> MazdaSpeed 3 - How-To's
Like Tree4Likes
  • 2 Post By BlueStreak
  • 1 Post By Nitr0EngiE
  • 1 Post By rfinkle2
 Old 08-24-2011, 02:22 PM   #1
BlueStreak's Avatar
Posts: 1,467   (View Stats)
Default Convert MAP Based Meth Controller to MAF Based
Ever since I started using my DO Stage 2 MAP based controller, I discovered how inferior this setup was to running MAF or IPW based. I am not knocking on DO's product at all as it does working as intended, I am merely commenting on how we activate and scale meth injection for our Speeds. I won't get into this any further as this thread is a "How To".
Anyways, this write up will guide you step by step on how to convert your MAP based meth controller to MAF based.
Note: This is for a 2.5BAR meth controller.
START OFF WITH THE CONTROLLER DISCONNECTED FROM THE BATTERY
Step 1: Locate the MAF wire connecting to the ECU.
The MAF wire connecting to the ECU is red and white with a painted silver stripe. On the ECU connector located closer to the back of the car, count 5 wires up on the left-hand side.
A quick check at idle speeds confirms this is the proper wire.
Click here for a video as well. Turn your head sideways...
Step 2: Connect the signal wire from your meth controller to the MAF wire.
Step 3: Determine when you want the meth system to activate and when it will reach full spray.
For argument sake, I would like my meth to start spraying at 150g/s and reach full spray at 250g/s.
Looking at the MAF table in ATR, I see the following.
150g/s = 3.71volts. Write that down.
250g/s = 4.41 volts. Write that down as well.
Step 4: Convert the aforementioned voltages to PSI.
Using the attached spreadsheet, input the desired voltages to get the corresponding PSI values. This will give you an approximation.
So, for 3.71 volts, we have 14.4PSI (write that down). For 4.41 volts, we have 19.8PSI (write that down).
Step 5: Dial in the PSI values into your controller.
- For the start value, enter 15PSI. (rounded up)
- For the full value, enter 20PSI. (rounded up)
Step 6: Plug in the power source to your meth controller.
Done.
At this point, you should run a few datalogs to make sure meth sprays as intended.
WARNINGS
- If the PSI you enter corresponds to a voltage less than or equal to 1.3v, meth will spray at idle. Be cautious (this will also occur with your basic MAF based controller as well).
- If you choose to turn off the meth system by unplugging the power source wire to the controller, be sure to disconnect the signal wire from the MAF. Not doing so will make the controller draw current from the MAF wire and make your car run extremely lean. Again, be cautious.
As always, do this at your own risk. It works but you have been warned if something goes wrong :-)
rfinkle2 and Pointless like this.
'07 CWP MS3
Forged.
The Following 9 Users Say Thank You to BlueStreak For This Useful Post:
AZSPEED3 (08-30-2011), f-castrillo (08-24-2011), Fobio (08-24-2011), Nitr0EngiE (08-28-2011), Pointless (08-04-2013), rfinkle2 (08-28-2011), TWOptSL0W (08-28-2011), wolly6973 (08-28-2011), Ziggo (08-24-2011)
 Old 08-24-2011, 02:37 PM   #2
f-castrillo's Avatar
Posts: 1,342   (View Stats)
f-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the world
Subbed for when I have more time to read!
(310whp, 341 ft/lb wtq) 91 octane + 100% methanol
JBR RSB, Stage2 OCC, Stage 2 SSP, IM TIG, 70D RMM, 70D PMM // DevilsOwn Stage 2 WMI kit + DO7 nozzle (MSF-prize) // COBB AP (Self-tune), XLE BPV // Corksport TMIC, SRI, TIP // Racing Beat Cat-back Exhaust // Denso Iridium ITV22 Spark Plugs // SURE TB TIG // Ultimate Racing Test Pipe // KMD HPFP Internals // TSW Nurburgring 18x7.5 ET45 Matte Black // SWIFT Spec-R Lowering Springs //
f-castrillo is offline   Reply With Quote
 Old 08-28-2011, 11:43 AM   #3
TWOptSL0W's Avatar
Posts: 3,289   (View Stats)
Groans: 125
So let me get this straight I can take the map based controller I have and by switching some wire I can have it go off of Maf and nothing extra needs to be bought? If so, thanks and you're awesome
The Following User Says Thank You to TWOptSL0W For This Useful Post:
 Old 08-28-2011, 02:57 PM   #4
BlueStreak's Avatar
Correct.
'07 CWP MS3
Forged.
The Following 3 Users Say Thank You to BlueStreak For This Useful Post:
Pointless (03-05-2014), rfinkle2 (08-28-2011), TWOptSL0W (08-28-2011)
 Old 08-28-2011, 05:12 PM   #5
Daily Driver
Nitr0EngiE's Avatar
Posts: 2,614   (View Stats)
i was doing this when i switched to a 3.5 bar map sensor, my voltages wont trigger the 2.5 bar controller because its out of its range.
but i tapped the red/white wire at the maf sensor plug itself.
on another note I just ordered the devils own DVC-30 Meth controller with a built in 3 bar MAP sensor so I can get my meth to spray correctly without tapping my MAF or MAP ....
can adjust from 2-30 psi
 Old 08-28-2011, 05:17 PM   #6
HAHA! Slick.
I was wondering if that is what you were going to do.
I believe that maf volts is also loggable (word?)... and I would imagine you could get a decent feel of psi per maf voltage that way.
Better to use the spreadsheet, but I was thinking about this the other day.
Nitr0EngiE likes this.
BlueStreak (08-29-2011), Nitr0EngiE (08-28-2011)
 Old 08-28-2011, 05:20 PM   #7
Daily Driver
Nitr0EngiE's Avatar
read what i said about the new DO controller i ordered, i edited the post
dvc-30
I called devils own and complained I could not control my meth properly because i upgraded my map to a 3.5 bar, then they told me about this controller that has its own MAP built in and i can use that, its 175 + shipping ....
anyone wanna buy my 2.5 progressive controller ?
 Old 08-28-2011, 05:20 PM   #8
TWOptSL0W's Avatar
Groans: 125
This is awesome I'll def do it this way. What's a good start/full spray g/sec to set it to?
 Old 08-28-2011, 05:24 PM   #9
Daily Driver
Nitr0EngiE's Avatar
its alot harder to controll using MAF instead because you can hit certain G/s without being in boost at all ....I had to constantly fidle with it for different styles of driving, the only good thing about it was at the track you can set the controller all the way down and simply Rev the car and get it to spray and cool down IM ... lol
 Old 08-28-2011, 05:31 PM   #10
TWOptSL0W's Avatar
Groans: 125
But I heard for bigger turbos it's better with Maf based over map based because much more air is flowing
 Old 08-28-2011, 06:51 PM   #11
Daily Driver
Nitr0EngiE's Avatar
that makes no sense to me. you should be scaling with a bigger nozzle not controller.
i can see where you get more g/s at certain psi for different turbos, so you simply change nozzle.
 Old 08-29-2011, 07:52 PM   #12
BlueStreak's Avatar
Just set it to an airflow that is only achievable with boost :-) I have mine set to 150g/s which can only be achieved after the turbo reaches 12PSI or so. It'll never reach that airflow otherwise.
It is effective on any turbo/nozzle setup. The only time I wouldn't say it was necessary is if you're flowing very little meth.
Running a controller off the MAF has nothing to do with scaling the flow to big turbos. As you said, you scale the amount of meth to the flow of the turbo with nozzle sizing.
Running off the MAF is better because the spray is more progressive throughout the powerband (as set by you). When running from a MAP based controller and you go WOT, you go from no spray to full spray within 300-600RPMs (depending on what turbo you're running) meaning when you hit full boost at the lowest possible RPM, the engine is essentially drowning in meth (assuming you have a nozzle large enough).
With a properly set MAF based controller, you adjust the flow of the meth to coincide with the increasing flow of the turbocharged air allowing you to a) conserve meth (this is a big big deal when flowing alot of meth) and b) maintain a constant AFR as opposed to having a giant dip on spool up then it gradually leaning out as the airflow outstrips the ability for the nozzle to maintain a richer AFR.
At the end of the day, MAF based is superior to MAP.
'07 CWP MS3
Forged.
The Following 2 Users Say Thank You to BlueStreak For This Useful Post:
f-castrillo (08-29-2011), Pointless (02-09-2014)
 Old 08-30-2011, 01:40 PM   #13
PapaSmurf's Avatar
Posts: 8,236   (View Stats)
subbed, just upgraded to a 3.5 bar map and will be doing this tonight most likely.
860whp/677wtq
2.7 V6 Ecoboost
 Old 08-30-2011, 01:47 PM   #14
BlueStreak's Avatar
Updated OP Excel attachment.
'07 CWP MS3
Forged.
 Old 08-30-2011, 02:00 PM   #15
PapaSmurf's Avatar
which tab do i use to put in my maf volts for psi conversion?
cant seem to find it on that spread sheet.
nvm im retarded, cant wait to get off work so i can fix my meth spray, has been bothering the shit out of me. haha
860whp/677wtq
2.7 V6 Ecoboost
BlueStreak (08-30-2011)
 Old 11-27-2011, 11:01 AM   #16
Tabasco69's Avatar
Posts: 554   (View Stats)
Tabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the world
How is this going to work on a maf that is clamped and skewed, I' am thinking it is not going to work?!
Tabasco69 is offline   Reply With Quote
 Old 11-27-2011, 11:32 AM   #17
TWOptSL0W's Avatar
Groans: 125
Move on to the genpu section please
 Old 11-27-2011, 01:44 PM   #18
Tabasco69's Avatar
owning a 2008 wtf would i do that?
a/ you have no clue
some people instead of changing out the maf have the ability to clamp it and skew out going signal to the oe ecm.....how about you move onto the remedial section cause this seems to be over you head smartass.
Last edited by Tabasco69; 11-27-2011 at 01:48 PM. Reason: MSF Database - Automerged Doublepost
 Old 11-27-2011, 01:56 PM   #19
TWOptSL0W's Avatar
Groans: 125
lols you win. i bet you have a jet chip too
 Old 11-27-2011, 01:58 PM   #20
Tabasco69's Avatar
AEM fic, gameboy much?
 Old 11-27-2011, 02:08 PM   #21
TWOptSL0W's Avatar
Groans: 125
ooo sorry sorry stickers then?
cpe meth controller and wi system johnac08 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 1 01-15-2009 04:25 PM
CPE Meth Controller with Custom Kit and Dyno TiZi Custom Performance Engineering (cp-e.com) 30 11-26-2008 06:01 PM
Page generated in 0.42320 seconds with 27 queries
