> MazdaSpeed 3 - How-To's
  • 2 Post By ms3blackmica
 Old 08-18-2012, 09:29 AM   #1
Nishan
ms3blackmica's Avatar
Posts: 5,635   (View Stats)
Default How To: Ugrade Your BPV Bolts
Okay lets face it.
You own a mazdaspeed. You quickly find out how fast the factory bolts that fasten many random things in your engine bay break extremely easy (your BPV being one of them). Heck, mine broke in the 2nd week of owning the car. This becomes really easy to do when you upgrade to a metal BPV. They are heavier and you need to wrench them down a little bit harder and your stock bolts snap. And the stock cold pipe is a cast aluminium peice and the threads that are already tapped in the flange will turn to dust in no time. So here is how you can upgrade them. This doesn't happen to everyone, but the in case that it does, and they don't know what to do, i wanted to make a useful thread showing how to permanently fix the issue. Things happen...and having a nice way to fix them is always nice.
Okay first thing...if your BPV bolt has already snapped, check to see if the end of the bolt has made it out to the other side. If it has, then your in luck. You can go ahead, remove your cold pipe (to make it easier to work with), and take some pliers/channel locks and spin the bolt end (lefty loosey) until it comes out. Your golden. If the bolt snapped while still stuck inside, you may need to drill it out. But be careful to not crack a peice of the cast flange off.
This is what you will need. Go to lowes, get to the bolt and fastener section, and pick up a bag of Hillman Hex Cap Screws. The factory thread tap in the flange is M6-1.00. Pick up M6-1.00 X 30. This is in metric. M distinguishes that is is metric. 6 is the thread diameter in mm. 1.00 is the thread pitch in mm. X 30 is the bolt length in mm. Make sure you pick up the accommodating hex nut as well (in the same thread). Although it is not pictured here, i would recommend picking up the hex nuts with the nylon insert in them to ensure your new upgrade stays good & tight. ***The hex nut is not necessary. If your cold pipe threads are still good then you only need the bolt. Also pick up accommodating washers. Please note that the hillman fasteners are grade 8.8 (much stronger than stock). I have been using the same exact bolts for 3 years now and they have not snapped or stripped one bit. Just be careful not to tighten it too much as the factory cold pipe is cast. Good & tight is plenty enough.
If the factory thread isn't damaged in the BPV flange, you can probably get away without using a nut on the end. But i like to because it gives me a good peice of mind and i know my BPV will not leak from the flange. Drilling the hole through and just sliding your bolt through is also an option but thats up to you. Once your done it will look like this.
This same procedure can be done for aftermarket cold pipe flanges on FMIC's and what not. Just make sure you see what length you need to ensure you can still get a nut on the end.
aromig and Pointless like this.
www.tunedbynishan.com
The Following 10 Users Say Thank You to ms3blackmica For This Useful Post:
bazzarino (10-13-2012), gar_lei (08-18-2012), impossible (04-12-2016), Kwilecki17 (03-01-2013), Miltron (09-30-2014), Monotonous ONE (08-18-2012), MS6FL (09-02-2012), Pointless (08-18-2012), Raider (08-19-2012), whos_MS3 (08-19-2012)
 Old 08-18-2012, 09:33 AM   #2
radbrad's Avatar
Posts: 538   (View Stats)
broken bpv bolts? why you hulk stuff up?
ive only broken dp bolts. well thanks
07Speed3
radbrad is offline   Reply With Quote
 Old 08-18-2012, 09:35 AM   #3
Nishan
lol i dont. damn things are just so fragile.
 Old 08-18-2012, 09:41 AM   #4
Captain KR's Avatar
Posts: 2,320   (View Stats)
Captain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the worldCaptain KR is the leader of the world
Groans: 391
Groaned at 75 Times in 49 Posts
You must have the hands of a rapist!
moore automitive 4/13/13 515whp 511 tq
Mason Dixon Raceway 11.289 @125 1.845 60'
Killah Built
Powered By Purple Drank
Captain KR is offline   Reply With Quote
The Following 14 Users Say Thank You to Captain KR For This Useful Post:
09Speed3Z (09-02-2012), breakfstincluded (08-18-2012), Cujo (09-02-2012), danieldolina70 (08-18-2012), dantes5823 (08-18-2012), KevMS6 (08-19-2012), lilred (08-19-2012), NoRegrets (08-18-2012), p057 (08-19-2012), Pointless (08-12-2013), Pseud0logik (08-18-2012), Ryguy (08-18-2012), SLOWHATCH (08-18-2012), span (10-13-2013)
 Old 08-18-2012, 09:43 AM   #5
Nishan
LOL
to be completely honest...damn things snapped before i even got to give it the initial snug.
oh well....
i know i'm not the only one who's snapped these SOB's !
 Old 08-18-2012, 09:52 AM   #6
aviator79's Avatar
Posts: 3,934   (View Stats)
It snapped because the flang on your new BPV is thinner then the OEM and the bolt bottomed out. You have to grind them (at least one of them) down before reusing them.
 Old 08-18-2012, 09:54 AM   #7
Nishan
good point.
I still don't like the quality of those factory bolts though. I've been much happier with these higher quality bolts for a long time now.
 Old 08-18-2012, 10:03 AM   #8
aviator79's Avatar
good point.
They are probably made that way to pevent dealers from overtorqing and cracking OEM BPV...not sure mazda engineers could put that much thoght into something, but ya, your probably right that once upgrading to a metal BPV and better bolt is a good idea...thou when I upgraded I still used them.
ms3blackmica (08-18-2012)
 Old 08-18-2012, 03:14 PM   #9
radbrad's Avatar
ive taken my bpv off over 100 times and never broke anything. lemon nuts for you
edit: *bolts*
07Speed3
 Old 08-18-2012, 03:23 PM   #10
I <3 your mom
Dash08's Avatar
Posts: 7,166   (View Stats)
Groans: 293
That's fucking ghetto.
I would not run that.
this forum serves 2 purposes
The Following User Says Thank You to Dash08 For This Useful Post:
faeker (08-18-2012)
 Old 08-18-2012, 04:12 PM   #11
faeker's Avatar
Posts: 5,091   (View Stats)
Groans: 731
I think this wins first place for "using the most words in a useless post".
tapahatericerfagstalk
Mods: stock
AZSPEED3 (08-18-2012), Dash08 (08-18-2012)
 Old 08-18-2012, 04:30 PM   #12
theurgy's Avatar
Posts: 2,580   (View Stats)
I've actually broken a BPV bolt before as well.
This is a great idea and thank you.
The Following 2 Users Say Thank You to theurgy For This Useful Post:
tddvrrn (08-18-2012), whos_MS3 (08-19-2012)
 Old 08-18-2012, 05:47 PM   #13
Nishan
could be lemon bolts....
but i know way too many people whos have snapped and thia helped them for good.
sorry if the post had a lot of words. im just way too informative. cant help it.
 Old 08-18-2012, 05:51 PM   #14
daztdMS6's Avatar
Posts: 214   (View Stats)
daztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond repute
With this car it is especially important to use a torque wrench to avoid breaking bolts or cracking something. But then again, if you are careful you can get by with tightening any bolt or nut with any wrench/socket.
His idea does work though for the bpv.
MazdaSpeed 6
DashHawk, CorkSport TIP & SRI, CorkSport TMIC, SU RMM, CPE rear diff mount, Perrin EBCS, TurboSmart BPV, TWM Stage 2 STS + metal bushings, Denso ITV-22, SM OCC, JBR EGR deletion & TIG, silicone boost tubes, Bilstein HD shocks, LED light bulbs, TRS clear projectors, 35W DDM Tuning HID foglights, Hawks HPS brake pads, Amsoil in the rear diff, pto & trans, factory navi, XCarLink USB.
daztdMS6 is offline   Reply With Quote
 Old 08-18-2012, 08:49 PM   #15
Captain KR's Avatar
Groans: 391
Ok how strong are you guy's..... like really I work on tons of speeds and never use a TQ wrench unless its engine/trans related..... I must be a weakling
Killah Built
The Following 3 Users Say Thank You to Captain KR For This Useful Post:
faeker (08-18-2012), ms3blackmica (08-18-2012), uncorked11 (08-18-2012)
 Old 08-18-2012, 10:25 PM   #16
tddvrrn's Avatar
Posts: 2,571   (View Stats)
Groans: 103
shit, i broke 3 bolts on the crappy subwoofer and a bolt to a frame brace. it's easy to do...
 Old 08-18-2012, 10:29 PM   #17
You guys are hacks then...
It takes less then 10ft lbs to secure a bpv into an alumn cold pipe... A little common sense goes a long ways.
3Gee Tee (08-18-2012), Easter Bunny (09-02-2012)
 Old 08-18-2012, 10:35 PM   #18
3Gee Tee's Avatar
Posts: 1,533   (View Stats)
Freaking gorillas here.
 Old 08-18-2012, 10:36 PM   #19
Captain KR's Avatar
Groans: 391
Im never living near any of you rapist's......
Killah Built
 Old 08-18-2012, 10:37 PM   #20
tddvrrn's Avatar
Groans: 103
don't worry, we'll come to you.
and i've never had a car with such weak nonessential bolts. i mean, i just like to make sure shit is tight, but some of the shit on this car isn't having it. i've learned my lesson as well, and haven't stripped or snapped in a good long while.
 Old 08-18-2012, 10:39 PM   #21
Do you guys not feel your tools? Bolts and nuts talk back to you through the handle. You can tell a bolt that's starting to bind... sometimes a little lubricant is needed... no need to take alittle bitty 8-10mm bolt and grab the ratchet like a monster.
 Old 08-18-2012, 11:06 PM   #22
Nishan
a tq wrench really isn't necessary for small bolts like this. All it needs to be is snug.
Well i haven't snapped any bolts on this car in years. I'm very deliciate with those smaller bolts. I even use a 1/4" ratchet. It was only the BPV bolts that i had a problem with. I could literally break them with my fingers easily. My bolts actually snapped on the stock BPV before i even got the hex head fully fastened down. The moment it made contact with the BPV flange the head just snaps off on me. I must have had shitty luck but i've helped many people with those louzy BPV bolts and getting the snapped ones out so i assumed their low quality was present on many speeds. It's happened to even some very knowledgable guys i know. You just never know...it could happen. My biggest problem wasn't the BPV bolts themselves. That was no problem to remove. My biggest issue was the thread tap in the cold pipe flange turned to dust and became smooth. No longer any threads present. So thats why i use the longer bolt with a a nut on the end.
All in all, i just thought i'd share a pretty good fix for this situation "IF" it does happen to anyone (whether it was an accident or not)
 Old 08-18-2012, 11:08 PM   #23
Well i haven't snapped any bolts on this car in years. It was only the BPV that i had a problem with. My bolts actually snapped on the stock BPV before i even got the hex head fully fastened down. The moment it made contact with the BPV flange the head just snaps off on me. I must have had shitty luck but i've helped many people with those louzy BPV bolts and getting the snapped ones out. It's happened to even some very knowledgable guys. You just never know...it could happen. My biggest problem wasn't the BPV bolts themselves. My issue was the thread tap in the cold pipe flange turned to dust and became smooth. So thats why i use the longer bolt with a a nut on the end.
I understand where you are coming from Dr Hacks, but you still deserved some shit for it
 Old 08-18-2012, 11:10 PM   #24
Nishan
no worries !
its accepted
 Old 08-18-2012, 11:15 PM   #25
uncorked11's Avatar
Posts: 1,238   (View Stats)
Groans: 165
OK how strong are you guy's..... like really I work on tons of speeds and never use a TQ wrench unless its engine/trans related..... I must be a weakling
You are easily overpowered due to your weakness, I just recently broke mine, in the soft cpe metal bpv flange. I am generally careful do to the constant reading of this forum and hearing the horror stories.
New....Camaro SS/RS
Stocked out selling parts.
2011 Black MS3
2006 Jeep Wrangler
-20 grand of Shit
 Old 08-19-2012, 01:45 AM   #26
whos_MS3's Avatar
Posts: 230   (View Stats)
whos_MS3 is the leader of the worldwhos_MS3 is the leader of the worldwhos_MS3 is the leader of the worldwhos_MS3 is the leader of the worldwhos_MS3 is the leader of the worldwhos_MS3 is the leader of the worldwhos_MS3 is the leader of the worldwhos_MS3 is the leader of the worldwhos_MS3 is the leader of the worldwhos_MS3 is the leader of the worldwhos_MS3 is the leader of the world
ah seems like only yesterday when i snapped a bolt...good times. thanks for the trip down memory lane OP
whos_MS3 is offline   Reply With Quote
 Old 09-24-2014, 04:31 AM   #27
irishking03's Avatar
Posts: 2,136   (View Stats)
Good write up. Need to go to Lowe's now. Just snapped my bolt yesterday. Fml
Po-Po tappin
2009 Metro Grey Numbers Fully Bolted.
Nator Pa Dyno Day: 311HP 328TQ Pump 93
Nator Pa Dyno Day: 310HP 329TQ Pump 93
End of Drive 9/24/2013
2012 Liquid Silver
Cobb AP
 Old 09-26-2014, 07:18 AM   #28
MBalik's Avatar
Posts: 500   (View Stats)
MBalik is the leader of the worldMBalik is the leader of the worldMBalik is the leader of the worldMBalik is the leader of the worldMBalik is the leader of the worldMBalik is the leader of the worldMBalik is the leader of the worldMBalik is the leader of the worldMBalik is the leader of the worldMBalik is the leader of the worldMBalik is the leader of the world
Guess what.... snapped mine too yesterday!
Quick question though, since i'll be removing the cold pipe anyways to extract the bolt that's sticking out.... would a temporary fix like putting on the OEM coldpipe on a CP-e TMIC work?
Gives me a little more time to take the fucker out of there.
2013 White Pearl Pu
Back to stock.... for now
MBalik is offline   Reply With Quote
 Old 09-26-2014, 07:23 AM   #29
faeker's Avatar
Groans: 731
WTF ryan!!!!!! 2 year rez?! I have something special for you when it's bnr install time now.
tapped by satan
Also, you reuse the oem pipe for any tmic. Not really sure what you're asking.
tapped by satan
Mods: stock
Last edited by faeker; 09-26-2014 at 07:23 AM. Reason: MSF Database - Automerged Doublepost
 Old 09-26-2014, 08:28 AM   #30
MBalik's Avatar
tapped by satan
tapped by satan
My apologies for being stupid lol.
I bought a used unit that already came with a cold pipe. So I guess I'm in luck
2013 White Pearl Pu
broken bolts kikidiaz38 Mazdaspeed3/6 General Discussion 5 03-18-2012 10:56 PM
Rod Bolts jordan4g63 MazdaSpeed 3 - Engine, Transmission & Driveline 18 05-23-2011 12:09 PM
Rod bolts 06Speed6 MazdaSpeed 6 - Engine, Transmission & Driveline 0 04-01-2010 11:57 PM
Page generated in 0.51704 seconds with 34 queries
