MAZDASPEED Protegé
> MSP - Turbo Induction
 Old 09-18-2013, 09:57 PM   #1
1superhunter's Avatar
Posts: 1   (View Stats)
1superhunter is an unknown quantity at this point
Default MSP turbo HELP!!!
Hello all,I'm new here and need HELP Please..I have 2003 MSP,I'm getting a major bucking/lurching when under turbo boost..I've changed the Vac line from the WGA cause that was rotten out..New plugs and wires,and did Both coil packs today..I'm new to the turbo and don't know much about them,but I'm very machincaly inclined..please any ideas on what else I can do..I also read that maybe I need to go to mazda and have them re map my fuel/air ratio..any help would be most appreciated..
1superhunter is offline   Reply With Quote
 Old 09-18-2013, 10:05 PM   #2
TheRoyceWay's Avatar
Posts: 224   (View Stats)
TheRoyceWay is the leader of the worldTheRoyceWay is the leader of the worldTheRoyceWay is the leader of the worldTheRoyceWay is the leader of the worldTheRoyceWay is the leader of the worldTheRoyceWay is the leader of the worldTheRoyceWay is the leader of the worldTheRoyceWay is the leader of the worldTheRoyceWay is the leader of the worldTheRoyceWay is the leader of the worldTheRoyceWay is the leader of the world
I havn't perused the MSP section at all, but I'm guessing you havn't either. I see a common thread here...
Any type of help appreciated
2003 mazdaspeed i need help!!!
TheRoyceWay is offline   Reply With Quote
 Old 09-21-2013, 04:55 AM   #3
StealthWyvern's Avatar
Posts: 76   (View Stats)
StealthWyvern has much to be proud ofStealthWyvern has much to be proud ofStealthWyvern has much to be proud ofStealthWyvern has much to be proud ofStealthWyvern has much to be proud ofStealthWyvern has much to be proud ofStealthWyvern has much to be proud ofStealthWyvern has much to be proud of
You're more then likely running to much boost and hitting boost/fuel cut. having Mazda reflash the ECU will not fix your issue. You have other issues going on other then AFR.
StealthWyvern is offline   Reply With Quote
The Following User Says Thank You to StealthWyvern For This Useful Post:
Raider (09-24-2013)
Official: 2014 Porsche 911 Turbo and Turbo S debut [w/video] Haltech Automotive News 0 05-03-2013 07:50 AM
First Drive: 2008 Ford Falcon G6E Turbo and XR6 Turbo Haltech Automotive News 2 05-04-2009 06:48 PM
Page generated in 0.24146 seconds with 22 queries
