  • 1 Post By Thor Hammer
  • 1 Post By Djohns
 Old 05-16-2017, 01:54 PM   #1
Carskick's Avatar
Posts: 315   (View Stats)
Carskick has a reputation beyond reputeCarskick has a reputation beyond reputeCarskick has a reputation beyond reputeCarskick has a reputation beyond reputeCarskick has a reputation beyond reputeCarskick has a reputation beyond reputeCarskick has a reputation beyond reputeCarskick has a reputation beyond reputeCarskick has a reputation beyond reputeCarskick has a reputation beyond reputeCarskick has a reputation beyond repute
Default 245/45R17 - Options & Prep
Hey guys!
I'm looking at new Wheels & Tires, and wanted to get some feedback on my plans after some reasearch:
Currently running the stock 215/45r18 on 17x7 Gen Waun setup.
I want something to improve grip & traction, improving straight line acceleration & cornering grip. Going to a size that's similar to stock in diameter with a slightly larger sidewall is prefered, as it has a relatively lower tire cost and is better on rough roads.
That being said, I'm looking at 245/45R17 on 17x8.5 wheels.
Old Vs New Comparison
I am on stock suspension and don't plan on changing that. I know I will have to roll at least my rear fenders, possibly front as well. I'd love some feedback on this size configuration, and possibly some wheel suggestions. Offset suggestions would be great as well. I am planning on an offset near +33 to keep the distance from the wheel and the suspension about the same. How close to the suspension can I safely get? What offset for this size would be optimal for handling & rube prevention?
Aesthetically, I'm primarily looking at an alloy silver color, but I would also consider gold & gunmetal. No black or chrome. Black accents against alloy would be fine.
Thank you in advance for the feedback & ideas!
2009 Mazdaspeed 3 Sport (Original Owner) - 95k miles on original Motor & Turbo and counting
Current Performance Mods: APv3 Freektune 93 & E-30 | JBR 3.0 SRI | ETS TMIC w/JBR Red Tubes | SpeedDaddy TP | AT HPFP | Damond Triple Mounted | Southbend S2 Endurance Clutch/Fly | Stoptech Slotted Rotors | EBC RedStuff Pads | Enkei PF01 18x8.5 +48 | Continental EC Sport 245/40R18 | KWv2 Coilovers | Whiteline LCA Bushings, Anti-Lift, & Bump Steer | Whiteline Endlinks | JBR .125 FSB & RSB w/billet bushings/mounts | CS Lower Tie Bar | DM OCC w/VTA | JBR Shifter Bushings
Stereo Mods: Pioneer AVH4100NEX | Phoenix Gold 6.5" Comps Front | Focal 6.5 Coax Rears | Polk 12" in Trunk Floor Enclosure | PPI 4x125W amp driving Fronts & Sub
Other Mods: FIAMM 72112 Low Note Horn alongside stock
Mods Awaitting Install: Redline Leather Center Armrest & Handbrake Boot
Future Mods: Injector Seals | Built Block & BNR S3v2 if ZZB
Removed Mods: JBR 70A RMM | Koni STR.T Orange Shocks
Carskick is offline   Reply With Quote
 Old 05-16-2017, 02:25 PM   #2
Thor Hammer's Avatar
Posts: 1,847   (View Stats)
Groans: 211
Everything you ask has been discussed, raped, repeated, and rinsed over and over.....
OFFICIAL AGGRESSIVE OFFSET THREAD
The Ultimate "Will They Fit" Thread - Everything you need to know about wheels, spacers and tires for your MS
monkey.bones.007 likes this.
 Old 05-16-2017, 02:31 PM   #3
Djohns's Avatar
Posts: 3,944   (View Stats)
And over and over and over. Just read.
2010 black mica speed3
Soon:built motor
FromMilwaukee (05-16-2017), Thor Hammer (05-16-2017)
 Old 05-17-2017, 07:51 AM   #4
Carskick's Avatar
Ok, fine, lol.
I've been reading so much about this. But I found this article last night, which I think is very helpful. I was having a hard time figuring out exactly which wheels will and won't hit the suspension:
Wheel Fitment Tutorial
So unless any has any specific recommendations for me, we can leave it at that.
As an aside, I think I've decided to go with bright white wheels.
 Old 05-17-2017, 09:01 AM   #5
jonathan13's Avatar
Posts: 25   (View Stats)
jonathan13 has a spectacular aura aboutjonathan13 has a spectacular aura about
You will be ok.
Im running 245/40/17s on 17x9+35 rota titans lowered on bc coils, fronts are clear and rear fenders only needed a slight roll.
Sent from my SM-G935W8 using Tapatalk
jonathan13 is offline   Reply With Quote
The Following User Says Thank You to jonathan13 For This Useful Post:
Carskick (05-17-2017)
 Old 05-17-2017, 09:16 AM   #6
Shwaykid's Avatar
Posts: 646   (View Stats)
Originally Posted by jonathan13 View Post
You will be ok.
How much camber are you running in the rear? And how much are you dropped with those BCs?
2008 Mazdaspeed3 GT
Jet Black Wax (06/24/2017)
 Old 05-17-2017, 11:27 AM   #7
Carskick's Avatar
You will be ok.
That's exactly what I wanted to hear! Almost the exact setup I was thinking, except I am looking 17x8.5 Wheels and not lowering. Glad to hear it didn't need much roll on your first gen. I need to calculate the exact range of offset I can run with my size, but I was thinking around the +40 area, probably similar to yours taking into account the smaller wheel size.
I'd also be curious to know what camber you're running.
Thanks again!
Current Intake Options for a non-BT Build: JBR PP S2 vs 3.0 Options Carskick MazdaSpeed 3 - Engine, Transmission & Driveline 58 04-25-2017 06:21 AM
Tire PSI suggestion 225/45R17 winters mhebert2001 2010 MS3 - Wheels & Tires 5 01-11-2015 09:01 AM
Winter prep anyone? TORQUERULES Exterior 9 12-04-2014 10:25 AM
Winter Prep Special--k 2010 MS3 - How-To's 8 11-23-2010 01:06 PM
Page generated in 0.28783 seconds with 24 queries
