> MazdaSpeed 3 - How-To's
Like Tree8Likes
 Old 01-07-2012, 02:51 PM   #121
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
Does anyone have the part number of the o-ring of the HP fuel pump? Mazda recommends replacing that if the pump is removed.
Later edit: L3K9-13-ZE5
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
 Old 01-13-2012, 10:56 AM   #122
TriO's Avatar
Posts: 676   (View Stats)
TriO is the leader of the worldTriO is the leader of the worldTriO is the leader of the worldTriO is the leader of the worldTriO is the leader of the worldTriO is the leader of the worldTriO is the leader of the worldTriO is the leader of the worldTriO is the leader of the worldTriO is the leader of the worldTriO is the leader of the world
subbing... need to check this thread down the shop buying bits for install today
Friday 13th... what could possibly go wrong
will any motor oil do for lubing?
TriO is offline   Reply With Quote
 Old 01-13-2012, 11:28 AM   #123
Sid3wayS's Avatar
Posts: 6,790   (View Stats)
Groans: 97
Yeah I just used some straight off the dipstick.
TEAM LUXURY
 Old 01-13-2012, 11:40 AM   #124
bigriver's Avatar
Posts: 1,123   (View Stats)
bigriver is the leader of the worldbigriver is the leader of the worldbigriver is the leader of the worldbigriver is the leader of the worldbigriver is the leader of the worldbigriver is the leader of the worldbigriver is the leader of the worldbigriver is the leader of the worldbigriver is the leader of the worldbigriver is the leader of the worldbigriver is the leader of the world
Dude, you are brave! I'm superstitious so I'm doing my tmic install tomorrow the 14th.
GL with install.
Just in case:
File Type: jpg ImageUploadedByTapatalk1326480014.664986.jpg (58.5 KB, 51 views)
2012 mazdaspeed 3, black mica w/ tech package, AFE drop in dry filter, Autotech internals and CS rmm inserts. .
bigriver is offline   Reply With Quote
The Following User Says Thank You to bigriver For This Useful Post:
TriO (01-13-2012)
 Old 01-13-2012, 02:14 PM   #125
TriO's Avatar
Haha.
Don't know if I can do it anyways I can't find that E8 torx bit anywhere...
 Old 01-13-2012, 03:45 PM   #126
Sid3wayS's Avatar
Groans: 97
I used a normal socket and it worked well. I think it was like an 11/32 or something small like that.
You should be able to reach the top right bolt without removing anything but maybe the shroud and try out the sizes before you start
TEAM LUXURY
The Following User Says Thank You to Sid3wayS For This Useful Post:
TriO (01-13-2012)
 Old 01-13-2012, 04:00 PM   #127
TriO's Avatar
cheers guys, found an E8 in the end so all should be good... well apart from not having a vice oh well.
gonna start install here in a bit
 Old 01-14-2012, 11:24 AM   #128
TriO's Avatar
OK so did the install last night... It's not really all that bad. Just a bit daunting putting the internals together whilst keeping them super clean and lubed...
One fuck up tho. Dropped one of those annoying plastic clips that secure the fuel lines into the engine bay and lost it. Temporary zip tie to the rescue again!
Started the car and all seemed good. Went for a drive... Couldn't help going WOT lol. Fuel pressure holding VERY nicely.
One query: my fuel pressure seems to jump high even at part throttle. Like it is over sensitive. Is this normal?? Can't remember what my stocker was like??
Cheers
 Old 01-14-2012, 11:50 AM   #129
bigriver's Avatar
My fp goes up to high 1700s with just normal driving.
That clip might have dropped down to the skid plate and might still be there.
TriO (01-14-2012)
 Old 01-14-2012, 12:00 PM   #130
TriO's Avatar
Cheers good to know!
nah it's not there i checked... pretty sure it's lodged somewhere around the gearbox. oh well i will just order a new one from mazda for $100
 Old 01-14-2012, 01:36 PM   #131
TriO's Avatar
68 bucks. They don't sell the plastic clip only the full hose... Fml
 Old 04-10-2012, 08:45 PM   #132
woodsmsp's Avatar
Posts: 169   (View Stats)
woodsmsp is just really nicewoodsmsp is just really nicewoodsmsp is just really nicewoodsmsp is just really nice
this will help me greatly thanks!
woodsmsp is offline   Reply With Quote
 Old 11-14-2012, 02:21 PM   #133
TheFlash's Avatar
Posts: 2,095   (View Stats)
Originally Posted by Lymerock View Post
Just got done installing the internals, fuel pressure at idle is 100psi higher
the pump does make more noise than the stock internals, no doubt there, but i only noticed when i started the car and had the hood up, inside the cabin I couldnt tell a difference.
So the louder noise was a clicking noise almost? I installed mine today and noticed the clicking from the fp.
 Old 11-14-2012, 02:37 PM   #134
Dizzy Turbo's Avatar
Posts: 2,173   (View Stats)
Yes aftermarket internals clack more/louder
 Old 11-14-2012, 03:27 PM   #135
TheFlash's Avatar
Cool, thanks.
 Old 11-15-2012, 02:12 PM   #136
TheFlash's Avatar
Hey guys I got a P0421 after installing my internals. Anything to worry about? I don't have an AP yet so I can't monitor fuel ratio.
I drive a Mazda
 Old 11-15-2012, 02:18 PM   #137
pwdunmore's Avatar
Posts: 368   (View Stats)
Why would you upgrade your FP if you can't even monitor if its working properly???
 Old 11-15-2012, 02:24 PM   #138
TheFlash's Avatar
Well shit because I was told too. I'm working on getting the ap
I drive a Mazda
 Old 11-15-2012, 02:29 PM   #139
pwdunmore's Avatar
I remember when I use to do what I was told, Do what makes sense to you and works with the platform we have. People are going to try to pressure you into different routes of modding but you need to use your head to think a step ahead. I am not trying to troll but you should get a AP ASAP. Good luck man, hope that the error code is nothing serious.
P0421:
Warm Up Catalyst Efficiency Below Threshold (Bank 1)
Could be O2 sensor or fouled spark plug
 Old 11-15-2012, 02:32 PM   #140
Keko's Avatar
Posts: 1,455   (View Stats)
Groans: 107
Groaned at 9 Times in 9 Posts
Some people are overly anal about internals, but really it comes down to if you need it or not. You should have done your reading, but you also can't monitor it without anything. There are other options besides an AP if you really wanted to check pressure.
2012 MS3
Stratified 91
 Old 11-15-2012, 03:05 PM   #141
TheFlash's Avatar
Ok I got my AP coming in the mail. Should be here soon. We will find out what's really going on
I drive a Mazda
 Old 03-12-2013, 11:18 PM   #142
tmnt shredder's Avatar
Posts: 13   (View Stats)
tmnt shredder will become famous soon enoughtmnt shredder will become famous soon enough
So I'm struggling to find any numbers after you guys installed your upgraded internals. I bought my ms3 used and have a slight feeling it was modded before hand. I'm monitoring my Fp at 1790-1800 psi. Does this sound like. Pretty strong running Fp or should it be much higher. Just can't decide whether to just get it ordered and installed or get my fmic. Thanks again and sorry for being a noob here
tikous360 likes this.
tmnt shredder is offline   Reply With Quote
 Old 03-13-2013, 07:36 AM   #143
Dimenus's Avatar
Posts: 2,825   (View Stats)
Groans: 33
What are you using to monitor your fuel pressure? An AccessPort?
If you do have an accessport, take a log and check your boost levels while making sure that your pressure isn't dipping once you hit 17 or 18 psi. If your boost targets are lower than that, increment them up by .5 psi at a time, reflash, and take another log. I was seeing my pressure dip down to 1500ish by 17.5 psi before I had internals, now it holds strong at 1800-1900 (I'm commanding higher pressure on this map).
If you aren't familiar with the tables, google Abilor's tooning guide or Bucker's guide.
2012 Velocity Red Mica
 Old 06-06-2014, 01:55 PM   #144
Focusfanatic01's Avatar
Posts: 19   (View Stats)
Focusfanatic01 will become famous soon enoughFocusfanatic01 will become famous soon enough
theres a how to video on this as well on youtube. a girl does a lot of mazda how to's, I think her name is alydiy
Focusfanatic01 is offline   Reply With Quote
The Following 2 Users Say NO Thank You to Focusfanatic01 For This Un-useful Post:
Agent_Orange (06-06-2014), Vansquish (06-06-2014)
 Old 06-06-2014, 01:59 PM   #145
Agent_Orange's Avatar
Posts: 3,575   (View Stats)
Groans: 665
Congrats. You just popped your groan cherry with this resurrection.
Look at dates before you bump a thread.
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f33/camshaft-driven-fuel-pump-internals-upgrade-11215/
The MZR Thread: Mazdas that aren't Miatas or rotaries - The Something Awful Forums This thread Refback 07-21-2014 02:17 AM
HPFP install guide (one I prepared a little earlier) This thread Refback 09-01-2013 10:09 PM
Very pleased with myself.... ? Mazda MPS Owners Club This thread Refback 08-08-2013 09:04 AM
CDFP internals upgrade - Mazdaspeed Forums This thread Refback 02-22-2013 12:28 AM
Parts needed for HIGH PRESSURE FUEL PUMP upgrade. - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 01-25-2013 01:41 PM
Autotech Install Help? This thread Refback 01-04-2013 05:14 PM
T25 safety Torx, where to buy? - 2010 Mazda 3/Mazdaspeed 3 Forums This thread Refback 10-14-2012 06:15 PM
Fuel pump advice • Mazda MPS Owners Club This thread Refback 10-11-2012 12:16 PM
GT3071R TWIN SCROLL - Page 2 This thread Refback 09-06-2012 08:21 AM
Mazda MPS Owners Club • View topic - GroupBuy 2nd Chance! AutoTech HPFP Internals - $375 - Round2 This thread Refback 08-15-2012 02:36 AM
Mazda MPS Owners Club • View topic - Fuel pump advice This thread Refback 06-23-2012 02:38 PM
dyno sheet - Page 3 This thread Refback 03-28-2012 10:35 AM
KMD Internals HPFP Install issue - help plz - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 12-27-2011 03:10 PM
MZR talk here **NO SUBARUS ALLOWED** - The Something Awful Forums This thread Refback 08-08-2011 01:19 AM
KMD internals (with TiCN-MP coating) installed - Page 2 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Refback 08-07-2011 07:56 PM
Fuel Pump problem This thread Refback 06-17-2011 03:57 PM
KMD internals (with TiCN-MP coating) installed - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 06-11-2011 04:36 PM
Forum Mazda Performance Series - Zobacz temat - PTP fuel pump internals This thread Refback 05-27-2011 08:39 AM
hpfp ? - Page 2 - Mazda 6 Forums : Mazda 6 / Mazda Atenza Forum This thread Refback 03-26-2011 04:34 AM
Fuel Pump problem This thread Refback 11-22-2010 01:56 PM
Mazda MPS Owners Club • View topic - Very pleased with myself.... This thread Refback 11-21-2010 09:41 AM
CDFP install This thread Refback 05-28-2010 09:31 PM
Fuel Pump problem - Mazda CX-7 Forums This thread Refback 03-25-2010 03:01 PM
Why you should run our HPFP.... - MazdasNW This thread Refback 01-20-2010 09:53 PM
MattJackson86's Bookmarks on Delicious This thread Refback 06-06-2009 06:34 PM
Walbro 255 Fuel Pump - TorontoMazda3 This thread Refback 02-07-2009 03:06 PM
Walbro 255 Fule Pump - TorontoMazda3 This thread Refback 02-07-2009 07:48 AM
High Flow Fuel Pump Internals Kit kingpin748 Mazdaspeed3/6 General Discussion 36 09-02-2008 09:50 AM
Fuel pump internals cgburton12 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 43 08-11-2008 01:29 PM
Pump internals in stock? Erich Mazdaspeed3/6 General Discussion 13 08-11-2008 12:32 PM
So now they offer the internals for pumps! Death-From-A-Mile MazdaSpeed 3 - Engine, Transmission & Driveline 25 07-11-2008 08:31 AM
Page generated in 0.42938 seconds with 33 queries
