom 3.gal E85
JBR 3" Intake--JBR RMM--JBR EGR Delete--JBR block off plate
JBR Coolant Bypass--JBR TB TIG--JBR RSB--JBR SSB--JBR SSP--JBR Knob
JBR Recirc tube--CS TMIC--M2 Long catless DP--AT HPFP
TV-22 Plugs--TS BPV--Street Unit Boost Tubes ( I know I know)
DDM 6K HID's--Eibach Pro Kit
MSpeed3013 is offline   Reply With Quote
 Old 10-12-2012, 01:28 PM   #53
smoogs12's Avatar
Posts: 7,731   (View Stats)
Groans: 423
light load fp (.3-.5 calc load) will fall somewhere between 1100-1300psi
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
 Old 11-19-2012, 12:11 PM   #54
ANITIX87's Avatar
Posts: 1,394   (View Stats)
ANITIX87 is the leader of the worldANITIX87 is the leader of the worldANITIX87 is the leader of the worldANITIX87 is the leader of the worldANITIX87 is the leader of the worldANITIX87 is the leader of the worldANITIX87 is the leader of the worldANITIX87 is the leader of the worldANITIX87 is the leader of the worldANITIX87 is the leader of the worldANITIX87 is the leader of the world
Groans: 93
Groaned at 27 Times in 16 Posts
Neutral  :  -1 score
Hey guys. I didn't know where else to post this, but it may be worthy of its own thread depending on how it develops @Raider; I'll leave it to your discretion where this use of bandwith should go).
My buddy has a 2012 VW GLI (completely stock), which uses the same HPFP internals as our AutoTech upgrade. Last month, his fuel pump went to complete shit, sending the car into limp mode and requiring a completely new HPFP. Apparently many GLI owners are seeing fuel pressure issues (even without mods), though his is the only outright failure he's heard of. Now, it was his first forced induction car, and his first stick-shift, so it's possible (likely, even) that he was loading the engine at low RPM and fucked something up. I'll get more details from him if you guys think this is worth keeping an eye on.
TL;DR - Buddy's GLI (same HPFP as our upgraded internals) had catastrophic fuel pump failure just 4 months into ownership (10K miles already).
TIS
TOTS
2012 Mazdaspeed3, CWP, Tech Package. COBB AccessPort V3, AUTOTECH HPFP Internals, JBR 3" Wide-path SRI+TIP, CP-E TMIC, UR 3" Test Pipe, CP-E Triton CBE, FORGE V2 BPV, DENSO ITV22 Plugs, JBR RMM 88a, JBR OCC, JBR RSB Kit, JBR Solid Shifter Bushings, CP-E Tow Plate, CorkSport ECU Relocation, TSW Nurburgring Bronze 18x7.5
alphasaur: "Fuck I just beat it to surprise tranny porn. Saw the dick right when I came fml"
ANITIX87 is offline   Reply With Quote
 Old 11-19-2012, 12:47 PM   #55
not sure how that is needed here. Just means they need to get MS3's, and we need to steal their fuel pumps and swap internals. Sounds like they need our entire pump use autotechs, and done.
 Old 11-24-2012, 08:38 AM   #56
qweedqwag's Avatar
Posts: 233   (View Stats)
qweedqwag is the leader of the worldqweedqwag is the leader of the worldqweedqwag is the leader of the worldqweedqwag is the leader of the worldqweedqwag is the leader of the worldqweedqwag is the leader of the worldqweedqwag is the leader of the worldqweedqwag is the leader of the worldqweedqwag is the leader of the worldqweedqwag is the leader of the worldqweedqwag is the leader of the world
Groaned at 22 Times in 10 Posts
So which one is the best to install, have seen alot of issues here with the Autotech...anyone.
qweedqwag is offline   Reply With Quote
 Old 11-24-2012, 08:57 AM   #57
jseams's Avatar
Posts: 1,414   (View Stats)
jseams is the leader of the worldjseams is the leader of the worldjseams is the leader of the worldjseams is the leader of the worldjseams is the leader of the worldjseams is the leader of the worldjseams is the leader of the worldjseams is the leader of the worldjseams is the leader of the worldjseams is the leader of the worldjseams is the leader of the world
Autotechs are just the most popular, so there are more posts about them... and the vast majority of posters that have issues with them (other than squeek squeek squeek, which can be fixed and has been attributed to pressure spikes/release on cold startups) had issues because they didn't install them correctly.
I honestly can't recall a thread where a set of properly installed AT's failed - and I know several people that have been running them for tens of thousands of miles with no issues.
If you are concerned with installation you can always order a CP-e pump, but all you are getting is a stock pump with upgraded internals, although they do have a lifetime warranty; I've heard that some folks have had issues taking advantage of it.
Anyhow, AT and CP-e seem the most common today.
CRMetallic 2019 Mercedes C43 AMG
SOLD MNBlue 2012 S4 Prestige... a few mods
SOLD IB 2015 3.8 Gencoupe Ultimate
BLOWED UP DIB 2014 Mustang 5.0... a few mods
SOLD - LS 2012 MS3
Cobb AP//SF//CAB
Autotech HPFP
Corksport TMIC//BPV//TIP//BTbs
JBR 88a RMM
Sure M3 TP
OBX CBE
Tanabe NF210's
ADVAN RG-D 18x8 +38
Freektuned 50/50 E85
jseams is offline   Reply With Quote
The Following User Says Thank You to jseams For This Useful Post:
Rainmens (11-24-2012)
 Old 11-24-2012, 07:44 PM   #58
MS6219's Avatar
Posts: 144   (View Stats)
MS6219 has a reputation beyond reputeMS6219 has a reputation beyond reputeMS6219 has a reputation beyond reputeMS6219 has a reputation beyond reputeMS6219 has a reputation beyond reputeMS6219 has a reputation beyond reputeMS6219 has a reputation beyond reputeMS6219 has a reputation beyond reputeMS6219 has a reputation beyond reputeMS6219 has a reputation beyond reputeMS6219 has a reputation beyond repute
Hey I just bought my Speed6 like 2 months ago and so far (that I know of) I have a F5 CAI, Cobb TIH, Cobb ap runing stage 1 with personal tune, Magnaflow CBE, ITV 22s, HKS SSQ rec, and I just got my downpipe. I don't know if I have HPFP internals or not. Using my AP my FP is staying between 1700 and 1800 at WOT. Does that sound normal or do you guys think I might have new internals? The temp where I'm at has been staying between 30* and 45* right now. I'm almost postive the previous owner had a downpipe because the turbo heat shield is gone so I'm aussuming I have internals. Thanks for any input.
06 MS6 GT W/NAVI Freektuned 411AWHP 397AWTQ W/3 gal E85, 93oct: 351AWHP 365AWTQ BNRs3, magnaflow CBE, eBay catless down pipe, CX-racing FMIC, Autotech internals, turbosmart dual port bpv, sure Full3 Aeros, grimmspeed 3 port EBC, ITV22, JBR EGR delete, JBR 80 TMM, JBR 80 PMM, SURE RMM, SURE Dreadnaught, CS short shift plate, 3 bar MAP w/PNP harness, block8head vent pod w/depot boost gauge, AP, ZZB...
06 MS6 GT W/NAVI CS stage II sri, JBR RMM, turbosmart dual port bpv, ultimate racing tp
MS6219 is offline   Reply With Quote
 Old 11-24-2012, 08:03 PM   #59
smoogs12's Avatar
Groans: 423
@MS6219; sounds like you might.
Though it would probably be best to take the pump appart and have a look just to be sure.
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
 Old 11-24-2012, 08:13 PM   #60
MS6219's Avatar
Ya I've looked at the bolts to see if maybe there was any wear on them or anything but they look untouched or at least for a good amount of time of coarse the car is 6 almost 7 years old. Ya I just thought that was a decent amount of mods plus I'm pushing 17.5 with no knock and FP staying high. Thanks for your input!
smoogs12; How do you like your hankook V12s? I had a set on my Si and Hated them. lol
Last edited by MS6219; 11-24-2012 at 08:13 PM. Reason: MSF Database - Automerged Doublepost
 Old 11-24-2012, 08:19 PM   #61
Rainmens's Avatar
Posts: 129   (View Stats)
Rainmens is the leader of the worldRainmens is the leader of the worldRainmens is the leader of the worldRainmens is the leader of the worldRainmens is the leader of the worldRainmens is the leader of the worldRainmens is the leader of the worldRainmens is the leader of the worldRainmens is the leader of the worldRainmens is the leader of the worldRainmens is the leader of the world
Those FP numbers aren't uncommon for stock internals, the only way to tell is to crack open the pump and take a look. Prior to installing the KMD's (do not purchase KMD btw) i was seeing 1700's.. the issue is there is really no warning signs of when (not if) they'll fail, they just do. And then well, zoom zoom.. you know the rest.
304whp/360tq Vdyno 1.01 CF
Cobb AP, Sure 3" Full3 Aeros Intake, Autotech Internals, M2 DP, 3" CP-E Single Exit (w/resonator), 3.25" ETS, PnP'ed IM w/VTCS removed, 1/16"Sure TIG spacer Synapse BPV, AWR 70 Duro RMM, JBR 70 Duro TMM, Denso 1-Step Colder Plugs, TWM Shifter Bushings, SM OCC, Custom Shift Knob, Custom Shifter Weight, SURE Shorcut, H&R Springs, Tenzo DC-6 Wheels
Rainmens is offline   Reply With Quote
 Old 11-24-2012, 08:22 PM   #62
smoogs12's Avatar
Groans: 423
As far as the bolts being untouched, it could be a cpe pump. They do a full replacement as apposed to an internals swap, so there shouldn't really be much wear on the bolts.
The v12s are alright. Better than my winter setup anyways (nankang as1). I plan on switching to nt05's or nt555r's this coming summer. But lets save any further talk on that for another thread.
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
 Old 11-24-2012, 08:30 PM   #63
MS6219's Avatar
Ya I guess I better just open it up and take a look at it to be safe. Thanks alot everyone. Deff not going with KMD's. I've read alot of issues with them. Deff gonna go with Autotechs if I don't have internals. Sorry for going a bit off topic with the tires. lol
The Following User Says Thank You to MS6219 For This Useful Post:
smoogs12 (11-24-2012)
 Old 11-25-2012, 08:07 AM   #64
qweedqwag's Avatar
Ya open it up, there also might be some donation money in there for the site hmmmmm?
Hook it up.
Mike
 Old 12-12-2012, 11:09 AM   #65
loganshaun's Avatar
Posts: 3   (View Stats)
loganshaun is an unknown quantity at this point
Default HPFP Internals
I've noticed most people have gone with the autotech internals and seem to be happy with them. has anyone done the KMD Tuning - 2.0T FSI High Pressure Fuel Pump Kit? It has free shipping and cost a little less at 330. I'm ready to buy internals today just want to make sure I get the best ones for my money. So does anyone run any internals that are not autotech?
loganshaun is offline   Reply With Quote
 Old 12-12-2012, 11:11 AM   #66
DamagedGoods's Avatar
Posts: 304   (View Stats)
Search and you shall receive all your answers
Tappin
 Old 12-27-2012, 10:59 AM   #67
Dizzy Turbo's Avatar
Posts: 2,173   (View Stats)
Do you guys know how much the internals rotate in the pump during operation?
 Old 12-27-2012, 12:47 PM   #68
doubleflusher's Avatar
Posts: 20,650   (View Stats)
Groans: 1,443
No
Beanfab / Tuned by Nishan
 Old 01-26-2013, 08:13 PM   #69
jlobato's Avatar
Posts: 0   (View Stats)
jlobato is on a distinguished road
Smile
Hello, Mazdapeeps!!
jlobato is offline   Reply With Quote
The Following User Says NO Thank You to jlobato For This Un-useful Post:
sidekick (02-11-2013)
 Old 01-26-2013, 08:19 PM   #70
Javier, you should not waste your first post like this. Make a new thread.
 Old 01-29-2013, 09:23 PM   #71
BoostedWagon's Avatar
Posts: 5   (View Stats)
BoostedWagon will become famous soon enoughBoostedWagon will become famous soon enough
My MS3 knowledge is shit, but if the HFFP goes out, wouldn't the car enter limp mode, prior to "engine going boom"? I know on my current car when my HFFP connection came loose, boost was unobtainable and anything past 3K was not happening either. Just curious if the MS3 does the same.
BoostedWagon is offline   Reply With Quote
 Old 01-29-2013, 09:57 PM   #72
Elvisrosales88's Avatar
Posts: 113   (View Stats)
Elvisrosales88 is the leader of the worldElvisrosales88 is the leader of the worldElvisrosales88 is the leader of the worldElvisrosales88 is the leader of the worldElvisrosales88 is the leader of the worldElvisrosales88 is the leader of the worldElvisrosales88 is the leader of the worldElvisrosales88 is the leader of the worldElvisrosales88 is the leader of the worldElvisrosales88 is the leader of the worldElvisrosales88 is the leader of the world
Groaned at 9 Times in 2 Posts
Neutral  :  -1 score
My GTI used to do this. I don't think this at does
Cobb AP+ Stratified OTS--JBR Powerpath Stage III intake-- Turbosmart BPV--AutoTech Fuel Pump Internals--CPE TMIC-- OBX test pipe+ UR catback--ITV-22 plugs-- H&R springs--CPE RMM- JBR PMM and TMM--
Elvisrosales88 is offline   Reply With Quote
 Old 01-30-2013, 03:09 AM   #73
You think that if it did, we would post this?
Dizzy Turbo (01-30-2013), Mooseknuckler (07-31-2015)
 Old 01-30-2013, 06:36 AM   #74
POWERED BY POLSKA
themytb's Avatar
Groans: 38
This isn't about absolute failure of the hpfp, but pump output being under desired pressure.
25%E85FREEKPERMED
 Old 01-30-2013, 06:42 AM   #75
Which causes people to blow up, I would consider that a total failure
Edit: read fail. I thought your post was that kid replying to raider. Whoops haha
 Old 02-11-2013, 01:19 PM   #76
Menace1's Avatar
Posts: 946   (View Stats)
Menace1 is the leader of the worldMenace1 is the leader of the worldMenace1 is the leader of the worldMenace1 is the leader of the worldMenace1 is the leader of the worldMenace1 is the leader of the worldMenace1 is the leader of the worldMenace1 is the leader of the worldMenace1 is the leader of the worldMenace1 is the leader of the worldMenace1 is the leader of the world
Groaned at 40 Times in 21 Posts
New questions. What is the difference in cpe's hpfp spring compared to stock besides number of coils as plainly seen. Stock having seven and cpe running a 6 coil spring. first is stock second is cpe. And if they are different is there a benefit or not? And where to buy? Cuz cpe wont sell you a replacement spring. @Raider; I couldn't find anything on this topic. @www.cp-e.com;
2012 MS3 / Cobb AP/ JBR / STRATIFIED Stage 1 Tuned / Stock K04 / CPE HPFP / Maisonvi Heavy Shift Knob / JBR Powerpath Intake / JBR TIP / JBR BT / JBR BVH / JBR 88D RMM /
FOR NOW...
Menace1 is offline   Reply With Quote
 Old 02-11-2013, 01:37 PM   #77
sidekick's Avatar
Posts: 3,093   (View Stats)
I'd assume it is a stiffer spring and/or a different material, but honestly, there is no way of knowing why they changed the spring without talking to them or APR. We can sit here and guess all day long.
@www.cp-e.com;
 Old 02-11-2013, 01:43 PM   #78
Menace1's Avatar
@www.cp-e.com;
This is true. but I wasn't sure if it was covered already and didn't want to start a new thread. I fixed the cpe mention.
FOR NOW...
The Following User Says Thank You to Menace1 For This Useful Post:
 Old 02-11-2013, 02:02 PM   #79
Menace1's Avatar
So I did some more research through apr and found it to be a high modulus spring. if cpe can expand on the benefits of this for our cars compared to the stock spring it would be very beneficial.
FOR NOW...
 Old 02-12-2013, 08:22 AM   #80
Doesn't the stock spring work fine? Not bashing, but why upgrade a working part, maybe I'm missing something.
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f303/official-hpfp-camshaft-driven-fuel-pump-fuel-105248/
Hopefully Boomba releases this aux fuel option soon - Page 3 This thread Refback 11-06-2015 06:37 AM
Visconti Tuning EcuTek Flash for Juke ! This thread Refback 09-05-2015 11:00 AM
Got some new car parts for my 2007 Speed 3! Cobb Accessport V3 and a Corksport Test Pipe : mazda This thread Refback 11-10-2014 08:14 PM
Convert any HDMI video input to ATSC tunable 8VSB outputs This thread Refback 04-29-2014 12:25 AM
http://aksprojekt.pl This thread Refback 04-22-2014 06:41 PM
HPFP is needed with just bolt ons - Page 4 This thread Refback 03-04-2014 10:02 PM
Ok a dangerous question ... Gulp - Page 4 This thread Refback 02-05-2014 03:19 PM
hoffa_dies comments on Talk me in or out of this 2009 MazdaSpeed 3 This thread Refback 01-13-2014 07:41 PM
What is going on! This thread Refback 10-31-2013 03:07 PM
Fuel system idea - Page 3 This thread Refback 10-31-2013 12:26 PM
HFPF internals This thread Refback 03-13-2013 02:21 AM
Grosse question sur la HPFP - Mazda 3 Quebec This thread Refback 03-06-2013 02:35 PM
Visconti Tuning EcuTek Flash for Juke ! - Page 14 This thread Refback 06-21-2012 02:12 PM
Visconti Tuning EcuTek Flash for Juke ! - Page 13 This thread Pingback 06-21-2012 08:25 AM
Page generated in 0.58949 seconds with 47 queries
