| MazdaSpeed 3/6 - Wheels & Tires HaveMazdaSpeed 3 - Wheels & Tires - Have a question about wheels or tires? Need a calculator to figure out offsets? We have them in here |
![]() | | #41 | ![]() |
![]() Join Date: Dec 2013 Location: St. Louis
Rep Power: 0 ![]() ![]() Thanks: 4
| Not Ranked : 0 score Sent from my SGH-M919 using Tapatalk |
![]() | | #42 | ![]() |
![]() Join Date: Jun 2013
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
Groaned at 7 Times in 2 Posts
| Not Ranked : 0 score unknown im on lowered springs and i dont rub, 255/50/16 if i recall right...
__________________ 08 Speed3 Mods- Fully Built/ Wiseco pistons(stock bore)/Manley H-beams/Gtx3076 EWG/ All supporting bolt ons/ Tuned e juice Track times Stock turbo best 12.5@112mph with hoosier QTP Bnr S3 best 12.4@117mph with Mickey et streets |
![]() | | #43 | ![]() |
![]() Join Date: May 2008 Location: Stamford, CT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 243
__________________ |
![]() | | #44 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 26
| Not Ranked : 0 score Any ms6s running qtps? Sent from my Nexus 4 using Tapatalk |
![]() | | #45 | ![]() |
| Not Ranked : 0 score I don't think so, but the few with 700+ will need them or a radial. Going to start spinning and hurting their 60Ft Sent from your girlfriends tapabedroom
__________________ Precision 6466, Golden Eagle Sleeves, Headgames Motorworks Head Fastest ET: 11.776 @ 123.161(35r setup, 7000ft DA, 450hp uncorrected) 3M Matte Blue Metallic Wrapped 860whp/677wtq 2016 Ford F150, XLT, 4x4 Supercrew 2.7 V6 Ecoboost |
![]() | | #46 | ![]() |
![]() Join Date: Jun 2008 Location: Tucson, AZ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 752
Groaned at 9 Times in 7 Posts
Just tapa it in.
__________________ Wiseco OTS pistons, Eagle Rods, ARP mainstuds, JBR BSD w/ baffle,GT2871R, 51R battery, JBR V1 3.5 aluminum widepath, CP-e Catted DP, custom 3in cat-back, Treadstone TR8L core w/ COBB piping, Damond OCC, HKS SSQV3 (full VTA), autotech HPFP internals, Self tune 33% E85, Grimmspeed EBCS (3port), JBR TM & PM, TRZ Rmm, COBB short shifter, COBB Front/Rear swaybars, Koni STR.T struts, AXIS Circuits 18x8.5 45offset **Old Motor** Best 1/4 -13.19 Stock Turbo/ street tires Best trap speed - 112mph **New Motor** Best 1/4 - 13.35 Stock turbo/ street tires Best trap speed - 112.5 | |
| The Following User Says Thank You to udntknw For This Useful Post: | Voltron (04-28-2014) |
![]() | | #47 | ![]() |
| Not Ranked : 0 score a little? I have seen 600hp evo's/sti's here that spin badddd. Big difference with a radial or slick set up on awd. Ive seen certain cars here run 1.7-1.8 60 ft on street tires spinning and then when they switch to a radial/slick set up they were running 1.4-1.5's 2-3 tenth gain in a 60ft is HUGE.
![]() | | #48 | ![]() |
| Not Ranked : 0 score I didn't realize they were spinning that bad and street tires at lower numbers. Haven't seen much for compared 60' times with street vs drag tires. Just tapa it in.
![]() | | #49 | ![]() |
(Thread Starter) | Not Ranked : 0 score What kind of skinnies you guys running?
![]() | | #50 | ![]() |
| Not Ranked : 0 score 15x4 1.75 backspacing Sent from your girlfriends tapabedroom
| The Following User Says Thank You to PapaSmurf For This Useful Post: | MZRSPEED (04-25-2014) |
![]() | | #51 | ![]() |
(Thread Starter) | Not Ranked : 0 score oh wolla
![]() | | #52 | ![]() |
(Thread Starter) | Not Ranked : 0 score What tire pressure you guys running?
![]() | | #53 | ![]() |
| Not Ranked : 0 score whatever hooks the best for your car and weather situation. Ive tried anywhere from 8psi-16psi.
![]() | | #54 | ![]() |
| Hide Yo Kids-No really, Hide them! ![]() Join Date: Oct 2011 Location: PMITA Jail until 12/2015
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,515
Groans: 77
| Not Ranked : 0 score I think a little bit of spin for the awd guys are good. If they dead hook, shit is going to break fast. As for tire psi, it really all depends on the track. Ive tried from 6 to 12, and usually if I can get a nasty long burnout in, 11 seems to be magic number for me. |
| The Following 3 Users Say Thank You to Voltron For This Useful Post: |
![]() | | #55 | ![]() |
![]() | | #56 | ![]() |
| Not Ranked : 0 score OK, so I had the 26x9.5 qtps before on fd wheels , has anyone had something else on them that are better, wider or just different.
![]() | | #57 | ![]() |
![]() Join Date: Oct 2013 Location: Memphis
Rep Power: 0 ![]() ![]() Thanks: 22
| Not Ranked : 0 score Does anyone on here have experience with these tires on the track? Hankook Ventus TD Z221 Hard I can get them new for pretty cheap right now but not sure if I should go with these or Toyo R888. Its a difference of about $25 per tire. I will be running 235/45/17 for now. |
![]() | | #58 | ![]() |
![]() Join Date: Dec 2012 Location: Peterborough, ON
Rep Power: 0 ![]() ![]() ![]() ![]() Thanks: 6
| Not Ranked : 0 score 28×11.5×16 MT ET slicks. I found a sweet deal on them. Anyone use? Sent from my SGH-I337M using Tapatalk
__________________ CWP Pu. #gingerbuilt longblock, gtx3076r, self tuned on 94, 420whp, 408wtq. 2015 highest HP in Ontario. CWP Juan. Speed#2. The racecar. Rebuild commencing. |
![]() | | #59 | ![]() |
![]() Join Date: Apr 2013 Location: Wilkesboro, North Carolina
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,221
| Not Ranked : 0 score @tanspeed3; good luck getting those to fit.
__________________ 2013 CWP and Stock |
![]() | | #60 | ![]() |
![]() Join Date: Jan 2009 Location: Cleveland, OH
Rep Power: 3292 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,280
| Not Ranked : 0 score No luck needed. They will not even come close to fitting. |
| The Following User Says Thank You to Realgib3 For This Useful Post: | NCspecV81 (08-26-2015) |
![]() | | #61 | ![]() |
| Not Ranked : 0 score Ok I kinda figured that haha. Thanks boys! @ncspecv81 @realgib3 Sent from my SGH-I337M using Tapatalk
![]() | | #62 | ![]() |
![]() Join Date: Aug 2017 Location: North Carolina
Rep Power: 0 ![]() Thanks: 2
| Not Ranked : 0 score Bump Anyone know if my 26x9.5-16 Hoosier qtps from my evo will fit okay on the front of the gen1? On a 16x7 +40 Rota slip. The evo requires a 25mm spacer to clear the huge brakes.
__________________ 07 GT MS3 - TBD 06 SSL Evo 9 - 10.1 @ 149.9mph @Bmurray_evo9 |
| Slicks / Drag Radials | 9900rpm | 2010 MS3 - Wheels & Tires | 8 | 11-27-2009 03:42 PM |
| 15" slicks on your MS3? Would you like... | ptperformance | Mazdaspeed3/6 General Discussion | 19 | 01-25-2009 08:13 PM |
