| MazdaSpeed 3 - How-To's MazdaSpeed 3 - How-To's - Want help out fellow owners? Post How-To's to simplify future installations for others. |
(Thread Starter) | Not Ranked : 0 score So here’s what we are installing today: So before you can install this work of art, you need to remove the OEM POS. This required me to disconnedt the DP and TIP from the turbo so I could slide it back away from the EM studs. Post EM install pic with DP removed from the turbo with WG at full open on my ATP 2871R. There is really only one modification you need to make before you can bolt up the SS EM. The mani stud between runners 2 and 3 [pass to driver] needs to be removed because it will be two long. I already asked Leen about this and to keep the flow correct this can’t be helped. I simply replaced the OEM stud with a turbo to DP stud I had left over from my K04 to GT28 install. If I were smart [I wasn’t] I would have also replaced the studs that are right behind the turbo as well. I THINK this would allow you to remove the EM a second time without having to undo anything from the turbo. PLEASE DO THAT! Ok, now wasn’t that easy! Hahah In realtime it took be about 4 hours which included frequent breaks to enjoy some NewCastle, DosXX and other mood altering remedies. I can say I don’t actually enjoy getting under the car about 100 times so the aforementioned remedies are integral to a successful install. Now on to some eye candy shots. OEM turbo bracket rigged up ghetto style [soon to be modified with the BT Lenny Turbo Mount mod or BTLTM for short…yes this acronym will be on wiki by the end of the week] ![]() ![]() ![]() ![]() Ok that's it for the install, tune in again for impressions and before and after dyno results.
| The Following 15 Users Say Thank You to Dano For This Useful Post: | Addikted To Boost (12-15-2010), AJ713 (11-13-2010), BLURSPORTS (11-12-2010), BrianZX10R (11-11-2010), cpolly69 (11-11-2010), DSIT995 (11-12-2010), EwMPS (11-15-2010), Fobio (03-26-2011), JacksonMS30 (11-12-2010), JmkC (11-11-2010), madvillain (11-11-2010), mazda.speed3 (11-12-2010), MS3-a(sore)ASS-rex (11-11-2010), rodrigo (11-12-2010), wankular (11-12-2010) |
![]() Join Date: Jan 2009 Location: Bangor PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,426
Groans: 88
| Not Ranked : 0 score nice man, you should have gone with 38mm EWG but whatever. hope it performs good for you
__________________ 1995 honda civic. 1.6L slow 2007 Kawasaki ZX10r |
| The Following User Says Thank You to BrianZX10R For This Useful Post: | Dano (11-11-2010) |
| rabble rabble ![]() Join Date: Aug 2008 Location: Delawhere
Rep Power: 3168 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,400
Groans: 221
| Not Ranked : 0 score ugh so jealous. i <3 your car
__________________ '08 CWP MS3 w/ T3 3071r Last edited by 802MS3; 11-11-2010 at 09:19 PM. Reason: MSF Database - Automerged Doublepost |
| The Following User Says Thank You to 802MS3 For This Useful Post: | Dano (11-11-2010) |
__________________ ![]() 07 Red MS3 GT - E40 - Carrillo Rods - Wiseco Pistons - BSD - JBR 3.5 WidePath - ATP GTX3071 - Forge BPV - GA - Cobb v2 FMIC - CPE EM - CPE DP - CNT CBE - APv3 - Grim EBC - PERM dual port PCV plate - Dano dual OCC - CPE CDFP - Labonte S2 WMI - ACT Street Kit - SUv2 RMM - SU TM - "Stiffy" MM - DG CF wing ext, skirts & front lip - Hotchkis RSB/FSB w PowerGrid Links - Koni FSDs - DBA SX4000 Rotors - Hawk Pads - Silver OZ Ultraleggera - 235/40/18 NT-01 | |
| The Following 2 Users Say Thank You to Dano For This Useful Post: | AJ713 (11-13-2010), BrianZX10R (11-11-2010) |
![]() Join Date: May 2010 Location: North Jersey, NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 68
| Not Ranked : 0 score the ex mani looks awesome with your setup, keep up the work man, in for before/after impressions |
Groans: 78
| Not Ranked : 0 score fuuuuuuuuuuuuuuuuuuuuu nice dano. and great job to you, leen!
__________________ [Precision 5557 T4 flanged Journal Bearing Turbo][Race Roots Ceramic Coated T4 Manifold][Race Roots 3" V-Band Catless Downpipe][Race Roots Under-Car FMIC kit][CXracing 18"x31"x3" IC Core][Tial 44mm EWG With 0.9Bar Spring][Cobb AP][Full Str33tunit Mount Set][Madvillain 4" Inlet/Intake][Cp-e xcelXL Maf Housing][Devilsown Meth Injection Kit][HKS Ignition Amplifier][Cp-e Catback Exhaust][HKS bov][PTP IM Spacer][Whoosh EGR Delete][AEM Digital Boost Gauge][Matt Damond OCC Kit][Trunk Mounted Optima Battery with KnuKonceptz Kit][Madvillain ECU box][TWM Short Shifter][BC Coilovers][Cobb Rear Sway Bar][Falken Azenis rt615's][Eibach Pro 25mm Spacers] |
| The Following User Says Thank You to madvillain For This Useful Post: | Dano (11-11-2010) |
Groans: 224
| Not Ranked : 0 score Hey Dano, is there a way you can circle or highlight which studs in particular you mean? I'm seriously considering this mani and being able to remove it without touching the turbo would be quite nice....
| The Following User Says Thank You to MS3-a(sore)ASS-rex For This Useful Post: | Dano (11-11-2010) |
![]() Join Date: Dec 2008
Rep Power: 403 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,254
Groans: 109
| Not Ranked : 0 score i love these. looks great |
| The Following User Says Thank You to JmkC For This Useful Post: | Dano (11-11-2010) |
your problem areas are right between the compressor housing and head and again between the top oil feed line and head. Now with a K04 this might be possible as the comp housing is TINY and might not interfere with the stud. BUT, If you were to replace those studs when you do the swap I think you wouldn't have to disconnect the turbo again. This is theory not fact at this point.
| The Following 2 Users Say Thank You to Dano For This Useful Post: | JmkC (11-11-2010), MS3-a(sore)ASS-rex (11-11-2010) |
| The Following User Says NO Thank You to Dano For This Un-useful Post: | phillyb (11-12-2010) |
![]() Join Date: Aug 2008 Location: Kahaluu, HI
| Not Ranked : 0 score Great pics and thanks for the heads up on bolt between runners 2 and 3, that would've been frustrating once I order mines. Good luck with the tuning, can't wait to see dyno results.
__________________ 07 Black Mica with Sunroof" 11/17/11 ZZ-SB (Spun #4 Rod Bearing @97,643 miles) "I'm back Baby" says the almighty Bender CURRENT MODS: Cobb ATR self tune+JBR WP+FMIC+BNR S3+MI+IM+CP-e EXMAN: VDyno 351hp and 331tq BEST 1320: COBB AP S2+MSCAI2+FMIC-v1.03i Best ET on 2Nov08 13.6@98mph (yeah I missed 5th gear) |
Groans: 109
| Not Ranked : 0 score when i did mine i didn't move the turbo. but if i recall all the studs off the compressor side came out |
| The Following User Says Thank You to JmkC For This Useful Post: | phillyb (11-12-2010) |
(Thread Starter) | Not Ranked : 0 score according to your sig you are OEM turbo and, yes it might be possible....with a GT series turbo ...I don't see that happening. 1) you can't get a reverse torx on the stud with a GT turbo on. 2) if you can even remove the nut you stil have the stud to clear with the EM. now mabe if you get lucky your nut sticks to the stud and it comes out ..maybe I have to quit saying "get nut" "nut sticks" "stud" etc....
| The Following 2 Users Say Thank You to Dano For This Useful Post: | JmkC (11-11-2010), MS3-a(sore)ASS-rex (11-12-2010) |
Groans: 109
| Not Ranked : 0 score yes that is true. still have the little stocker k04. i was just confirming that its possible if you still have the k04. i like all this nut stick and stud talk haha |
| The Following User Says Thank You to JmkC For This Useful Post: | Dano (11-12-2010) |
![]() ![]() Join Date: Mar 2008 Location: Boise, Idaho
Rep Power: 1905 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 229
| Not Ranked : 0 score Im not even gonna lie. I really like this manifold. I wish I had it. What day are you dynoing? I should have mine back to the dyno here very soon. 18psi tune coming.
__________________ 2008 Mazdaspeed3, Fully built then fully parted. Sold 2007 ccsb Silverado, 3/5 drop Procharged, longtubes, 10psi Daily Mazdaspeed 12.5 @109 k04 stock ecu 18psi pump gas stock motor 311whp 11.7 @120 atp gtx3071r ap tuned 22psi 30/70 e85/pump stock motor. 422whp |
| Not Ranked : 0 score fuck you speed3 mother fuckers and your full access to the bottom of the turbo.
| The Following 7 Users Say Thank You to superskaterxes For This Useful Post: | Dano (11-12-2010), JmkC (11-12-2010), jracer (11-12-2010), madvillain (11-12-2010), MS3-a(sore)ASS-rex (11-12-2010), phillyb (11-12-2010), SIXual Panda (11-12-2010) |
(Thread Starter) | Not Ranked : 0 score hahaha yes we could put another turbo down there!!!
so have you put up another thread yet? Anyway looking forward to your results.
__________________ ![]() 07 Red MS3 GT - E40 - Carrillo Rods - Wiseco Pistons - BSD - JBR 3.5 WidePath - ATP GTX3071 - Forge BPV - GA - Cobb v2 FMIC - CPE EM - CPE DP - CNT CBE - APv3 - Grim EBC - PERM dual port PCV plate - Dano dual OCC - CPE CDFP - Labonte S2 WMI - ACT Street Kit - SUv2 RMM - SU TM - "Stiffy" MM - DG CF wing ext, skirts & front lip - Hotchkis RSB/FSB w PowerGrid Links - Koni FSDs - DBA SX4000 Rotors - Hawk Pads - Silver OZ Ultraleggera - 235/40/18 NT-01 Last edited by Dano; 11-12-2010 at 07:33 AM. Reason: MSF Database - Automerged Doublepost | |
| Banned ![]() Join Date: Jun 2008 Location: misery
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 11,510
Groans: 1,940
| Not Ranked : 0 score did you also say you removed the tip? ghhahahaha this ain't cpe man. did you drain coolant and take off the bumper as well? |
| The Following 2 Users Say Thank You to phillyb For This Useful Post: | Dano (11-12-2010), MS3-a(sore)ASS-rex (11-12-2010) |
(Thread Starter) | Not Ranked : 0 score Hahah Damn I knew I forgot a few steps Didn't remove TIp just disconnected it
![]() | | #19 | ![]() |
| Not Ranked : 0 score Fp will be here in morning. Ill start a new thread this weekend with all my trials, errors and successes. Ill say this. CAr is running really really good and pulling hard at 14psi I been running. 18-22psi coming soon. Im really curious to see if you pick up boost creep with the new manifold? YOu should see atleast 20whp gains across the board.
| LOC, Amp, Sub Install | ChimmyChong | 2010 MS3 - Car Audio & Electronics | 8 | 07-20-2010 08:15 AM |
| What if or What would it take to install.... | manofhonor24 | MazdaSpeed 6 - Engine, Transmission & Driveline | 6 | 06-30-2010 04:34 PM |
| DDM HID kit install. | mzdaspeed3 | Exterior | 6 | 02-13-2010 11:58 AM |
| ATP DP install | 06Speed6 | MazdaSpeed 6 - Engine, Transmission & Driveline | 7 | 12-22-2008 06:33 PM |
| MBC install help! | jlocurto | Mazdaspeed3/6 General Discussion | 5 | 09-28-2008 01:08 PM |
