Like Tree8Likes
 Old 03-14-2013, 07:19 PM   #41
Mr Wilson's Avatar
Posts: 120   (View Stats)
Mr Wilson is the leader of the worldMr Wilson is the leader of the worldMr Wilson is the leader of the worldMr Wilson is the leader of the worldMr Wilson is the leader of the worldMr Wilson is the leader of the worldMr Wilson is the leader of the worldMr Wilson is the leader of the worldMr Wilson is the leader of the worldMr Wilson is the leader of the worldMr Wilson is the leader of the world
May have sourced a local set, but I'll let you know and thanks.
2008.5 CWP SPEED3
MODS TO DATE: KW V3 Cobb AP V3, RSB, STS TWM Shifter Extender Sure Shortcut, Countershift CP-e Tow Plate, FMIC, HPFP, DP, Exhaust Manifold, HeliHose, PMM/TMM, Nexus CBE, Injector Seals TiAL bpv JBR WP, Solid Shifter Bushings, TB/IM Gasket, RMM Celestspeed3 Coolant Bypass DBA 4300 T3 Hawk HP+ Denso itv22 Saikou Michi OCC DGM Lip HTP Slim Battery Tray SilverDemon EGR Block Off Rays Volk TE37 SL 18x9.5 +22, Formula Lugs Bridgestone RE-11 265/35-18 SilverDemon EGR Delete Kit Stratified ECBS, 3-Bar Map Sensor Intake Manifold PnP
Mr Wilson is offline   Reply With Quote
 Old 03-24-2013, 10:04 AM   #42
BigBoostMS3's Avatar
Posts: 1,429   (View Stats)
I found these on Craigslist in Atlanta. At about 8pm I asked my gf if she wanted to go for a road trip and we left at 830. Got to ATL at 1145, bought the tires, went and visited a friend for an hour, then headed back. Got back to Knoxville at about 430am. Quite the memorable evening for them.
But it was worth it, because I got them for a great deal. The tires are about 75% new. I cleaned them, sanded them, painted and clear coated them. I haven't really been able to run them much with the weather the way it's been, but they have all but eliminated tire spin in 3rd. They did bring to light the fact that I need side mounts next lol.
Pics
I have a pic of it on the car, but everytime I upload it to photobucket it flips on its side. Can't get it to rotate back for some reason
Scott
www.TorqueSteerStickers.com
 Old 03-24-2013, 10:06 AM   #43
minger's Avatar
Posts: 1,064   (View Stats)
minger is the leader of the worldminger is the leader of the worldminger is the leader of the worldminger is the leader of the worldminger is the leader of the worldminger is the leader of the worldminger is the leader of the worldminger is the leader of the worldminger is the leader of the worldminger is the leader of the worldminger is the leader of the world
@BigBoostMS3; what size are the tires?
2011 MS3 - AP, AutoTech Internals, TP, 30% e85. N9thRacing RSB, JBR SSP, HKS SSQV, CPE Intake+TIP, TurboXS TP and UR Catback.
2002 Miata. Racelands, Hard Dog Roll Bar, RPF1s.
Zoom Zoom.
minger is offline   Reply With Quote
 Old 03-24-2013, 10:37 AM   #44
225/50/16 nitto 555r drag radials
I am fairly certain they are wide for a 225. I haven't been able to find any specs for this size of this tire either.
Scott
 Old 03-24-2013, 06:16 PM   #45
Mr Wilson's Avatar
So the local deal for the caps fell through. I wanted flat caps and didn't want to wreck the stock ones.
Toyota makes a 2.5 in (63mm) cap that fits. It is indented about 2-3 mm from the face, but it fits. Have to remove the 'T' and it gives you a flat face.
My bill says the part number is 42603-48138, but the bag says 42603-30580.
Just gives another option for those looking for caps.
2008.5 CWP SPEED3
The Following User Says Thank You to Mr Wilson For This Useful Post:
SLOWHATCH (04-02-2013)
 Old 03-24-2013, 08:56 PM   #46
Celestspeed3's Avatar
Posts: 1,136   (View Stats)
@Mr Wilson;
Just run no centre caps.
I can get you some knock fillers we use at work for centre caps.
Mr Wilson likes this.
The Following 2 Users Say Thank You to Celestspeed3 For This Useful Post:
Mr Wilson (03-25-2013), SLOWHATCH (04-02-2013)
 Old 03-24-2013, 10:07 PM   #47
865ms3's Avatar
Posts: 2,602   (View Stats)
my fds with hankook rs3s. 225/50/16
File Type: jpg 548122_10151045873051048_1311895999_n.jpg (129.8 KB, 107 views)
File Type: jpg 486758_10151049932876048_1347311775_n.jpg (39.0 KB, 100 views)
File Type: jpg 311604_10150960549336048_998001173_n.jpg (164.1 KB, 126 views)
minger likes this.
Brent
-Built Block-5858-Meth
Dragon Slayer Setup
FreekTuned
The Following 2 Users Say Thank You to 865ms3 For This Useful Post:
CWP_MS3 (12-24-2013), minger (03-25-2013)
 Old 03-25-2013, 10:02 AM   #48
minger's Avatar
Looks like 225 might be where to go with these as everything seems to be running wide enough for these. Assuming tire sidewall sticks out past the rim of the wheel?
Also...looks good with the gold. I was thinking of doing that and your car looks just like mine...I guess I'm sold.
I contacted Nitto, and the only real information they gave me was the Overall Diameter at 24.88" and Overall Width at 9.02". I'm assuming Overall Width = Section Width.
Zoom Zoom.
The Following 2 Users Say Thank You to minger For This Useful Post:
865ms3 (03-25-2013), BigBoostMS3 (03-25-2013)
 Old 03-25-2013, 02:59 PM   #49
That's actually helpful.
I'm not sure if the overall width = section width or not. I found the RS3 data to compare to...
Section width = 9.1"
Tread width = 8"
If it does, then the RS3 is just a hair smaller, which makes sense in my head. Since I don't have much rubbing at all (and it's not rubbing when sitting still). I think it's the flex in the sidewall on corners that allows the tire to rub.
Scott
 Old 04-02-2013, 08:30 AM   #50
minger's Avatar
I guess. I'm still confused as to how @walv89; runs 245s on his in post 5, but he isn't really on the board anymore as most 245s have a section width of somewhere between 9.6-10".
Zoom Zoom.
 Old 04-09-2013, 06:38 PM   #51
Mr Wilson's Avatar
Bit the bullet and put them on. Tires are Bridgestone RE-11 245/45R-16. Came out pretty well.
Fitment is tight on the front KW coilover. It clears, but I may get a 5mm spacer for piece of mind. Rears are fine, not rolled.
2008.5 CWP SPEED3
 Old 04-09-2013, 07:30 PM   #52
08cosmic3's Avatar
Posts: 2,920   (View Stats)
I have Koni FSD's with 225/50-16 Re-11's and there is only 1/8" gap on the rears between the shock and tire. I'm getting 245/45-16 RE-11's next but will almost certainly need spacers on the rear. I guess it's all in what shock/strut you have.
 Old 04-19-2013, 08:14 AM   #53
Adam is so pro's Avatar
Posts: 410   (View Stats)
Adam is so pro is the leader of the worldAdam is so pro is the leader of the worldAdam is so pro is the leader of the worldAdam is so pro is the leader of the worldAdam is so pro is the leader of the worldAdam is so pro is the leader of the worldAdam is so pro is the leader of the worldAdam is so pro is the leader of the worldAdam is so pro is the leader of the worldAdam is so pro is the leader of the worldAdam is so pro is the leader of the world
Anyone else running m/t 255/50's?
Adam is so pro is offline   Reply With Quote
 Old 04-19-2013, 09:07 AM   #54
jdm_mica's Avatar
Posts: 525   (View Stats)
Avg. price paid for a good set of FD's? Would like a set, would get rid of my Gen1 stockers for a clean set
Cobb AP (Stratified Tuned)
Streetunit testpipe
Autotech internals
NGK LTR7Ix-11
Corksport RMM
Whiteline RSB+endlinks
HKS turbo timer
Prosport boost gauge+ventpod
 Old 04-19-2013, 09:36 AM   #55
Alejo_NIN's Avatar
Posts: 1,700   (View Stats)
Alejo_NIN is the leader of the worldAlejo_NIN is the leader of the worldAlejo_NIN is the leader of the worldAlejo_NIN is the leader of the worldAlejo_NIN is the leader of the worldAlejo_NIN is the leader of the worldAlejo_NIN is the leader of the worldAlejo_NIN is the leader of the worldAlejo_NIN is the leader of the worldAlejo_NIN is the leader of the worldAlejo_NIN is the leader of the world
Groans: 88
Groaned at 186 Times in 83 Posts
had these on the pu for a little bit...but i bought them mainly for the protege
so imma join this..since they wer eon the pu for about 3 months
you should'n't pay more than 300$ for bare rims..
radonelement.com
Last edited by Alejo_NIN; 04-19-2013 at 09:36 AM. Reason: MSF Database - Automerged Doublepost
Alejo_NIN is offline   Reply With Quote
 Old 04-19-2013, 12:16 PM   #56
I got 2 of them in 9/10 condition for 120 shipped.
 Old 04-27-2013, 01:15 PM   #57
teaser.
 Old 04-27-2013, 05:33 PM   #58
Alejo_NIN's Avatar
Groans: 88
nasty...why would you do that?
radonelement.com
 Old 04-27-2013, 07:24 PM   #59
minger's Avatar
Weight reduction.
Zoom Zoom.
The Following User Says Thank You to minger For This Useful Post:
Alejo_NIN (04-29-2013)
 Old 04-28-2013, 07:09 AM   #60
why would I polish them? Or only get 2?
Cause it's gonna look nasty. Because slickz.
only gonna take like 50 hours though.
The Following User Says Thank You to Adam is so pro For This Useful Post:
djrich26 (11-05-2017)
 Old 04-29-2013, 07:47 AM   #61
Alejo_NIN's Avatar
Groans: 88
yea, why would you polish them,,,,i dunno...don't like it.
please don't be offended....
i understand the slicks parts, thats the only reason why i got the rx7 wheels for my protege as well..for track use.
radonelement.com
The Following User Says NO Thank You to Alejo_NIN For This Un-useful Post:
Adam is so pro (04-29-2013)
 Old 04-29-2013, 09:47 AM   #62
Why would I polish them?
Why would you buy the color wheels you have? Because you like them? Why would you drive a Mazda? Because you want to?
and because racecar.
The Following User Says NO Thank You to Adam is so pro For This Un-useful Post:
 Old 04-29-2013, 02:45 PM   #63
Alejo_NIN's Avatar
Groans: 88
why would you always answer with a question?
why would you not go to school?
why would you not grow up?
why would you not go kill yourself?
because fail-man
radonelement.com
 Old 04-29-2013, 02:57 PM   #64
Domino81's Avatar
Posts: 5,081   (View Stats)
Anyone got 2 they're willing to sell?
2008 CosmicBlue Mazdaspeed3
294whp/335wtq - Stock K04
370whp/370wtq - BNR stage 3
 Old 04-29-2013, 03:00 PM   #65
because fail-man
damn son u mad.
Alejo_NIN (04-30-2013)
 Old 05-15-2013, 10:55 AM   #66
minger's Avatar
Pics
What paint did you use? I did probably the worst thing and did rustoleum bright and cleared it, but the bright stuff you can't really ever touch it or wet sand or anything. Bad idea but came out okay enough...not great.
Zoom Zoom.
 Old 05-15-2013, 11:27 AM   #67
I used lowes valspar metallic paint. The color is classic bronze. They look awesome on a white car. I was gonna do gold but decided it would be too light of a color. I also did the front mazda badge in the same color. Debating doing the back ones or leaving them black.
Sent from my SPH-L710 using Tapatalk 2
Scott
 Old 05-15-2013, 02:12 PM   #68
minger's Avatar
Nice. I'm kicking myself for not painting the inside of the wheel or at least inside of the spokes - at extreme angles there is some silver or primer visible.
Zoom Zoom.
 Old 05-15-2013, 02:35 PM   #69
08cosmic3's Avatar
Just got in a set of RE-11's in 245/45-16 to mount on one of my FD sets. I'm almost certain I'll need at least 5mm spacers to clear the rear shocks, going to roll the rears also. Can't wait to see them bad boys on the car.
 Old 12-23-2013, 11:16 PM   #70
Mortose's Avatar
Posts: 2,441   (View Stats)
Groans: 39
Default Official RX7 FD Wheel Thread
Ok, so bit of a thread revival, but wanted to ask the folks who are already running these. I have a line on a ridiculous deal for fd's with tires and wanted to know if anyone is running these on coils and lowered? I'm going to pick up some 5mm spacers to assist, and roll the fenders, but I don't want to drop the cash if they aren't going to fit without some fairly in depth modification.
Please excuse the newb question. I'm on my phone, and it's a pain in the dick to search.
99 miata: sold
 Old 12-24-2013, 12:50 AM   #71
minger's Avatar
What? You...don't need to roll fenders (they're 16x8 +50), probably not even if you run the spacers. I'm lowered a bit on a gen2. They're stupid close to stock specs
Granted...I forgot I raised it back up a bit, but I'm on Mazdaspeed coils.
Plenty o space
Zoom Zoom.
Mortose (12-24-2013), MZRSPEED (12-24-2013)
 Old 12-24-2013, 09:34 AM   #72
08cosmic3's Avatar
Is the deal from a guy that used to live in TN? I was going to buy them but shipping would be too much. If he was still here I would have bought them. Maybe not the same guy.
I ended up not needing spacers or a roll.
 Old 12-24-2013, 09:55 AM   #73
Mortose's Avatar
Groans: 39
No it's a guy local to me. That's good. I was honestly worried just because of how close my current tires are now to the spring perch on the coils. I'm gunna pick them up regardless now, and just fit them to see if spacers are needed to clear the coils.
Thanks for the quick replies.
99 miata: sold
 Old 01-29-2014, 09:03 PM   #74
08cosmic3's Avatar
For those of you needing tires for your FD's check out this deal. While these tires rank below other Extreme tires for this price the are a steal. $75 a piece shipped.
4 New 225 50ZR16 inch Kumho Ecsta XS Tires 2255016 225 50 16 R16 50R | eBay
donjohnk (01-30-2014)
 Old 11-04-2017, 07:13 PM   #75
RusianKid's Avatar
Posts: 353   (View Stats)
RusianKid is the leader of the worldRusianKid is the leader of the worldRusianKid is the leader of the worldRusianKid is the leader of the worldRusianKid is the leader of the worldRusianKid is the leader of the worldRusianKid is the leader of the worldRusianKid is the leader of the worldRusianKid is the leader of the worldRusianKid is the leader of the worldRusianKid is the leader of the world
Just got some FD wheels for my winter setup!
"RACING IS AN ADDICTION CURED ONLY BY POVERTY"
RusianKid is offline   Reply With Quote
 Old 02-25-2018, 08:59 PM   #76
ACM210's Avatar
Posts: 1   (View Stats)
ACM210 is an unknown quantity at this point
What size tire?
ACM210 is offline   Reply With Quote
 Old 02-25-2018, 09:13 PM   #77
RusianKid's Avatar
Originally Posted by ACM210 View Post
What size tire?
245/50/16
The Following User Says Thank You to RusianKid For This Useful Post:
07mazzy3 (07-29-2018)
Official HID thread? supraman MazdaSpeed 3/6 - Appearance 22 03-23-2011 08:19 AM
Winter Wheel Thread ryandlor CX-7 > Wheels, Tires, Brakes & Suspension 9 12-29-2010 12:35 PM
Page generated in 0.60933 seconds with 33 queries
