MAZDASPEED Protegé
> MSP - Turbo Induction
 Old 08-25-2011, 10:31 AM   #1
popester112's Avatar
Posts: 4   (View Stats)
popester112 will become famous soon enough
Default Any type of help appreciated.
I've got a 2003 Mazdaspeed protege. it is turbo and everything is mainly stock. looks like a stock turbo and it has front mount, bov, boost gauge. Problem is.. at high boost which is 15psi, (i think is too much) it starts cutting out, stalling, bucking. etc possibly fuel cut. and to this day i still have not heard the wastegate open. Im not even sure if these cars have to have a tune . Idk if they come stock turbo. anyways, how do i fix?
popester112 is offline   Reply With Quote
The Following User Says Thank You to popester112 For This Useful Post:
sellers (08-25-2011)
 Old 08-25-2011, 11:01 AM   #2
m4tic's Avatar
Posts: 4,928   (View Stats)
dont those cars run only 6~7psi .... but 15psi!!! sounds like you've already damaged the engine
2017 Daytona 392
STOLEN//2015 BMW S1000R
2007 MS6 w/ Cheez
 Old 08-25-2011, 11:50 AM   #3
03 Mazdaspeed protege - YouTube heres vid, and engine runs fine and does smoke rattle or anything. i would like it to run around 6 to 10 psi.
*doesnt
Last edited by popester112; 08-25-2011 at 11:50 AM. Reason: MSF Database - Automerged Doublepost
 Old 08-25-2011, 12:07 PM   #4
m4tic's Avatar
if you are running that much boost, it probably is boost/fuel cut. how are you controlling boost. if MBC you need to open/loosen it a bit.
id still do a compression test
2017 Daytona 392
2007 MS6 w/ Cheez
 Old 08-25-2011, 12:14 PM   #5
well i know it doesnt have a manual or electronic boost controller and if theres another way to turn it down let me know .. because that would get rid of my fuel cut and my whole problem.
 Old 08-25-2011, 12:17 PM   #6
m4tic's Avatar
too much preload on the wastegate? can you shorten the arm on the actuator?
2017 Daytona 392
2007 MS6 w/ Cheez
Black Metal (08-25-2011)
 Old 08-25-2011, 12:22 PM   #7
I have no idea.. Im pretty much lost on this one.. i just dont get why its boosting 15psi and everything is pretty much stock that i know of..
 Old 08-28-2011, 05:58 AM   #8
StealthWyvern's Avatar
Posts: 76   (View Stats)
StealthWyvern has much to be proud ofStealthWyvern has much to be proud ofStealthWyvern has much to be proud ofStealthWyvern has much to be proud ofStealthWyvern has much to be proud ofStealthWyvern has much to be proud ofStealthWyvern has much to be proud ofStealthWyvern has much to be proud of
You are hitting boost cut and ingore morris as he doesn't know what he is talking bout or just a little mixed up.
Your WGA should be adjust able. What you will need to do is lengthen the rod and release tension or preload off the internal wastegate. Also check your vac line on yoru WGA. You should have a line that goes from the WGA to the intake manifold. If you have anything between the line and where ever it connects to depending on how your car is setup remove it and run just a straight vac line to the wga. Post of pics of your setup.
Edit: I'm not normally on this forum so fire me a pm and ill get back with you asap.
StealthWyvern is offline   Reply With Quote
 Old 08-28-2011, 06:22 AM   #9
Holy shit, 15 lbs on a stock MSP is about 9 too much. So what Stealth said. I think a ton of engine bay pics of all that is set up is key. Do you know if you have an 03 or 03.5, and the production #?
Try Googling your VIN. It will have the Mazda list of MSP production #'s. Then go onto mazdas247.com and see if the previous owner had posted. That is my advice, as you will pot a piston through the block at that level of boost.
 Old 08-28-2011, 06:29 AM   #10
Good point raider! Yes OP look up your production # and try to find the previous owner and it should give more insight to whats going on with your car and history of it. Also raider knows how to get hold of me if needed.
 Old 08-30-2011, 01:53 PM   #11
Brian MP5T's Avatar
Posts: 1,101   (View Stats)
Subs for Boom
 Old 08-30-2011, 02:46 PM   #12
m4tic's Avatar
my bad lengthen it... but isnt the rest wtf i said... but you are right i have no idea about the workings of a MSP
2017 Daytona 392
2007 MS6 w/ Cheez
 Old 08-30-2011, 10:45 PM   #13
Brian MP5T's Avatar
You can tell the 03 and 03.5 by the cup holder if I am not mistaken..
Flap Door or Open...
 Old 08-31-2011, 03:41 AM   #14
Easiest way is just by the lip spoilers and the rear spoiler.
Input appreciated Nliiitend1 MazdaSpeed 3/6 - Suspension & Brakes 6 08-04-2011 11:59 AM
Much Appreciated Airman3454 Gen2 MS3 General Discussion 23 06-10-2011 03:14 PM
Your best guesses appreciated pkrobot Mazdaspeed3/6 General Discussion 7 06-06-2011 02:39 PM
assistance appreciated Chriscote MazdaSpeed 6 - Engine, Transmission & Driveline 19 07-21-2010 12:47 PM
Any help would be appreciated...UR TP miztigerszou52 2010 MS3 - Engine, Transmission & Driveline 4 05-18-2010 08:25 PM
Page generated in 0.31851 seconds with 24 queries
