| MazdaSpeed 3/6 - Wheels & Tires HaveMazdaSpeed 3 - Wheels & Tires - Have a question about wheels or tires? Need a calculator to figure out offsets? We have them in here |
![]() Join Date: Sep 2017 Location: Western Mass
Rep Power: 43 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9
(Thread Starter) | Not Ranked : 0 score background on my car, stock suspension for now, just picked up some rx8 wheels to run for summer duty. I was thinking it was between Nitto NT555 G2, Hankook Ventus V12 evo2 or Sumitomo HTR ZIII. looking to spend no more then $750ish for a set and have both good wet and dry traction
__________________ 06 Speed6 White/Black interior Sure Diff Mounts, JBR Intake, JBR I/C Hoses, Wiesco pistons .5mm over, Molnar H-Beam Rods, King bearings, New to me Cylinder Block, CS turbo, CS catted turbo back exhaust, CS HPFP, CS EBCS, CS injector seals, AP v3, FREEKTUNE, rebuilt clutch from Falcon Clutch with kevlar lining, DM PCV plate, DM stage 1 OCC, EcoBoost oil pump, vented oil cap with baffle, Speed Solutions PTO bearing caps, All Damond mounts To think... this is suppose to be my winter car... because, '72 AMC Javelin AMX 366 CI, 4speed 13.13 quickest 1/4 mile et so far '12 1/2 Triumph Daytona 675R stock some how '79 AMC Spirit AMX, 4.6L stroker I6 |
![]() Join Date: Feb 2012 Location: Li ny
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,290
Groans: 74
| Not Ranked : 0 score I was in the same boat for a set 9f summer tires for rims i just purchased. I did not want to spend more then 160 a tire.I just picked up a set of conti extreme contact sports due to there wet traction reviews the nitto. Hopefully mounting them tommorow. Michelin pilot sport 4 is a better tire but its 200 a pop. Dont have much Experience with the others.
__________________ MECP 2012 BM PTE 5858 Vband .82ar // Tial EWG // CPE Mani // 3" Turboback // JBR Under route hot pipe // MD ST mani+spacer with PI // Siemens 60lb Injectors // Splitsecond inj controller // JBR 88 duro RMM/TMM // MD PMM // TWM Full replacement shifter // JBR CC // Autotech FP Internals // SP63 SB/Manley rods SP63 pro pistons // Treadstone FMIC TR824 // FoMoCo Tranny Jizz // South Bend Clutch Stage 3 enduro// GFB Respons // FJ 4" intake // WMI 100% VPM1 // Air Lift 1000 in rear // N2MB WOT BOX Rfinkle tune in progress The Brooklyn beater: 2005 1.8 Auto Sentra |
![]() Join Date: Mar 2016
Rep Power: 0 ![]() ![]() ![]() ![]() Thanks: 4
| Not Ranked : 0 score had experience with federal 595 rs-rr over all better fgrip than nt05 but treadware is terrible, and if you dont have exhaust then road noise is loud but grip is really good barely spins at 3rd gear |
Groans: 211
I switched to a set of Hankook Ventus V12 Evo2 and its like night and day. Wet traction is surprisingly good. AWD helps. But the dry traction is amazing. Way better than the Conti's. Those felt like sponges compared to the Hankooks. I commute over a twisty mountain highway and these tires have much less sidewall flex. They just feel planted mid corner and I cant seem to break them loose. Which is a good thing!
__________________ 2007 MS6- H&R Coilovers/ C-PE Catted DP/Corksport HPFP Internals/ AEM CAI/ ETS TMIC/ CPE Austenite Dual CBE/ CPE TIH/ Synapse Synchronic/ Freektuned/ AP Short Shifter/ AWR RMM and OEM TMM with CS Inserts/ Southbend Stage 2 Endurance/Stop Tech Slotted Rear and DBA T3 4000 Series Front with EBC Reds/CPE xFlex Rear Diff Mount/ Whiteline Rear Sway Bar/DSS Level 2.9 Rear Axles | |
(Thread Starter) | Not Ranked : 0 score awesome! thank you guys for the replies, now I'm just in a dilemma for size, i got some rx8 18" wheels, I'm thinking about 225/45. the wheels have junk tires of that size but it seems like that would fit very well under the car. I am at stock hight right now but planning a suspension overhall next summer if not sooner, lowest I'd go is 1-1.5" lower then stock.
| Not Ranked : 0 score btw the federals and nittos have freeshipping in amazon idk about any other tire company but here in hawaii, its free (sucks here) |
Groans: 211
| New Nitto NT555's | Mooose | 2010 MS3 - Wheels & Tires | 1 | 09-08-2015 09:28 PM |
| Need input on tires (Nitto NT555) | Cell Block 54 | 2010 MS3 - Wheels & Tires | 9 | 02-01-2013 03:26 PM |
