MAZDASPEED Protegé
> MSP - Turbo Induction
 Old 06-25-2012, 09:35 PM   #1
ilikegame's Avatar
Posts: 1   (View Stats)
ilikegame is an unknown quantity at this point
Default Turbosmart dual port BOV question
Bought a dual port BOV for my 2003 msp, everything besides wastegate is stock. I adjusted the BOV to where it needs to be, no bad idle or stalling. Seems to work fine in the field of recirculating but i cant hear it blow off at all when i romp on it. Is there something i should try or something i should be doing to get it to work right?
ilikegame is offline   Reply With Quote
 Old 06-25-2012, 09:36 PM   #2
Mortose's Avatar
Posts: 2,441   (View Stats)
Groans: 39
/facepalm
99 miata: sold
The Following User Says Thank You to Mortose For This Useful Post:
Alejo_NIN (07-26-2012)
 Old 06-25-2012, 09:44 PM   #3
Dmurray06's Avatar
Posts: 3,279   (View Stats)
 Old 06-25-2012, 09:46 PM   #4
jeopardy98's Avatar
Posts: 1,920   (View Stats)
jeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the world
You can't be serious! FFS!
Bone Stock 2012 BM Non-Tech for 2500 miles. (250 whp/265 wtq Moore Auto). Currently: K04/Cobb AP/AT internals/Magnaflow CBE/M2 DP/Cobb SRI/HTP TIP/CS boost tubes/CS recirc hose/TS BPV/SU TMIC/GS EBCS/JBR EGR delete/Coolant bypass/Thermal TB gasket/NGK 6510's/JBR SSP/JBR Knob/JBR 88 RMM/JBR SSB/DDM 35w 5000k HIDs/PAC Gateway iPod integration and Sirius. (301whp/360wtq Moore Auto). Finklefied Hypnotic tune. 14.1@106 Mason Dixon- Driver mod needed.
jeopardy98 is offline   Reply With Quote
 Old 07-07-2012, 07:22 AM   #5
usmc0651dns's Avatar
Posts: 18   (View Stats)
usmc0651dns has a spectacular aura aboutusmc0651dns has a spectacular aura about
Good info guys. I would imagine that getting an intake would help your situation. As far as I know, people have had look getting extra turbo noise with an intake even while using the stock BPV. I read on the manufacturer's website a while back that the dual port can be set to recirculate, vent to atmosphere, or the recommended setting letting you do both. I would try some more fine tuning if you don't want to splurge on a short ram intake yet.
usmc0651dns is offline   Reply With Quote
The Following User Says Thank You to usmc0651dns For This Useful Post:
 Old 07-26-2012, 03:46 PM   #6
Alejo_NIN's Avatar
Posts: 1,700   (View Stats)
Alejo_NIN is the leader of the worldAlejo_NIN is the leader of the worldAlejo_NIN is the leader of the worldAlejo_NIN is the leader of the worldAlejo_NIN is the leader of the worldAlejo_NIN is the leader of the worldAlejo_NIN is the leader of the worldAlejo_NIN is the leader of the worldAlejo_NIN is the leader of the worldAlejo_NIN is the leader of the worldAlejo_NIN is the leader of the world
Groans: 88
Groaned at 186 Times in 83 Posts
before getting that wooosh sound make sure you get supporitng mods.
no, i don't mean AP or anything crazy like the MS3 but at least a CAI or SRI.
a blow off DOES NOTHING for performanc eon this car as the first mod other than perhaps getting rid of the turkey, which you don't have because you have a stock intake.
should've saved your money for other goodies like hard pipes/intake and exhaust.
ps: exhaust mods does wonders for the protege!
radonelement.com
Alejo_NIN is offline   Reply With Quote
Page generated in 0.26417 seconds with 25 queries
