Like Tree131Likes
 Old 08-16-2012, 08:06 PM   #321
smoogs12's Avatar
Posts: 7,731   (View Stats)
Groans: 423
Gonna be a tight fit to say the least.
Tapa
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
 Old 08-16-2012, 08:25 PM   #322
dastpe's Avatar
Posts: 1,644   (View Stats)
dastpe is the leader of the worlddastpe is the leader of the worlddastpe is the leader of the worlddastpe is the leader of the worlddastpe is the leader of the worlddastpe is the leader of the worlddastpe is the leader of the worlddastpe is the leader of the worlddastpe is the leader of the worlddastpe is the leader of the worlddastpe is the leader of the world
Originally Posted by KRNAGE View Post
Tell me about it. I'm checking fitment threads as I want to get on the rota grid 18x9.5 wagon so really want to be sure as no one around me has this setup for me to test fit to be 100%
Sent from my GT-I9100 using Tapatalk 2
can and has been done here in the states. run a 225 with 'natural camber' and a flat roll with a slight pull and grind the tab down and youll be golden.
dastpe is offline   Reply With Quote
The Following User Says Thank You to dastpe For This Useful Post:
KRNAGE (08-16-2012)
 Old 08-20-2012, 07:55 PM   #323
ericdebruyn1's Avatar
Posts: 344   (View Stats)
ericdebruyn1 is the leader of the worldericdebruyn1 is the leader of the worldericdebruyn1 is the leader of the worldericdebruyn1 is the leader of the worldericdebruyn1 is the leader of the worldericdebruyn1 is the leader of the worldericdebruyn1 is the leader of the worldericdebruyn1 is the leader of the worldericdebruyn1 is the leader of the worldericdebruyn1 is the leader of the worldericdebruyn1 is the leader of the world
Groaned at 43 Times in 17 Posts
WhAts the offset?
2008 cosmic blue, h&r lowering springs, koni struts,HKS intake, rx8 wheals,pump internals
v3 ap coming soon car got broken into and v2 got stolen
ericdebruyn1 is offline   Reply With Quote
 Old 08-20-2012, 08:05 PM   #324
MS3MYK's Avatar
Posts: 1,967   (View Stats)
Planning this set up:
17x8 +40 MB Weapons with 235/45 tire
CS springs and Koni yellows.
Would it work out?
Sent from my EVO LTE
2008.5 CWP Speed3 GT - SOLD /
1991 Ford Mustang LX 5.0 SSP
 Old 08-20-2012, 08:52 PM   #325
Would it work out?
that wold be sick
 Old 08-20-2012, 08:54 PM   #326
TazFc3s's Avatar
Posts: 184   (View Stats)
TazFc3s has a reputation beyond reputeTazFc3s has a reputation beyond reputeTazFc3s has a reputation beyond reputeTazFc3s has a reputation beyond reputeTazFc3s has a reputation beyond reputeTazFc3s has a reputation beyond reputeTazFc3s has a reputation beyond reputeTazFc3s has a reputation beyond reputeTazFc3s has a reputation beyond reputeTazFc3s has a reputation beyond reputeTazFc3s has a reputation beyond repute
Work CR KAI 18x9.5 +22 on 245/40? i figure a roll at least.... i have these on my rx8 and i am thinking about trading it in for a MS3 for the practicality of the wagon... thanks in advance
TazFc3s is offline   Reply With Quote
 Old 08-20-2012, 09:03 PM   #327
smoogs12's Avatar
Groans: 423
lol
Good luck fitting those. Would take a lot more than "a roll at least" to make it work.
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
 Old 08-20-2012, 09:24 PM   #328
TazFc3s's Avatar
lol
thanks i guess... would it have ridiculous poke?
 Old 08-20-2012, 09:35 PM   #329
dastpe's Avatar
get some fender flares if you want to fit those.
TazFc3s (08-20-2012)
 Old 08-20-2012, 09:45 PM   #330
smoogs12's Avatar
Groans: 423
Very much so.
Tapa
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
 Old 08-20-2012, 09:49 PM   #331
Sid3wayS's Avatar
Posts: 6,790   (View Stats)
Groans: 97
Figured I would ask since you guys know wtf you are talking about, Ive currently got 235/40s wrapped on 18x9.5 +38 rims. Ive got coilovers, 5mm spacers up front and I did a slight roll on the back, they fit great but the tires are a bit stretched, what do you guys suggest would be the widest tire I could fit on there. Id rather not pull the fender but wouldnt be against rolling it more. I basicly want the rim and tire to be even and not stretched.
TEAM LUXURY
 Old 08-20-2012, 09:52 PM   #332
TazFc3s's Avatar
well if i end up doing the trade ill be selling those wheels lol thanks
 Old 08-20-2012, 10:12 PM   #333
smoogs12's Avatar
Groans: 423
I feel like 245/40 wouldn't be a problem with what you are saying. How are all your clearances atm?
Tapa
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
Sid3wayS (08-20-2012)
 Old 08-20-2012, 10:30 PM   #334
Sid3wayS's Avatar
Groans: 97
Tapa
With out the slight fender roll I was scraping the very edge of the tire whenever I would hit a bump. Now after it, I can fit 4 nator heads in the car and only slighty scrape the fender on a large dip/bump, otherwise zero issues. Ive got about 1"1/2 gap between the fender and wheel. And my kw's are super skinny so they still have over an inch of room between wheel and strut when turned all the way.
TEAM LUXURY
 Old 08-20-2012, 10:35 PM   #335
smoogs12's Avatar
Groans: 423
Ok. Because with 245/40 you would gain like .30" of diameter or something like that, as well as loose the stretch. So fender clearance was my main concern. Feel like you would definitely want a flat roll. Are you against running more camber if need be? Not sure what you are at right now but that's another way to go about it.
Also section widths can vary from brand to brand. When you are dealing with fitment like this that's something to keep in mind.
Tapa
Sid3wayS likes this.
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
 Old 08-20-2012, 10:53 PM   #336
Sid3wayS's Avatar
Groans: 97
Tapa
Im not against it per say but do not want the crazy negative numbers that alot of the extreme guys run. Some slight tucking in I can live with. Im not 100% on what they are at now I have to look up my receipt from when I last had it alighned. By "flat roll" what do you mean? Like roll the fenders even more or in a specific manner?
TEAM LUXURY
 Old 08-20-2012, 10:59 PM   #337
smoogs12's Avatar
Groans: 423
Yeah just get the lip as flat as you can.
Tapa
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
 Old 08-20-2012, 11:13 PM   #338
Sid3wayS's Avatar
Groans: 97
Thanks for all the help man, I can build motors all day but when it comes to fitment, Im a total fucking newb lol
TEAM LUXURY
 Old 08-21-2012, 04:04 AM   #339
dastpe's Avatar
do you have the bumper tab ground down? a lot of guys think they are rubbing fender when in fact its the bumper tab. you also may want to slightly pull your fenders before your tires do it for you.
smoogs12 (08-21-2012)
 Old 08-21-2012, 04:07 AM   #340
smoogs12's Avatar
Groans: 423
Yep. No problem.
That's my opinion on it. See what @dastpe think about it.
Tapa
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
 Old 08-21-2012, 04:25 AM   #341
KRNAGE's Avatar
Posts: 120   (View Stats)
KRNAGE has a reputation beyond reputeKRNAGE has a reputation beyond reputeKRNAGE has a reputation beyond reputeKRNAGE has a reputation beyond reputeKRNAGE has a reputation beyond reputeKRNAGE has a reputation beyond reputeKRNAGE has a reputation beyond reputeKRNAGE has a reputation beyond reputeKRNAGE has a reputation beyond reputeKRNAGE has a reputation beyond reputeKRNAGE has a reputation beyond repute
Originally Posted by ericdebruyn1 View Post
WhAts the offset?
+38
from the aggressive thread, a spacer up front will be required with that offset.
06 Black MPS3 Sport Pack - Australia edition
Cobb AP (RichTune e85 / 98 maps) - Autotech HPFP Internals, JBR WP, CorkSport DP, Catback, Forge v1 BPV, Denso ITV22, PG FMIC Pipes JDM Core - TWM SS, PG Shift Weight, JBR Heavy Knob - JBR 88 Trilogy - JBR Rear Sway bar, Yellowspeed Coilovers, Centric Slotted/Drilled Rotors, Hawk HP+ pads, RX8 gen1 wheels - HTP Battery Tray - JBR EGR delete, JBR TB TIG - Spin-on oil convert - Polarised HU Screen
EXE-Crew
KRNAGE is offline   Reply With Quote
 Old 08-21-2012, 06:34 AM   #342
apawk's Avatar
Posts: 606   (View Stats)
apawk is the leader of the worldapawk is the leader of the worldapawk is the leader of the worldapawk is the leader of the worldapawk is the leader of the worldapawk is the leader of the worldapawk is the leader of the worldapawk is the leader of the worldapawk is the leader of the worldapawk is the leader of the worldapawk is the leader of the world
Groaned at 8 Times in 4 Posts
08 MS3 on Eibach PK - I want to get some new rims and i want them to be almost flush with fenders, just a touch inside ~2-3mm or so. I would greatly appreciate any input you guys can give me in order to make this happen. I am currently running 215/45s on my stockers and would like to run a 18x8/8.5 wheel with wider tires. Can anyone help me figure out exactly what size wheels/tires i would need to achieve my goal? I was looking at the XXR line and i like the 527s but +35 is out of the question for the simple fact that i dont want the wheels poking out past the fenders.
Thanks in advance for any input on my dilemma
2008 Sunlight Silver MS3 GT // Because racecar SOLD
Cobb AP || Autotech Internals || CP-e Safe Seals || Bosch 3Bar|| Godspeed FMIC with Godspeed piping || ATP catless downpipe || GT3076R || 3" HTP Intake/Inlet || Turbo Smart Dual Port running in 50/50 || SI Boost Tubes || JBR RMM 80a || JBR SSP || JBR Shifter Bushings || EGR Delete || Corksport LED Lighting || Apexi auto timer || Eibach PK || 18x8 Motegi SP10s || 225/40/18 Nitto NT555 || NGK 1 Step Colder plugs
Dynojet 7/6/2013 349.71whp 333lb tq
Dynojet 8/2/2013 378.26whp 384lb tq
Dynojet 8/31/2013 392.14whp 397lb tq
PERM Tuned by Alan and DJ
apawk is offline   Reply With Quote
 Old 08-21-2012, 10:38 AM   #343
dastpe's Avatar
18x8 ~+42 with 235/40
 Old 08-21-2012, 10:42 AM   #344
apawk's Avatar
Thank you for the response! So around 40 - 42 would be ok? I see several rims that i like with +35 offset but i am afraid of them being bull-frogged.
 Old 08-21-2012, 12:57 PM   #345
Sid3wayS's Avatar
Groans: 97
Yeah the member who had these rims before me had told me about that and I took off the top portion of them using a dremel. And by pulling you mean now or if I go up in size.
TEAM LUXURY
 Old 08-21-2012, 03:54 PM   #346
dastpe's Avatar
i would pull now personally, but just slightly. you can tell if you actually NEED a pull by looking to see if there is any paint on your tires and checking for burn marks on the inside of the fender. if either of those is there, get yourself a little pull. make sure to do it right and pull the whole quarter, dont just heat the fender and get that gay looking 3" flare of the fender.
Sid3wayS (08-21-2012)
 Old 08-30-2012, 03:32 PM   #347
memoriesmazda's Avatar
Posts: 157   (View Stats)
memoriesmazda has a reputation beyond reputememoriesmazda has a reputation beyond reputememoriesmazda has a reputation beyond reputememoriesmazda has a reputation beyond reputememoriesmazda has a reputation beyond reputememoriesmazda has a reputation beyond reputememoriesmazda has a reputation beyond reputememoriesmazda has a reputation beyond reputememoriesmazda has a reputation beyond reputememoriesmazda has a reputation beyond reputememoriesmazda has a reputation beyond repute
Was OMW home from class today and one of my stock tires totally exploded at about 25k miles on them. The rest are pretty much bald so i was going to go a head and by new Wheels and tires, From what I've read 18x8.5 44 offset on stock suspension should be fine, but i could use some advice on which tires work well for DD and if i should go 225 or 235. Was looking at these guys
18x8.5 Rota Grid - Hyper Black (5x114.3/e44/73) Wheeldude.com - Professional wheel dealer.
Cobb SRI ll Jbarone SSP ll CP-e 60 RRM ll UR Test Pipe ll Cobb Knob ll Cobb AP Running Stage 2 + SF ll Auto tech Internals
Coming Soon: ll UR Cat-back ll
memoriesmazda is offline   Reply With Quote
 Old 08-30-2012, 04:17 PM   #348
dastpe's Avatar
235/40. tirerack reviews for our cars are your best bet. tires depends way too much on personal preference and goals for the car and price range.
smoogs12 (08-30-2012)
 Old 08-30-2012, 05:03 PM   #349
cchiang89's Avatar
Posts: 55   (View Stats)
cchiang89 is a splendid one to beholdcchiang89 is a splendid one to beholdcchiang89 is a splendid one to beholdcchiang89 is a splendid one to beholdcchiang89 is a splendid one to beholdcchiang89 is a splendid one to behold
Groaned at 6 Times in 2 Posts
Got a question boys. I drive a 2012 Genpu and I'm looking for a winter set up. I've done my research on the forums and I've decided to go with 205/60R16. I know the biggest issue with 16s is clearing the calipers. I have found 16"x6.5" rims and my question is... how much of an impact will the offset have in terms fit? I can get an offset of 40 mm or 45 mm. The guy in this thread R32 GTS-T Wheels, winter test fit! managed to fit his 16s that had an offset of 40. Would 45 be better in terms of clearing the calipers? Or does offset really only impact how flush the tire is with the body of the car.
cchiang89 is offline   Reply With Quote
 Old 09-03-2012, 09:03 PM   #350
naoandlater's Avatar
Posts: 655   (View Stats)
Glad you didn't do it because they would poke out like crazy. I just got some CR Kai's from a buddy that were on his old evo. Tried the 17x9 +28 wrapped in 255/40/17 start specs lowered on h&r springs with rears rolled . I also have +17 rims too, which I can't imagine how much more poke there will be...Going to figure if I should keep these things.
15 Soul Red Mazda3s GT HB
 Old 09-03-2012, 09:17 PM   #351
smoogs12's Avatar
Groans: 423
Wow...that's bad
Tapa
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
naoandlater (09-05-2012)
 Old 09-05-2012, 12:06 AM   #352
ms3daily's Avatar
Posts: 8   (View Stats)
ms3daily is an unknown quantity at this point
Would 255/40/17 with the enkei rpf1 17x9 with 45mm offset fit on stock suspension for GenPu?
ms3daily is offline   Reply With Quote
 Old 09-05-2012, 11:18 AM   #353
cabrone's Avatar
Posts: 529   (View Stats)
cabrone is the leader of the worldcabrone is the leader of the worldcabrone is the leader of the worldcabrone is the leader of the worldcabrone is the leader of the worldcabrone is the leader of the worldcabrone is the leader of the worldcabrone is the leader of the worldcabrone is the leader of the worldcabrone is the leader of the worldcabrone is the leader of the world
My friend has a set of nt03s for cheap. They are 17x8 +38. I'd planned on going 17x9 and sticking with stock suspension like I've seen on Goodwin racing. I'm on stock suspension and plan to stay that way. Will it look like a monster truck on my gen 1? Not sure about the tires he has with them yet. Thanks for the reply.
08.5 CWP MS3 GT
AP Stage 2 S-OTS+ | Cobb Catted DP | Magnaflow CBE | JBR SRI | Cobb TIP | JBR 70 Duro RMM |NGK Iridiums | Autotech Internals | Lamin-X Yellow Fog Overlays
cabrone is offline   Reply With Quote
 Old 09-05-2012, 12:07 PM   #354
smoogs12's Avatar
Groans: 423
225/45 would give the best fitment.
235/45 would give you closest to stock diameter.
You'll want to roll fenders either way though.
Tapa
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
cabrone (09-17-2012)
 Old 09-05-2012, 03:02 PM   #355
franz's Avatar
Posts: 1,258   (View Stats)
franz is the leader of the worldfranz is the leader of the worldfranz is the leader of the worldfranz is the leader of the worldfranz is the leader of the worldfranz is the leader of the worldfranz is the leader of the worldfranz is the leader of the worldfranz is the leader of the worldfranz is the leader of the worldfranz is the leader of the world
I have a set of 16x7.5" 40mm offset rims for my winter setup. They fit great and I got them cheap on craigslist.
Regarding offset, on the same width rim, lower offset will push the rim farther away from the caliper. You can plug some values into this calculator to see where the rim will sit.
That being said, if I had to do it all again I would get 215/50-17 or 225/50-17. We dont usually have a ton of snow up here so the extra width and less sidewall will be a better all around winter setup than the 16" and 205s.
2007 MS3 Black Mica. Stock. 235whp/244wtq Dynojet
FREEKtuned 277/316 Dynojet
Corksport SRI/TIP/FMIC/GFB BPV/AT Internals/EBCS/Gutted 2nd Cat
Bilstein B8/Swift Spec-R/ST120s/Nitto 555
JBR 70dur. RMM-TMM-PMM/SSP+Bushings/TIGs/OCC
franz is offline   Reply With Quote
The Following User Says Thank You to franz For This Useful Post:
cchiang89 (09-05-2012)
 Old 09-10-2012, 10:00 AM   #356
Haggis3's Avatar
Posts: 23   (View Stats)
Haggis3 has much to be proud ofHaggis3 has much to be proud ofHaggis3 has much to be proud ofHaggis3 has much to be proud ofHaggis3 has much to be proud ofHaggis3 has much to be proud ofHaggis3 has much to be proud ofHaggis3 has much to be proud ofHaggis3 has much to be proud of
Default 17" wheels & stock suspension: maximum width tire?
I'm looking for track wheels & tires and am considering 17x8.5 wheels, with 245/45x17 NT-01s.
  1. How much of a roll would I need for this?
  2. I'm thinking spacers will be required up front: is 3mm enough?
  3. Can I go wider (255/40x17?) without a pull?
This is for a 2007 Gen 1.
Edit: realised this question is useless without a wheel offset! Doh! I'll come back with one soon....
Thx
Haggis3 is offline   Reply With Quote
 Old 09-11-2012, 05:30 AM   #357
Bobforapples's Avatar
Posts: 219   (View Stats)
Bobforapples has a reputation beyond reputeBobforapples has a reputation beyond reputeBobforapples has a reputation beyond reputeBobforapples has a reputation beyond reputeBobforapples has a reputation beyond reputeBobforapples has a reputation beyond reputeBobforapples has a reputation beyond reputeBobforapples has a reputation beyond reputeBobforapples has a reputation beyond reputeBobforapples has a reputation beyond reputeBobforapples has a reputation beyond repute
Just got my Speed3 genwon and wondering if this setup would work on stock suspension without a roll.
Motegi Sp-10 18x8 +40 wrapped in KDW 2's 235/40-18.
Thanks for the help.
Bobforapples is offline   Reply With Quote
 Old 09-11-2012, 06:54 AM   #358
apawk's Avatar
LOL! I guess i will let you know Wednesday... I ordered the Hyper Black SP10s +40 with 235/40s ... They came in yesterday!!!!! Beautiful rim! I'm on Eibach PK lowered almost an inch. I'm going the trial and error way
BTW: Good choice on rims... i effing love the way they look!!!
Thx
Really glad you edited this one I was going to have to for no wheel offset
Last edited by apawk; 09-11-2012 at 06:54 AM. Reason: MSF Database - Automerged Doublepost
 Old 09-15-2012, 09:15 AM   #359
Haggis3's Avatar
Thx
Trying again....this time with a wheel offset!
So....will a 17x8 ET 45 (Konig Lace) with 245/40R-17 (Kumho Ecsta XS) work with stock suspension?
Will I need a roll & if so how aggressive?
Thx
 Old 09-15-2012, 09:19 AM   #360
anavrinIV's Avatar
Posts: 4,490   (View Stats)
Groans: 63
Thx
If you put konig laces on your car I will find you and murder you. I'm fucking serious, they are ugly ugly wheel on anything.
that size will fit but you'll definitely need at least a roll. And don't do laces.
Blue Pu.
smoogs12 (09-15-2012)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f319/ultimate-will-they-fit-thread-everything-you-101473/
rustysurfsa comments on Wheel spacers? This thread Refback 02-04-2015 03:02 PM
Wheel spacers? : mazda This thread Refback 02-04-2015 12:36 PM
Tire and Wheel replacement - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 11-20-2014 04:07 PM
The Ultimate "Will They Fit" Thread - Everything you need to know about wheels, spacers and tires for your MS - Mazdaspeed Forums This thread Refback 11-07-2014 10:15 AM
Spacers This thread Refback 09-25-2014 11:53 PM
Mazdaspeed Wheel Spacers - AE Autos This thread Refback 08-14-2014 11:42 AM
Bbs c5-s This thread Pingback 08-11-2014 12:43 AM
Pic Request Thread, No Photoshops - Page 217 - Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum This thread Refback 02-05-2014 12:52 AM
Pic Request Thread, No Photoshops - Page 145 - Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum This thread Refback 01-12-2014 07:19 PM
Pic Request Thread, No Photoshops - Page 111 - Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum This thread Refback 01-09-2014 04:29 PM
Pic Request Thread, No Photoshops - Page 107 - Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum This thread Refback 12-18-2013 09:19 PM
Pic Request Thread, No Photoshops - Page 214 - Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum This thread Refback 12-14-2013 12:18 PM
Pic Request Thread, No Photoshops - Page 182 - Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum This thread Refback 12-09-2013 01:28 PM
Pic Request Thread, No Photoshops - Page 216 - Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum This thread Refback 12-04-2013 07:41 PM
Pic Request Thread, No Photoshops - Page 200 - Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum This thread Refback 11-19-2013 09:00 AM
Tires & Rims Spec Questions! - Mazda3Club.com This thread Refback 11-12-2013 05:31 PM
My New(used) Car - Mazda3Club.com This thread Refback 09-16-2013 10:44 AM
Pic Request Thread, No Photoshops - Page 11 - Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum This thread Refback 09-03-2013 06:38 AM
Pic Request Thread, No Photoshops - Page 5 - Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum This thread Refback 08-06-2013 08:39 AM
Pic Request Thread, No Photoshops - Page 213 - Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum This thread Refback 05-25-2013 12:26 AM
Pic Request Thread, No Photoshops - Page 211 - Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum This thread Refback 05-10-2013 01:01 AM
Post Your Rims Here! - Page 54 This thread Refback 04-15-2013 04:11 PM
Pic Request Thread, No Photoshops - Page 4 - Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum This thread Refback 03-28-2013 11:37 AM
Pic Request Thread, No Photoshops - Page 174 - Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum This thread Refback 03-17-2013 02:44 AM
Pic Request Thread, No Photoshops - Page 204 - Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum This thread Refback 03-14-2013 03:13 PM
Pic Request Thread, No Photoshops - Page 210 - Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum This thread Refback 01-19-2013 07:57 PM
Pic Request Thread, No Photoshops - Page 2 - Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum This thread Refback 12-18-2012 08:24 PM
Pic Request Thread, No Photoshops - Page 171 - Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum This thread Refback 12-06-2012 07:37 PM
Pic Request Thread, No Photoshops - Page 83 - Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum This thread Refback 12-03-2012 03:41 AM
Pic Request Thread, No Photoshops - Page 14 - Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum This thread Refback 11-26-2012 01:57 PM
Decision made for wheels This thread Refback 10-20-2012 07:58 AM
Forum Mazda Performance Series - Zobacz temat - [S] Nowe oryginalne felgi Mazda 18" This thread Refback 10-15-2012 04:23 PM
Pic Request Thread, No Photoshops - Page 147 - Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum This thread Refback 09-29-2012 08:46 AM
Pic Request Thread, No Photoshops - Page 202 - Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum This thread Refback 09-14-2012 02:08 PM
Pic Request Thread, No Photoshops - Page 20 - Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum This thread Refback 08-06-2012 02:45 AM
Pic Request Thread, No Photoshops - Page 109 - Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum This thread Refback 08-01-2012 02:38 AM
Pic Request Thread, No Photoshops - Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum This thread Refback 07-23-2012 12:55 AM
Pic Request Thread, No Photoshops - Page 207 - Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum This thread Refback 07-22-2012 09:55 AM
Pic Request Thread, No Photoshops - Page 87 - Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum This thread Refback 07-12-2012 03:02 PM
Pic Request Thread, No Photoshops - Page 21 - Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum This thread Refback 07-03-2012 11:33 PM
Pic Request Thread, No Photoshops - Page 196 - Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum This thread Refback 06-19-2012 10:21 PM
Pic Request Thread, No Photoshops - Page 49 - Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum This thread Refback 05-21-2012 09:47 PM
Weight of OEM 18" wheels/tires on 2010 MS3 Driver72 2010 MS3 - Wheels & Tires 19 11-14-2009 09:43 AM
Separate "Appearance" from "Wheels/Tires" KaiserSoze Website Help/Feedback 1 04-21-2008 08:33 PM
Page generated in 0.63662 seconds with 37 queries
