MAZDASPEED Protegé
> MSP - Turbo Induction
 Old 09-09-2011, 06:26 PM   #1
StealthWyvern's Avatar
Posts: 76   (View Stats)
StealthWyvern has much to be proud ofStealthWyvern has much to be proud ofStealthWyvern has much to be proud ofStealthWyvern has much to be proud ofStealthWyvern has much to be proud ofStealthWyvern has much to be proud ofStealthWyvern has much to be proud ofStealthWyvern has much to be proud of
Default massive boost creep after 3" dp install on my msp
Anyone else have this problem?
3" dp + 3" midpipe = to much flow.. = boost creep = zoom zoom boom
I was spiking around 7/8psit and settling around 5/6psi before the 3" dp and well now if I keep on it i can hit 11psi and then some if i let it... but on low rpms it stays at 7/8 psi untell i really dog it and it climbs freakign quick!!!
I guess its time for a new exhaust mani and external wastegate.
StealthWyvern is offline   Reply With Quote
 Old 09-10-2011, 12:19 PM   #2
New mani, or uninstall dp....
 Old 09-10-2011, 05:40 PM   #3
Cant uninstall the dp as i no longer have the factory midpipe... so I guess ill have to go with a EWG setup.
 Old 09-10-2011, 05:57 PM   #4
aguilabrian's Avatar
Posts: 24   (View Stats)
aguilabrian has a spectacular aura aboutaguilabrian has a spectacular aura aboutaguilabrian has a spectacular aura about
I had the same problem I installed a manual boost controller and problems went away no creep or boost spike. Or tune with ap.
THE BEAST
aguilabrian is offline   Reply With Quote
 Old 09-10-2011, 06:29 PM   #5
No ap for mazdaspeed protege.
 Old 09-12-2011, 12:46 PM   #6
tommybdragon's Avatar
Posts: 4   (View Stats)
tommybdragon will become famous soon enough
You can go with a SSAFC for tuning. There are a number of maps out there on other forums and I know they come pre-loaded with a 7psi map for the MSP. I would think about doing that and getting a manual boost controller as well just as a safety measure.
tommybdragon is offline   Reply With Quote
 Old 09-12-2011, 03:26 PM   #7
If I'm having boost creep issues why would I want a MBC? I don't wait to raise boost but lower it... I've tought about the SSAFC but I kinda like it running pig rich because its less likely to knock like that and I don't have to worry about cats currently! My current issue with the stock tune isnt so much the fuel trims but more or less the trigger that goes into open loop.
I've at the point where I'm pretty much forced to go standalone( more of less dont care to go piggy back) and forged or so I feel.
 Old 09-18-2011, 06:41 AM   #8
well looking at my old turbo and old wga I think my issue is the fact that the wga can only open the internal wastegate so far before the wga rod hits the internal wasteage rod preventing it from opening further.
 Old 09-18-2011, 06:43 AM   #9
Hm. Ms3 mod?
 Old 09-18-2011, 06:49 AM   #10
Hm. Ms3 mod?
Sure you going to foot the bill? it would be dramticly cheaper for em to go EWG and i can get a steedspeed with EWG for the stocker via special order... pretty damn penny but still cheaper then teh ms3 mod.. grant it slow then the ms3 mod. lol
Edit: I think I found someone who can weld cast as well here local to me. Just have to sve up for everything to go ewg.
 Old 09-18-2011, 06:58 AM   #11
That cast mount will crack. Not if, when it will crack is the worry.
Save for steedspeed. Or find a MAM...
 Old 09-18-2011, 07:32 AM   #12
yeah, I plan on going steedspeed with ewg mounted onto the stock replacement manifold from steedspeed beings that a MAM is extremely rare.
Boost Creep? Silver Ecstasy MazdaSpeed 3 - Engine, Transmission & Driveline 17 02-14-2012 04:28 PM
Boost creep? psmith22 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 8 07-24-2011 11:47 PM
Boost creep? DubVms3 MazdaSpeed 3/6 - Turbo Induction 4 03-11-2011 04:12 AM
Boost Creep RocketScientist MazdaSpeed 3/6 - Turbo Induction 3 08-02-2010 11:13 AM
Boost creep with ATP turbos dadasracecar MazdaSpeed 3/6 - Turbo Induction 34 08-08-2008 04:19 PM
Page generated in 0.31402 seconds with 23 queries
