 Old 06-13-2016, 09:01 PM   #1
bitbandit's Avatar
Posts: 42   (View Stats)
bitbandit is a glorious beacon of lightbitbandit is a glorious beacon of lightbitbandit is a glorious beacon of lightbitbandit is a glorious beacon of lightbitbandit is a glorious beacon of light
Default Wheel stud question
Do you guys think its safe to reuse these wheel studs?
Bought a new MS6 and the studs were A1 top condition as you can see. Just got done putting all new studs in. It was a sketchy hour drive home with only two to three lugs holding each rear wheel on. The front was a good three to four holding them on.
I should add that the car came with another set of wheels and they had bad tires on them. I had to put my wheels and tires from my wrecked MS6 on to get it home.
06 MS6 - Totaled
07 MS6 - Sure intake, Cobb AP, CS Turbo, CS Turbo Back Exhaust, CS HPFP Internals, CS TMIC, CS BPV, CS EBCS and Both Sure rear diff mounts.
bitbandit is offline   Reply With Quote
 Old 06-14-2016, 05:12 AM   #2
KiwiFlavor's Avatar
Posts: 2,447   (View Stats)
Why are those 4 studs shorter than the rest?
2012 NASA Spaceship Gray MS3
 Old 06-14-2016, 05:18 AM   #3
anavrinIV's Avatar
Posts: 4,490   (View Stats)
Groans: 63
I believe those have sheared
Is this a serious question? Because it can't be a serious question. The ones that are the proper length and not stripped could be reused if lugnuts will properly thread onto them....but I wouldn't bother
Blue Pu.
The Following 2 Users Say Thank You to anavrinIV For This Useful Post:
Crarrs (06-14-2016), KiwiFlavor (06-14-2016)
 Old 06-14-2016, 05:19 AM   #4
KiwiFlavor's Avatar
Ah i see!
Lol. OP just buy new ones dude. Better to shell out $50 for a set than tens of thousands of dollars to fix your car, call an ambulance, and your surgery.
 Old 06-14-2016, 05:34 AM   #5
TiGraySpeed6's Avatar
Posts: 3,981   (View Stats)
Wow are those totally jacked up.... (wheel humor there.... )
How was it installing the replacement studs? They go in nice & tight? I'd hate to think you had to replace hubs also, but things like that are, to me at least, indicative of how your cars PO handled, well, everything....
I'd look that car over pretty damn closely!
340hp / 371tq
 Old 06-14-2016, 06:17 AM   #6
Stingray69's Avatar
Posts: 1,197   (View Stats)
Stingray69 is the leader of the worldStingray69 is the leader of the worldStingray69 is the leader of the worldStingray69 is the leader of the worldStingray69 is the leader of the worldStingray69 is the leader of the worldStingray69 is the leader of the worldStingray69 is the leader of the worldStingray69 is the leader of the worldStingray69 is the leader of the worldStingray69 is the leader of the world
Groans: 48
Groaned at 49 Times in 30 Posts
Ah i see!
This............they are cheap and oh yeah they hold the wheels on.
AP, Corksport SRI/TIP, MD OCC, Autotech internals, CPE stage 2 RMM
Stingray69 is offline   Reply With Quote
The Following User Says Thank You to Stingray69 For This Useful Post:
 Old 06-14-2016, 06:19 AM   #7
KiwiFlavor's Avatar
<------ Reading fail. OP did put new studs in. OP just throw all those junk studs away.
 Old 06-14-2016, 07:02 AM   #8
bitbandit's Avatar
Yeah, these were tossed after i took the picture.
I was just being dumb and seeing what kind of reactions I would get. Hopefully it gave you guys a good chuckle.
06 MS6 - Totaled
The Following User Says Thank You to bitbandit For This Useful Post:
 Old 06-14-2016, 07:10 AM   #9
KiwiFlavor's Avatar
Be thankful this place is not like how it used to be.. Or else, prepare your anus. Lol
kgb (09-16-2016)
 Old 06-14-2016, 07:17 AM   #10
bitbandit's Avatar
Be thankful this place is not like how it used to be.. Or else, prepare your anis. Lol
I have noticed its gotten a lot more easy going around here the last few months.
06 MS6 - Totaled
Wheel/Lug Nut Stud Extensions Craig Foos MazdaSpeed 3 - How-To's 1 04-10-2016 10:39 AM
rear wheel stud install TrueReddd MazdaSpeed 3/6 - Suspension & Brakes 14 06-11-2015 08:59 PM
Wheel stud ABOSWORTH 2010 MS3 - Wheels & Tires 9 04-09-2014 04:54 PM
WHEEL STUD RELACEMENT Realgib3 MazdaSpeed 3/6 - Wheels & Tires 2 05-23-2009 08:25 PM
Wheel stud replacement xcoldricex MazdaSpeed 3/6 - Wheels & Tires 0 05-02-2009 07:46 PM
Page generated in 0.29486 seconds with 25 queries
