| MazdaSpeed 3/6 - Wheels & Tires HaveMazdaSpeed 3 - Wheels & Tires - Have a question about wheels or tires? Need a calculator to figure out offsets? We have them in here |
![]() Join Date: Nov 2008 Location: Vancouver, WA
Rep Power: 0 ![]() Thanks: 0
![]() Join Date: May 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,642
Groans: 78
| Not Ranked : 0 score Which ones? Which year?
__________________ In reality I love lenny |
(Thread Starter) | Not Ranked : 0 score This is what the guy has posted in his add. "These 4 wheels are from my 2008 Mazda 3 5-door with only 5500 miles on them. They are in perfect condition with no scratches or scuffs. The factory tire size is 205/50/R17. The lug nut fit pattern is 5 x 114.3 (same as 5 x 4.5). Width is 6.5 inches with zero offset." |
![]() Join Date: Mar 2008 Location: Minnetonka, MN
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 58
| Not Ranked : 0 score Yes, many things are interchangable between a Mz3 and MS3. I'm running the MS3 strut, lower control arm and hub assembly in my Mz3 with my Mz3 wheels. There will be no problem doing this.
__________________ Summer Car - '05/'07 Mazdaspeed/Mazda 3 SP23 with Cobb FMIC, SRI and Stage 2 Suspension, Koni Yellows, AWR Front End Links(in the mail), HKS SSQV, TXS Mid-Pipe, 225/40R18 Nitto NeoGens. Dyno'd on 4/25/2009 - 271whp/286wtq Spring/Fall/Winter Car - '08 Mazda 5 Sport Toyo Observe Garit HT Winter Tires |
![]() Join Date: Aug 2008 Location: Buffalo Grove, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 307
| Not Ranked : 0 score Here is another thing. last year i was using my 2001 mazda protege rims, which are 16s. and then fit fine. It was gonna be my winter rims. but this year i had a problem. i got my front brake pads replaced at the dealership. they said that mazdaspeed pad would cost about 225 to replace, but i had the option of using regular mazda 3 pads, and the cost would be 90. so i went wit that. but now when i try to get the 16s back on for the winter, they wont fit. i took my car back to the dealership and they said that the pads from the regular 3 are thicker. which now causes the brake calipers to touch my rims. so now i this problem of either buying mazdaspeed brake pads. or getting 17s and get a whole new set of tires to go wit them. |
(Thread Starter) | Not Ranked : 0 score Well that sucks about your snow tires mate. |
| Not Ranked : 0 score well i got shit taken care of over the weekend. i went to murray's, and got a pair of wheel spacers. they were 5/8", and they gave just enough clearance for the rims and the calipers not to meet. it cost me $20, instead of 200+ for new brake pads, or 600+ for new tires. time for some snow drifting. |
| Banned ![]() Join Date: Jun 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 283
Groans: 213
Groaned at 274 Times in 187 Posts
| Not Ranked : 0 score Yes reg mazda rims fit on the speed. I was rocking 16" stockers on my speed! Wooooo |
![]() Join Date: Apr 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
| Not Ranked : 0 score Mazda3 17 inchers for speed3 winter use. |
| 16" Mazda 3 Wheels that fit MS3? | SpdFreak | MazdaSpeed 3/6 - Wheels & Tires | 16 | 12-10-2008 11:14 AM |
