  • 2 Post By Vansquish
 Old 09-28-2009, 06:14 PM   #1
Team Überfrazn
labikesrcool's Avatar
Posts: 782   (View Stats)
labikesrcool is the leader of the worldlabikesrcool is the leader of the worldlabikesrcool is the leader of the worldlabikesrcool is the leader of the worldlabikesrcool is the leader of the worldlabikesrcool is the leader of the worldlabikesrcool is the leader of the worldlabikesrcool is the leader of the worldlabikesrcool is the leader of the worldlabikesrcool is the leader of the worldlabikesrcool is the leader of the world
Default weird tire wear pattern. stock tires. stock rim. stock suspention. stock tire pressure what's up with this?
so first off i realize that these tires are extremely wore and illegal and whatnot. i drove a different car when it rained. i was trying to get to winter and have failed. i am not necessarily disappointed in the 35000 miles i have gotten out of these. I check tire pressure every week and inflate them to stock door 34front 32back.
i have weird tire wear on the insides of some of my tires. one has worn to the point of ripping and starting to delaminate on the inside. here are some pictures of the tire.
other tires.
so does anybody know what's going on? they look similar to this guys tires.
http://www.mazdaspeedforum.org/forum/foru...ls-susp-36756/
but he had bigger tires. these are stock.
it seems like stock tire pressures are a bit low.
from what i've read this may be too much toe out?
needless to say i'm getting new tires. any suggestions? there are some Hankook Ventus R-S2's on tirerack for 85bucks a tire on closeout. the reviews aren't awesome but does anybody here have any experience with them? any other suggest tires?
"My car won't start!"
"Well, maybe there's a killer after you."-Mitch Hedberg
I know a lot about cars. I can look at a car's headlights and tell you exactly which way it's coming.
- Mitch Hedberg
labikesrcool is offline   Reply With Quote
Best tire to use at the track on stock rim speed_3 MazdaSpeed 3/6 - Wheels & Tires 2 08-15-2009 11:11 AM
Max tire size on stock MS6 kbee00 MazdaSpeed 3/6 - Wheels & Tires 4 06-02-2009 04:37 PM
How long before stock tires wear down? Zeya MazdaSpeed 3/6 - Wheels & Tires 31 08-08-2008 09:37 PM
Page generated in 0.42802 seconds with 35 queries
