| MazdaSpeed 3/6 - Wheels & Tires HaveMazdaSpeed 3 - Wheels & Tires - Have a question about wheels or tires? Need a calculator to figure out offsets? We have them in here |
![]() Join Date: Oct 2016 Location: West Virginia
Rep Power: 0 ![]() ![]() ![]() Thanks: 15
(Thread Starter) | Not Ranked : 0 score I was driving home after work and slowly accelerated. At 3k rpm my traction control kicks in for no reason, cuts power and the car shakes. I pulled over and checked for codes on my AP, nothing. I went back on the road with traction control turned off but the light stays on, and no issue? whats going on? Im thinking maybe some type of sensor? |
Rep Power: 3747 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,744
| If you push the traction control button to turn the system off, the TCS light should stay on. If you want us to diagnose your problems, then you're going to need to provide more than a three sentence squib that barely gives any indicia of a problem. You have an AP, why don't you datalog?
| The Following User Says Thank You to Vansquish For This Useful Post: | WetzMS3 (10-31-2016) |
| Not Ranked : 0 score Disconnect the connector in the steering column, the light will stay on, but you will never have traction control problems again :-)
__________________ Max Bolted and Built Stock K04 |
(Thread Starter) | Not Ranked : 0 score Sorry guys I'm new to the forums and I just bought the car. Sent from my Pixel XL using Tapatalk |
| ABS and traction control | andrew22888 | Mazdaspeed3/6 General Discussion | 55 | 03-07-2015 03:00 PM |
| Traction Control MS6 | hinkema1 | Mazdaspeed3/6 General Discussion | 14 | 10-16-2012 07:29 PM |
| Strange launch control interaction with traction control | fortressofcomfort | Gen2 MS3 General Discussion | 47 | 03-29-2012 08:41 AM |
| can't stop, ABS/Traction Control lights, no cruise control...vacuum leak? | btstarcher | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 13 | 06-17-2011 11:06 PM |
