| MazdaSpeed 3 - How-To's MazdaSpeed 3 - How-To's - Want help out fellow owners? Post How-To's to simplify future installations for others. |
![]() Join Date: Dec 2010 Location: Muncie, Indiana
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,066
Groans: 82
(Thread Starter) | Neutral : +3 score You will need: 3/8 inch drill bit/drill 2 inch PVC pipe cap ($1.25) 3 inch to 2 1/2 inch coupler with clamps ($6 at advanced auto parts) Tire Valve Stem ($6 for a set of 2 at AAP) This is how the pieces will be oriented... First, drill a hole in the top of the 2 inch PVC cap with the 3/8 inch drill bit Now, remove the nut for the valve stem so you can thread it into the new hole in your PVC cap. Leave the washer and the rubber washer (to create a seal) Then, get some vice grips on the valve stem, and thread it through the hole I actually tried to use pliers at first, but my hands weren't strong enough to hold the valve stem, and I got it a lil scratched up. Make sure you screw it in far enough so the rubber washer doesn't allow air through Next screw that nut onto the top of the valve stem To finish it off, Put the cap in the 3" end of the coupler, tighten it down, and you're ready to do a boost leak test!!! To do this, remove your intake, and tighten the 2 1/2" side of the coupler on your TIP. Get an air compressor and pressurize the system.... Listen for leaks. Putting the tester on the TIP will pressurize all your boost/vacuum lines.
__________________ ... TRADED : 07 MS3 GT Silver... fully bolted w/K04 CURRENT : 06 MS6 GT Silver.... KMD V2.something ~ Cobb AP ~ SURE SRI ~ Cobb TIH ~ Forge V1 BPV ~ SLS TP ~ SURE Torq R6 Last edited by Fatguy729; 05-18-2011 at 05:06 PM. |
| The Following 62 Users Say Thank You to Fatguy729 For This Useful Post: | 3ONBOOST (02-23-2013), aggierandy (03-26-2013), Dahouse702 (11-26-2011), Dash08 (10-27-2012), david001wj (10-26-2012), daztdMS6 (01-01-2012), dereeek (02-06-2012), djuosnteisn (09-06-2011), Docnox (06-14-2011), Domino81 (07-26-2012), dot584 (05-13-2013), Drumheller (05-18-2011), Duke A Luke (07-12-2014), Familyguy427 (05-07-2013), Ferdball (05-18-2011), Flight_SkoolSpeed (05-03-2013), GLORIFIEDBOZO (02-02-2012), Grim_BL3FW (04-29-2012), iLLin (04-22-2013), jabeel00 (11-23-2015), JacksonMS30 (08-22-2011), K.Mah (10-17-2012), kabobulate (05-18-2011), kaprikorn (04-03-2013), kolosok17 (12-26-2013), kylec_2003 (04-30-2013), labikesrcool (05-19-2011), Mase (12-14-2012), mazda dude (03-26-2014), mczimer (04-06-2013), meelo88 (02-19-2014), Menace1 (02-12-2013), mike w (06-26-2013), Mistersix (03-26-2013), Monotonous ONE (08-21-2011), NewCar (04-16-2013), nichall10 (05-19-2011), omgvance (08-15-2012), phate (02-02-2012), Pointless (10-01-2012), Pseud0logik (02-18-2012), rfinkle2 (05-22-2011), robbspeed (09-06-2016), silvapain (07-04-2011), skeeter149 (05-18-2011), Sneak (05-18-2011), spals (03-22-2013), speed3Texas (02-15-2016), SpeedViktm (10-14-2012), Speed_j23 (02-02-2012), suparobg (01-25-2015), supraman (06-11-2011), Tacheny (02-06-2013), TexasSpeed3 (09-30-2011), theschrum (06-10-2011), tkephart (10-21-2012), Tokay444 (05-23-2011), tomek_46 (12-15-2011), Tommy (07-30-2012), vdgmcool (05-18-2011), wankular (05-18-2011), whos_MS3 (09-29-2011) |
Groans: 82
(Thread Starter) | Not Ranked : 0 score Damn, why doesn't anyone sell something like this (besides the simplicity of making one)? Hell, maybe I will start... $20 plus shipping? They have flat rate boxes for $5-6... so $25 shipping included? Hmmm.... Fatguy = MSF vendor? LOL |
![]() Join Date: May 2009 Location: Scottsdale, AZ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,450
| Not Ranked : 0 score haha I made one but my coupler's blue. It's also a 2.75" - 2.5". I tried the 3" but it was too big for the cap and the coupler buckled due to how much I had to tighten it.
__________________ 2009 MS3 sport MGM |
Groans: 82
(Thread Starter) | Not Ranked : 0 score hmmm... I didn't have any issues with the 3", but that was the only size I could find at AAP (plus it's a quality coupler, 5 ply, nice and thick). Where did you get the 2.75"? |
| Not Ranked : 0 score The 2.75" was the TB one from my CX Racing fmic. I ended up buying a 4" long coupler to adjust my cold pipe a little better (and ended up having to cut a 1/2" off haha). It's a bitch trying to find a 4" long reducer coupler.
| The Following User Says Thank You to wankular For This Useful Post: | Fatguy729 (06-10-2011) |
Groans: 82
(Thread Starter) | Not Ranked : 0 score Oh Ok, rock on LOL. I bet it was hard to find something like that! |
![]() Join Date: Aug 2008 Location: Ashburn, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 305
Boostpro.net : Products - Boost Leak Testers | |
Groans: 82
(Thread Starter) | Not Ranked : 0 score SHUT UP!!! LOL... Oh well... | |
![]() Join Date: Jul 2008 Location: West Des Moines, IA
Rep Power: 854 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14
| Not Ranked : 0 score It's OK fatguy, you still made yours instead of buying someone else's and saved some cash. And you still have one more valve stem in your pocket.
__________________ _________________________________________ 2008.5 MS3 GT - Sold! 2011 Ford Flex LTD Ecoboost - Sold! 2013 Ford Focus SE - Sold! 1986 Porsche 944 Turbo - Sold! 2002 BMW M3 - Sold! 2014 Mustang GT 5.0 Track Pack 1974 GMC Super Custom 1500 built 350/TH400 3200 stall |
| The Following User Says Thank You to bnoon For This Useful Post: | Fatguy729 (06-10-2011) |
![]() Join Date: May 2008 Location: ME, MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,600
| Not Ranked : 0 score Nice improvising, kinda funny our shop just spent around $1600 for a smoke machine and with one or 2 more modifications you would have a vacuum leak tester for a fraction of the price.
__________________ [SIGPIC][/SIGPIC] |
| The Following User Says Thank You to jtspells For This Useful Post: | Fatguy729 (06-10-2011) |
Groans: 82
| Tripple OG ![]() Join Date: Dec 2008 Location: North Jersey
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,643
Groans: 113
| The Following User Says Thank You to NJSPEED3 For This Useful Post: | Menace1 (02-12-2013) |
![]() Join Date: May 2010 Location: Miramar,FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7
Groaned at 7 Times in 5 Posts
| Not Ranked : 0 score this came out on car mods,look it up on youtube.props to them. |
Groans: 82
![]() Join Date: Nov 2010 Location: Baltimore, Md
Rep Power: 356 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 20,356
| Not Ranked : 0 score FUCKING GENIUS
__________________ _____________________________________________ 2008 Silver Gen 1, MS3 MSCAI, Cobb TIP, Full Catless Race/Downpipe, Cobb XLE Bpv, MAPerformance rmm, Cobb AP, HPFP, xt-m5-qs, Shift bushings(washers), denso ITV22, Torque Android app, . |
| The Following User Says Thank You to MSpeedzilla For This Useful Post: | Fatguy729 (11-14-2011) |
Groans: 82
(Thread Starter) | Not Ranked : 0 score LOL glad to help!
__________________ ... TRADED : 07 MS3 GT Silver... fully bolted w/K04 CURRENT : 06 MS6 GT Silver.... KMD V2.something ~ Cobb AP ~ SURE SRI ~ Cobb TIH ~ Forge V1 BPV ~ SLS TP ~ SURE Torq R6 |
![]() Join Date: Sep 2009 Location: Skokie, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,341
| Not Ranked : 0 score You sure about the 3/8 drill cuz the valve stem doesn't seem to fit.
__________________ New: 06 WWP MS6 Old: 06 LPM MS6 |
![]() Join Date: Apr 2011 Location: Huntington Beach, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,626
| Not Ranked : 0 score 3/8 bit was perfect for me. a little snug, but that's how it should be ![]() what size is the stem u have? .453 or something like that?
__________________ |
![]() | | #19 | ![]() |
Groans: 82
(Thread Starter) | Not Ranked : 0 score Its a tight fit but it was the perfect size when I did mine... I had to use vice grips (shown in the picture after trying to use pliers)
![]() | | #20 | ![]() |
Groans: 82
(Thread Starter) | Not Ranked : 0 score Epic!
![]() | | #21 | ![]() |
![]() Join Date: Nov 2010 Location: Stormville, NY
Rep Power: 1415 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,027
Groans: 155
| Not Ranked : 0 score Thanks for the write up. |
| The Following User Says Thank You to Tommy For This Useful Post: | Fatguy729 (10-14-2012) |
![]() | | #22 | ![]() |
![]() Join Date: Jun 2008 Location: SF CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1
| Neutral : -1 score Thanks to the OP. I dont have an advanced auto parts but the local oreillys had the same exact part so I was able to follow through with making the tester. I added a boost gauge that I had laying around to mine so I could see how quickly/slowly my leak was. |
![]() | | #23 | ![]() |
![]() Join Date: Dec 2011 Location: Oceanside, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
Groaned at 7 Times in 4 Posts
| Not Ranked : 0 score Another thanks to the OP, this helped me confirm my major boost leak suspicion, found approximately where its coming from, now gotta pull my intake out and figure out the exact location. |
| The Following User Says Thank You to Cudarich For This Useful Post: | Fatguy729 (10-14-2012) |
![]() | | #24 | ![]() |
![]() Join Date: Apr 2012
Rep Power: 0 ![]() Thanks: 0
| Not Ranked : 0 score I bought all the supplies tonight except the metal tire valve stems. Went to 3 different places and all I can find are the rubber ones. Do you think that would work too? Imagine I'd have to drill a much larger hole. |
![]() | | #25 | ![]() |
Groans: 82
NICE!!! If I had an unused guage laying around it would be cool, but I wasn't gonna spend extra money for such a simple piece. I just plug my AP in and monitor boost on it while I test.
__________________ ... TRADED : 07 MS3 GT Silver... fully bolted w/K04 CURRENT : 06 MS6 GT Silver.... KMD V2.something ~ Cobb AP ~ SURE SRI ~ Cobb TIH ~ Forge V1 BPV ~ SLS TP ~ SURE Torq R6 | ||
![]() | | #26 | ![]() |
| nothing to see here.... ![]() Join Date: Jul 2010 Location: Round Lake, IL
Rep Power: 279 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 455
Groans: 39
Groaned at 43 Times in 18 Posts
| Not Ranked : 0 score So once it'sinstalledhow do you operate it? Smoke or air? Sorry I`m a nub!
__________________ 2008 Mazdaspeed 3 GT in Black Mica: 60ft: 2.167 1/8: 9.052 1/4: 13.922 @ 100.37 (26psi tire pressure & stock tires) CP-E CAI; CP-E Turbo Inlet Pipe; CP-E RMM; Engals ETD; TRZ TM; PG ExhMani; JBarone Shifter Weight, E4 Performance Shift Knob; Solid Shifter bushings; JBarone SSP ![]() ![]() : |
![]() | | #27 | ![]() |
Groans: 82
(Thread Starter) | Not Ranked : 0 score Ummm air. Like the original post says
![]() | | #28 | ![]() |
![]() Join Date: Mar 2012 Location: San Luis Obispo, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 86
| Not Ranked : 0 score For those having trouble finding a quality valve stem, places like Miner's Ace Hardware or Lowe's etc. will have valve stems, they aren't automotive but it doesn't matter, they are all metal and will hold the pressure.
__________________ 2007 MS6- BNR S3, HTP 3" Intake, 3 Bar MAP, DO Meth, CP-E Catted DP, Autotech Internals, SRI, ETS TMIC, Sure Sidewinder, Sure Charge Tubes, Lex tuned, BC Coils, Sure RMM, JBR SSP, Dreadnaught, Whiteline RSB 2008 Mazdaspeed3- Totalled! |
![]() | | #29 | ![]() |
![]() Join Date: Aug 2008 Location: Pittsburgh, PA
Rep Power: 637 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,048
| Not Ranked : 0 score Approximately how much pressure should one pressurize with? |
![]() | | #30 | ![]() |
Groans: 82
(Thread Starter) | Not Ranked : 0 score I usually do about 25 psi... My tune only boosts 19, so I feel that's good enough. Side note... Even if its clamped down as much as possible, the shit factory tip usually only holds about 10 lsu before leaking or popping off. My Cobb holds like a champ. Don't freak out though, cuz nothing on the intake side is ever pressurized during normal operation
| The Following User Says Thank You to Fatguy729 For This Useful Post: | Mistersix (03-27-2013) |
![]() | | #31 | ![]() |
![]() Join Date: Jul 2012 Location: Oceanside, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,654
| Not Ranked : 0 score Also, a good idea is too block off the recirc inlet on the TIP and let the BPV open to air while you pressurize. If you're running 20 PSI, and the BPV leaks at 20-24 PSI you're BPV is leaking. Just a tip.
__________________ 2010 Alternative Lifestyle Blue Mazdaspeed3 (sold)2008 Chevy Colorado. The only truck that comes with a lifetime guarantee... |
| The Following User Says Thank You to ABolewski For This Useful Post: | Mistersix (03-27-2013) |
![]() | | #32 | ![]() |
![]() Join Date: Mar 2010 Location: Colorado Springs, CO, USA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,160
Groans: 201
| Not Ranked : 0 score Here's the one I built tonight to test my intake system. Not the same as a boost leak, but I'm getting air into the system post-MAF/pre-turbo, so here's my tester: ![]() Goes right onto the MAF Housing for my ID300.
__________________ Stealth01 2006 Mazdaspeed6 GT Black Cherry Mica, Two-tone Leather interior, Sunroof, Bose SURE Full3 Aeros ID300 | SURE Shortcut | SURE Countershift | SURE Anchors | SURE AGS Atom Shift Knob | SURE Torque R6 RMM | SURE Ventus in Hybrid Mode | SURE Dreadnaught | SURE Juggernaught | SURE Flow M6 TP | SURE Charge Tubes | SURE Return | SURE S6 Side Motor Mounts | SURE Breather Line | Hawk HPS F/R Brake Pads | StopTech F/R Rotors | Technafit SS BL | Technafit SS Clutch Line | Primewell PZ900 Tires (blech) | Red LED Dome & Door Lights | O-series Stubby Antenna | Cobb AP | ACT 6 Puck Clutch w/Prolite FW | Autolite XP Plugs (One Step Colder) | Whistler Pro-78SE Hard-wired | STRATIFIED Tuned by Lex | COMING SOON: Autotechs | SURE TIG Read my stories: https://www.smashwords.com/books/view/55318 Last edited by Stealth01; 04-06-2013 at 09:51 AM. |
![]() | | #33 | ![]() |
| Not Ranked : 0 score Thats a good idea too. Looks like a HDP boost leak tester. |
![]() | | #34 | ![]() |
Groans: 82
(Thread Starter) | Not Ranked : 0 score I assume you meant pre turbo LOL
![]() | | #35 | ![]() |
Groans: 201
| Not Ranked : 0 score Yes, but being retarded I sometimes mis-type.
__________________ Stealth01 2006 Mazdaspeed6 GT Black Cherry Mica, Two-tone Leather interior, Sunroof, Bose SURE Full3 Aeros ID300 | SURE Shortcut | SURE Countershift | SURE Anchors | SURE AGS Atom Shift Knob | SURE Torque R6 RMM | SURE Ventus in Hybrid Mode | SURE Dreadnaught | SURE Juggernaught | SURE Flow M6 TP | SURE Charge Tubes | SURE Return | SURE S6 Side Motor Mounts | SURE Breather Line | Hawk HPS F/R Brake Pads | StopTech F/R Rotors | Technafit SS BL | Technafit SS Clutch Line | Primewell PZ900 Tires (blech) | Red LED Dome & Door Lights | O-series Stubby Antenna | Cobb AP | ACT 6 Puck Clutch w/Prolite FW | Autolite XP Plugs (One Step Colder) | Whistler Pro-78SE Hard-wired | STRATIFIED Tuned by Lex | COMING SOON: Autotechs | SURE TIG Read my stories: https://www.smashwords.com/books/view/55318 |
![]() | | #36 | ![]() |
![]() Join Date: May 2013 Location: Cody Wyoming
| Not Ranked : 0 score Just joined on here. Thanks for the info and pics built one of these today and was super simple. |
| The Following User Says Thank You to Tattooboost For This Useful Post: | Fatguy729 (05-06-2013) |
![]() | | #37 | ![]() |
| Banned ![]() Join Date: Dec 2011 Location: wisconsin
Rep Power: 0 ![]() ![]() ![]() Thanks: 1
Groaned at 40 Times in 10 Posts
| Not Ranked : 0 score so do u block off the bpv off the tip or leave that hooked up |
![]() | | #38 | ![]() |
![]() Join Date: May 2011 Location: Vero Beach, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 417
| Not Ranked : 0 score to those wondering, you can use a rubber valve stem. I've had mine, exactly the same as the OP's for a couple years with a rubber stem and its perfectly fine. If they can seal a tire/wheel at 35+ psi they can hold 25~ no problem. As far as drilling the hole, start with a 3/8 bit and see how it fits, I can't remember what size I used. it just pulls through and has a ridge that seals it.
__________________ '02 Bmw 330ci Kinda low and really slow. '94 Mazda Protege -SOLD 1.8 BPT Vf10 263whp 258wtq 13.1 @ 107 mph '05 ZX-6RR - Two Brothers slip on, GPR dampener V1, More to come |
![]() | | #39 | ![]() |
![]() Join Date: Mar 2012 Location: Middletown, CT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 84
How do you suggest I block off the recirc inlet....which I am assuming is the smaller pipe on the TIP (is it?). What do you mean "let the BPV open to air". Is that the valve on the cold pipe between the TMIC and TB ? Thanks | |
![]() | | #40 | ![]() |
![]() Join Date: Jul 2011 Location: New London, CT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 759
| Not Ranked : 0 score Making one of these tomorrow. Thanks op |
| The Following User Says Thank You to ABloodBrother For This Useful Post: | Slickasice (04-28-2017) |
| Boost leak? | mrQQ | MazdaSpeed 3/6 - Turbo Induction | 16 | 04-09-2011 02:09 AM |
| Vacuum leak, but no boost leak? | vbt101 | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 23 | 04-18-2010 01:06 PM |
| Possible MS6 Boost Leak Need Help | TheNewGuy | MazdaSpeed 6 - Engine, Transmission & Driveline | 7 | 12-10-2009 08:18 PM |
| boost leak tester | fdkss03 | MazdaSpeed 3/6 - Turbo Induction | 18 | 07-09-2008 08:36 AM |
