> MazdaSpeed 3 - How-To's
Like Tree8Likes
 Old 01-20-2010, 03:37 PM   #81
CraigHJr's Avatar
Posts: 676   (View Stats)
CraigHJr is the leader of the worldCraigHJr is the leader of the worldCraigHJr is the leader of the worldCraigHJr is the leader of the worldCraigHJr is the leader of the worldCraigHJr is the leader of the worldCraigHJr is the leader of the worldCraigHJr is the leader of the worldCraigHJr is the leader of the worldCraigHJr is the leader of the worldCraigHJr is the leader of the world
Check the first post I think you will see it was updated before you even posted this...I am about to go read the other CDFP info in the fuel deliv sub forum, if they are way better I don't see why people are still comming to this thread asking questions.
If anyone needs install help in my area (Bergen County NJ) let me know. I have all the tools and work for cheap.
CraigHJr is offline   Reply With Quote
 Old 01-20-2010, 04:05 PM   #82
AFcadet's Avatar
Posts: 937   (View Stats)
AFcadet is the leader of the worldAFcadet is the leader of the worldAFcadet is the leader of the worldAFcadet is the leader of the worldAFcadet is the leader of the worldAFcadet is the leader of the worldAFcadet is the leader of the worldAFcadet is the leader of the worldAFcadet is the leader of the worldAFcadet is the leader of the worldAFcadet is the leader of the world
I see that you did now. Thanks.
The threads about this problem was pages and pages of discussion, problems, tests, and finally a solution. The people that were all having failures watched that thread closely. But now the CDFP hubub has settled...people will find this thread A LOT easier considering the name when they search.
AFcadet is offline   Reply With Quote
 Old 01-20-2010, 04:40 PM   #83
DaleNixon's Avatar
Posts: 2,079   (View Stats)
Groans: 91
I checked out this thread because it's the first sticky in the Mazdaspeed3 How-To section.
DaleNixon is offline   Reply With Quote
 Old 01-22-2010, 09:01 AM   #84
darth vader's Avatar
Posts: 665   (View Stats)
darth vader is the leader of the worlddarth vader is the leader of the worlddarth vader is the leader of the worlddarth vader is the leader of the worlddarth vader is the leader of the worlddarth vader is the leader of the worlddarth vader is the leader of the worlddarth vader is the leader of the worlddarth vader is the leader of the worlddarth vader is the leader of the worlddarth vader is the leader of the world
Groaned at 9 Times in 9 Posts
How 'bout we just add to use motor oil as assembly lube instead of gasoline and, confirm torque values for the cap at 50 pounds/ft max?
darth vader is offline   Reply With Quote
 Old 02-06-2010, 12:53 AM   #85
nesiospeed's Avatar
Posts: 29   (View Stats)
nesiospeed will become famous soon enough
Default help with a cel p0091 after install a sb and pnp arnees
hi guys , i need your help , i tried to install a sb and a pnp arness yesterday , when i finished i start the car , and i have a cel p0091 , i put my ecu without sb and pnp , and this code disappear...my mods are wot bx n2mb , turboback 3" , boost tubes , one step colder ngk, cai injen , i have installed a atp fcd ,in this moment.
nesiospeed is offline   Reply With Quote
 Old 02-06-2010, 01:19 AM   #86
CraigHJr's Avatar
failing to connect how this is related to a cdfp when you dont even have one.
 Old 02-10-2010, 01:14 PM   #87
nickdbz's Avatar
Posts: 30   (View Stats)
nickdbz has a spectacular aura aboutnickdbz has a spectacular aura about
Groaned at 8 Times in 2 Posts
Hey, I need some help with how to get stains out of jeans....oh wait....this isn't that thread? Crap....Well nice write up anyway!
nickdbz is offline   Reply With Quote
 Old 12-20-2010, 02:28 PM   #88
relenger's Avatar
Posts: 17   (View Stats)
relenger will become famous soon enough
Nice, lots of pics
relenger is offline   Reply With Quote
 Old 12-22-2010, 09:21 AM   #89
drewsifer86's Avatar
Posts: 137   (View Stats)
drewsifer86 is the leader of the worlddrewsifer86 is the leader of the worlddrewsifer86 is the leader of the worlddrewsifer86 is the leader of the worlddrewsifer86 is the leader of the worlddrewsifer86 is the leader of the worlddrewsifer86 is the leader of the worlddrewsifer86 is the leader of the worlddrewsifer86 is the leader of the worlddrewsifer86 is the leader of the worlddrewsifer86 is the leader of the world
So I'm just about to do the instal of the CPe pump, which blue relay do I need to pull? I don't see any that says "circuit".
07 MS3 - Cobb AP/PG Custom FMIC/Cobb RSB/Cobb XLE BPV/Fujita CAI/Jbarone SSP & Bushings/Jbarone AP mount/NGK Step Colder Plugs/ATP Catted DP/CP-e HPFP/PG Tow Plate/Protune (270whp/345wtq)
drewsifer86 is offline   Reply With Quote
 Old 12-22-2010, 05:14 PM   #90
bait's Avatar
bait is on a distinguished road
Groaned at 7 Times in 4 Posts
a ton of people seem to think this should be one of your first mods, even before SRI/DP/RP etc... anyone want to give their two cents? Thinking about doing this...
bait is offline   Reply With Quote
 Old 12-22-2010, 05:43 PM   #91
YokiMazoku's Avatar
Posts: 320   (View Stats)
YokiMazoku is the leader of the worldYokiMazoku is the leader of the worldYokiMazoku is the leader of the worldYokiMazoku is the leader of the worldYokiMazoku is the leader of the worldYokiMazoku is the leader of the worldYokiMazoku is the leader of the worldYokiMazoku is the leader of the worldYokiMazoku is the leader of the worldYokiMazoku is the leader of the worldYokiMazoku is the leader of the world
There is a good reason why so many people think this should be one of your first mods. I ran into fuel cut with just a cai. The stock one is a pos and fails often but you might not know its failing and could cause problems. Also i dont know what it is with people and not getting a monitoring device before they start doing all these upgrades. Before you do ANY MOD (including this) you need that first. Ex what happens if you do this and you fuck up the install (or the part is defective) and you cant monitor your DI pressure to notice you fucked up then you find out the hard way when you throw a rod or something. MONITORING DEVICE FIRST NOOB LESSON 101.
PS: donate and help the forum
Boobs.....because you can't motorboat a personality.
YokiMazoku is offline   Reply With Quote
 Old 01-10-2011, 07:14 PM   #92
zumin's Avatar
Posts: 623   (View Stats)
zumin is the leader of the worldzumin is the leader of the worldzumin is the leader of the worldzumin is the leader of the worldzumin is the leader of the worldzumin is the leader of the worldzumin is the leader of the worldzumin is the leader of the worldzumin is the leader of the worldzumin is the leader of the worldzumin is the leader of the world
*** you should be able to pressurize the fuel system by holding your gas petal to the floor, this will turn over engine but you wont get any spark, this usually works on newer cars. idk
zumin is offline   Reply With Quote
 Old 02-02-2011, 11:33 AM   #93
dachtler's Avatar
Posts: 170   (View Stats)
dachtler has a reputation beyond reputedachtler has a reputation beyond reputedachtler has a reputation beyond reputedachtler has a reputation beyond reputedachtler has a reputation beyond reputedachtler has a reputation beyond reputedachtler has a reputation beyond reputedachtler has a reputation beyond reputedachtler has a reputation beyond reputedachtler has a reputation beyond reputedachtler has a reputation beyond repute
Any idea why the factory manual states you should drain the coolant from the engine before removing the CDFP on the Gen2 Speed3? I have not seen that step outlined in any of the writeups on CDFP upgrades.
dachtler is offline   Reply With Quote
 Old 02-02-2011, 12:55 PM   #94
atvfreek's Avatar
Posts: 7,787   (View Stats)
No idea why they have that step. I didn't drain my coolant when I did mine.
2010 Speed3-PTE5858
Freek built/Freektuned
510hp420tq
11.321@129.93
rfinkle2 (12-19-2011), TexasSpeed3 (08-28-2011)
 Old 02-02-2011, 02:08 PM   #95
TRex's Avatar
Posts: 3,139   (View Stats)
people still getting their internals from ptg?
 Old 02-04-2011, 09:39 AM   #96
AFcadet's Avatar
Don't worry about pulling the relay...like someone else said...just hold down the gas pedal all the way to the floor and crank the motor.
Watch your DI fuel pressure and after 5-10 seconds of cranking you will see the fuel preassure quickly rise above 500. once its primed let off the gas and start it normally.
I've personally done this about a dozen times on my car...and multiple times on my buddies cars when I was changing out fuel pumps.
 Old 02-07-2011, 10:16 AM   #97
k-speed's Avatar
Posts: 56   (View Stats)
k-speed is a jewel in the roughk-speed is a jewel in the roughk-speed is a jewel in the roughk-speed is a jewel in the rough
excited to do this this weekend!
k-speed is offline   Reply With Quote
 Old 03-05-2011, 03:20 PM   #98
dizzydtrain's Avatar
Posts: 2,476   (View Stats)
Groans: 64
reading some of the threads regarding the hpfp installs, I have not come across anyone mentioning how to re-install the pump and some of the difficulties. I am starting to think that it may just be me but I can not get the pump back in.
I am trying really hard to align the 3 etorx bolts but I can not press onto the fp hard enough.. Any suggestions?
 Old 03-05-2011, 03:35 PM   #99
skeeter149's Avatar
Posts: 3,742   (View Stats)
Groans: 91
it happened to bmorrisj hit him up.
The Following User Says Thank You to skeeter149 For This Useful Post:
dizzydtrain (03-05-2011)
 Old 03-05-2011, 05:41 PM   #100
Groans: 64
Wow, I still can't believe how tough this install has been. I have the cp-e fuel pump and have followed this install guide--until I was ready to install the pump back in, everything went smoothly.
So the advice so far that I have received is to just torque the etorx bolts back in slowly one by one--this is a lot easier said than done. There is so much resistance getting the pump back into place that myself and my buddy could not even get close. At one point we got one of the bolts back in partially but that was about as close as we got to it.
I even tried to screw the 19mm nut back in first in hopes of aligning in correctly and then getting the etorx botls lined up--this even failed.
I don't want to keep forcing the fp back into place with this much resistance. Had to leave my car at my friends house for the night and will try again tomorrow. Any input would be appreciated.
The pic below is where I am at right now.
 Old 03-05-2011, 06:08 PM   #101
patrick failman
karl-hungus's Avatar
Posts: 4,635   (View Stats)
Groans: 74
buy it some drinks.
buckeyepost likes this.
The Following 3 Users Say Thank You to karl-hungus For This Useful Post:
dizzydtrain (03-05-2011), ScarMS3 (03-06-2011), TexasSpeed3 (08-28-2011)
 Old 03-05-2011, 06:18 PM   #102
patrick failman
Groans: 74
does the stock pump go on okay? maybe it's the cp-e pump?
The Following User Says Thank You to karl-hungus For This Useful Post:
 Old 03-05-2011, 07:21 PM   #103
Groans: 64
it does not. I got a pm from bmorrisj and it looks like the cam follower needs to be depressed in again in order to fit the fuel pump back to where it belongs. Fucking noob fail by me but I am learning, which is great.
 Old 03-06-2011, 07:37 AM   #104
patrick failman
Groans: 74
status?
 Old 03-06-2011, 08:14 AM   #105
atvfreek's Avatar
Make sure the cam follower slides in and out easily. What i think is happening is that the cam stopped in the pumps fully compressed position. Therefor making you compress the pump while its going in. Try to turn the engine over by hand by putting a ratchet on the crank pully, and have a friend watch the cam follower until it's at the furthest in position. I think that will help you out.
2010 Speed3-PTE5858
510hp420tq
11.321@129.93
 Old 03-06-2011, 10:03 AM   #106
Groans: 64
still having some issues. The cam lobe is that bronze looking pin where the hpfp spring would be insterted in, correct?
I am bump starting the car but it's still in the same position.
 Old 03-07-2011, 06:43 PM   #107
AFcadet's Avatar
Yea the Cam follower is just pushed up by the cam.
I've put on the fuel pump almost a dozen times now lol...and this happens every now and then. Just fully remove the fuel pump, hop in the car, depress the clutch and the gas pedal all the way (so the injectors won't fire) and just flip the key on and off real quick to turn the engine over for a breif second.
This will turn over the motor...turning the cam as well. Its nothing cosmic...just turn over the engine and try inserting the fuel pump. It should go in easier (so to speak). If not...try it again.
I bet your cam follower is extended all the way...thats why you can even get it close. Any other position and you should be able to depress it enough to at least get one bolt in...then you can get the others on and slowly screw it down onto the engine.
The Following 2 Users Say Thank You to AFcadet For This Useful Post:
dizzydtrain (03-07-2011), p057 (11-20-2011)
 Old 03-07-2011, 07:38 PM   #108
Groans: 64
I was posting in the other thread. I was able to get it done today, it was a pain in the ass to get the follower (cup) back in due to the cold weather we had here but I got in after a while.
You are right tho, the cam follower was extended all the way.
 Old 07-27-2011, 02:56 PM   #109
RMCAT's Avatar
RMCAT has a reputation beyond reputeRMCAT has a reputation beyond reputeRMCAT has a reputation beyond reputeRMCAT has a reputation beyond reputeRMCAT has a reputation beyond reputeRMCAT has a reputation beyond reputeRMCAT has a reputation beyond reputeRMCAT has a reputation beyond reputeRMCAT has a reputation beyond reputeRMCAT has a reputation beyond reputeRMCAT has a reputation beyond repute
Do we flip the key to the "ON' position or the "START" position? The car battery has to be connected to do so right?
Sorry about the dump questions...
||Cobb AP(DJ tuned)||Cobb SRI||Cobb TIP||Cobb FMIC||Cobb SW||KMD v2.2 HPFP||Catted TBE(TurboXS DownPipe+Vibrant DPback)||TurboXS Hybrid BOV||Fortune Auto Coilovers||Powergrid Endlinks||Eibach Camber Kit||CPE RMM||Denso ITV22||STRI DSD 60mm Boost Gauge||5000K HID Fogs||Lamin-x Foglight Tints||Speedy Lite-Fin 18x7.5||General UHP 235/40/18||ADR 17x7(Winter)||Nextmod GV front Lip/spoiler Lip||AutoEXE Carbon Fiber Shifter Knob||Carbon Fiber Ebrake Cover||TWM Bushings||TWM Shift/Ebrake Boots||
RMCAT is offline   Reply With Quote
The Following User Says Thank You to RMCAT For This Useful Post:
TRSpeed (10-12-2011)
 Old 08-08-2011, 12:22 PM   #110
evidence's Avatar
Posts: 1,033   (View Stats)
You actually need get the engine moving to move the follower, so push down the gas and clutch so the injectors aren't active and just give it a quick tap to START to roll it over.
Some things.
 Old 08-16-2011, 01:14 PM   #111
zumin's Avatar
no battery needed
 Old 08-16-2011, 08:16 PM   #112
buckeyepost's Avatar
Posts: 295   (View Stats)
buckeyepost has a reputation beyond reputebuckeyepost has a reputation beyond reputebuckeyepost has a reputation beyond reputebuckeyepost has a reputation beyond reputebuckeyepost has a reputation beyond reputebuckeyepost has a reputation beyond reputebuckeyepost has a reputation beyond reputebuckeyepost has a reputation beyond reputebuckeyepost has a reputation beyond reputebuckeyepost has a reputation beyond reputebuckeyepost has a reputation beyond repute
sub
07 MS3 GT {DD} \\ 295whp 328wtq (pre E mix) \\ Cobb AP {Stage 2} \\ MS CAI & CBE \\ ATP DP/MP {catless} \\ Corksport TMIC \\ SURE TIH \\ TurboSmart Kompact BPV \\ AutoTech FP internals \\ Denso ITV22's \\ SU RMM \\ Ralco STS\\ Hawk HPS pads \\ StopTech rotors \\ Sensen dampers \\ Moog swaybar links \\ DashHawk \\ 225/45 Kuhmo Ecsta XS's on 18x7.5 Momo S-five's \\ 205/60-16 Dunlop Winter Sport 3D's on steelies
1:3 E85 mix Dizzy tuned by Boost_creep
...... sold :-(
buckeyepost is offline   Reply With Quote
 Old 08-25-2011, 01:43 PM   #113
MSpeedzilla's Avatar
Posts: 121   (View Stats)
MSpeedzilla is the leader of the worldMSpeedzilla is the leader of the worldMSpeedzilla is the leader of the worldMSpeedzilla is the leader of the worldMSpeedzilla is the leader of the worldMSpeedzilla is the leader of the worldMSpeedzilla is the leader of the worldMSpeedzilla is the leader of the worldMSpeedzilla is the leader of the worldMSpeedzilla is the leader of the worldMSpeedzilla is the leader of the world
great write up i gotta do this next im getting fuel cut after i put that Catless Dp on
_____________________________________________
2008 Silver Gen 1, MS3 MSCAI, Cobb TIP, Full Catless Race/Downpipe, Cobb XLE Bpv, MAPerformance rmm, Cobb AP, HPFP, xt-m5-qs, Shift bushings(washers), denso ITV22, Torque Android app, .
MSpeedzilla is offline   Reply With Quote
 Old 08-30-2011, 07:14 PM   #114
buy it some drinks.
Classic! LMFAO!
Anyway, much better after the AutoTech internals install. Pretty easy install (once you have all the tools, DOH!)
...... sold :-(
The Following User Says Thank You to buckeyepost For This Useful Post:
TexasSpeed3 (09-03-2011)
 Old 10-14-2011, 09:21 AM   #115
ken671's Avatar
Posts: 79   (View Stats)
ken671 is a name known to allken671 is a name known to allken671 is a name known to allken671 is a name known to allken671 is a name known to allken671 is a name known to all
i need to order and install one really bad.
i blew a plug and pulled a p0301 and pretty much that plug from the first cylinder was toasted and had nomore gap. finally replaced my plugs to step colders but since then i've been scared to boost.
ken671 is offline   Reply With Quote
 Old 10-19-2011, 03:02 PM   #116
TexasSpeed3's Avatar
Posts: 1,996   (View Stats)
TexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the world
Groans: 273
subbed once again to help another
2011 Black Mica - Daily
JBR SSP and heavy knob and SSB | Sure RMM | Corksport SRI/TIP/RSB/TMIC | Tanabe FSTB | Cobb AP getting PERM'd | Autotech internals | H&R springs | DDM HID | pussy delete - catless ebay dp and tp
TexasSpeed3 is offline   Reply With Quote
 Old 11-14-2011, 01:47 PM   #117
great write up... question for anyone who will listen... I think and i say think because i bought my speed used... I think that i have a stock fp but i just finished logging on a 40F day and i didnt see my FP dip below 1700 I was told that if at wot it didnt dip below 1700 id be fine, From my logs everything stays just a bit richer than 14.1afr when Wot and ive got a good number of bolt ons does that mean i dont need a pump or i just dont need one yet
 Old 12-28-2011, 12:39 PM   #118
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
Until a few days ago I had the hypertech tune and even with my bold-ons I didn't have to worry about the HPFP as long as it was performing normally.
However, with this more aggressive tune (Versatune) I noticed an increase of the FRP even up to 1860PSI.
What does this mean? That I can delay the HPFP internals as of right now my stock pump with 64k miles on it is going unexpectedly strong?
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
 Old 12-28-2011, 07:02 PM   #119
Bob-o's Avatar
Posts: 1,312   (View Stats)
I think it means you just had a strong pump all long, and your previous tune didn't request as high of fuel pressure? I'm not sure, but i dont think that by switching from a hypertech to a versatune will make your CDFP "better."
 Old 01-02-2012, 01:21 PM   #120
mituc's Avatar
Groans: 111
Bob, no, I was wondering if it really can keep up or if maybe the increased FRP demand will not damage it in any way.
However, i decided to upgrade the pump internals. I don't feel safe at all with a more aggressive tune, a better flowing TMIC and a downpipe on stock pump internals. With hypertech everyone should be fine with full bolt-ons minus the pump internals, but not with a more aggressive tune.
Now, does it really matter if I get the KMD V3's or Autotech? Or just pick whichever I find first?
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f33/camshaft-driven-fuel-pump-internals-upgrade-11215/
The MZR Thread: Mazdas that aren't Miatas or rotaries - The Something Awful Forums This thread Refback 07-21-2014 02:17 AM
HPFP install guide (one I prepared a little earlier) This thread Refback 09-01-2013 10:09 PM
Very pleased with myself.... ? Mazda MPS Owners Club This thread Refback 08-08-2013 09:04 AM
CDFP internals upgrade - Mazdaspeed Forums This thread Refback 02-22-2013 12:28 AM
Parts needed for HIGH PRESSURE FUEL PUMP upgrade. - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 01-25-2013 01:41 PM
Autotech Install Help? This thread Refback 01-04-2013 05:14 PM
T25 safety Torx, where to buy? - 2010 Mazda 3/Mazdaspeed 3 Forums This thread Refback 10-14-2012 06:15 PM
Fuel pump advice • Mazda MPS Owners Club This thread Refback 10-11-2012 12:16 PM
GT3071R TWIN SCROLL - Page 2 This thread Refback 09-06-2012 08:21 AM
Mazda MPS Owners Club • View topic - GroupBuy 2nd Chance! AutoTech HPFP Internals - $375 - Round2 This thread Refback 08-15-2012 02:36 AM
Mazda MPS Owners Club • View topic - Fuel pump advice This thread Refback 06-23-2012 02:38 PM
dyno sheet - Page 3 This thread Refback 03-28-2012 10:35 AM
KMD Internals HPFP Install issue - help plz - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 12-27-2011 03:10 PM
MZR talk here **NO SUBARUS ALLOWED** - The Something Awful Forums This thread Refback 08-08-2011 01:19 AM
KMD internals (with TiCN-MP coating) installed - Page 2 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Refback 08-07-2011 07:56 PM
Fuel Pump problem This thread Refback 06-17-2011 03:57 PM
KMD internals (with TiCN-MP coating) installed - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 06-11-2011 04:36 PM
Forum Mazda Performance Series - Zobacz temat - PTP fuel pump internals This thread Refback 05-27-2011 08:39 AM
hpfp ? - Page 2 - Mazda 6 Forums : Mazda 6 / Mazda Atenza Forum This thread Refback 03-26-2011 04:34 AM
Fuel Pump problem This thread Refback 11-22-2010 01:56 PM
Mazda MPS Owners Club • View topic - Very pleased with myself.... This thread Refback 11-21-2010 09:41 AM
CDFP install This thread Refback 05-28-2010 09:31 PM
Fuel Pump problem - Mazda CX-7 Forums This thread Refback 03-25-2010 03:01 PM
Why you should run our HPFP.... - MazdasNW This thread Refback 01-20-2010 09:53 PM
MattJackson86's Bookmarks on Delicious This thread Refback 06-06-2009 06:34 PM
Walbro 255 Fuel Pump - TorontoMazda3 This thread Refback 02-07-2009 03:06 PM
Walbro 255 Fule Pump - TorontoMazda3 This thread Refback 02-07-2009 07:48 AM
High Flow Fuel Pump Internals Kit kingpin748 Mazdaspeed3/6 General Discussion 36 09-02-2008 09:50 AM
Fuel pump internals cgburton12 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 43 08-11-2008 01:29 PM
Pump internals in stock? Erich Mazdaspeed3/6 General Discussion 13 08-11-2008 12:32 PM
So now they offer the internals for pumps! Death-From-A-Mile MazdaSpeed 3 - Engine, Transmission & Driveline 25 07-11-2008 08:31 AM
Page generated in 0.57436 seconds with 46 queries
