| MazdaSpeed 3/6 - Wheels & Tires HaveMazdaSpeed 3 - Wheels & Tires - Have a question about wheels or tires? Need a calculator to figure out offsets? We have them in here |
![]() Join Date: Jun 2009 Location: Old Bridge, NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,044
Groans: 125
(Thread Starter) | Not Ranked : 0 score i was sort of inspired by this: Black Enkei RPF1s i don't want to do the same setup as him, because i want the same rims all around. i also will be staying on stock suspension because its my daily and potholes and shit blah blah. id like to slap some 255/40 gfg g-force kdw 2s BFGoodrich—g-Force T/A KDW 2 I have no problem doing a fender roll and cutting tabs or whatever other type of body work, except not a crazy pull or anything, but i want to AVOID camber. is this setup possible? I did read many many threads to find the answer, but couldnt find the same setup as myself. thanks in advance |
![]() Join Date: Nov 2010 Location: Phoenix, AZ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,658
| Not Ranked : 0 score You can match that setup easily. You can run all four wheels at +45 with an 8mm spacer on the front if you need it. Then you can still rotate tires.
__________________ 2010 MS3 - Restockified (The former STX Battle Wagon) Progress RSB - Koni Sport - EBC Yellow - MD OCC - CS MonoCBE - Cobb SRI 2004 MSM TiGrey AEM SRI - Turbosmart MBC - FM TBI - eBay DP - Turbosmart BPV - Mishimoto FMIC - Denso 305cc Koni Sport - GC Coilover - Racing Beat 1.25" Front Sway Bar - SS Lines - 15x8 Flatout - 225/45 RS3 Last edited by Crarrs; 04-11-2012 at 08:21 PM. |
Groans: 125
(Thread Starter) | Not Ranked : 0 score yes but the main thing is to avoid camber, i have no problem with rolling fenders and using spacers |
| Not Ranked : 0 score Not sure, start plugging numbers in here and bust out the tape measure to get a better idea.
__________________ 2010 MS3 - Restockified (The former STX Battle Wagon) Progress RSB - Koni Sport - EBC Yellow - MD OCC - CS MonoCBE - Cobb SRI 2004 MSM TiGrey AEM SRI - Turbosmart MBC - FM TBI - eBay DP - Turbosmart BPV - Mishimoto FMIC - Denso 305cc Koni Sport - GC Coilover - Racing Beat 1.25" Front Sway Bar - SS Lines - 15x8 Flatout - 225/45 RS3 |
![]() Join Date: Dec 2010
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 189
Groaned at 249 Times in 46 Posts
| Not Ranked : 0 score You are not going to get that look without lowering. End of story. |
| Not Ranked : 0 score He doesn't want the look. He wants traction. That's why he wants to avoid camber.
![]() Join Date: Jul 2010 Location: Arlington, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 12
| Not Ranked : 0 score FEDERAL 595 RS-R Racing 235/40-17 (they run 5-10mm larger) 595 RS-R Racing - OnlineTires.com FEDERAL 595 RS-R Racing 255/40-17 (they run 5-10mm larger) or serious meat: 595 RS-R Racing - OnlineTires.com I am running 18x8.5 et 48 with 245/40/18s on stock suspension: You will rub the rear fenders and will need to get a spacer to clear the front struts. |
Groans: 125
(Thread Starter) | Not Ranked : 0 score how can you tell how wide it is? are you basically saying that a 255 is different for each tire? |
![]() Join Date: May 2009 Location: Chicago, IL
Rep Power: 10249 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,116
Groans: 136
Tapadatass
__________________ | |
![]() Join Date: May 2011 Location: Lexington, KY / Troy, MI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 311
Tapped
__________________ 08.5 CWP MS3 GT AP Stage 2 S-OTS+ | Cobb Catted DP | Magnaflow CBE | JBR SRI | Cobb TIP | JBR 70 Duro RMM |NGK Iridiums | Autotech Internals | Lamin-X Yellow Fog Overlays | |
Groans: 125
(Thread Starter) | Not Ranked : 0 score ok so im thinking possibly doing a staggered setup. while it may look dumb, it will be much more functional. i want to get the widest possible tire for the rears without having to do camber (aggressive roll is perfectly fine) so im thinking possibly an 8.5 rim and 245 wheels and then very wire tires in the front. 9"rim still but maybe 265 or 275 if they fit. it wont look tooo terrible and may not even be noticable unless you really check. i'm also looking for an idea for a good tire. id like great traction of course, but i also need to be able to drive in the rain. i know the bf g-force kdw2s are great in the rain, but the traction i heard is lacking...ideas? |
![]() Join Date: Jun 2010
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 176
Groaned at 8 Times in 5 Posts
| Not Ranked : 0 score If you're curious, here's a picture I just took of 245/40/17 Hankook RS3s vs 265/40/17 Star Specs on my 17x9+35 RPF1s. ![]() |
| The Following 5 Users Say Thank You to grantmm For This Useful Post: | AZSPEED3 (07-15-2012), burntRice (04-17-2012), helmetface (07-16-2012), SLOWHATCH (04-17-2012), TWOptSL0W (04-17-2012) |
Groans: 125
| Not Ranked : 0 score We're figuring that out now. Due to the coils, I have to run an additional 8mm spacer to clear the lower spring perch, so my fitment will be quite different. ![]() ![]() There is slight rubbing while turned, but I'm heat molding the fender liners to alleviate that. |
| The Following User Says Thank You to grantmm For This Useful Post: | TWOptSL0W (04-18-2012) |
![]() ![]() Join Date: Mar 2008 Location: Boise, Idaho
Rep Power: 1904 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 229
| Neutral : +1 score Hey bud quick question. What were you trying to accomplish with this setup? Are you gonna autocross with it or just street use? I have 2 new 245/40/17 rs3s that I might be selling. I have some ideas in my head. I think I might just go 265/35/18 rs3's all the way around or I have a few other ideas. Let me know if your interested or why u went with that setup. thakns
__________________ 2008 Mazdaspeed3, Fully built then fully parted. Sold 2007 ccsb Silverado, 3/5 drop Procharged, longtubes, 10psi Daily Mazdaspeed 12.5 @109 k04 stock ecu 18psi pump gas stock motor 311whp 11.7 @120 atp gtx3071r ap tuned 22psi 30/70 e85/pump stock motor. 422whp |
| Not Ranked : 0 score Autocross only for the new tires. I'll be dailying the Volks and 245 RS3s now. I'm sure someone on here well take those Hankooks off your hands though |
![]() Join Date: Jan 2011
Rep Power: 0 ![]() Thanks: 0
| Not Ranked : 0 score Hey driver311 i recently saw a post from you and saw your previous street setup with the rpf1's. My goal for next summer is to run either 255/40/17 Potenza RE-11's on 17x9 +45 rpf1's with 5mm spacers up front as well, rolled rear fenders and a rear camber of -2.0...Or 245/40/17 Advan Neova AD08's on the same setup with 3mm spacers upfront.. Im also gonna be lowered with COBB springs and Koni yellow sports. Witch setup would i be more beneficial with in your experience and will i be ok in the front and rear running the first setup with 255's ??? It will be my first rodeo lowering and going that wide especially with 17's... |
![]() | | #19 | ![]() |
![]() Join Date: Oct 2008 Location: Carson, CA
Rep Power: 977 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 168
__________________ *COBB: AP, shifter weight *BITWISE: Harness, 3bar BNR: S3v2 *CP-e: Stage 2 RMM ,TMIC *JBR: RSB, EGR delete, WP *GRIMMSPEED: EBCS *TWM: Full Shifter *KDM: HPFP internals *DENSO:ITV22 *FORD: syn trans fluid *OBX: TBE *BILSTEIN: B8 Sport *SWIFT: Spec-R springs *GTSPEC: 4point ladder brace, rear subframe brace *NITTO: NT-05 * Whiteline: BSK *MOOG: F/R endlinks* SPC: Adj. camber arms *MORIMOTO: 5K HID elite | |
![]() | | #20 | ![]() |
| Not Ranked : 0 score Ive heard nt-05's were quite noisy |
| 17x9 +45 extremecontact DW's! | taf0422 | Wheels & Tires - COSMIC BLUE | 42 | 08-06-2013 09:01 AM |
| 17x9+38 255/40R17 | bmannn | 2010 MS3 - Wheels & Tires | 28 | 03-03-2012 08:47 AM |
| 255-40-17, 17x9 +48 on ms6, check | jroc | MazdaSpeed 3/6 - Wheels & Tires | 14 | 07-25-2011 02:49 AM |
| 17x9 that fit stoptech bbk? | fastdreams | MazdaSpeed 3/6 - Wheels & Tires | 2 | 06-21-2010 10:08 AM |
| To those with 17x9, 18x9 45 offset | bnoon | MazdaSpeed 3/6 - Wheels & Tires | 39 | 02-23-2009 01:24 PM |
