| MazdaSpeed 3 - How-To's MazdaSpeed 3 - How-To's - Want help out fellow owners? Post How-To's to simplify future installations for others. |
| Bob Ross Fanclub ![]() Join Date: Jan 2009 Location: SEFL
Rep Power: 4333 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,534
(Thread Starter) | Neutral : +1 score Nothing really difficult about the install. Just replace the bracket holding the caliper. The following is worth noting: * Mazda 5 rear brake discs are larger in diameter than MS3 but same width and offset. * Mazda 5 rear calipers have the same piston diameter as the MS3. I read they weren't but I measured and they are exactly the same. The only difference to the MS3 calipers is the bracket which extends a little longer as the pics show to accommodate the larger disc. * Mazda 5 pads are shorter than the MS3s but will fit. ******************* you need caliper brackets of a Mazda5 2008.5 or earlier******************************************* ** Impressions: Don't feel anything different than stock. It looks better due to the larger rotor but that's about it.
__________________ Last edited by Tomas; 03-26-2011 at 10:17 AM. |
| The Following 15 Users Say Thank You to Tomas For This Useful Post: | 3mazdaspeed (03-10-2011), ak_spray (03-26-2011), asall667 (09-08-2011), Awal (06-17-2015), BLURSPORTS (03-07-2011), Easter Bunny (06-26-2013), grantmm (02-17-2013), gtlaw (03-08-2011), impossible (05-25-2016), silvapain (08-26-2012), SLOWHATCH (06-26-2013), snailD (03-09-2017), super_pablo_ (01-09-2013), uninc (04-08-2011), xcoldricex (03-07-2011) |
| I'm a caveman ![]() Join Date: Jun 2008 Location: Pittsburgh, PA
Rep Power: 308 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 561
Groans: 68
Groaned at 22 Times in 16 Posts
| Not Ranked : 0 score where did you get the brackets? might be worthwhile if you need to replace the rotors anyway
__________________ 2015 MUSTANG GTPP |
| ILL3ST ![]() Join Date: Jun 2008 Location: Ann Arbor, MI
Rep Power: 1317 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,292
| Not Ranked : 0 score forgive me for asking - it's implied but not absolutely clear - so you can reuse the ms3 calipers with the mz5 brackets correct? all you replaced were the rotors and the bracket? what's the rotor diameter of the ms3 vs. the mz5? larger rotor will net you better cooling for the track i suppose, probably no difference on the street. |
hold on re rotor size. ok, here it is. stock is 280mm. Maxda 5 is 302mm
__________________ | ||
| The Following 5 Users Say Thank You to Tomas For This Useful Post: | ak_spray (03-26-2011), Easter Bunny (06-26-2013), gtlaw (03-08-2011), super_pablo_ (01-09-2013), xcoldricex (03-08-2011) |
![]() Join Date: Dec 2009 Location: Lakewood, OH
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 13
| Neutral : +1 score this is a cool find...might be doing this at my first brake change!
__________________ COBB SRI/TIP, HKS SSQV, HYPERTECH TUNE (COBB), CS TEST PIPE, HKS CBE, KONI YELLOWS, H&R SPRINGS, GT SPEC TRUNK CAGE, PROGRESS RSB, E4P SHORT SHIFTER, SU RMM, TRZ TRANNY MOUNT, KONIG COUNTERSTEERS...OTHER AESTHETIC MODS |
![]() Join Date: Dec 2010 Location: Dayton, OH
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,193
| Not Ranked : 0 score What year did you take them off of? |
| Not Ranked : 0 score How much larger is the surface area of the Mazda5 pad? |
| The Following User Says Thank You to Lex For This Useful Post: | SC08Speed3 (01-27-2013) |
| Not Ranked : 0 score I wonder if there is a similar swap for the ms6, I need to change my rear brakes pretty soon.
Groans: 68
| Not Ranked : 0 score it should be exactly the same. this will just give it more leverage moving it farther out from the center of the rotor
| The Following User Says Thank You to gtlaw For This Useful Post: | Tomas (03-10-2011) |
Groans: 60
| Not Ranked : 0 score IIRC Our rear rotors are already larger than the CX-7 Parts.. The only mazda vehicle with larger rear brakes is the CX-9..
| The Following User Says Thank You to SSinstaller For This Useful Post: | 06Speed6 (03-10-2011) |
| The Angry Goose ![]() Join Date: Jun 2008 Location: Villa Park, IL
Rep Power: 701 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,192
Groaned at 9 Times in 6 Posts
| Not Ranked : 0 score Someone needs to make a bracket! I've looked and haven't found too man 5s in the junkyards. I wanted to do this too when I changed my brakes!
__________________ Hector 2014 Mazda 3 2008 Mazdaspeed3-SOLD 1979 Mazda Rx7 |
| Not Ranked : 0 score I got some cx-9 rear brake specs off of ebay (lol) and they do seem pretty large. I wonder if they swap to either the ms3 or ms6. Sorry for the slight thread jack, but I figure you might as well get the biggest ones you can find.
__________________ 2006 Mazdaspeed 6 P&P, flow benched, head with welded EGR and +1mm inconel exhaust valves (260/200cfm @ .500"), Web Cams, Custom crankcase breather with integrated air/oil seperator, Custom 3/4" ID pan vac system, Blow through maf, Port matched IM, CNC AN-12 ORB block oil adapter, CP-e 88mm Stage 2 pistons, Pauter 22.5mm rods, ARP main, head, and crank studs, CP-e injector seals, Injector stud kit, Cometec 88mm 5 layer HG, Deatschworks flow tested matched injectors, DCR VVT, PTP 2250psi RV, Corksport front sway, Whiteline rear sway, AWR front/rear sway links, TT FMM, AWR 70d DMM, JBR 80D PMM, SU RMM, TT FRDM, CP-e RRDM, Autotech CDFP, DW65c ITFP, Custom L/A IC with a dual pass 20x25x1.5 heat exchanger, Dual Cobra I/C pumps, 2.5" ID 700hp I/A intercooler, Custom DP, Corksport catback, Corksport exhaust hangers, chrome plated genpu valve cover, chrome plated timing cover, Spin on oil filter, Fluidyne dual pass AN-12 oil cooler, Hayden oil cooler fan controller, Dual 4.7" SPAL oil cooler fans, Canton Racing 22-480 oil tstat, Custom BMRS AN-12 oil lines, SPC ball joints, 55w/35w headlights and independently switched fogs on custom waterproof harnesses, PIAA Super Plasma driving and interior lights, rear diff cutout switch, 3M clear front cover, Volk 17x7.5 wheels, Custom tcase bearing cap upgrade, GS EBC 3 port, Redline SS hood lift, Versatune, Defi gauges, Innovate MTX-L WB gauge, triple center gauge pod, Block8head dual vent pod, Redline shift boot & ebrake cover & arm rest cover, Mazdaspeed CF ebrake handle, SBC Full Face Feramic Clutch Disc, Dashawk, ACL rod bearings, King main bearings, Cosworth BSD, Custom windage tray, Holset HX35w, Creative Performance T3 EWG manifold, HKS VTA BOV, A1 H11 head studs, Hylomar HG sealant, SSP EGR delete plate, JBR EGR IM plug, JGS 40mm Race EWG Last edited by 06Speed6; 03-10-2011 at 10:04 AM. |
| The Following User Says Thank You to 06Speed6 For This Useful Post: | Tomas (03-10-2011) |
| Not Ranked : 0 score Mazdaspeed 3 rear brakes, Mazdaspeed 6 rear brakes, Mazda 5 rear brakes...
| The Following 9 Users Say Thank You to 06Speed6 For This Useful Post: | ak_spray (03-27-2012), Awal (06-17-2015), Easter Bunny (03-13-2014), jdcms6 (03-27-2011), Lex (03-10-2011), SLOWHATCH (06-26-2013), super_pablo_ (01-09-2013), Tomas (01-25-2013), xcoldricex (03-11-2011) |
| Not Ranked : 0 score Parts.com has these brackets for $72. That's not too bad considering the list from the dealer is $104. |
| The Following User Says Thank You to ak_spray For This Useful Post: | super_pablo_ (01-09-2013) |
Not sure if this big would be really needed on an MS3. May be on a MS6 due to more rear weight but for an MS3 is prob a little too big. The rears don't get that much action on the MS3. The rotor is also 6 lbs heavier. Great find. Hope someone tries it out. The Mazda5 pad is smaller than the MS3. If you look at the pic above the shorter pad is the MAzda5 pad.
Incorrect about the pad. See above brake pad surface to brake pad surface pic.
__________________ Last edited by Tomas; 03-10-2011 at 02:38 PM. Reason: MSF Database - Automerged Doublepost | ||
| The Following User Says Thank You to Tomas For This Useful Post: | ak_spray (03-27-2012) |
| Not Ranked : 0 score Seems like there is a lot of weight lost by having smaller rotors. Less rotor weight is less rotational weight.
| The Following User Says Thank You to Hectik1 For This Useful Post: | PhorB13 (08-01-2019) |
(Thread Starter) | Not Ranked : 0 score Fuck. Great question. Forgot to add that you need 2008.5 or earlier brackets. OP updated.
| The Following User Says Thank You to Tomas For This Useful Post: | ak_spray (03-26-2011) |
![]() | | #19 | ![]() |
I didn't change the caliper. Just the bracket. Pic #2. I am using the MS3 caliper with the MAzda5 bracket holding the caliper. Wakarimaska?
| The Following 5 Users Say Thank You to Tomas For This Useful Post: | 06Speed6 (03-10-2011), ak_spray (03-27-2012), Easter Bunny (03-13-2014), Lex (03-10-2011), xcoldricex (03-11-2011) |
![]() | | #20 | ![]() |
| Banned ![]() Join Date: Feb 2010
Rep Power: 0 ![]() ![]() ![]() ![]() Thanks: 0
Groaned at 7 Times in 4 Posts
| Not Ranked : 0 score I understand the reason for larger rotors etc. but larger rotors don't always add up to better performance. if you're using the same caliper and pad size, you're not gaining any more friction surface area, so if anything you just added weight and more rotational mass... for those considering this upgrade, why not just invest in a better performance rotor and pad? |
![]() | | #21 | ![]() |
A brake rotor is really just a heat sink. Any BBK you buy will get you a larger and/or thicker rotor. If you follow your logic than a BBK would really not be of any benefit. The reason for using a larger rotor is to increase the ability of the brake system to increase its heat absorption capability where the brakes do not get so hot you start getting brake fade or other symptoms associated with overheating of the brake system. For DD this is certainly not needed. But when you do track work it is quite possible your rotors will get so hot the heat seeps into the caliper and your fluid starts boiling = brake fade or worse no brakes at all. A high heat pad is obviously the first thing you should do before upping up rotor size, but if the pad gets too hot because the rotor is too hot, the pad will start to lose its ability to bite into the rotor to slow it down.
| The Following 2 Users Say Thank You to Tomas For This Useful Post: | ak_spray (03-28-2011), xcoldricex (03-28-2011) |
![]() | | #22 | ![]() |
![]() Join Date: Nov 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,528
| Not Ranked : 0 score old thread is old... but I just wanted to follow up on something, as well as comment on your last post @Tomas ... I feel that, while your statement is true (about larger size, heat absorption and shit)... thats really irrelevant for the rear rotors, at least in our platform... so really, it comes down to, is the increase in torque worth the 70-100 buck bracket? Did anyone else did any more testing on track? Im changing my rear pads for more rear bias, but also was considering this... whats the concluding point on it? Worth it or not? |
![]() | | #23 | ![]() |
![]() Join Date: Jan 2011 Location: Toronto, Ontario
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 937
| Not Ranked : 0 score also interested in hearing. @tomas im assuming you have tracked the car since, was the shift in bias due to the greater torque noticable?
![]() | | #24 | ![]() |
(Thread Starter) | Not Ranked : 0 score Was the rear brake torque on the rotors higher with the bigger rotors / sort of more rear bias? Yes. Was the difference eye popping huge? No Could it be placebo effect? May be. I would only recommend the upgrade if your rear rotors need to be replaced. Then, you might as well get the Mazda 5 ones and the bracket. IMO there is nothing like simple bolt on OEM upgrades such as this one. Much simpler and cheaper than multi piston calipers and hydraulic e brakes. There is actually a name for this type of upgrade I just don't remember what it is.
| The Following 4 Users Say Thank You to Tomas For This Useful Post: | breakfasteatre (01-09-2013), Easter Bunny (01-10-2013), Fobio (01-09-2013), super_pablo_ (01-10-2013) |
![]() | | #25 | ![]() |
![]() Join Date: Mar 2008 Location: Chicago
Rep Power: 4020 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,876
__________________ Stance is not a verb. 2008 MS3 GT 2016 MX-5 Club | |
![]() | | #26 | ![]() |
(Thread Starter) | Not Ranked : 0 score I remember talking to a KNS brakes dude over the phone when I ordered pads once telling him about the conversion and he mentioned they offered the same thing for Subarus. He called it some fucking name but I am senile. Or may be the dude was on crack. Either option is viable.
| The Following 2 Users Say Thank You to Tomas For This Useful Post: | Easter Bunny (03-13-2014), silvapain (01-10-2013) |
![]() | | #27 | ![]() |
![]() Join Date: Jul 2010 Location: Rowland Heights, California
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 121
| Not Ranked : 0 score a lot of guys with the earlier 1.6 miatas do this and swap the bracket with the later 1.8 rear brakes. I've heard the term "brake conversion" used all the time. But regardless, it works, I might try this when it comes time to do my brakes. First probably get myself a pyrometer to see brake temps after hard driving/tracking to see where temps are at and do a before and after comparison. |
| The Following User Says Thank You to fredricktsang For This Useful Post: | Tomas (01-25-2013) |
![]() | | #28 | ![]() |
![]() Join Date: Feb 2011 Location: Vaughan, Ontario, Canada
Rep Power: 1135 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 977
| Not Ranked : 0 score When I go my stoptechs I got the mazda5 rear kit as well to keep the balance the same. Even so I think the car has ebfd so I'm not sure how much of a difference it will make.
__________________ Fueled by the haters. |
| The Following 2 Users Say Thank You to Celestspeed3 For This Useful Post: | super_pablo_ (01-10-2013), Tomas (01-25-2013) |
![]() | | #29 | ![]() |
Indeed it does.
| The Following 3 Users Say Thank You to Nliiitend1 For This Useful Post: |
![]() | | #30 | ![]() |
![]() Join Date: May 2009 Location: Chicago, IL
Rep Power: 10249 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,116
Groans: 136
| Not Ranked : 0 score Hydraulic e-brake FTMFW. I want one so I can do rally-style handbrake turns. I'm such a fucking ricer. Tapadatass
| The Following 3 Users Say Thank You to silvapain For This Useful Post: |
![]() | | #31 | ![]() |
![]() Join Date: Nov 2012 Location: North East
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 261
Groaned at 29 Times in 14 Posts
| Not Ranked : 0 score sorry to bring back from the dead... has anyone measured whether the ms6 rear bracket can be used with the ms3 rear calipers? Might as well go with the bigger rear ms6 rotors... sil80
__________________ I drive fast, I turn fast, I do everything fast. I even breakfast. I tend to confuse people with my sudden changes of heart. Sometimes I even confuse myself, which tends to cause problems. "... if u can't find' em - grind 'em" - old Chinese proverb ![]() ![]() http://www.mazdamotorsports.com/ |
![]() | | #32 | ![]() |
(Thread Starter) | Not Ranked : 0 score ^ No. But post 13 has some info on the MS6 rear brakes.
![]() | | #33 | ![]() |
| Not Ranked : 0 score I saw that but can't really get the bolt offset from it... might have to just order a bracket and see if it fits....
![]() | | #34 | ![]() |
![]() Join Date: Dec 2011 Location: Central PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 221
| Not Ranked : 0 score I may have missed this but does anybody know the part number for the Mz5 bracket I need?
__________________ 2014 Snowflake White Pearl Mazda 3 2.0l 6spd Hatchback 2012 Black Mica Mazdaspeed3 - Sold ![]() 2004 Strato Blue Mazda 3 2.3L 5spd Hatchback - Sold |
![]() | | #35 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 337
| Not Ranked : 0 score ^^^That. I've recently tried dealing with some of the local forum's Mazda dealers as we get a discount and have been met with nothing but grief. They want the VIN to make sure the part is correct......apparently without that they cannot confirm it is the correct part. It's the f*cking rear caliper bracket!!! how hard is that. Even when I explain I do not have an Mz5 they still ask for the VIN. @Celestspeed3; do you remember?
__________________ . . 2008.5 CWP SPEED3 MODS TO DATE: KW V3 Cobb AP V3, RSB, STS TWM Shifter Extender Sure Shortcut, Countershift CP-e Tow Plate, FMIC, HPFP, DP, Exhaust Manifold, HeliHose, PMM/TMM, Nexus CBE, Injector Seals TiAL bpv JBR WP, Solid Shifter Bushings, TB/IM Gasket, RMM Celestspeed3 Coolant Bypass DBA 4300 T3 Hawk HP+ Denso itv22 Saikou Michi OCC DGM Lip HTP Slim Battery Tray SilverDemon EGR Block Off Rays Volk TE37 SL 18x9.5 +22, Formula Lugs Bridgestone RE-11 265/35-18 SilverDemon EGR Delete Kit Stratified ECBS, 3-Bar Map Sensor Intake Manifold PnP |
![]() | | #36 | ![]() |
![]() Join Date: Nov 2010 Location: Phoenix, AZ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,658
Here's a couple VINs I just got off cars.com by searching for a pre-2009 MZ5. JM1CR293170144730 JM1CR293270154196
__________________ 2010 MS3 - Restockified (The former STX Battle Wagon) Progress RSB - Koni Sport - EBC Yellow - MD OCC - CS MonoCBE - Cobb SRI 2004 MSM TiGrey AEM SRI - Turbosmart MBC - FM TBI - eBay DP - Turbosmart BPV - Mishimoto FMIC - Denso 305cc Koni Sport - GC Coilover - Racing Beat 1.25" Front Sway Bar - SS Lines - 15x8 Flatout - 225/45 RS3 | |
| The Following 5 Users Say Thank You to Crarrs For This Useful Post: | 802MS3 (03-13-2014), Easter Bunny (03-14-2014), El_Diablo (03-17-2014), Mr Wilson (03-13-2014), Tomas (03-13-2014) |
![]() | | #37 | ![]() |
| Not Ranked : 0 score Hahaha thanks @Crarrs; Ended up finding a Parts Manager that just understood what I was looking for. It wasn't so much finding a VIN (+ not sure if it would throw them off even more with a US VIN), more of the fact I don't get how that would confirm anything for them. He said they have them in stock, so I'll pick them up tomorrow and post some numbers.
![]() | | #38 | ![]() |
| Not Ranked : 0 score Part # C2Y6-26-28XA they were just over $60 CAN each. Now mine does not have the sliders in the OP's picture. Assuming I can carryover the stock ones, or should I just get new?
| The Following 2 Users Say Thank You to Mr Wilson For This Useful Post: | El_Diablo (03-17-2014), Mattyhawk1 (03-18-2014) |
![]() | | #39 | ![]() |
![]() Join Date: Jul 2012 Location: Toledo, OH
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,271
| Not Ranked : 0 score They unthread from the old brackets and install on the new ones. Ive been running this swap conversion for awhile now
__________________ 07 Mazdaspeed 3 Grand Touring Black Mica (The Summer Daily / Toy) Fanboy Brand Mods: A'PEXi Turbo Timer, Autotech Internals, BNR S3 V1, Bosch 3 Bar MAP, CNT 3" CBE, COBB AP V3, STS, FMIC Piping, Corksport Adjustable Shocks/Struts, CP-E Dash Pod, Safe-Seals, Enkei Evo IX (17x8+38), Exide 51RX Battery, FoMoCo XT-M5-QS, Grimmspeed EBCS, Ground Control Bumpstops, Hankook RS-3 (235/45/17), H&R Springs, Hawk HPS Pads, HTP 51R Battery Tray, JBR 88d RMM, 80d PMM, Shifter Bushings, TIG's, Secondary EGR Delete, 3.5" Aluminum WP, Mudflaps, Kozmic Primary EGR Delete, maisonvi Knob Collection, Damond OCC, NGK LTR7IX-11, Progress RSB, Prosport Boost, Oil Temp, Oil Press, Redline Tuning Hood Struts, SPC Camber Arms, Speed Daddy (Ebay) Catless DP, SP63 MAP Harness, Stratified Guardian Angel, Treadstone TR8, TRZ TMM, TurboXS H-RFL VTA BOV, XS Power V1 Manifold Maisonvi's Inherited Motor Build: ARP L19 Head Studs, Crank Bolt, Cam Bolts, Manley H-Beam Rods, SP63 Wiseco Armor Plated Pistons, New Rice, AKA To be Installed: Autoexe Front Bumper Cover, GT Spec Strut Brace, Wedge Engineering Seat Base, Sparco Speed Bucket Seat, 08 Mazda 6i Hatchback (The Daily MPG Commuter) 93 Mazda B2600i 4wd (The Winter Beater / terMINATOR Parts Hauler) |
| The Following 3 Users Say Thank You to speed3 britz For This Useful Post: |
![]() | | #40 | ![]() |
![]() Join Date: Jul 2014 Location: savannah ga... area
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() Thanks: 17
doing my brakes soon and would like to add this to the list.. wanted to make sure its the right part number.. looks like it for the 13 touring m3... any help would be great....or link..
__________________ 2012 white ms3|G2 caliper paint|jbr shifter bushings|jbr short shift linkage|jbr shifter weight| matt damond 3some\3 bar map\3 port ebcs\3.5 htp intake\egr delete\coolant bypass\ets tmic\small batterybox\yellow top battery\autotech hpfp/accessport v3\corksport bpv\corksport springs\koini yellows\freektuned on 93\ UR race pipe\jbr com rear swaybar\ebc redstuff pads\ | |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f33/mazda-5-rear-brake-conversion-74274/ | ||||
| Rear Brake Conversion ? Mazda MPS Owners Club | This thread | Refback | 07-10-2013 04:55 AM | |
| rear brake calipers | qtrmile beast | MazdaSpeed 3/6 - Suspension & Brakes | 0 | 02-22-2011 11:56 AM |
| Right rear brake pad gone | HefMS6 | MazdaSpeed 3/6 - Suspension & Brakes | 9 | 11-12-2010 04:52 PM |
| has anyone had rear brake issues? | long101 | MazdaSpeed 3/6 - Suspension & Brakes | 8 | 05-07-2009 01:52 PM |
