> MazdaSpeed 3 - How-To's
 Old 08-12-2013, 03:47 PM   #1
Ms3bimbo's Avatar
Posts: 7   (View Stats)
Ms3bimbo will become famous soon enough
Default How to open hood with broken latch
Couldnt find any threads on how to open hood if latch breaks or comes undone from engine bay wich happened to me. So thought id make a quick right up hopefully its usefull. So i closed my hood the other day and it came undone from engine bay so trying to mess with latch was pointless. So first pry between hood and grill with screwdriver or similar make sure to put tape around so it wont chip paint. Tht should give u enough room to fit socket Then remove 2 10mm bolts tht should get hood open more to where u can stick ur hand in and reach behind latch on the right side and pull lever to the right and tht should do the trick. Hope this helps.
Ms3bimbo is offline   Reply With Quote
 Old 03-04-2018, 10:43 AM   #2
Rh2racing's Avatar
Posts: 5   (View Stats)
Rh2racing can only hope to improve
Groaned at 4 Times in 1 Post
This won't help if the hood won't move at all. How can you pop it from underneath? I'm getting flush hood pins soon. I can't keep doing this. I've never had a car that had this problem. This is the 3rd time but the first time it didn't pop up at all
Rh2racing is offline   Reply With Quote
 Old 07-27-2018, 12:31 PM   #3
E.Murray's Avatar
Posts: 35   (View Stats)
E.Murray is an unknown quantity at this point
So what did you do when it wouldn't pop at all? Unfortunately, this is relevant information for me...
E.Murray is offline   Reply With Quote
 Old 07-27-2018, 04:23 PM   #4
Rh2racing's Avatar
I had to undo the bolts from under the car. Undoing the bolts allows the hood to raise up a few inches then you can you can undo the latch.
GM recalls 145,628 mid-sized pickups for hood latch issue Haltech Automotive News 0 12-20-2012 08:10 AM
Broken piece of broken shit won't start turd burglar MazdaSpeed 3/6 - Troubleshoot/Diagnostics 142 09-09-2011 07:51 PM
Nearly 300,000 HHRs to be recalled for latch failure Haltech Automotive News 0 09-09-2008 06:40 AM
Latch fix set for nearly 300,000 HHRs Haltech Automotive News 0 09-08-2008 12:30 PM
Page generated in 0.23736 seconds with 22 queries
