> MazdaSpeed 3 - How-To's
Like Tree8Likes
 Old 09-09-2008, 12:05 AM   #1
CraigHJr's Avatar
Posts: 676   (View Stats)
CraigHJr is the leader of the worldCraigHJr is the leader of the worldCraigHJr is the leader of the worldCraigHJr is the leader of the worldCraigHJr is the leader of the worldCraigHJr is the leader of the worldCraigHJr is the leader of the worldCraigHJr is the leader of the worldCraigHJr is the leader of the worldCraigHJr is the leader of the worldCraigHJr is the leader of the world
Neutral  :  +3 score
Default CDFP internals upgrade
I tackled a Speed 3 CDFP build at the CP-E/PG/DC meet last weekend and found it to be very simple. The following write up is hopefully going to help a bunch of you guys out and save you a ton of cash. Thank knyghtryda for the pictures, Darksun280 for the pump/donor Speed3, mrlilguy157 for the internals and info, and lastly me CraigHJR if the car runs afterwards.
Tools; E8 inverted torx, 17&19mm open end wrenches, one zip tie, 18mm deep 3/8” socket and long handle ratchet, bench vice with soft jaws and possibly a second set of hands, needle nose pliers, misc 10mm wrenches and sockets.
Start with the car cold preferably.Remove the smaller blue relay in the under hood fuse box that says “circuit“.
Start the car and it should die when the fuel pressure runs low in 10 seconds. (if not the car being cold means the gas can't really catch fire though it will spray out at high pressure)Remove the entire battery box/ecu and turbo inlet hose if you want to make things easier for your self.
Locate the solid steel line under the CDFP and put a zip tie an inch under the 19mm nut.
This keeps the nut from wandering too far down the line.
Remove the 2 upper fuel lines and electrical connector.
The yellow clip hugs the plastic and has to be opened on both sides while slid out.
The blue clip has a twist motion to release the line.
Simultaneously use the 17mm open end to hold the lower base of the CDFP (this CAN NOT SPIN!!!) and the 19mm to break the nut loose (it will spin off easily once broken loose).
Use the E8 inverted torx to remove the 3 screws (back them out evenly as to not cock the spring loaded pump mechanism).
I will say that all that was the hard part and things will be easier from here on out.We are starting with this.
First pull the spring and stock plunger straight out of the pump. This is the stock plunger (left) and upgrade internals and stock spring(right).
Now support the pump in the bench vice a grab a buddy to steady this thing. Be careful of your lines and sealing surfaces against the vice. Remove the 18mm nut that is now exposed where the spring came off. Righty tighty and lefty loosey.
Here you see the 18mm nut assembly removed.
Now gently use needle nose pliers to lift the stock piston out. Notice the small shoulder and large shoulder on the piston. The large side points out towards you.
Now dip all the reused and new parts in gasoline this works as a solvent to remove any debris. Lightly oil the moving parts and then slide the upgrade piston and shaft into the 18mm cap. The small end with the retainer groove will be outside the pump. It is unclear if the internals come with the pistons on the shafts already but make sure yours looks like pictured in the first steps above before forcing anything together.
With your finger push the shaft to reveal as much of the retainer groove side through the 18mm nut.
Now slide the spring over the external side of the shaft and seat it on the grove it originally came off of. The spring retainer goes on next with the centering dish going into the spring. Put on the 2 retainer halves and balance everything. Push the retiner end into the assembly jamming the retainer into the spring retainer. The spring is now centered and assembled like pictured below.
Make sure no foreign objects fell into your pump and begin to screw the assembled spring and piston assembly into the pump housing by hand.
Once your confident the threads are engaged properly put that deep 18mm over the whole spring and tighten her down. I was not given a spec for this but it is very tight to remove so make it very tight. Again beware of the o-ring, fuel lines and now spring sticking up into the socket. I would say the pump is ready for reinstallation now. Put some fresh oil on the tip of the spring side that rides the camshaft and the o-ring. Use the 3 E-8’s to evenly and slowly draw the pump onto the head. Also be careful to not bend or mutilate the threads on the 17/19 mm stuff underneath by slightly wiggling the steel line downward to allow an even seating as the pump nears its final installed position. Make sure to hold the 17 and do not allow it to spin at all while putting the 19mm nut on. Do not cross thread the 19mm it will spin on freely by hand until the very last ½ turn.
If you made it this far I hope you can put everything else back together paying special attention to the turbo inlet hose being tightened down properly to the turbo.
You should disable the coil packs to allow the engine to crank and build up fuel pressure slightly before you just start the car up. There is a black or gray connector right next to the coil on cylinder 4 that will disconnect them all. If all is well you will be up and running now. If not you probably have a lot of noise and a lean condition which will lead you to be sitting in the same spot as Randy!!!
CraigHJr is offline   Reply With Quote
The Following 73 Users Say Thank You to CraigHJr For This Useful Post:
08_ms3_gt (04-13-2010), 3mazdaspeed (01-09-2011), 94jedi (06-09-2009), aaronc7 (09-09-2008), Arnie1229 (01-13-2015), ATAZ (12-27-2009), atenza_freak (12-27-2009), Axel907 (01-16-2013), badams118 (10-29-2008), BobtailedSnail (04-10-2012), Broxer (08-25-2011), ChrisK (09-09-2008), Dahouse702 (08-29-2011), Darksun280 (09-09-2008), dead-zone (04-27-2012), dimaxxxl (09-09-2008), Docnox (02-09-2012), Domino81 (01-13-2012), dougefresh_ (04-04-2010), dread (01-03-2009), EddyV1987 (08-06-2012), ELiTeNeSs (12-26-2011), eljefe62 (05-26-2012), EvilSpeed3 (04-25-2009), fishin53 (01-10-2011), galens47 (02-04-2014), ganque (04-19-2011), Gibbo (08-20-2013), Grim (09-09-2008), gsrtype1 (10-06-2008), Hamilton69 (07-26-2011), indianaryan (03-16-2011), karl-hungus (08-15-2009), kgb (12-11-2009), kingbird72 (05-21-2012), kingpin748 (09-10-2008), labikesrcool (09-21-2008), Lymerock (09-09-2008), magicka (01-25-2013), MazdaSpeed3NY (08-26-2012), meelo88 (02-02-2011), mituc (11-21-2010), ms3077 (01-01-2010), MS6FL (12-09-2011), nindoja (07-01-2011), NoTraction (04-14-2011), phantomspeed3 (05-27-2009), PunjabiPlaya (03-05-2011), randallrus (02-10-2012), redmnsterut (01-13-2012), Roszko (09-06-2011), Scynfewl (02-16-2011), Shenanigans (12-20-2008), Sid3wayS (11-26-2011), Sines (07-02-2012), Skyman88 (03-08-2014), SpdDemon89 (05-26-2012), speed23 (12-15-2011), Speed3eak (02-03-2011), Stan-O (01-28-2009), steven88 (07-18-2009), superskaterxes (09-09-2008), sweetpickles (09-09-2008), TexasSpeed3 (08-09-2011), TheFlash (11-14-2012), tigermack (04-13-2011), tragik (08-19-2011), Twofer (12-02-2012), VRMSPD6 (12-24-2010), WhiteWidow (01-17-2014), willix231 (01-09-2013), Z3roFlaw (05-30-2011), zpele (06-03-2011)
 Old 09-09-2008, 12:45 AM   #2
sweetpickles's Avatar
Posts: 375   (View Stats)
sweetpickles is the leader of the worldsweetpickles is the leader of the worldsweetpickles is the leader of the worldsweetpickles is the leader of the worldsweetpickles is the leader of the worldsweetpickles is the leader of the worldsweetpickles is the leader of the worldsweetpickles is the leader of the worldsweetpickles is the leader of the worldsweetpickles is the leader of the worldsweetpickles is the leader of the world
Awesome! Appreciate the writeup!
calidad likes this.
sweetpickles is offline   Reply With Quote
 Old 09-09-2008, 07:27 AM   #3
Grim's Avatar
Posts: 2,395   (View Stats)
Groans: 70
Sticky!
Grim is offline   Reply With Quote
 Old 09-09-2008, 08:14 AM   #4
Lymerock's Avatar
Posts: 1,436   (View Stats)
Lymerock is the leader of the worldLymerock is the leader of the worldLymerock is the leader of the worldLymerock is the leader of the worldLymerock is the leader of the worldLymerock is the leader of the worldLymerock is the leader of the worldLymerock is the leader of the worldLymerock is the leader of the worldLymerock is the leader of the worldLymerock is the leader of the world
this will come in handy in the near future
thanks!
Lymerock is offline   Reply With Quote
 Old 09-09-2008, 08:18 AM   #5
CraigHJr's Avatar
The six how-to section is seperate should I post it in there too? I am thinking about posting it up on the other forums as well, I know this place isn't always easy to find. It should be a sticky because I followed the rules and wrote how-to do something and didn't ask a how-do question in this section!!! Is there any way that both 3 and 6 sections could go to the same write up to prevent questions being repeatedly asked?
 Old 09-09-2008, 08:28 AM   #6
dimaxxxl's Avatar
Posts: 397   (View Stats)
dimaxxxl is the leader of the worlddimaxxxl is the leader of the worlddimaxxxl is the leader of the worlddimaxxxl is the leader of the worlddimaxxxl is the leader of the worlddimaxxxl is the leader of the worlddimaxxxl is the leader of the worlddimaxxxl is the leader of the worlddimaxxxl is the leader of the worlddimaxxxl is the leader of the worlddimaxxxl is the leader of the world
great write up!!!
dimaxxxl is offline   Reply With Quote
 Old 09-09-2008, 08:58 AM   #7
numbnuts22715's Avatar
Posts: 904   (View Stats)
numbnuts22715 is the leader of the worldnumbnuts22715 is the leader of the worldnumbnuts22715 is the leader of the worldnumbnuts22715 is the leader of the worldnumbnuts22715 is the leader of the worldnumbnuts22715 is the leader of the worldnumbnuts22715 is the leader of the worldnumbnuts22715 is the leader of the worldnumbnuts22715 is the leader of the worldnumbnuts22715 is the leader of the worldnumbnuts22715 is the leader of the world
Groaned at 9 Times in 6 Posts
awesome write up man! I will probably be doing this some time.
numbnuts22715 is offline   Reply With Quote
 Old 09-09-2008, 09:04 AM   #8
LBV
LBV's Avatar
Posts: 700   (View Stats)
LBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond repute
Here's great write-up from Wayne on the Aussie forums ... hate to say it but the instructions & pics you sent out Ken suck!
2007 White MazdaSpeed 6 for sale ... new wheels = G8 GXP manual.
LBV is offline   Reply With Quote
The Following 4 Users Say Thank You to LBV For This Useful Post:
aaronc7 (01-25-2009), rednofive (04-18-2012), sweetpickles (09-09-2008), tomek_46 (11-28-2011)
 Old 09-09-2008, 09:34 AM   #9
CraigHJr's Avatar
HAHA wish I had that before I did the pump build and before I spent 2 hours building this write up!
 Old 09-09-2008, 01:51 PM   #10
LBV
LBV's Avatar
haha ... yours is good too - I didn't even have THAT to go on.
On a side note I'm loving this upgrade - part throttle response is great and the car always has that sound & feel like it's always "in the zone", if u know what I mean. My accelerating LTFT's went to zero bang on too!!!
 Old 09-11-2008, 06:28 PM   #11
4thStroke's Avatar
Posts: 481   (View Stats)
4thStroke has a reputation beyond repute4thStroke has a reputation beyond repute4thStroke has a reputation beyond repute4thStroke has a reputation beyond repute4thStroke has a reputation beyond repute4thStroke has a reputation beyond repute4thStroke has a reputation beyond repute4thStroke has a reputation beyond repute4thStroke has a reputation beyond repute4thStroke has a reputation beyond repute4thStroke has a reputation beyond repute
Very true, they suck. I didnt really use mine, I pulled up MSF to check things out when things were unclear, even so, it wasnt much fun this way. Too bad This wasnt out by the time I did mine!
Corksport downpipe, race pipe, and motor mount inserts. Cobb AP tuned by Surgeline, SRI, STS. TWM shifter bushings. Forge BPV. WOT box w/ 2 step. CP-E FMIC. CDFPI. H&R coilovers. SPC camber links. -Long gone, sold to some punk bitch
1991 Galant VR4 - Garrett FP HTA3076R @ 557awhp on ethanol. Full weight and daily driven at 440awhp on 92.
4thStroke is offline   Reply With Quote
 Old 09-11-2008, 07:02 PM   #12
LBV
LBV's Avatar
Oh ya!!
Issues I had ... 1 - which way does the silver rod go in? 2 - which way does the dark barrel (the one with the hole) go? 3 - Where the hell do those 2 clips go?
When you think of the importance of doing this properly it really makes you shake your head at the lack of proper & clear pics & instructions on this. Good thing the Aussies are better at writing instructions. LOL
 Old 09-16-2008, 06:42 PM   #13
Grim's Avatar
Groans: 70
im about to do this,i need to know whats the exact fuse i pull to do it.
 Old 09-16-2008, 08:54 PM   #14
CraigHJr's Avatar
LBV is that a knock at my write up or the dirrections with the kit (which I have never seen).
Grim in the underhood fuse box there are mini blue relays not fuses that you want to pull. There is one labled "fuel 2" and then the one you want is next to that. They are arranged in a line from battery to headlight. I think its closer to the battery. If you start first thing in the am with the car not run and cold you can just skip the pulling the relay all together. Pm me your number if you have a problem, I check my mail several times a day. And that aussie write up is good so make sure you read that too.
 Old 09-16-2008, 10:21 PM   #15
Grim's Avatar
Groans: 70
im finished,the relay you are talking about was called "circut".The install was pretty simple,both writeups were very helpful.Thanks!
The Following User Says Thank You to Grim For This Useful Post:
CraigHJr (09-17-2008)
 Old 09-16-2008, 11:04 PM   #16
Renzokuken's Avatar
Posts: 900   (View Stats)
Renzokuken is the leader of the worldRenzokuken is the leader of the worldRenzokuken is the leader of the worldRenzokuken is the leader of the worldRenzokuken is the leader of the worldRenzokuken is the leader of the worldRenzokuken is the leader of the worldRenzokuken is the leader of the worldRenzokuken is the leader of the worldRenzokuken is the leader of the worldRenzokuken is the leader of the world
Great writeup, and I must say this is an awesome bang for buck mod. Very simple.
1990 Totoya Corrolla DX TRD limited edition w/ Back to the future Delorian body kit/ K&N snorkel inlet ram-air intake/ Mazdaspeed T3/T4 turbo-supercharged hybrid 5 PSI and many more mods. 11.92 @120 MPH
Renzokuken is offline   Reply With Quote
The Following User Says Thank You to Renzokuken For This Useful Post:
 Old 09-17-2008, 07:07 AM   #17
LBV
LBV's Avatar
Definitely a knock on the original directions sent with the kit! I applaud you for taking the time to do what you did ... I did the same when I installed my Prosport boost gauge so I know the extra effort involved to help others.
The Following User Says Thank You to LBV For This Useful Post:
 Old 09-24-2008, 08:20 PM   #18
phillyb's Avatar
Posts: 14,702   (View Stats)
Groans: 1,940
one does this upgrade before or at the onset of one getting fuel cut?
too lean conditions?
is that what the worry is?
please pardon my ignorance, but any help is appreciated
 Old 09-24-2008, 09:34 PM   #19
kingpin748's Avatar
Posts: 2,611   (View Stats)
Groans: 78
You can do it anytime you want. I did it after I started getting fuel cut.
In reality I love lenny
kingpin748 is offline   Reply With Quote
 Old 09-24-2008, 09:47 PM   #20
Grim's Avatar
Groans: 70
the stock pump just plain sucks,and its a good failsafe to get a new pump regardless if you get cut or not.
 Old 10-03-2008, 09:26 PM   #21
cosmicspd3's Avatar
Posts: 447   (View Stats)
cosmicspd3 has a brilliant futurecosmicspd3 has a brilliant futurecosmicspd3 has a brilliant futurecosmicspd3 has a brilliant futurecosmicspd3 has a brilliant futurecosmicspd3 has a brilliant futurecosmicspd3 has a brilliant futurecosmicspd3 has a brilliant futurecosmicspd3 has a brilliant futurecosmicspd3 has a brilliant futurecosmicspd3 has a brilliant future
I just got my spare fuel pump in the mail to do a this mod to! Are these the same internals as mrlilguys or cpe's?
2009 Cobalt SS
Originally Posted by northvibe
ABS is really for lazy americans
cosmicspd3 is offline   Reply With Quote
 Old 10-03-2008, 09:40 PM   #22
Grim's Avatar
Groans: 70
yes
 Old 10-04-2008, 12:25 AM   #23
CraigHJr's Avatar
Mrlilguy's vw kmd or something
 Old 10-06-2008, 09:10 AM   #24
cosmicspd3's Avatar
Grim you bastard. I love your avatar so much I just starred at it for 5 min straight at work cuz I am bored.....i wish this door locked.....
well I'll prolly just get the internals then once they are stocked...
2009 Cobalt SS
 Old 10-06-2008, 09:45 AM   #25
gsrtype1's Avatar
Posts: 7,514   (View Stats)
Groans: 102
great write up! sub
 Old 10-21-2008, 09:57 AM   #26
Must Have Teh 10's!
superskaterxes's Avatar
Posts: 10,442   (View Stats)
heres the instructions from KMD
KMD Tuning - KMD FSI Fuel Pump Kit
First K04 in the 12's
First MS6 in the 11's
Certified RichTune E-Tuner
 Old 10-21-2008, 10:19 AM   #27
CraigHJr's Avatar
Good stuff, I wonder if they have them in stock as well as they always seem out on the Mazda end.
 Old 10-21-2008, 10:34 AM   #28
Must Have Teh 10's!
i need them bad but im out of money for a longggg time. good thing i got that 180 bucks cashback coming nov 30th from ebay hehe
 Old 10-22-2008, 03:09 PM   #29
Jarods7920's Avatar
Posts: 1,415   (View Stats)
What are you guys using to data log with?
 Old 10-22-2008, 03:25 PM   #30
Eazy's Avatar
Posts: 1,539   (View Stats)
Eazy is the leader of the worldEazy is the leader of the worldEazy is the leader of the worldEazy is the leader of the worldEazy is the leader of the worldEazy is the leader of the worldEazy is the leader of the worldEazy is the leader of the worldEazy is the leader of the worldEazy is the leader of the worldEazy is the leader of the world
Groaned at 32 Times in 14 Posts
Dashhawk
Eazy is offline   Reply With Quote
 Old 10-23-2008, 03:38 PM   #31
Jarods7920's Avatar
so i guess having your fuel pressure fall below a 1100psi is bad then? Maybe that is why my car messes up when i run more than 16psi.
 Old 11-19-2008, 05:15 PM   #32
Ferdball's Avatar
Posts: 1,340   (View Stats)
I don't get fuel cut, and I don't go lean. Do I really need a new fuel pump?
 Old 11-19-2008, 05:29 PM   #33
bova's Avatar
Posts: 3,820   (View Stats)
Groans: 45
where can one get an E8 inverted torx? home depot? lowes? auto parts store?
 Old 11-19-2008, 07:22 PM   #34
Grim's Avatar
Groans: 70
i got mine from harbor freight.basically any hardware store
 Old 11-25-2008, 02:23 PM   #35
Lymerock's Avatar
imo, no
your pump logs look like mine. Never dip below 1100 usually. However, i grabbed some for the "just cuz" reason, but at 250 a wack, its an easy mod to overlook if you dont need it.
07 CB Speed3
COBB AP S2+, MS CAI (shorty w/ straightener), RPMC inlet, ETS 3.25", Devils Own S2 Alchy Injection, PG Manifold V2, TXS DP (with Cobb highflow cat soon), TXS mid, MS CBE, HKS Plugs (1 step colder), Fidanza Flywheel, KMD CDFP internals, COBB Sways, Koni Dual Adjustable Shocks, AWR 88 trans mount, Hawk HP+ pads (F+R), Motul RBF 600 brake fluid, 18x8 +50 weds sa70's 245/40 falken rt-615's, V1 hardwired, Autometer ES Gauges (boost/vac, water, oil pres), Dashhawk, stock turbo with modified boost control system
 Old 11-25-2008, 02:38 PM   #36
BreakTheStatic's Avatar
Posts: 280   (View Stats)
BreakTheStatic has a brilliant futureBreakTheStatic has a brilliant futureBreakTheStatic has a brilliant futureBreakTheStatic has a brilliant futureBreakTheStatic has a brilliant futureBreakTheStatic has a brilliant futureBreakTheStatic has a brilliant futureBreakTheStatic has a brilliant futureBreakTheStatic has a brilliant futureBreakTheStatic has a brilliant futureBreakTheStatic has a brilliant future
I think you guys are minimizing the importance of the cdfp upgrade. Yes I did get it to cure my pressure drop, but it also made the overall power delivery much smoother. It's hard to fully describe, but the car just wants to pull harder with it and doesn't feel taxed at all. If you were showing no drop in pressure whatsoever, I'd say to *maybe* pass it up. But looking at your log, you should definitely consider getting one. Have you dynoed your car? I bet you'd see a big difference in mid-range power between the faulty oem pump and an upgraded one. On my car, I noticed a difference of 25+whp around 4k-5k rpm (where the pressure drop occurs).
BreakTheStatic is offline   Reply With Quote
 Old 11-25-2008, 02:39 PM   #37
Ferdball's Avatar
You know, we're discussing a theory about the affects of the fuel pressure. I sometimes get pops and mild backfires during WOT. If the lack of pressure causes a lack of atomization, inefficient ignition, and more fuel being read by the O2 sensor, then the theory explains the pops too.
http://www.mazdaspeedforum.org/forum/foru...tml#post112525
 Old 11-30-2008, 07:45 AM   #38
Lymerock's Avatar
how crucial is it to have a vice to hold the pump? I realize that nut is in there tight, but might I be able to do this on a bench with a few wood clamps?
Ive been historically too cheap to buy a nice vice... all the ones I like are 100 if not 3 times that.
anyway, its snowing and I got my summers tires on, so if there is a chance of doing this without driving to work, it would make it alot easier on me
07 CB Speed3
 Old 11-30-2008, 09:38 AM   #39
CraigHJr's Avatar
Anything is possible. It is a simple swap once you break that nut loose.
If anyone needs install help in my area (Bergen County NJ) let me know. I have all the tools and work for cheap.
 Old 11-30-2008, 10:02 AM   #40
Jarods7920's Avatar
here ya go man...i picked this little gem up a few weeks ago
http://www.harborfreight.com/cpi/cta...emnumber=94428
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f33/camshaft-driven-fuel-pump-internals-upgrade-11215/
The MZR Thread: Mazdas that aren't Miatas or rotaries - The Something Awful Forums This thread Refback 07-21-2014 02:17 AM
HPFP install guide (one I prepared a little earlier) This thread Refback 09-01-2013 10:09 PM
Very pleased with myself.... ? Mazda MPS Owners Club This thread Refback 08-08-2013 09:04 AM
CDFP internals upgrade - Mazdaspeed Forums This thread Refback 02-22-2013 12:28 AM
Parts needed for HIGH PRESSURE FUEL PUMP upgrade. - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 01-25-2013 01:41 PM
Autotech Install Help? This thread Refback 01-04-2013 05:14 PM
T25 safety Torx, where to buy? - 2010 Mazda 3/Mazdaspeed 3 Forums This thread Refback 10-14-2012 06:15 PM
Fuel pump advice • Mazda MPS Owners Club This thread Refback 10-11-2012 12:16 PM
GT3071R TWIN SCROLL - Page 2 This thread Refback 09-06-2012 08:21 AM
Mazda MPS Owners Club • View topic - GroupBuy 2nd Chance! AutoTech HPFP Internals - $375 - Round2 This thread Refback 08-15-2012 02:36 AM
Mazda MPS Owners Club • View topic - Fuel pump advice This thread Refback 06-23-2012 02:38 PM
dyno sheet - Page 3 This thread Refback 03-28-2012 10:35 AM
KMD Internals HPFP Install issue - help plz - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 12-27-2011 03:10 PM
MZR talk here **NO SUBARUS ALLOWED** - The Something Awful Forums This thread Refback 08-08-2011 01:19 AM
KMD internals (with TiCN-MP coating) installed - Page 2 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Refback 08-07-2011 07:56 PM
Fuel Pump problem This thread Refback 06-17-2011 03:57 PM
KMD internals (with TiCN-MP coating) installed - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 06-11-2011 04:36 PM
Forum Mazda Performance Series - Zobacz temat - PTP fuel pump internals This thread Refback 05-27-2011 08:39 AM
hpfp ? - Page 2 - Mazda 6 Forums : Mazda 6 / Mazda Atenza Forum This thread Refback 03-26-2011 04:34 AM
Fuel Pump problem This thread Refback 11-22-2010 01:56 PM
Mazda MPS Owners Club • View topic - Very pleased with myself.... This thread Refback 11-21-2010 09:41 AM
CDFP install This thread Refback 05-28-2010 09:31 PM
Fuel Pump problem - Mazda CX-7 Forums This thread Refback 03-25-2010 03:01 PM
Why you should run our HPFP.... - MazdasNW This thread Refback 01-20-2010 09:53 PM
MattJackson86's Bookmarks on Delicious This thread Refback 06-06-2009 06:34 PM
Walbro 255 Fuel Pump - TorontoMazda3 This thread Refback 02-07-2009 03:06 PM
Walbro 255 Fule Pump - TorontoMazda3 This thread Refback 02-07-2009 07:48 AM
High Flow Fuel Pump Internals Kit kingpin748 Mazdaspeed3/6 General Discussion 36 09-02-2008 09:50 AM
Fuel pump internals cgburton12 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 43 08-11-2008 01:29 PM
Pump internals in stock? Erich Mazdaspeed3/6 General Discussion 13 08-11-2008 12:32 PM
So now they offer the internals for pumps! Death-From-A-Mile MazdaSpeed 3 - Engine, Transmission & Driveline 25 07-11-2008 08:31 AM
Page generated in 0.60265 seconds with 39 queries
