 Old 02-02-2012, 08:22 PM   #1
Must Have Teh 10's!
superskaterxes's Avatar
Posts: 10,442   (View Stats)
Default OFFICIAL MS6/3 deatschwerks DW65C Install HOW-TO
so presumably im the first member to actually install this thing and do a write-up so i just wanted to make sure everyone was aware of a few things that were different from the POS install instructions.
i diddent take any picts because i did this alone and my hands were covered in gas the whole time. it took me about 25 mins but it was the 3rd time i have taken the ITFP out of this car. dustin will add picts later of the install but heres a quick rundown + notes
this is for the MS6 ONLY:
-jack up back of car high as fuck. i backed it up on ramps then lifted the wheels another 6 inches off the ramps using a single jack under the diff.
-loosen all 4 tank straps till the bolt is about 1" unthreaded. this will allow access for the SST inside the car.
-take off bottom of back seat.
-remove 3 screws from fuel pump cover on the drivers side
-unplug the fuel connection (almost identical to the yellow one when doing a CDFP)
-unplug the electrical connector
-use the SST with either 2 or 3 of the legs attached to unscrew the ring around the basket. its tight as fuck the first time you do it. make sure you pry back the 2 clips on either side. dont worry if you break them they are useless anyway.
-pull off ring and lift basket and wait for fuel to leak out.
-pull basket out farther and remove the line coming from the passenger side bucket (same connector as on top)
-slowly pull out the basket as not to bend the float for the level.
-un clip the float from the side and leave it elsewhere
-push the top of the bucket down and you will see a spring around one of the metal supports
-take the c-clip off the bottom of this and it will allow you to pull the top of the bucket off
-un-do the 2 electrical connectors from the lid of the bucket
-you will see 3 clips around the edges of the bucket holding the center cartridge in
-un-do these and pull the center section out.
-turn it over and you will see the filter which is clipped on in 5 places.
-slowly work all these clips off starting with the 2 on the pressure regulator
-once this is off pull the pump out
-reverse steps to put it all back.
IMPORTANT NOTES!!!
-when you take out the stock pump the outlet will have a white plastic sleeve on it.
-transfer this to the new pump
-reuse the stock O-ring (which may have stayed inside the cartridge)
DO NOT USE THE 2 SUPPLIED O-RINGS FROM THE DW KIT!!!!
-the lube they provide is also unnecessary. everything is covered in gas and plenty slippery.
the directions say to stack the 2 supplied o-rings onto the outlet but this prevents the pump from going all the way back into the sleeve. the rings are also a smaller OD then the stock ring and they dont provide a nice tight seal like the stock one does (you can feel it when you push the pump back in the sleeve.
First K04 in the 12's
First MS6 in the 11's
Certified RichTune E-Tuner
The Following 20 Users Say Thank You to superskaterxes For This Useful Post:
06Speed6 (02-04-2012), Alpha (02-08-2012), BigjohnB20 (02-03-2012), Ckmazdaspeed3 (03-17-2013), Dahouse702 (02-07-2012), Docnox (02-16-2012), doubleflusher (02-08-2012), GLORIFIEDBOZO (02-07-2012), Grab21 (04-07-2012), i8urgti (02-08-2012), JacksonMS30 (02-07-2012), jman46 (02-02-2012), jmhinkle (02-08-2012), jracer (02-02-2012), mason (02-05-2012), qtrmile beast (02-02-2012), rfinkle2 (02-08-2012), Scribbles (02-02-2012), TWOptSL0W (02-07-2012), Ziggo (02-02-2012)
 Old 02-02-2012, 08:33 PM   #2
jracer's Avatar
Posts: 1,706   (View Stats)
Groans: 89
So you don't have to drop the fuel tank ? If not why did you jack it up ?
H&R springs/H&R 15mm spacers
MAP catless testpipe
MAP UICP
Grimmspeed 3 port
Cosworth filter
SSP relay kit
TWM Desert Eagle shift knob
AEM wideband gauge
Prosport boost gauge
EvoX piller pod
30%Tint
Slowpoke Tuned 339hp/336tq
**** SOLD *****
2006 speed6
The Following 2 Users Say Thank You to jracer For This Useful Post:
rfinkle2 (02-08-2012), superskaterxes (02-02-2012)
 Old 02-02-2012, 08:37 PM   #3
Must Have Teh 10's!
fml editing a step i forgot haha
 Old 02-07-2012, 03:14 AM   #4
hnda etr's Avatar
Posts: 4,173   (View Stats)
Groans: 90
Did you notice any difference with the new pump? I'm wondering what the benefits would be.. I haven't heard of anyone's itfp crapping out...
Sent from my iPhone using lame ass Tapatalk
 Old 02-07-2012, 07:09 AM   #5
Must Have Teh 10's!
if your not doing any sort of aux injection, then you dont need this upgrade.
hnda etr (02-08-2012)
 Old 02-08-2012, 12:08 AM   #6
hnda etr's Avatar
Groans: 90
do you mean like adding ports to the IM and then plugging in additional injectors run by their own fueling computer?
yeah, i'm not doing that lol... in for pics of yours though!
 Old 02-08-2012, 11:23 AM   #7
Alpha's Avatar
Posts: 3,711   (View Stats)
I wouldn't say that... More stable/reliable FP is always nice to have. Cheap insurance IMHO, also gives you room to grow in the future.
I'm definitely doing this as soon as my car comes back.
 Old 02-07-2012, 07:08 AM   #8
GLORIFIEDBOZO's Avatar
Posts: 1,928   (View Stats)
GLORIFIEDBOZO is the leader of the worldGLORIFIEDBOZO is the leader of the worldGLORIFIEDBOZO is the leader of the worldGLORIFIEDBOZO is the leader of the worldGLORIFIEDBOZO is the leader of the worldGLORIFIEDBOZO is the leader of the worldGLORIFIEDBOZO is the leader of the worldGLORIFIEDBOZO is the leader of the worldGLORIFIEDBOZO is the leader of the worldGLORIFIEDBOZO is the leader of the worldGLORIFIEDBOZO is the leader of the world
Doing this soon, thanks man.
"Intelligence isn't the ability to store information, but to find it" - Albert Einstein
"When I read about the evils of drinking, I quit reading" - Henry Youngman
GLORIFIEDBOZO is offline   Reply With Quote
 Old 02-08-2012, 02:21 AM   #9
i8urgti's Avatar
Posts: 1,660   (View Stats)
i8urgti is the leader of the worldi8urgti is the leader of the worldi8urgti is the leader of the worldi8urgti is the leader of the worldi8urgti is the leader of the worldi8urgti is the leader of the worldi8urgti is the leader of the worldi8urgti is the leader of the worldi8urgti is the leader of the worldi8urgti is the leader of the worldi8urgti is the leader of the world
Groans: 267
There is also the possibility of running an additional pre throttle body injector. It's currently being tested
2006 LPM MS6 GT (totaled)
0-60 mph : 4.2 second (as per DH)
12.83 @ ???MPH 1.67 60ft
2002 Miata Se (convertible whore)
i8urgti is offline   Reply With Quote
The Following User Says Thank You to i8urgti For This Useful Post:
 Old 02-08-2012, 10:26 AM   #10
Tripple OG
NJSPEED3's Avatar
Posts: 5,703   (View Stats)
Groans: 113
pics or it didnt happen.
 Old 02-08-2012, 10:37 AM   #11
doubleflusher's Avatar
Posts: 20,650   (View Stats)
Groans: 1,443
Pics?
Beanfab / Tuned by Nishan
 Old 02-10-2012, 02:35 PM   #12
SPEED6 KILLAH's Avatar
Posts: 1,176   (View Stats)
Pics
SPEED6 KILLAH is offline   Reply With Quote
 Old 02-16-2012, 06:16 AM   #13
Must Have Teh 10's!
picts here
HMMMMM What Do We Have Here!?!?!
Docnox (02-16-2012)
 Old 03-01-2012, 10:37 AM   #14
DeatschWerks's Avatar
Posts: 5   (View Stats)
DeatschWerks has a brilliant futureDeatschWerks has a brilliant futureDeatschWerks has a brilliant futureDeatschWerks has a brilliant futureDeatschWerks has a brilliant futureDeatschWerks has a brilliant futureDeatschWerks has a brilliant futureDeatschWerks has a brilliant futureDeatschWerks has a brilliant futureDeatschWerks has a brilliant futureDeatschWerks has a brilliant future
Would you (or anyone else) by change have a measurement of the OE o-ring/seal?
Might be able to find a better match than what is supplied in the kits currently being used.
-Chris
Chris @ DeatschWerks
DeatschWerks is offline   Reply With Quote
 Old 03-02-2012, 06:12 PM   #15
Must Have Teh 10's!
-Chris
i dont have a measurement of the stock size. it was a pube hair bigger but it just felt like a much more solid fit. hopefully you guys can revise this to make it a perfect fit!!!
EDIT: they both had the same ID AFAIK, it was just the OD of the stock one that was a lil bigger
wolly6973 (03-02-2012)
 Old 05-13-2012, 11:58 AM   #16
Grab21's Avatar
Posts: 58   (View Stats)
Grab21 has much to be proud ofGrab21 has much to be proud ofGrab21 has much to be proud ofGrab21 has much to be proud ofGrab21 has much to be proud ofGrab21 has much to be proud ofGrab21 has much to be proud ofGrab21 has much to be proud of
Anyone know where to get the tool for the removal of the lid assembly... ? Brute strength is slowly destroying my lid :-(
2006 speed6 ... bnr s4 soon- on order... when danger to manifold explodes... 8 port
335i day driver
LSA supercharged Caddy CTS-V stealth gray-sold
Porsche Panamera turbo- sold
Bmw m3-sold
Z4m- sold
Grab21 is offline   Reply With Quote
 Old 05-18-2012, 07:54 PM   #17
Must Have Teh 10's!
the dealer
 Old 05-25-2012, 09:25 PM   #18
Steve@VersaTune's Avatar
Posts: 432   (View Stats)
Autozone has a loaner tool that works well. I just used it to install a DW pump.
Steve
Lead Tuner
The Following User Says Thank You to Steve@VersaTune For This Useful Post:
superskaterxes (05-28-2012)
 Old 02-10-2015, 08:34 AM   #19
MS6_life's Avatar
Posts: 6   (View Stats)
MS6_life is an unknown quantity at this point
Default DP
Is this a necessary upgrade if I plan on upgrading my downpipe?
Thanks.
MS6_life is offline   Reply With Quote
 Old 02-10-2015, 08:49 AM   #20
razerer's Avatar
Posts: 168   (View Stats)
razerer has a reputation beyond reputerazerer has a reputation beyond reputerazerer has a reputation beyond reputerazerer has a reputation beyond reputerazerer has a reputation beyond reputerazerer has a reputation beyond reputerazerer has a reputation beyond reputerazerer has a reputation beyond reputerazerer has a reputation beyond reputerazerer has a reputation beyond reputerazerer has a reputation beyond repute
Groaned at 8 Times in 4 Posts
Thanks.
No.. You just need to upgrade your hpfp
Cobb AP V3 // Cp-e HPFP // Cobb SRI TIP // Cobb DP // Cobb FMIC // Denso ITV22 // Cp-e Triton Cat-Back // Forge V2 BPV // JBR 88 Duro RMM
Cobb SoCal tuned
razerer is offline   Reply With Quote
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f303/official-mazdaspeed-6-3-deatschwerks-dw65c-install-104068/
????????!!!!!!! This thread Refback 03-28-2012 06:24 AM
MS3 Deatschwerks DW65C Fuel Pump Caldwell MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 21 01-25-2012 03:32 AM
PRI and DeatschWerks Chimmike MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 18 12-29-2011 12:19 AM
New ITFP solution 100% Drop in from DeatschWerks Calvin@COBB MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 43 11-05-2011 09:48 AM
DeatschWerks HPFP 327whp 2010 MS3 - Fuel, Nitrous & Water Injection 15 05-17-2011 05:57 PM
Page generated in 0.40042 seconds with 33 queries
