> MazdaSpeed 3 - How-To's
Like Tree16Likes
 Old 12-14-2012, 10:43 AM   #41
Police - Grammarhead
Vansquish's Avatar
I drove for about 4 months with a P0126, and highway cruising coolant temps in the mid 160s. It's probably not terribly detrimental to the engine to run at that kind of temperature, but it's probably better to get it taken care of earlier rather than later.
 Old 12-14-2012, 11:09 AM   #42
$40 from onlinemazdaparts.com, and then a few hours...
Or trade it in for a Speed 3...
cam0070 (03-27-2015)
 Old 12-24-2012, 05:20 PM   #43
radioflyer's Avatar
Posts: 729   (View Stats)
radioflyer is the leader of the worldradioflyer is the leader of the worldradioflyer is the leader of the worldradioflyer is the leader of the worldradioflyer is the leader of the worldradioflyer is the leader of the worldradioflyer is the leader of the worldradioflyer is the leader of the worldradioflyer is the leader of the worldradioflyer is the leader of the worldradioflyer is the leader of the world
Groaned at 22 Times in 12 Posts
Just did this a couple of days ago. It was not nearly as bad as I thought it was going to be. I had read people were removing the whole fucking IM to get to it, really glad I didn't have to go through that.
Bought the autozone special for $27. Low coolant temp problem solved, hopefully for good.
Overall took about 4 hours with an oil / filter change and OCC drain included in that time.
-2007 MS3 - Sold
-2015 BMW m235i - Painfully stock and incredibly comfortable.
radioflyer is offline   Reply With Quote
 Old 12-24-2012, 07:10 PM   #44
mach69's Avatar
Posts: 79   (View Stats)
mach69 has a reputation beyond reputemach69 has a reputation beyond reputemach69 has a reputation beyond reputemach69 has a reputation beyond reputemach69 has a reputation beyond reputemach69 has a reputation beyond reputemach69 has a reputation beyond reputemach69 has a reputation beyond reputemach69 has a reputation beyond reputemach69 has a reputation beyond reputemach69 has a reputation beyond repute
Originally Posted by BobTeatow View Post
Cleared P0126 but in test drive this morning in freezing CT, OBD/ELM/Torque shows temperature never going above 160F.
So what are the risks of delaying thermo replacement?
I'm not noticing any problems, engine running okay and cabin heat okay.
Thanks,
Bob T
Mazda 3 / hatchback with 2.x engine, no-turbo.
The risks? Your ECT doesn't come up to the temperature it should (along with the oil). This will cause premature wear on the engine. My friend had a Mazda 3 with that code for months. Didn't seem to have problems from it, but he did sell it not long after he replaced the thermostat.
Haha. And people thought taking off the PS pump was absurd. Taking off the IM... completely unnecessary. But if you do take off the IM, might as well clean the valves.
2008 Mazdaspeed 3 - True Red
Engine: CPE Nano, CPE TIP, CPE TMIC, CPE HPFP, CS BeCuse Injector Seals, SU Boost Tubes, Forge BPV V1, ITV-22, AQ Motorsports DP, Dashhawk, Spin-on Oil filter conversion, Saikou Michi OCC, Cobb AP Self-tuned, VTCS Delete, EGR Delete, TB Coolant Bypass, DFDD VVT, 3 bar map
Drivetrain: Southbend Clutch Stage 3 DD, JBR Short Shift Plate, SU Shifter Bushings, CPE Stage 2 RMM, CPE TMM
Suspension: Koni Yellows, Eibach Springs, Cobb RSB, MOOG Swaybar Endlinks, Energy Suspension FSB Bushings
mach69 is offline   Reply With Quote
 Old 01-20-2013, 10:06 AM   #45
pzr2874's Avatar
Posts: 6,778   (View Stats)
Groans: 146
Thanks for the write-up. Might want to add a quart of PS fluid to the list. I lost about a 1/4 quart moving the PS pump.
 Old 01-20-2013, 10:14 AM   #46
radioflyer's Avatar
wait. what.
you mean to say you disconnected the lines to the pump?! why?!
-2007 MS3 - Sold
 Old 01-20-2013, 06:06 PM   #47
Decepticon's Avatar
Posts: 1,221   (View Stats)
Decepticon is the leader of the worldDecepticon is the leader of the worldDecepticon is the leader of the worldDecepticon is the leader of the worldDecepticon is the leader of the worldDecepticon is the leader of the worldDecepticon is the leader of the worldDecepticon is the leader of the worldDecepticon is the leader of the worldDecepticon is the leader of the worldDecepticon is the leader of the world
Groaned at 43 Times in 28 Posts
just did this an hour ago with my ms6..I didn't remove the ps pump nor the IM. The hardest part was sliding off the hoses from the thermostat. I unbolted the the bolts and took the thermostat off the housing first before taking the hoses off..I think this is the best way because it allows you to move the hoses around to get better access to the clamps. It was a tight fit getting the thermostat out and up while its still attached to the two hoses but there was enough space.
06 MS6, Cobb AP, -TUNED on corn mix, KMD v2 fp internals, NGK Iridium IX sp, Cp-e Xcel NANO, PG tip, SU bpv, AWR rear MM, Jbarone shifter plate and bushings, ATP catted dp, Corksport catback, Altered Custom fmic, H&R springs...
R.I.P. 08.5 MS3, Cobb Ap, KMD v2 fp internals, Denso ITV22 sp, Cobb Sri, TurboXS bpv, SU rear mm, SU shifter bushings, ETS TMIC, SU boost tubes, Cp-e catted dp, Enkei EKM3.
Decepticon is offline   Reply With Quote
 Old 01-20-2013, 08:31 PM   #48
radioflyer's Avatar
Lol! I did the same thing, I went through the trouble of re-attaching the thermostat to the block just to get the hoses off.
-2007 MS3 - Sold
 Old 01-20-2013, 10:21 PM   #49
skeeter149's Avatar
Posts: 3,742   (View Stats)
Groans: 91
as a note on this speed 3 uses atf for power steering. i put power steering fluid when i did my fmic then read somewhere that it uses atf. drain and fill i did but i never had issues with the power steering fluid. but yes manual says atf.
 Old 01-21-2013, 06:41 AM   #50
pzr2874's Avatar
Groans: 146
wait. what.
I don't have the smallest of hands.
To add, Mazda changed the ATF to M5 and can be mixed with the old M3 ATF stuff.
 Old 01-21-2013, 11:20 AM   #51
radioflyer's Avatar
Oh I see, I just kind of bent it out the way. I didn't bother actually disconnecting the hydrolic lines.
-2007 MS3 - Sold
 Old 01-25-2013, 05:31 PM   #52
mach69's Avatar
You are welcome. I did not remove the PS lines so I didn't need any PS fluid. I have big hands as well and just moved the pump out of way without having to disconnect the lines. More than enough space.
Actually, I had difficulty removing the hoses as well from the thermostat. I rebolted the thermostat back to the block as well. I used just one bolt, I put so much force on the plastic thermostat housing while trying to take off the hoses I broke the housing.
I did the same thing. I'll edit the how-to when I'm sober.
Neither do I. I probably bent the lines more than I should have getting the PS pump out of the way, but the lines seem fine. Palming a basketball with one hand ftw.
I did the same thing. The hoses were flexible and made it easy to move the PS pump.
The Following 2 Users Say Thank You to mach69 For This Useful Post:
pzr2874 (01-25-2013), radioflyer (01-26-2013)
 Old 01-25-2013, 06:10 PM   #53
pzr2874's Avatar
Groans: 146
Once that was out took 15 mins to get to the butterfly clamps and change the thermo. Just another idea. Didn't think about riding the bolt out while pulling the pump.
I WAS DONE FUCKING WITH IT. Thanks again.
 Old 01-27-2013, 04:06 PM   #54
DynoBunny's Avatar
Posts: 66   (View Stats)
DynoBunny has a reputation beyond reputeDynoBunny has a reputation beyond reputeDynoBunny has a reputation beyond reputeDynoBunny has a reputation beyond reputeDynoBunny has a reputation beyond reputeDynoBunny has a reputation beyond reputeDynoBunny has a reputation beyond reputeDynoBunny has a reputation beyond reputeDynoBunny has a reputation beyond reputeDynoBunny has a reputation beyond reputeDynoBunny has a reputation beyond repute
Groaned at 9 Times in 4 Posts
I don't see how you guys got the god damn belt on by yourselves.
DynoBunny is offline   Reply With Quote
 Old 01-27-2013, 05:06 PM   #55
pzr2874's Avatar
Groans: 146
I had to have a friend loop it over the PS pump as well. Some ppl have ape arms.
 Old 01-27-2013, 05:17 PM   #56
DynoBunny's Avatar
Yea waiting on the wife to get home, fuck that shit.
 Old 01-27-2013, 11:55 PM   #57
miklo13's Avatar
Posts: 22   (View Stats)
miklo13 is infamous around these parts
Groaned at 22 Times in 7 Posts
i have p0126 on my ms3 u guys saying that is the tt
miklo13 is offline   Reply With Quote
 Old 01-28-2013, 06:09 AM   #58
radioflyer's Avatar
yes
-2007 MS3 - Sold
 Old 01-28-2013, 06:11 PM   #59
 Old 02-10-2013, 06:29 PM   #60
spals's Avatar
Posts: 305   (View Stats)
spals is the leader of the worldspals is the leader of the worldspals is the leader of the worldspals is the leader of the worldspals is the leader of the worldspals is the leader of the worldspals is the leader of the worldspals is the leader of the worldspals is the leader of the worldspals is the leader of the worldspals is the leader of the world
Thanks for the write-up. I threw a P0126 on my way back to Dallas from buying the car in Austin. Got home yesterday and ended up replacing the thermostat. CEL hasn't returned and the temp gauge has returned to normal.
One thing that you might add that stumped me for five minutes is that when you remove the electrical connector from the power steering pump you need to compress the clip to get it to release. I tried to pull the tab out of the connector and it wouldn't release from the sensor.
CP Pistons 88mm, Manley H-Beams, Balanced Crank
BNRS3V2, Cobb Catted DP, ETS TMIC, 3.5" JBR Alum Intake, AT HPFP
GS EBCS, 3 Bar Map, JBR 88 RMM, DM OCC, TIGs, BSD+Baffle
SBC Stage 2 Daily, JBR RSB, Koni Yellow, Konig Miligrams 18x8.5, Nitto NT-05 245/45
Spalsbuilt-Freektuned
spals is offline   Reply With Quote
 Old 02-13-2013, 11:04 AM   #61
v8 convert
p057's Avatar
Posts: 1,782   (View Stats)
p057 has disabled reputation
Groans: 220
I've done the serp belt replacement by myself. without any issue. trick is using a LONG thick flathead screwdriver. and a long ratcheting wrench, hold that with your foot to keep the tension pulley off. LOL.
My ECTs are starting to dip to 165 during highway cruises. It gets up to 190-200 easily if i'm ragging on it or sitting in traffic, but i'm sure i need to replace it. Hopefully in about a month. (hopefully the goddamn house closes by then!!! ARGG!)
Thanks for the guide, i think this will be my first repair in my brand new garage.... along with valve cleaning, IM spacer install and CPE seals install.... hahaha, gonna really break that thing in!!
p057 is offline   Reply With Quote
 Old 02-13-2013, 10:35 PM   #62
mach69's Avatar
Its easy. Grab 14mm and 15mm combination wrenches. You are going to put the box/closed end of the 14mm wrench onto the tensioner. Before you do that, wrap the box/closed end of the 15mm wrench around the open end of the 14 mm wrench. You get a lot of leverage with this. Pic below. I know its a shitty cel phone pic, but you get the idea.
Once you have your wrenches wrapped around each other, put your serpentine belt on every pulley except the crankshaft pulley. Loosen up the tensioner with your left hand and force the belt over the crankshaft pulley with your right hand.
Done. Even used your exact wording.
You are welcome. Valve and IM cleaning, VTCS delete, EGR delete, and TB coolant bypass is my next 'project'.
 Old 06-21-2013, 07:51 PM   #63
Jeter_1's Avatar
Posts: 43   (View Stats)
Jeter_1 is a splendid one to beholdJeter_1 is a splendid one to beholdJeter_1 is a splendid one to beholdJeter_1 is a splendid one to beholdJeter_1 is a splendid one to beholdJeter_1 is a splendid one to beholdJeter_1 is a splendid one to behold
Subbed for easy reference..
Jeter_1 is offline   Reply With Quote
 Old 08-10-2013, 04:35 PM   #64
CaptainCode's Avatar
Posts: 81   (View Stats)
CaptainCode has a reputation beyond reputeCaptainCode has a reputation beyond reputeCaptainCode has a reputation beyond reputeCaptainCode has a reputation beyond reputeCaptainCode has a reputation beyond reputeCaptainCode has a reputation beyond reputeCaptainCode has a reputation beyond reputeCaptainCode has a reputation beyond reputeCaptainCode has a reputation beyond reputeCaptainCode has a reputation beyond reputeCaptainCode has a reputation beyond repute
Groaned at 6 Times in 2 Posts
Did mine today. No way I could do it without unbolting the power steering pump and moving it out the way. That thing was a motherfucker to get off. Bolts were quite difficult to get off, especially the bottom one. Tensioner belt was also a huge PITA to get back on but I did it without help. I got 1 gallon of FL22 from the dealer. Looks like I might need to add a little bit of distilled water but not much.
Thermostat was quite the rip compared to some of you guys(I live in Canada, bought OEM from the dealer). It cost $79+tax. Went and looked at Part Source and they weren't much cheaper for the aftermarket one.
The swap took me 4 hrs.
Thanks for the how-to!
CaptainCode is offline   Reply With Quote
 Old 08-25-2013, 08:12 AM   #65
He Hate Me's Avatar
Posts: 460   (View Stats)
He Hate Me is the leader of the worldHe Hate Me is the leader of the worldHe Hate Me is the leader of the worldHe Hate Me is the leader of the worldHe Hate Me is the leader of the worldHe Hate Me is the leader of the worldHe Hate Me is the leader of the worldHe Hate Me is the leader of the worldHe Hate Me is the leader of the worldHe Hate Me is the leader of the worldHe Hate Me is the leader of the world
*Edit*
Don't buy the Stant from Pep Boys. The main inlet is 1" longer, thus going right into your A/C line.
He Hate Me is offline   Reply With Quote
 Old 08-25-2013, 09:47 AM   #66
new_speed's Avatar
Posts: 5   (View Stats)
new_speed is an unknown quantity at this point
This was a great how to! Only took me like 2 hrs to do this install. Thanks!
new_speed is offline   Reply With Quote
 Old 09-08-2013, 01:13 AM   #67
meelo88's Avatar
Posts: 557   (View Stats)
meelo88 is the leader of the worldmeelo88 is the leader of the worldmeelo88 is the leader of the worldmeelo88 is the leader of the worldmeelo88 is the leader of the worldmeelo88 is the leader of the worldmeelo88 is the leader of the worldmeelo88 is the leader of the worldmeelo88 is the leader of the worldmeelo88 is the leader of the worldmeelo88 is the leader of the world
Great How-to, did mine in about an hour only took off the intercooler cover. Extensions and thumb ratchets saved my butt!
Vansquish likes this.
"If I can't fix it, it was meant to be broken"
[SIGPIC][/SIGPIC] 2007 MazdaSPEED 6 Titanium Grey
TUNED BY NISHAN
POWER
SpeedPerformanc3 Wiseco Pistons (88mm)::Manley Forged H-Beams::BNR S3::Bosch 3Bar Map Sensor::CP-E Ex Mani::SBC Stg 2 Clutch::JBR RMM 80a::JBR STG II SRI::JBR Boost Tubes::JBR BPV Return::JBR SSP::CS TMIC::CS DP::Stratified 3 Port EBCS::Stratified Guardian Angel::TurboXS RP::Custom 3" Catback Exhaust::KMD 2.1::Flex Innovations Ground Kit::Turbosmart BPV::MD OCC::TWM Stage 1::BC Coilovers::Hawks HPS::EGR Delete::SURE Dreadnaught::SURE Juggernaut::SURE TIG
COSMETIC AND AUDIO
Mori H1 Proj Retrofit::DDM 3k HID Fogs::RPM Rear LED Reflectors::RPM Side LED Reflectors::Morel Elate 6 2W 6.5" Components::Morel Maximo 5C 5.25" Coaxial::Arc Audio KS300.4::Arc Audio KS1000.1::Audison BitOne.1::Zapco ST4
meelo88 is offline   Reply With Quote
The Following User Says Thank You to meelo88 For This Useful Post:
Vansquish (09-08-2013)
 Old 10-27-2013, 04:04 PM   #68
dougpt10's Avatar
dougpt10 is an unknown quantity at this point
Default Di anyone's A/C also run warm with the thermostat problem?
2008 and the fan has been running crazy the last 3 days. Just today notice engine temp running hot and A/C warm. Burped the system and A/C was cold for a few minutes but then went hot and engine temps rose again. Sounds like the thermostat is bad?
dougpt10 is offline   Reply With Quote
 Old 11-10-2013, 11:31 PM   #69
a2j7's Avatar
Posts: 1   (View Stats)
a2j7 is an unknown quantity at this point
Default Change termo on Mazda 3
Thanx for the photos and instructions mate, worked like a charm thanx to your help. New thermostat
and house plus sealing ring $135.00 au.
a2j7 is offline   Reply With Quote
 Old 11-16-2013, 04:30 PM   #70
mach69's Avatar
How did you burp the coolant system? I ask because there is no radiator cap. The coolant is refilled through the coolant reservoir which has its own way of bleeding air from the cooling system.
The fans staying on was a clear cut sign for me the system was running hot. I also would monitor my temps and even on the highway I was at 220+F. My A/C never went warm. My engine temp gauge in the gauge cluster never went above the usual spot.
Do you have a way to monitor the ECT? I have a dashhawk and that is how I noticed the temp.
Easiest way to check the thermostat is to touch your radiator hoses. After a longish drive touch both hoses. If the top hose is HOT and the bottom hose is cool, your thermostat is not opening.
I'm not sure if the engine running so hot would cause the A/C to run hot, you may have two problems. Possible low on freon in the A/C system?
The Following User Says NO Thank You to mach69 For This Un-useful Post:
bertrand_CX_7 (01-11-2014)
 Old 01-12-2014, 06:01 AM   #71
CBRKnightRiderS2K's Avatar
Posts: 2   (View Stats)
CBRKnightRiderS2K is an unknown quantity at this point
Thanks for the write-up! Took me 2.5hrs to complete! I had to take off PS pump.
CBRKnightRiderS2K is offline   Reply With Quote
 Old 01-12-2014, 12:44 PM   #72
bertrand_CX_7's Avatar
Posts: 1,455   (View Stats)
Did Mazda ever issued a recall or at least a TSB on this thermostat issue?
Because such a high failure rate on thermostats is normal, specifically with the low milenage they are failing.
 Old 01-12-2014, 01:19 PM   #73
Nope. Actual failure rates are unknown, we are a fraction of total produced, and part is $40.
 Old 01-12-2014, 07:10 PM   #74
Hey raider do you know if the thermostat for the CX-7 is the same as the one for the Speed3?
So got mine from Mazdamotorsport and the part department at the dealership confirmed that the part number for CX-7 and speed3 is the same.
The internals on the new one seems a little different from the OM one that was mounted on the CX-7.
Can you or anyone confirm?
Thanks
 Old 01-12-2014, 07:15 PM   #75
I know there was a revision made, based on posts.
IMO when mine went out, I took it as an excuse to clean the valves. $40 part, NCE. Now the VVT and turbo, well that just pissed me off when they capped miles at 70k.
bertrand_CX_7 (01-12-2014)
 Old 01-12-2014, 07:22 PM   #76
Thanks man. This will confirm the difference. Just attached a pic to my previous post. Thanks for the heads up.
 Old 01-12-2014, 07:30 PM   #77
Autozone just confirm it's the same part number for both cars.
Part number is 51280 for the CX-7 and cost $26.99@ autozone. I'll highly recommend anyone to get the OM part from a trusted vendor $26.99 sounds too cheap to me and I'm concern with the the quality.
Obviously you don't want to save $$$ on engine parts.... FYI I paid around $40 for my thermostat from Mazdamotorsport and I believe those are genuine parts....
 Old 01-19-2014, 01:57 PM   #78
a4tek's Avatar
a4tek is a splendid one to beholda4tek is a splendid one to beholda4tek is a splendid one to beholda4tek is a splendid one to beholda4tek is a splendid one to beholda4tek is a splendid one to beholda4tek is a splendid one to behold
great write up i might be doing this next week
a4tek is offline   Reply With Quote
 Old 01-23-2014, 09:07 PM   #79
kidrabbit84's Avatar
Posts: 4   (View Stats)
kidrabbit84 will become famous soon enoughkidrabbit84 will become famous soon enough
Originally Posted by He Hate Me View Post
*Edit*
+1 - just ran into this with Napa, O'Riely's, and Advance Auto. All they have is the long neck one. I thought I would try aftermarket instead of the Mazda part that crapped with only 62k. In the end I finally ended up with OEM.
Anyways you might want to take a tape measure with you if you don't have the old one pulled yet - see below.
kidrabbit84 is offline   Reply With Quote
 Old 01-23-2014, 09:15 PM   #80
Correct T-Stat on top and wrong on bottom:
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f33/how-thermostat-103450/
Thermostat beim Maza 3 MPS BK wechseln This thread Refback 11-30-2015 08:09 AM
Mazda 3 mps running fan/overheating ? Mazda MPS Owners Club This thread Refback 02-22-2015 10:20 AM
Mazda 3 mps running fan/overheating This thread Refback 07-30-2014 11:44 AM
Mazda 3 mps running fan/overheating This thread Refback 02-27-2014 02:29 AM
Engine Temperature stays low This thread Refback 12-23-2013 06:38 AM
Engnie Temperature stays low This thread Refback 11-28-2013 11:17 AM
Thermostat replaced: Speed 6 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 04-06-2012 04:08 PM
Replacing Thermostat socks Mazdaspeed3/6 General Discussion 23 10-06-2013 12:33 PM
Overheating....Thermostat?? MS6FL MazdaSpeed 3/6 - Troubleshoot/Diagnostics 10 11-25-2011 11:36 AM
Coolant Thermostat Install help? Scribbles MazdaSpeed 3 - Engine, Transmission & Driveline 7 06-11-2011 03:16 PM
getting dtc:P0126 Coolant thermostat stuck open ON 2 Thermostat dixie789456 MazdaSpeed 6 - Engine, Transmission & Driveline 4 06-08-2010 10:52 AM
cooler thermostat rodrigo MazdaSpeed 6 - Engine, Transmission & Driveline 26 07-07-2009 10:34 PM
Page generated in 0.57887 seconds with 42 queries
