  • 1 Post By ms_3
 Old 10-13-2016, 06:21 PM   #1
ms_3's Avatar
Posts: 374   (View Stats)
ms_3 is the leader of the worldms_3 is the leader of the worldms_3 is the leader of the worldms_3 is the leader of the worldms_3 is the leader of the worldms_3 is the leader of the worldms_3 is the leader of the worldms_3 is the leader of the worldms_3 is the leader of the worldms_3 is the leader of the worldms_3 is the leader of the world
Default Potential fuel pressure relief valve failure
Hey fellas I've got an 07 ms3 and it's been down for the better part of a month now. After hitting a small pot hole my check engine light came on for a misfire in cylinder 3 and my fuel pressure dropped to dangerously low levels, between 200-300 while putting around and 50-80 at idle. I babied the car for the next mile until i could beach it and do a bit of diagnosing. I took off the hpfp and inspected the internals. Everything seemed to be in pristine condition. Since i really dont have time to work on the car that was pretty much the extent of the diagnosing that I performed. I then had the car towed to the mazda dealership where they diagnosed the issue to be a bad injector in cylinder 3. I found this to be strange as i had just replaced the injectors in april with new CS seals. After getting in touch with the folks at CS I had a replacement seal overnighted to the dealership and they replaced the injector with a new seal. Upon completing the injector install the car is still experiencing the same issue. 50-80 psi at idle and never builds up higher than 300psi if the throttle is blipped. After starting the car, turning it off, then powering on without cranking, there is no climb in pressure. While the car is running i also hear a whining/more pronounced clicking sound. I havent been in the car since prior to it getting towed to the dealer but im being told it still has a misfire in cylinder 3 as well.. If i had the car i could throw up a log but unfortunately im not able to do that at the moment.
Any help or input would be greatly appreciated
2007 True Red Mazdaspeed 3 GT
Power - Cobb AP v3, AT HPFP internals, Ultimate racing DP, Borla CBE, Forge v2 bpv, CP-E TIP, Mazdaspeed OEM CAI
Handling - CS Genwin Steering wheel, Maisonvi custom shift knob, Koni FSD shocks, Hotchkis f+r sway bars, Damond RMM,
EBC USR rotors + Yellowstuff pads, JBR SSP + weight + bushings
Soon - FMIC
Followed by a protune
2008.5 CWP Mazdaspeed 3 SOLD
ms_3 is offline   Reply With Quote
 Old 10-13-2016, 06:57 PM   #2
monkey.bones.007's Avatar
Posts: 3,853   (View Stats)
Pressure relief valve? That's my guess.
 Old 10-13-2016, 08:19 PM   #3
ms_3's Avatar
My thoughts as well but I haven't heard of anyone having a misfire when the prv failed. I guess its not too big of an investment to replace it and go from there.
monkey.bones.007 likes this.
Soon - FMIC
 Old 10-13-2016, 09:23 PM   #4
doctavus's Avatar
Posts: 1,728   (View Stats)
That's the same symptoms I was having when my relief valve failed. However, I did not have any CEL's and I drove that way for about a week or two, drove fine, just didn't boost.
This was when I had the CS Turbo on too.
 Old 05-13-2017, 11:34 AM   #5
michaelhanson96's Avatar
Posts: 15   (View Stats)
michaelhanson96 will become famous soon enoughmichaelhanson96 will become famous soon enough
Groaned at 9 Times in 3 Posts
So my speed is clunking from my hpfp and it is shutting off while driving sometimes after I rev not all the time but it happened twice, its running like shit, I'm thinking it's the to but I'm not sure .
michaelhanson96 is offline   Reply With Quote
 Old 07-18-2017, 12:36 PM   #6
loak1er's Avatar
Posts: 28   (View Stats)
loak1er is a splendid one to beholdloak1er is a splendid one to beholdloak1er is a splendid one to beholdloak1er is a splendid one to beholdloak1er is a splendid one to beholdloak1er is a splendid one to behold
I am having the exact same issue with my car, 100% same symptoms. I have pulled my hpfp and inspected, I purchased a new prv, I just have to install it. My car was throwing cyl 3 misfire code, rich at idle previous to failure, shitty fuel pressure. I will post update when I install prv.
loak1er is offline   Reply With Quote
 Old 07-19-2017, 06:29 AM   #7
GroceryGtr's Avatar
Posts: 472   (View Stats)
I may have a used good one in my parts pile if you want to save some change. those things aren't exactly cheap for "guess diagnosing".
I would be ok with saying its the prv, except those things dont just fail because of a hard bump. You sure the hpfp was fine? Did you check the spill vavle as well? I'd also check inj. 3 to see if its hung open. That would explain the misfire and the drop in fuel pressure. I could certainly see a piece of something breaking loose in the fuel system over a hard bump and getting hung up in the injector.
 Old 10-20-2017, 05:43 PM   #8
Bramma's Avatar
Posts: 56   (View Stats)
Bramma is a glorious beacon of lightBramma is a glorious beacon of lightBramma is a glorious beacon of lightBramma is a glorious beacon of lightBramma is a glorious beacon of lightBramma is a glorious beacon of light
Any luck with replacing the prv? Experiencing the same issue.
2006 Titanium Gray MS6
__________________________________________________ ___
Mods:
CS Stage II SRI, CS RMM, Cobb AP V3, Sure Diff Mounts(both),
CS HPFP, CS TMIC, CS DP, CS RP, CS Dual VTA BPV, CS Lowering Springs
Quietly reading and learning...
Bramma is offline   Reply With Quote
 Old 10-20-2017, 05:52 PM   #9
loak1er's Avatar
Yes it worked. But i had shit fuel pressure thats why I replaced it.
 Old 10-20-2017, 06:41 PM   #10
Bramma's Avatar
Gotcha! My fuel pressure is between 50-120 at idle which has me terrified. Hoping that will fix the issue. How much did you pay for the relief valve? Were you getting bad gas mileage prior to the prv fail?
Mods:
 Old 10-20-2017, 06:49 PM   #11
loak1er's Avatar
125 I believe
Fuel Pressure Relief Valve Question twintzs MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 40 11-25-2018 09:51 AM
Potential Relief Valve Failure Polish_Eagle 2010 MS3 - Troubleshoot/Diagnostics 48 04-07-2014 06:52 AM
Page generated in 0.32566 seconds with 26 queries
