> MazdaSpeed 3 - How-To's
Like Tree7Likes
 Old 11-14-2011, 01:41 PM   #121
MSpeedzilla's Avatar
Posts: 121   (View Stats)
MSpeedzilla is the leader of the worldMSpeedzilla is the leader of the worldMSpeedzilla is the leader of the worldMSpeedzilla is the leader of the worldMSpeedzilla is the leader of the worldMSpeedzilla is the leader of the worldMSpeedzilla is the leader of the worldMSpeedzilla is the leader of the worldMSpeedzilla is the leader of the worldMSpeedzilla is the leader of the worldMSpeedzilla is the leader of the world
any idea if the kit they are selling fits in the same place or is this totally one of a kind
_____________________________________________
2008 Silver Gen 1, MS3 MSCAI, Cobb TIP, Full Catless Race/Downpipe, Cobb XLE Bpv, MAPerformance rmm, Cobb AP, HPFP, xt-m5-qs, Shift bushings(washers), denso ITV22, Torque Android app, .
MSpeedzilla is offline   Reply With Quote
 Old 11-16-2011, 02:49 PM   #122
Etipp98's Avatar
Posts: 1,947   (View Stats)
Groaned at 7 Times in 4 Posts
Same place as what? there are a couple different locations that these can be mounted, location depends on what gen and if ms3/ms6.
 Old 11-16-2011, 02:57 PM   #123
wankular's Avatar
Posts: 4,343   (View Stats)
When you buy one of these from Matt you have to state whether you want it in Location 1 (under the intake) or Location 2 (passenger side) and he'll send you the correct size hoses.
2009 MS3 sport MGM
 Old 11-19-2011, 10:59 AM   #124
oh i was talking about the same location as in the tut in this tread but that last post was what i was looking for thanks
 Old 04-24-2012, 09:13 AM   #125
pzr2874's Avatar
Posts: 6,778   (View Stats)
Groans: 146
Got my OCC kit in from Matt and was taking the PCV to IM hose off and heard a crack (stock pcv)... No biggie right as the kit eliminates the pcv?
Thanks for the help guys
Edit... Nevermind, it retains it.
 Old 03-10-2016, 09:55 PM   #126
anna alyssa's Avatar
Posts: 13   (View Stats)
anna alyssa will become famous soon enoughanna alyssa will become famous soon enough
Great info thanks for all the pics
anna alyssa is offline   Reply With Quote
 Old 05-21-2016, 11:37 PM   #127
Xenios's Avatar
Posts: 18   (View Stats)
Xenios is an unknown quantity at this point
Thank you for this write up!!
2008 MS3
Salt Lake City • 801
Xenios is offline   Reply With Quote
 Old 10-10-2016, 09:00 AM   #128
here.n.there's Avatar
Posts: 89   (View Stats)
here.n.there has much to be proud ofhere.n.there has much to be proud ofhere.n.there has much to be proud ofhere.n.there has much to be proud ofhere.n.there has much to be proud ofhere.n.there has much to be proud ofhere.n.there has much to be proud ofhere.n.there has much to be proud ofhere.n.there has much to be proud of
Originally Posted by bnoon View Post
Pics of where I mounted my SM catch can. I don't even have to lift the car or use tools to drain it.
I mounted it via heavy duty ty-wraps to the bracket that holds to two hard lines that run on the passenger's side bottom of the radiator (I didn't even look to see if those were AC lines, oil lines, or whatever). I used a 3" hole saw to cut the hole in the 3 pieces of plastic that converge on that area with no problems. Gotta watch those damn parking curbs even more now though, I tweaked it just a bit even with it NOT being the lowest thing hanging down... Still though, it works like a charm.
I also did something I doubt nobody else has done. I used copper hard line instead of the heavy duty hose. I tried the braided clear hose from Home Depot and it's not fuel resistant and was getting some deforming. The heavy duty heater hose was getting some collapsing, so I got some 5/8" nominal (1/2" ID) formable copper tube and bent my own hard lines. I'll get pics at the next oil change.
I was thinking of using copper myself and read what you did with your setup.
I'm surprised that nobody here had anything to say about your copper setup. I must be jaded from past experience.
But, yeah. Yours is the first time I've read of anyone going that route and i can see how hose collapse and deformation would be a thing of the past.
...just because you're paranoid doesn't mean they're not after you...
...what do I call my car?!!
I call it...RAGE...
...I'll lead with a straight, follow with a hook, then I'll step to my right...if you don't know these steps, you shouldn't dance with me...for those who do recognize these steps, you'd know that I can dance with the best of them...in my prime, anyway...
here.n.there is offline   Reply With Quote
 Old 12-29-2016, 11:47 PM   #129
SpeedThrills's Avatar
Posts: 172   (View Stats)
SpeedThrills has a reputation beyond reputeSpeedThrills has a reputation beyond reputeSpeedThrills has a reputation beyond reputeSpeedThrills has a reputation beyond reputeSpeedThrills has a reputation beyond reputeSpeedThrills has a reputation beyond reputeSpeedThrills has a reputation beyond reputeSpeedThrills has a reputation beyond reputeSpeedThrills has a reputation beyond reputeSpeedThrills has a reputation beyond reputeSpeedThrills has a reputation beyond repute
Phenomenal and very helpful how to. Appreciate it! Even though its making me dread the day i do this install
SpeedThrills is offline   Reply With Quote
 Old 01-28-2018, 08:02 PM   #130
Speed_Rat's Avatar
Posts: 12   (View Stats)
Speed_Rat is an unknown quantity at this point
Is there any scenario where the OCC would be run with an "in" line only and function properly?
Speed_Rat is offline   Reply With Quote
 Old 01-28-2018, 08:08 PM   #131
JSmith's Avatar
Posts: 707   (View Stats)
Groans: 106
Search more. Most do.
 Old 01-29-2018, 03:53 AM   #132
Speed_Rat's Avatar
Will do. Thanks..
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f33/how-mazdaspeed-3-catch-can-install-tons-7216/
oil catch tank mazda 6 - Szukaj w Onet.pl This thread Refback 04-13-2015 01:21 PM
?????????????? - ???????? 8 - ??? ? Mazda3 MPS - ????? 3 ???? (Mazda 3 .ru) This thread Refback 04-09-2013 08:58 AM
Ìàñëîóëîâèòåëü - Ìàçäà 3 êëóá (Mazda 3 .ru) This thread Refback 01-10-2013 03:53 AM
Catch cans: what are you running? - Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB This thread Refback 09-03-2012 08:43 PM
Catch Can WHY use it, HOW to use - MX-5 Miata Forum This thread Refback 07-24-2012 02:45 AM
3 (Mazda 3 .ru) > This thread Refback 07-05-2012 07:58 AM
Oil Catch Can - Everything you need to know This thread Refback 05-02-2012 01:14 PM
- 3 (Mazda 3 .ru) This thread Refback 03-28-2012 12:30 AM
Occ, pita, diy, help - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 10-07-2011 08:47 AM
Corsa Sport - for Vauxhall, Opel and Holden Corsa and Barina This thread Refback 02-22-2011 06:10 AM
Corsa Sport - for Vauxhall, Opel and Holden Corsa and Barina This thread Refback 02-22-2011 01:46 AM
Saikou michi occ + ptp pcv fix. This thread Refback 01-08-2011 02:15 PM
The GRM Mazdaspeed 3 project car?-Page 2: Grassroots Motorsports forum: Grassroots Motorsports Magazine This thread Refback 05-31-2010 04:59 PM
OCC This thread Refback 05-11-2010 10:17 AM
Saikou michi occ + ptp pcv fix. - Page 2 - Utah Mazdas This thread Refback 04-25-2010 11:34 PM
Catch Can - Colorado Mazda Club This thread Refback 02-10-2010 08:26 PM
2 locations for an OCC? - MazdasNW This thread Refback 12-22-2009 10:43 PM
Saikou Michi Oil Catch Cans - TorontoMazda3 This thread Refback 05-19-2009 12:12 PM
Saikou Michi Oil Catch Cans - TorontoMazda3 This thread Refback 05-17-2009 11:38 AM
MS3: bent rods/blown engines and Mazda - Page 2 - TorontoMazda3 This thread Refback 05-12-2009 12:32 PM
MS3: bent rods/blown engines and Mazda - Page 2 - TorontoMazda3 This thread Refback 05-12-2009 12:27 PM
Oil Catch Can - OzMPSclub - Australia's fastest growing Mazda MPS community This thread Pingback 02-15-2009 08:12 PM
occ install - COBB Forums This thread Refback 12-06-2008 09:07 AM
occ install - COBB Forums This thread Refback 12-06-2008 08:54 AM
Oil Catch Cans: What is the correct way to fit one? - OzMPSclub - Australia's fastest growing Mazda MPS community This thread Refback 11-12-2008 06:18 PM
Oil Catch Cans: What is the correct way to fit one? - OzMazdaClub.com - Australia's Best Mazda Car Club and Forum This thread Pingback 11-12-2008 05:23 PM
ADD Purchases!!!!! HELP! - Mazda6 / Atenza This thread Refback 09-08-2008 07:59 PM
Oil Catch Can? - OzMazdaClub.com - Australia's Best Mazda Car Club and Forum This thread Pingback 09-06-2008 04:35 AM
Serious exhaust problem - POURING OUT WHITE SMOKE - OzMazdaClub.com - Australia's Best Mazda Car Club and Forum This thread Pingback 08-24-2008 05:22 PM
What is EGR delete? - TorontoMazda3 This thread Refback 07-23-2008 06:58 PM
What is EGR delete? - TorontoMazda3 This thread Refback 07-23-2008 05:38 PM
What is EGR delete? - TorontoMazda3 This thread Refback 07-23-2008 04:47 PM
What is EGR delete? - TorontoMazda3 This thread Refback 07-23-2008 04:45 PM
What is EGR delete? - TorontoMazda3 This thread Refback 07-23-2008 04:25 PM
What is EGR delete? - TorontoMazda3 This thread Refback 07-23-2008 04:08 PM
How to install an oil catch can? Death-From-A-Mile MazdaSpeed 3/6 - Turbo Induction 7 09-13-2014 06:03 PM
Catch Can Install bova MazdaSpeed 3 - How-To's 67 12-03-2009 01:56 PM
Cops now charging for gas used to catch you Haltech Automotive News 2 06-20-2008 11:46 AM
$20 catch can yay or nay? kraz3y MazdaSpeed 3 - Engine, Transmission & Driveline 3 04-30-2008 04:58 AM
Catch can installed but I am still smoking Death-From-A-Mile MazdaSpeed 3/6 - Turbo Induction 21 03-28-2008 12:28 PM
Page generated in 0.34618 seconds with 30 queries
