> MazdaSpeed 3 - How-To's
 Old 10-20-2009, 12:54 PM   #1
Mcopping's Avatar
Posts: 14   (View Stats)
Mcopping is an unknown quantity at this point
Default Engine mounts?
How difficult is it to change out the engine mounts? and another question, is cobb still making the replacement shifter weight? just wondering...
Mcopping is offline   Reply With Quote
 Old 10-20-2009, 12:57 PM   #2
8.5MS3's Avatar
Posts: 4,636   (View Stats)
Groans: 326
changing the rear mount takes roughly a half hr, not hard at all. having 2 people helps a lot as the engine may need to be rocked to get re aligned with the bolt holes. Not sure about the other 2 tho....
No, cobb's shifter weight has been discontinued, but if you do some digging you may find a few vendors still have some. i got mine from JSCSpeed. you could also just get a saw and cut half the stock weight off
 Old 04-06-2010, 04:02 PM   #3
mazdaspeedkt's Avatar
Posts: 16   (View Stats)
mazdaspeedkt will become famous soon enoughmazdaspeedkt will become famous soon enough
Thanks for the info.
mazdaspeedkt is offline   Reply With Quote
 Old 10-20-2009, 01:36 PM   #4
soccerballz's Avatar
Posts: 596   (View Stats)
soccerballz is the leader of the worldsoccerballz is the leader of the worldsoccerballz is the leader of the worldsoccerballz is the leader of the worldsoccerballz is the leader of the worldsoccerballz is the leader of the worldsoccerballz is the leader of the worldsoccerballz is the leader of the worldsoccerballz is the leader of the worldsoccerballz is the leader of the worldsoccerballz is the leader of the world
I have heard that some people drill holes in their stock weight for the same effect. The rear motor mount is cake. The side engine mount and the tranny mount are more challenging but very doable, you have to hold the engine up with a jack when you replace those two and I would recommend a tq wrench to make sure the bolts get tight enough. If you plan on doing the side mounts there is a great write-up on SUF, there may be one on this site as well but idk.
08' Black Mica MS3
Mods: Vibrant 3" SRI, CP-E 3" TIP, GT3071 IWG, Manley H-beam rods, Wiseco Pistons, BSD, PG Exhaust Mani V3, CP-E Catted Downpipe, Borla CBE, CP-E FMIC, Cobb AP, CP-E HPFP, Turbosmart DP BOV, Cobb SS + Bushings, Cobb Shifter Weight.
Sponsored by NATOR VA
soccerballz is offline   Reply With Quote
The Following User Says Thank You to soccerballz For This Useful Post:
wette460 (03-04-2011)
 Old 10-20-2009, 02:40 PM   #5
patrick failman
karl-hungus's Avatar
Posts: 4,635   (View Stats)
Groans: 74
rear and passenger mounts are easy and the engine doesn't shift much.
the tranny mount isn't hard, but you have to remove your battery and the engine really shifts if your jacks aren't in the right place. there's a great how to by abilor over on 247.
 Old 10-20-2009, 04:26 PM   #6
reddeerspeed3's Avatar
Posts: 689   (View Stats)
reddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the world
i took me about 2hrs to install my side mounts. now that i've had them out-in-out again, the last time i pulled them out was 45min. a torque wrench is an absolute must for any of the mounts, and i use blue loctite for piece of mind. torque specs for the mounts can be found in the shop service manual
reddeerspeed3 is offline   Reply With Quote
 Old 12-02-2009, 09:45 PM   #7
kevdog's Avatar
Posts: 2,449   (View Stats)
kevdog is the leader of the worldkevdog is the leader of the worldkevdog is the leader of the worldkevdog is the leader of the worldkevdog is the leader of the worldkevdog is the leader of the worldkevdog is the leader of the worldkevdog is the leader of the worldkevdog is the leader of the worldkevdog is the leader of the worldkevdog is the leader of the world
at what point do upgraded motor mounts pay off? DO you have to be pushing major HP to see any improvement?
gtx3076 and shit
kevdog is offline   Reply With Quote
 Old 12-03-2009, 05:10 AM   #8
The rear motor mount will pay off on a stock ms3, its a must have. The sides help but aren't necessary on motors that are just lightly modded, imo anyway.
08' Black Mica MS3
predapio (12-11-2009)
 Old 12-03-2009, 05:40 AM   #9
patrick failman
Groans: 74
watch one of those sri install videos on youtube and see how much the ms3 engine shakes on the stock mz3 mounts.
i'd say upgraded rear and tranny mounts are worth it on an otherwise stock car (less wheel hop and missed shifts). an upgraded passenger mount is probably just preventive from the stocker going poop.
 Old 12-03-2009, 05:43 AM   #10
8.5MS3's Avatar
Groans: 326
This is what your motor is doing under the hood
scary isnt it...rmm cleans that up a lot
The Following 4 Users Say Thank You to 8.5MS3 For This Useful Post:
JNR5005 (01-08-2010), karl-hungus (12-03-2009), tbear2001 (06-08-2010), xfeejayx (06-08-2010)
 Old 12-03-2009, 08:39 AM   #11
kevdog's Avatar
wow, that is impressive! so what brand is best, and where do i start?
gtx3076 and shit
 Old 12-03-2009, 08:50 AM   #12
socks's Avatar
Posts: 3,250   (View Stats)
Groans: 125
I have a CPe rear engine mount, and its like they combined some sort of magic pixie dust, and black magic voodoo to make a stiff engine mount that didnt rattle my car to death.
i dig it. I tried the poly TRZ and Delrin TRZ and both were MUCH MUCH more vibrations.
The Following User Says Thank You to socks For This Useful Post:
kgb (03-31-2010)
 Old 12-03-2009, 08:58 AM   #13
wakeboarddude's Avatar
Posts: 860   (View Stats)
wakeboarddude is the leader of the worldwakeboarddude is the leader of the worldwakeboarddude is the leader of the worldwakeboarddude is the leader of the worldwakeboarddude is the leader of the worldwakeboarddude is the leader of the worldwakeboarddude is the leader of the worldwakeboarddude is the leader of the worldwakeboarddude is the leader of the worldwakeboarddude is the leader of the worldwakeboarddude is the leader of the world
With the mods in my sig i can def tell you that you need mounts all around! The RMM does a good job for a while but as you get closer to fully bolted it doesnt cut it. I have SU rmm in right now and getting the other 2 SU mounts when the mail comes. With my mods you can feel the engine move esspecially around turns. Also the whole engine shakes pretty good when you turn on the car and turn it off so i want to prevent all those movements. Its gonna suck for vibrations though!
09 CWP Speed3 GT- CP-e Nano, Speedie6 TIP, CP-e Catless Downpipe, ED FMIC w/ GodSpeed core, Devils Own Stage 2 Meth Injection Kit, KMD v2 fuel pump internals, HKS BPV, SU full motor mounts & shifter bushings, Cobb Springs, 1 res delete in cbe, HID Fogs, AutoMeter Cobalt boost gauge, Michi OCC, Denso 1 step colder plugs, MSD DH, COBB AccessPort V105 Stage 2+sf 93 fmic
[Today 11:50 PM] aaronc7: i just measured mine, a little over 12
wakeboarddude is offline   Reply With Quote
 Old 12-03-2009, 09:06 AM   #14
8.5MS3's Avatar
Groans: 326
cp-e 75 duro is awesome
 Old 12-03-2009, 09:18 AM   #15
patrick failman
Groans: 74
trz combo ftw.
 Old 12-03-2009, 10:52 AM   #16
full SU mount set
08' Black Mica MS3
 Old 12-11-2009, 11:18 AM   #17
Mcopping's Avatar
Thanks guys, I appreciate the input!
 Old 12-11-2009, 01:05 PM   #18
RayRayBauder's Avatar
Posts: 1,999   (View Stats)
RayRayBauder is the leader of the worldRayRayBauder is the leader of the worldRayRayBauder is the leader of the worldRayRayBauder is the leader of the worldRayRayBauder is the leader of the worldRayRayBauder is the leader of the worldRayRayBauder is the leader of the worldRayRayBauder is the leader of the worldRayRayBauder is the leader of the worldRayRayBauder is the leader of the worldRayRayBauder is the leader of the world
Groans: 234
Groaned at 154 Times in 122 Posts
if you cant find the shifter cobb shifter weight anywhere i have one im willing to sell you.
'08 MazdaSpeed3 - sold
RayRayBauder is offline   Reply With Quote
 Old 12-11-2009, 01:24 PM   #19
NewMexican's Avatar
Posts: 19   (View Stats)
NewMexican will become famous soon enough
I just have the rear, feels real solid but when the car is ideling with the AC on its kinda annoying.....
NewMexican is offline   Reply With Quote
 Old 12-11-2009, 01:31 PM   #20
BudUMfan's Avatar
Posts: 1,204   (View Stats)
BudUMfan is the leader of the worldBudUMfan is the leader of the worldBudUMfan is the leader of the worldBudUMfan is the leader of the worldBudUMfan is the leader of the worldBudUMfan is the leader of the worldBudUMfan is the leader of the worldBudUMfan is the leader of the worldBudUMfan is the leader of the worldBudUMfan is the leader of the worldBudUMfan is the leader of the world
Groaned at 9 Times in 7 Posts
Default Re: Engine mounts?
I also have the CP-E rmm, but still get hop. I'm going to try SU other two mounts as well. Probably the ptp kicker mount too.
BudUMfan is offline   Reply With Quote
 Old 12-12-2009, 05:37 AM   #21
patrick failman
Groans: 74
i'd start with a tranny mount and see what that does for you. i added a passenger mount in fear of the stocker exploding, but i don't think it's necessary.
The Following User Says Thank You to karl-hungus For This Useful Post:
BudUMfan (12-12-2009)
 Old 12-12-2009, 05:25 AM   #22
erod550's Avatar
Posts: 467   (View Stats)
erod550 is the leader of the worlderod550 is the leader of the worlderod550 is the leader of the worlderod550 is the leader of the worlderod550 is the leader of the worlderod550 is the leader of the worlderod550 is the leader of the worlderod550 is the leader of the worlderod550 is the leader of the worlderod550 is the leader of the worlderod550 is the leader of the world
Yea my bone stock car bucked the fan off the TMIC on the dyno, heh. Once I saw that I knew I had to start looking into mounts.
2011 Mustang GT Premium 5.0
2009 True Red Mazdaspeed3 - Sold
Cobb SRI | Cobb TIP | Cobb AP | CP-E DP | SU TMIC | Denso ITV22 | PTP HPFP | Synapse Synchronic BPV | Saikou Michi OCC | SU 90A RMM | SU Side Mounts | TWM Stage 2 STS w/Bushings | Dashhawk
erod550 is offline   Reply With Quote
 Old 12-12-2009, 06:31 AM   #23
BudUMfan's Avatar
I'll start there! Thanks.
 Old 12-15-2009, 03:31 PM   #24
HLR Element's Avatar
Posts: 2,477   (View Stats)
Groans: 109
all you need to do is remove 4 bolts right? i just got my RMM in yesterday and i'm thinking of doing it tomorrow morning... just need to get it done before i have to leave for classes... lol, maybe i should wait till the weekend
 Old 12-15-2009, 05:38 PM   #25
patrick failman
Groans: 74
rear...
HOW TO: Install TRZ DogBone Rear MotorMount - Mazda Forums
tranny...
How to: Install TRZ Transmission Mount - Mazda Forums
247 sucks...
Hello faggot it appears that you have not posted on Mazda Forums (Mazdas247.com) in several weeks, why not take a few moments to ask a question, help provide a solution or just engage in a conversation with another Member in the Community?
See you on the forums!
Sincerely,
Antoine Tokar
 Old 12-15-2009, 05:58 PM   #26
Groans: 109
^ post pics of naked people and get banned, you'll stop getting those emails lol, and thanks for the links... just wasn't sure how great 247 was for tutorials, i found one of M3F and that one seems fine too
 Old 01-07-2010, 07:56 PM   #27
zigezig's Avatar
Posts: 76   (View Stats)
zigezig is a name known to allzigezig is a name known to allzigezig is a name known to allzigezig is a name known to allzigezig is a name known to allzigezig is a name known to all
Groaned at 16 Times in 2 Posts
thanks for all the info all. now going to look for the diy rmm
Jesus saves!
07 ms3
zigezig is offline   Reply With Quote
 Old 12-15-2009, 02:52 PM   #28
mrjoshyman's Avatar
Posts: 238   (View Stats)
mrjoshyman is a splendid one to beholdmrjoshyman is a splendid one to beholdmrjoshyman is a splendid one to beholdmrjoshyman is a splendid one to beholdmrjoshyman is a splendid one to beholdmrjoshyman is a splendid one to beholdmrjoshyman is a splendid one to behold
anyone have a recommendation of a tranny mount vs ETD? i've currently got the SU rmm installed and an ETD thats still in the box. wondering would would be preferable as far as performance gain & minimal increase in vibes....dont wanna install the ETD if id b better off w/ a tranny mount
mrjoshyman is offline   Reply With Quote
 Old 01-10-2010, 06:12 PM   #29
carfanatic101's Avatar
Posts: 25   (View Stats)
carfanatic101 has a spectacular aura aboutcarfanatic101 has a spectacular aura about
Need to do mine Bad
carfanatic101 is offline   Reply With Quote
 Old 01-12-2010, 02:51 PM   #30
blackrs99's Avatar
Posts: 314   (View Stats)
blackrs99 is the leader of the worldblackrs99 is the leader of the worldblackrs99 is the leader of the worldblackrs99 is the leader of the worldblackrs99 is the leader of the worldblackrs99 is the leader of the worldblackrs99 is the leader of the worldblackrs99 is the leader of the worldblackrs99 is the leader of the worldblackrs99 is the leader of the worldblackrs99 is the leader of the world
Groaned at 8 Times in 5 Posts
You prolly won't have to rock the engine if u use a spare jack to just raise it a half a click (depending on the jack). I did that and everything went smooth.
::: Cobb AP ::: HTP 3" Full Intake ::: Ebay DP ::: CNT CBE ::: JBR Triology ::: JBR SSP ::: JBR RSB ::: CS TMIC ::: MSD Dashhawk ::: White PC RX-8 Wheels wrapped in Continental DWS 225-40-18 :::
::: DIZZY TUNED by Boost_creep :::
blackrs99 is offline   Reply With Quote
 Old 01-22-2010, 02:43 PM   #31
nycMS3's Avatar
Posts: 1,067   (View Stats)
nycMS3 is the leader of the worldnycMS3 is the leader of the worldnycMS3 is the leader of the worldnycMS3 is the leader of the worldnycMS3 is the leader of the worldnycMS3 is the leader of the worldnycMS3 is the leader of the worldnycMS3 is the leader of the worldnycMS3 is the leader of the worldnycMS3 is the leader of the worldnycMS3 is the leader of the world
Groans: 129
Just a quick question...
Im assuming some of you go to the dealer for various reasons, did the dealer ever hassle you guys for the mount?
NATOR NJ/NY/FL
09 MS3 tuned by Nishan
nycMS3 is offline   Reply With Quote
 Old 01-22-2010, 02:50 PM   #32
8.5MS3's Avatar
Groans: 326
no
 Old 01-22-2010, 02:51 PM   #33
BudUMfan's Avatar
Never.
 Old 01-22-2010, 03:02 PM   #34
wankular's Avatar
Posts: 4,343   (View Stats)
I know it's been said a million times already, but the rear mount is easy and makes the car drive 100x better. After about 10 minutes trying to rock the new one in, I took out those two tranny bracket bolts and the thing slid right in and all the bolts lined right up. You definitely feel the vibrations but it's nothing major. For reference I have the street unit one with the street bushing.
2009 MS3 sport MGM
 Old 03-04-2010, 03:41 PM   #35
Sniper2606's Avatar
Posts: 569   (View Stats)
Sniper2606 is the leader of the worldSniper2606 is the leader of the worldSniper2606 is the leader of the worldSniper2606 is the leader of the worldSniper2606 is the leader of the worldSniper2606 is the leader of the worldSniper2606 is the leader of the worldSniper2606 is the leader of the worldSniper2606 is the leader of the worldSniper2606 is the leader of the worldSniper2606 is the leader of the world
Groans: 33
Groaned at 32 Times in 15 Posts
i been looking at all the forums i could and see an installation with pictures for the rear mount and side mounts.. but no luck, unless im blind,, anybody that has a link i would really appreciate
Silly Lebron, rings are for Kobe
2011 WRX STI pro tune Invidia Downpipe and Exhaust,Cobb Intake Cobb AP 91
The nigga bought aluminum tubes! Do I need to tell you what the fuck you can do with an aluminum tube!?! ALUMINUM!!
Dave Chappelle
Sniper2606 is offline   Reply With Quote
 Old 03-04-2010, 07:13 PM   #36
StreetUnitForum.com
08' Black Mica MS3
 Old 03-04-2010, 09:51 PM   #37
jliu's Avatar
Posts: 8   (View Stats)
jliu will become famous soon enough
I just installed the CPE-RMM / 60. The shifting is totally different from stock. Very direct and smooth. The install was very easy. Make sure you take the three bolts off of the tranny bracket. This will make the install a lot easier.
There is a slight vibration when I tip the throttle, but it is very slight. Overall very please with the upgrade. My 08.5 only has 14,000 miles and the stock RMM look fine but the improvement with the CPE RMM is instantaneous.
jliu is offline   Reply With Quote
The Following User Says Thank You to jliu For This Useful Post:
kgb (03-31-2010)
 Old 03-04-2010, 10:16 PM   #38
I only took two bolts off and used the third to swivel it on, worked out well. That vibration will go away as your mount breaks in.
08' Black Mica MS3
 Old 03-25-2010, 11:15 PM   #39
jmonterr's Avatar
Posts: 45   (View Stats)
jmonterr will become famous soon enough
I just bought a set of trz mounts does any one have any recommendations for bushings and when they would have to be replaced?
jmonterr is offline   Reply With Quote
 Old 03-30-2010, 09:34 PM   #40
sean80's Avatar
Posts: 38   (View Stats)
sean80 has a spectacular aura aboutsean80 has a spectacular aura about
The rear mount is easy to install. Just 4 bolts. I did it with the car on ramps, it's a little tight, but you can do it. Once you get the mount in and are trying to line the 3 bolts up, just push up on the motor. I spent 15 minutes trying to wrestle the mount around until I figured that out lol. I put the SU mount in and it makes a huge difference. The power is now getting to the ground in 1st and 2nd (for the most part).
sean80 is offline   Reply With Quote
side engine mounts or torque damper jamspeed3 MazdaSpeed 3 - Engine, Transmission & Driveline 9 08-10-2009 08:34 PM
TRZ TM and SU engine mounts ms3boost MazdaSpeed 6 - Engine, Transmission & Driveline 2 03-27-2009 07:56 PM
SU Side Engine Mounts Completed & Installed Grim MazdaSpeed 3 - Engine, Transmission & Driveline 22 10-30-2008 02:29 PM
Page generated in 0.58620 seconds with 44 queries
