> MazdaSpeed 3 - How-To's
 Old 10-10-2009, 07:47 AM   #81
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
The side effects of a VTA valve cover ONLY exist if the stock pcv system is kept, dumping CC vapors into the intake manifold.
If you go with a venturi in the exhaust, then non of that vapor will reach your intake, and you shouldn't have any LTFT issues like deadman. This would cure your trims too deadman!
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
MATT DAMOND (10-10-2009), phantom3 (10-10-2009)
 Old 10-10-2009, 11:21 AM   #82
SilverDemon's Avatar
Posts: 3,034   (View Stats)
I think I have the solution in using a dual vacuum set up, the intake mani for the idle and low load situations, and the exhaust for the "in boost" situations. I have my catch can out of the car and just finished modding to accept the exhaust venturi and a vac gauge. I will be reinstalling it tomorrow and doing some testing, so with fingers crossed this should be it for the crank case evacuation building.
The Following 3 Users Say Thank You to SilverDemon For This Useful Post:
djuosnteisn (10-10-2009), MATT DAMOND (10-10-2009), spnkr21 (10-10-2009)
 Old 10-10-2009, 01:42 PM   #83
spnkr21's Avatar
Posts: 2,827   (View Stats)
will u need 2 catch cans if you do this?
The Following User Says Thank You to spnkr21 For This Useful Post:
SilverDemon (10-10-2009)
 Old 10-10-2009, 02:38 PM   #84
No, if everything works out, one catch can will do.
 Old 10-10-2009, 03:31 PM   #85
spnkr21's Avatar
Are you just going to put a T on the "OUT" of the CC, where one goes to the venturi and the other goes to the intake mani?
 Old 10-10-2009, 04:22 PM   #86
delete
Last edited by SilverDemon; 02-29-2012 at 02:02 PM. Reason: MSF Database - Automerged Doublepost
 Old 10-10-2009, 05:58 PM   #87
Speedie6's Avatar
Posts: 1,838   (View Stats)
The check valve on the exhaust, and the second PCV on the IM which will act as as check-valve will make it so that whichever has the higher vacuum will be open while the other will be closed.
The Following User Says Thank You to Speedie6 For This Useful Post:
 Old 10-11-2009, 11:20 AM   #88
delete
The Following 2 Users Say Thank You to SilverDemon For This Useful Post:
Speedie6 (10-11-2009), spnkr21 (10-11-2009)
 Old 10-11-2009, 12:32 PM   #89
Speedie6's Avatar
Hmm. That is interesting!
 Old 10-11-2009, 07:23 PM   #90
spnkr21's Avatar
So what if you had 2 catch cans. Would that help get just vaccuum at wot with the venturi and then vaccuum with IM during cruising. That way they're not fighting eachother. What vac did u get when u had just the venturi hooked up under wot?
 Old 10-11-2009, 09:20 PM   #91
Speedie6's Avatar
This leads me to wonder if an actual check valve in place of the Napa PCV would prove to be more of a safety measure.
So, you are saying pressure is coming through the PCV you added to the IM? In that case, yeah, sounds like you need an actual check-valve. Maybe another Moroso. Or, is there a check-valve design that would more directly plug in there? I looked at check-valves at Jegs, and they have a lot of expensive ones designed for fuel. Didn't quite find one exactly appropriate for our needs. I'm sure they exist, just, didn't find it.
Wouldn't buy you anything. They still have to T into the PCV. Sounds like he just needs a real check-valve.
 Old 10-12-2009, 03:16 AM   #92
I have thought about this after the testing results, I wonder if the pressure is just from the Napa pcv not acting fast enough, there is a spring inside the valve that is designed for metering air. I thought about another Moroso check valve, but I would like to try some other options and maybe some bench testing to see how fast some of the different check valves react.
 Old 10-12-2009, 03:50 AM   #93
I have candy in my van
MATT DAMOND's Avatar
Posts: 1,931   (View Stats)
Groans: 70
Silver, why not put another check valve between the mani and the CC? That way the valve closes under boost, and is open when vacuum in the mani is present.
I'm sure that a regular Mazda PCV valve would do the trick.
Current Fail:
 Old 10-12-2009, 08:47 AM   #94
Speedie6's Avatar
He did exactly that already, except he used a Napa PCV valve which was a part recommended by Cobb in their whitepaper on their recommended catch-can configuration. And it looks like at least the Napa part is not acting like a real check-valve. My understanding is that PCV valves are not really check-valves, they have a metering capability. So, I think he needs a real check-valve.
MATT DAMOND (10-12-2009)
 Old 10-12-2009, 09:07 AM   #95
JumpingJackson's Avatar
Posts: 967   (View Stats)
Silver Demon, What catch can are you using that has 2 outlets and 1 inlet? (looking at that diagram)
 Old 10-12-2009, 09:24 AM   #96
Speedie6's Avatar
The SilverDemon special, of course! He said he made it himself.
 Old 10-12-2009, 10:09 AM   #97
Thanks Speedie, I am using the one I made. I had modified my original version to accept the second vacuum source from the venturi pipe. The original version worked great, it would catch about a cup or so of sludge every oil change (2500 - 3000 miles)
I just ordered another Moroso check valve from Jegs, we will see what happens.....
 Old 10-12-2009, 10:24 AM   #98
Speedie6's Avatar
The original version worked great, so, you had to go fuckin' with it!
Seriously, I like the work you doing, man. I bet the Moroso check-valve, unless you get a fucked one like me, will work great. I haven't contacted Jegs yet about mine.
SilverDemon (10-12-2009)
 Old 10-12-2009, 12:12 PM   #99
Thanks.....I often wonder sometimes why we work on things that were fine to begin with.......LOL!
 Old 10-12-2009, 12:28 PM   #100
Speedie6's Avatar
Jegs and Summit Racing sell several brands of basically the same thing. Like there is a Jegs brand that you can get their brand check-valve for about $4 cheaper than the Moroso brand. It could be just the Moroso part just with the Jegs name on it. But it might not, as their weld-in tube is not the Moroso part, you can tell from the picture.
None of the other brands I found sold the check-valve as a separate item. Not that it matters much, I just thought it might be of interest to compare the quality of different brand check-valves. But, maybe not.
 Old 10-12-2009, 01:58 PM   #101
I looked at work today, but could not find anything that had a light enough spring to work the way we want it to. Most of the ones were 25 psi or greater......
 Old 10-12-2009, 02:44 PM   #102
Speedie6's Avatar
What kind of parts were you looking at? PCV values in order to try to get them to work as check-valves? If that is the case, then, I'd say we don't want a PCV valve at all.
 Old 10-12-2009, 03:31 PM   #103
No, I am sorry I did not type what I was thinking.....I was looking into actual check valves from an industrial stand point, like pneumatic controls. But the ones I found did not work in the range we need.
 Old 10-12-2009, 03:40 PM   #104
Speedie6's Avatar
Ah. I was thinking, 25 PSI, WTF? Didn' t make any sense.
I'm sure there are checkvalves perfect for our application. I just don't know where to look. But, the Moroso part will probably do fine.
SilverDemon (10-13-2009)
 Old 10-13-2009, 01:49 AM   #105
phantom3's Avatar
Posts: 1,223   (View Stats)
Groans: 190
If you want as much vacuum in the CC as possible then I would go with a low cracking pressure check valve form a pneumatic supply store.
You cab get them rebuildable with metal housings. They come as low as 0.005 PSI cracking pressure. You would have to mount it vertically on the chassis some where. The nice thing is that there is no spring inside (hence the need to mount it vertically).
http://www.directindustry.com/prod/a...30-30194.html#
Too bad we couldn't figure out a way to use a vacuum generator.
http://img.directindustry.com/images...ctor-30200.jpg
Compressed air is run through the middle and the outside 2 ports (!!) provide the vacuum.
On a side note; You can also get orifice flow restricters in various diameters. They would make switching out pills really easy.
My mission is to go fast.
Currently Designing:
The golden girdle of the gods
The CF "fuck your face" IM
phantom3 is offline   Reply With Quote
The Following User Says Thank You to phantom3 For This Useful Post:
 Old 10-13-2009, 03:12 AM   #106
Pneumatic check valves - - AIR-LOGIC - Valve, Clapper, Bursting disc
That was what I was looking for, I almost put in an order until I saw the operating temperature, 40* - 120*
 Old 10-13-2009, 03:29 AM   #107
_Toxic_'s Avatar
Posts: 643   (View Stats)
_Toxic_ is the leader of the world_Toxic_ is the leader of the world_Toxic_ is the leader of the world_Toxic_ is the leader of the world_Toxic_ is the leader of the world_Toxic_ is the leader of the world_Toxic_ is the leader of the world_Toxic_ is the leader of the world_Toxic_ is the leader of the world_Toxic_ is the leader of the world_Toxic_ is the leader of the world
Groans: 35
Groaned at 16 Times in 11 Posts
Good work! great pictures!
2010 Mazda 3 MPS White Pearl Mica
K&N Typhoon SRI // Ray Catback Exhaust // Eibach Pro Kit // Tenzo R Type M 18x8 Titanium // 20% Tint all wind
_Toxic_ is offline   Reply With Quote
The Following User Says Thank You to _Toxic_ For This Useful Post:
 Old 10-13-2009, 11:16 AM   #108
phantom3's Avatar
Groans: 190
Those are just examples. Those are all plastic units. They were the first pics I could find.
 Old 10-13-2009, 05:42 PM   #109
delete
The Following 6 Users Say Thank You to SilverDemon For This Useful Post:
amoosenamedhank (06-07-2011), cookieheadjenkins (03-17-2010), djuosnteisn (10-13-2009), FreeFlyFreak (10-30-2009), MATT DAMOND (10-14-2009), Speedie6 (10-13-2009)
 Old 10-13-2009, 06:26 PM   #110
Speedie6's Avatar
I took the car into boost, the gauge went to zero, and then barley pulled off the zero mark. My gauge is not sensitive enough to accurately read low vacuum like this. I am going to guess at around .1 - .5 inches of vacuum, and at one time I saw a little pressure, but I am not going to take that too serious because I was in between shifts and it could have been a little needle bounce. All in all I am satisfied with the results.
1) I was able to achieve a slight vacuum in the catch can while under boost.
2) I now know for sure that there is no pressure in the catch can, and crank case.
3) The catch can is virtually "catching" everything all the time.
All this is great info, except, I thought with your original setup with just the venturi and no IM connection, you were getting more vacuum at boost. Not a lot, but, more than what you were seeing this time. Right?
 Old 10-13-2009, 06:36 PM   #111
delete
 Old 10-13-2009, 09:03 PM   #112
Speedie6's Avatar
You are right.....I can't explain the difference in the readings. I will say that I like this set up better.......vacuum at low load and rpm, and a slight vacuum at boost conditions.
Great! Where did you get that idea from, he must be a fucking genius!
Seriously, 99.9% of the props go to you. You da man!
MATT DAMON has been participating in this thread, and he's the guy I was going to buy the cc kit from. He makes a kit using the Saikou Michi can. So, now that he has seen your results and what I am going to do, hopefully he can get me the kit soon.
SilverDemon (10-14-2009)
 Old 10-14-2009, 03:48 AM   #113
Groans: 70
Silver, are you using a check valve between the OCC and the exhaust? I'm just wondering if that while the I/M is at high vacuum, can that vacuum over-power the venturi effect at the exhaust, and pull in exhaust vapors into the manifold? There might just be something I'm not seeing here.
Can you run VTA on the valve cover with this set-up?
Regardless, amazing work!
Speedie, I'll email you when I get the parts in, I'm still waiting on a shipment, but I expect it to be here either today or tomorrow.
Current Fail:
The Following User Says Thank You to MATT DAMOND For This Useful Post:
 Old 10-14-2009, 05:41 AM   #114
delete
The Following User Says Thank You to SilverDemon For This Useful Post:
 Old 10-14-2009, 01:38 PM   #115
Speedie6's Avatar
Great. If your kit includes the secondary PCV, I won't need it, I'm going to buy another Moroso like Silver did.
It sounds like there is still some debate on what is best to do with the valve cover. Some options include leave it stock, VTA, conceivably to another exhaust venturi. I think I heard that someone also put a cc on the valve cover but left it connected to the intake. Maybe that was DJ, not sure. Of possible note, the install instructions for the crankcase evacuation system show you connecting it to the valve cover, so, that seems to be the "standard" way to do it, with a NA V8 anyway.
There was also some people that modded the valve cover, and at one time, PTP had plans on modding the valve cover.
I suppose we could install a second venturi and hook it to the valve cover. Maybe that can be SD's next project, figure out what best to do there.
Yeah, we'll get SilverDemon to do it! He likes projects!
The Following 2 Users Say Thank You to Speedie6 For This Useful Post:
MATT DAMOND (10-14-2009), SilverDemon (10-14-2009)
 Old 10-14-2009, 02:50 PM   #116
Must Have Teh 10's!
superskaterxes's Avatar
Posts: 10,442   (View Stats)
i have my valve cover tapped for my occ and i put a plate in to block off the stock PCV box.
btw the other stock port to the CAI is still stock.
First K04 in the 12's
First MS6 in the 11's
Certified RichTune E-Tuner
 Old 10-14-2009, 03:03 PM   #117
delete
 Old 10-19-2009, 09:01 AM   #118
Speedie6's Avatar
Thanks for all your hard work on this, SD. As far as parts, the Moroso check-valve has a 1/2" NPT fitting, correct? So, I guess you got a 1/2" NPT to 5/8" hose barb adapter?
Since I'm getting the Saikou Michi kit from Matt, I'll need to get a T. I'm sure I can find a 5/8" hose T.
I've got my second Moroso check-valve on the way from Jegs.
in my opinion it would be best to either keep it to the inlet pipe, or vent to atmosphere. I really don't see an advantage to either.
Well, I think some people said there was some crap coming through the valve cover connection. I think I remember even hearing of one person that put a second CC on that connection, but, I could be mistaken. At any rate, it is my expectation that I should be eliminating sufficient crap that I can leave the valve cover stock.
 Old 10-19-2009, 12:32 PM   #119
Yes, you are right, I used a 1/2" NPT to 5/8" barbed adapter. Yeah a "T" will have to put in the hose, those can be found at most home improvment stores.
 Old 10-19-2009, 01:55 PM   #120
Speedie6's Avatar
I don't think a 5/8" hose barb T is a particularly common size that you would find at Home Depot. As I said, I found it online in brass for about $16. In nylon, it was about about $1.50. The temp where it is at is probably okay to go nylon.
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f33/crankcase-evacuation-system-39239/
Blown engine theory - Page 23 This thread Refback 01-21-2015 02:43 AM
PCV bypass for VW 2.0 FSI Description/DIY (long) | Mechanical /Maintenance Forum | Bob Is The Oil Guy This thread Refback 03-08-2014 05:59 AM
Our PCV System and improving Vacuum on the Crankcase - Eliminate Smoking Turbo Issue - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum Post #150 Pingback 03-24-2012 04:53 PM
Solution to solve smoking turbo problem indefintly - Page 2 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 09-14-2011 07:10 PM
Draco Performance Crank Case "Breather" System Group Buy This thread Refback 05-31-2011 05:46 AM
OCC, short trips or long trips? - Page 2 - Mazda 6 Forums : Mazda 6 / Mazda Atenza Forum This thread Refback 12-01-2010 01:16 AM
Blown engine theory This thread Pingback 05-04-2010 04:31 AM
PCV bypass for VW 2.0 FSI Description/DIY (long) - Bob Is The Oil Guy This thread Refback 03-15-2010 04:26 PM
Draco Performance Crank Case This thread Refback 11-05-2009 03:30 PM
Need advice from the pros about recirculating crankcase blowby or not? Wenis Prinkle MazdaSpeed 3/6 - ECU Computer Tuning 9 08-03-2009 05:11 PM
Why install a OCC when you can vent the Crankcase to the ground? jamesthebikeguy MazdaSpeed 3 - Engine, Transmission & Driveline 48 03-28-2009 01:43 PM
Looking at getting a MI system, little help Stan-O MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 7 12-18-2008 09:09 PM
From Cow to Crankcase: Synthetic oil from animal fat Haltech Automotive News 0 12-03-2008 03:50 PM
PTP's CAT back exhaust system, soon to be TBE system. ptperformance Mazdaspeed3/6 General Discussion 56 10-05-2008 02:08 PM
Page generated in 0.55788 seconds with 29 queries
