| MazdaSpeed 3 - How-To's MazdaSpeed 3 - How-To's - Want help out fellow owners? Post How-To's to simplify future installations for others. |
![]() Join Date: Dec 2018
Rep Power: 0 ![]() Thanks: 0
![]() Join Date: Aug 2018 Location: NYC
Rep Power: 0 ![]() Thanks: 3
| Not Ranked : 0 score Do you hear the noise just driving and stepping on gas or right after shifting? specifically when releasing the clutch pedal/getting on the throttle. My car makes a metal noise when I release the clutch and "step" the gas, after shifting into 2,3, and sometimes 4. Unless I do everything extra slow/smooth. From what I've read here so far these cars tend to shift loud. I'm pretty new to MS3. Had mine for just a few month and my non speed 6-speed manual 3 hatch never made that sound so I'm still kinda weary of it. |
Groans: 60
| Not Ranked : 0 score Have you looked at the actual firewall and pedal assembly? Ive seen more than a few that cracked.
(Thread Starter) | Not Ranked : 0 score Yeah or if I’m in 2nd and gun it it’ll do that weird metal on metal or “cracking” noise if you will then I’ll go to 3rd and like you said the second I release clutch and gas it’ll do it, but if I go slow and smooth I’m chillin, sounds like we have the same thing. I had also had my speed for a month P.s. not sure if I replied right, still new to the threads |
(Thread Starter) | Not Ranked : 0 score It’s neither of those, idk how to explain other than the way I did, once almost any gear I’m in if I smash the pedal as opposed to gradually increasing I just hear cracks or pops or like 2-4 quick knocks from it seems like the front left side but if I start in and 2nd and make my way up flying down the highway it’ll pop til I’m cruising in 5th |
| Not Ranked : 0 score Well I've been daily driving mine pretty extensively for these few months since I bought it (in NYC traffic no less so I shift very often) and aside from it being annoying I haven't really seen/felt issues. From what I've read here it seems like these cars have some loud ass throwout bearings and that would fit with this type of noise. It does sound like it could be it (at least on my car). I've actually been hearing it less after getting more used to shifting/driving this car. So I'm leaning towards it being normal. But not having much experience with this specific car I still makes me uncomfortable hearing it since it doesn't sound like something you'd want to hear in your car, and for all I know it could be that. But so far my research and lack of issues seem to point to it not being anything bad. Only thing is that you said you also get it when gunning it in second, and I have't gotten it outside of releasing the clutch/getting on throttle after shifting. So you might have something else happening there also. |
| Not Ranked : 0 score Could it possibly be a worn axle?
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 549
| Not Ranked : 0 score Inspect the control arm bushings?
__________________ Stockish |
(Thread Starter) | Not Ranked : 0 score No they aren’t perfect I spent quite a bit fixing all the suspension Bc that’s exactly what I thought it was
That may be it but the rattling is only when I accelerate, I thought worn bushings rattled almost constantly Last edited by Dossantosms3; 12-19-2018 at 04:22 PM. Reason: MSF Database - Automerged Doublepost | ||
| High Pitched Metal-On-Metal Noise | Spid3r | 2010 MS3 - Troubleshoot/Diagnostics | 10 | 06-01-2016 04:21 PM |
| Gun metal Evo X wheels on MS6 | Waltzy | Wheels & Tires - WHITE | 18 | 01-27-2011 08:35 PM |
