| MazdaSpeed 3/6 - Wheels & Tires HaveMazdaSpeed 3 - Wheels & Tires - Have a question about wheels or tires? Need a calculator to figure out offsets? We have them in here |
![]() Join Date: May 2011
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 56
(Thread Starter) | Not Ranked : 0 score I'll post pics with them on the car in this thread once I get them mounted, balanced and slapped on in a day or two. |
![]() Join Date: Jul 2010 Location: Arlington, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 12
| Not Ranked : 0 score No need for a spacer. I too am running 18x8.5 but are et48 with 245/40s. Iam 3mm closer to the front strut then your setup and I have no issues. I had to roll the rears on stock suspension. I thought I could get away without a roll and my poor tires paid the price. Since you stick out 3mm more you will rub more. Can't wait to see them on the car! |
| The Following User Says Thank You to goob_os101 For This Useful Post: | Baloo (04-26-2012) |
(Thread Starter) | Not Ranked : 0 score This is going on a speed 6. Not sure how similar the wheel wells are, I am fully expecting to have to roll at least the rears. |
![]() Join Date: Jan 2011 Location: Wisconsin
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 93
| Not Ranked : 0 score I think they look great, should be a snug fit for sure. |
![]() Join Date: Jun 2010 Location: APO AE
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 176
| Not Ranked : 0 score Isn't there like a fitment page somewhere on the forum where it talks about all this shit? |
(Thread Starter) | Not Ranked : 0 score Yes, I have gone through more fitment forums/threads than you can shake a stick at. It was sure alot easier to find speed 3 fitments that work than it was for the 6. I'm 99% sure it will all work out. I definitely didn't create the thread to find out if this exact setup will work or not (its a little late to be asking anyway). Please don't go down that road. |
![]() Join Date: Jan 2011 Location: Pueblo West, Colorado
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,812
Groans: 76
| Not Ranked : 0 score fuck that wheel is sex
__________________ | 2007 True Red Mazdaspeed 3 GT | GO: | SURE SRI V2 | COBB TIP | CP-E FMIC | Corksport DP | Corksport CBE | Cobb AP RICHTUNED | Autotech Internals | SURE RMM | Denso ITV-22's | Turbosmart BPV | SHOW: | Evo X Enkei's 18x8.5 +38 Painted CWP| Nitto Motivo's 225/40 | BC Racing Coilovers | SPC Camber Arms | DDM 3000k fogs | CPE Tow Plate | |
| Not Ranked : 0 score you should be fine still... |
(Thread Starter) | Not Ranked : 0 score Finally got them mounted on the car! Here are a few shots. The iPhone hardly does it justice. As far as fitment goes, I can still fit a finger between the front strut and tire so it is all good up there. Just as I suspected the rears will have to be rolled, it rubs when fully compressed. Finally the rubber looks proportional to the cars size... |
![]() Join Date: Jul 2010 Location: Riverside,CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 917
| Not Ranked : 0 score not to be a dick, but on the car they remind me of the stock first Gen Scion TC wheels. Sent from my 3VO bitches.
__________________ [SIGPIC][/SIGPIC] 2008.5 CWP Speed3 GT - SOLD / ![]() 1991 Ford Mustang LX 5.0 SSP 331 Stroker 9:1 compression - AFR 185 Heads ported to 205 specs - 1.6 Roller Rockers - Comp Turbo Cam - Edelbrock RPM Performer II Upper and Lower intake mani - 24# injectors - 70mm throttle body and EGR spacer - C&L Intake - BBK Headers - MSD Billet Distributor - MSD Coil - Ford Racing Wires - MSD Ignition - A/C delete - Built 3 spd With reverse manual valve body - B&M Shifter - Aluminum driveshaft - 3.55 gears - Moser 31 spline Axles - Nitrous Express 125 shot - 5 lug conversion With SN95 Brakes |
(Thread Starter) | Not Ranked : 0 score These Scion tC wheels? They may have pairs of spokes as well, but that's where the similarity ends. |
![]() Join Date: Dec 2008 Location: CT :: Stratford :: 203
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 632
| Not Ranked : 0 score umm.. nice wheels.. but that thing is too high.. u going off.road w/ it?
__________________ :: somewhere between CT & VA :: yea yea - i know i cant spell |
(Thread Starter) | Not Ranked : 0 score Hahaha, I figured someone would pipe up about the ride height. It's on the to-do list. I will have to be more thorough with the fender rolling in the rear if I do end up dropping it. |
| Not Ranked : 0 score Car looks good. Just need to get that drop down. Otherwise put some flaps on that thing and rally it. |
