> MazdaSpeed 3 - How-To's
Like Tree15Likes
 Old 05-27-2014, 09:46 AM   #41
himurax13's Avatar
Posts: 4,585   (View Stats)
Groans: 255
Has anyone figured out how to get this to work with a 3 bar Map sensor yet?
Sent from Stockish Pu
Pickles Tune in progress
 Old 05-27-2014, 02:34 PM   #42
Jeff23spl's Avatar
Posts: 2,237   (View Stats)
10$ones on ebay works but only gives 15-20pids seconds
Meh, I ended up buying a BAFX off of amazon, because it was $23 and had nothing but good reviews on there and on some forums. If it's too slow, I'll sell it and buy the one I linked. I should have it some time this week and I'll make a post here about it for people looking in the future.
let us know about connection speed (pids/sec)
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
Last edited by Jeff23spl; 05-27-2014 at 02:34 PM. Reason: MSF Database - Automerged Doublepost
 Old 05-27-2014, 03:27 PM   #43
Design's Avatar
Posts: 1,887   (View Stats)
Groaned at 9 Times in 5 Posts
I've fooled around with various OBDII emitters. All of them average 1/4 - 1/2 second latency depending on the number of PIDs running.
Nothing beats wired.
09 CWP MS3 GT
Ownership & Build Thread
 Old 05-27-2014, 11:52 PM   #44
sidekick's Avatar
Posts: 3,093   (View Stats)
Have you tried adjusting the equation? I'd assume that is what would stop you from getting a proper reading. If the ECU can interpret the 3bar MAP signal, I don't see why this wouldn't be able to. It's odd that it doesn't just read whatever the ECU is seeing to begin with. I suppose it could be hard coded somewhere that X voltage = Y MAP reading. Maybe the OBDII port is pulling MAP from a different PID? It could be a lot of things. We'd probably need someone with more knowledge of how the ECU/CAN BUS function and communicate to figure it out.
@Lex;?
Thank you for the helpful info. At least post which adapters you ran, which version of torque, which phone/hardware you're using, etc... There are plenty of people who use higher quality adapters and claim little to no lag whatsoever. The CAN BUS is limited to 512kbps, IIRC. If your bluetooth connection, phone, and adapter can transmit at least that fast, theoretically there shouldn't be any lag.
Last edited by sidekick; 05-27-2014 at 11:52 PM. Reason: MSF Database - Automerged Doublepost
 Old 05-28-2014, 05:58 AM   #45
Monforte88's Avatar
Posts: 324   (View Stats)
Monforte88 is the leader of the worldMonforte88 is the leader of the worldMonforte88 is the leader of the worldMonforte88 is the leader of the worldMonforte88 is the leader of the worldMonforte88 is the leader of the worldMonforte88 is the leader of the worldMonforte88 is the leader of the worldMonforte88 is the leader of the worldMonforte88 is the leader of the worldMonforte88 is the leader of the world
Not a bad set up for cheep.
ELM 327. $12. Ebay
Window mount. $4. Ebay
Old sprint htc evo setting in closet free.
Sent from my P.O.S iPhone!!!
2007 mazdaspeed 3. SRI\ TIP\ Forge v2\ Auto Tech HPFP\Ebat Catless DP\ Test Pipe\ CP-e Cat back\ 88a RMM \ Shift Plate\ JBR Short throw shifter\ solid shifter bushings\ #Bakerytuned 18PSI.
Monforte88 is offline   Reply With Quote
 Old 05-28-2014, 06:44 AM   #46
Jtaylor's Avatar
Posts: 656   (View Stats)
Does anybody have the custom PID information for knock and WGDC? I am unable to install the custom Mazdaspeed extension since my phone is on the older firmware.
08 MazdaSpeed3
 Old 05-28-2014, 09:01 AM   #47
@Lex;?
The standard PID for the MAP signal is scaled to only work from 0-2.5bar from 0 to 1024. To get a reading for a 3 bar you have to read the PID for sensor voltage and apply the linear equation to that to get the correct pressure reading.
sidekick and DevinTheDood like this.
DevinTheDood (08-20-2014)
 Old 05-28-2014, 10:21 AM   #48
Jeff23spl's Avatar
If you find it, let us know but good luck ! As far as i know, it seem to be a well keep secret. I don't know why you can't install it, i run it from a very old galaxy S1
Wife drive 2010 CX7
 Old 05-28-2014, 10:30 AM   #49
Jeff23spl's Avatar
I expect we can't modify the actual pids? We would need to add a new one using the same pid adress with the new equation? Do you know what would be the adress of the maf voltage pids ?
Wife drive 2010 CX7
 Old 05-28-2014, 11:00 AM   #50
Jtaylor's Avatar
It has the old "market" and not the new google play so I am unable to find it via the "market". I can go to the site and when I click on the link to download it cant load. I wonder if I could install it on my sd card and then transfer it over
08 MazdaSpeed3
 Old 05-28-2014, 12:16 PM   #51
Design's Avatar
Work friend of mine received three adapters from OBDKey to try out and review:
OBDKey. Automotive Diagnostics
The issue over wireless is simply the refresh rate. And the cheap BT versions like the BAFX module run an older version of the ELM327 chip. Even with more recent firmware, OBDKey BT variant runs around 1/4-1/3 second lag. The Wifi variant runs just under 1/4 second lag. And the wired version runs nearly 0 lag.
BT and wired were paired with my Note II running Android 4.3. on Torque Lite 1.1.49. Wired requires OBDKey firmware to run on Android:
https://play.google.com/store/apps/d...systems.obdkey
WiFi was paired with an iPhone5 on DashCommand 4.2.1.
09 CWP MS3 GT
 Old 05-28-2014, 01:40 PM   #52
Jeff23spl's Avatar
why not saving your contacts to sd card and upgrade it's firmware?
Wife drive 2010 CX7
 Old 05-28-2014, 01:53 PM   #53
Jeff23spl's Avatar
What was your results for speed of PID/sec?
Does a wired usb dongle will also power the smart phone/tablet? For a permanent (or near to) it needs to recharge from the car...
I have few different tcheap models and all of them operate at 15-20 pids/sec
I read from a lot of places that cheap dongles are slow and expensive ones, could go 5x faster but will it go 5x faster on speed pcm ? It wouldn't worth the expence of a 100$ dongle to get the same speed of a 10-15$ one but ii it is really 5x faster, i'll order one asap.
Wife drive 2010 CX7
 Old 05-28-2014, 02:07 PM   #54
Jtaylor's Avatar
Its an extra verizon phone so it has no network connectivity. I can connect to wifi but the current firmware can only be updated over the verizon network. Ive searched everything and cannot find a solution.
08 MazdaSpeed3
 Old 05-28-2014, 02:49 PM   #55
Design's Avatar
BT: 66 PIDs/sec
WiFi: 72 PIDs/sec
USB: 180+ PIDs/sec
Any module costing less than $70 is using outdated firmware needed to read of Mazda's CAN_J68C OBD2 protocol. That by itself is the single largest difference between 15 PIDs/sec and 60+ PIDs/sec in the $75-100 modules. IMO, unless you're wanting to log a lot of parameters all at once, wanting real time monitoring with near-0 lag, or are trying to sync with a measurement tool independent of the ECU (i.e. GPS or accelerometer); anything over 60 PIDs/sec is unnecessary.
By comparison, I am running the BAFX OBD2 emitter on DashCommand at 24 PIDs/sec. Average lag is 1/2 sec. I can log AFR, FT, RPM, FP, HP and TQ pretty consistently. But if I add another 4-5 PIDs, everything slows to a crawl.
EDIT: The USB connector will trickle charge the device but will still drain the battery (abet more slowly).
09 CWP MS3 GT
The Following User Says Thank You to Design For This Useful Post:
speedaholic (05-28-2014)
 Old 05-28-2014, 04:51 PM   #56
sidekick's Avatar
But is that half a second really a big deal? Torque is not really for logging, but rather live monitoring. If I was datalogging, the lag would be an issue, but for live monitoring it should be sufficient. I guess I'll see when I get my adapter.
I have some PIDs that might work.
Knock retard:
PID - 1746
Equation - (A*90)/256
WGDC:
PID - 16E1
Equation - (A*100)/256
BAT:
PID - 1723
Equation - (A-64)*625/1000
VVT Advance:
PID - 1724
Equation - (A*35)/255
These may or may not work, but they are worth a shot.
 Old 05-28-2014, 07:01 PM   #57
Design's Avatar
Most here would say it's used for both equally. Logging is not going to be an issue providing that 1) there aren't an excessive number of PIDs clogging the pipeline, 2) the time stamp is consistent across all data collected, and 3) the app isn't prioritizing one PID over another (which Torque does not).
The only time it's going to be a problem is when people try to cross-reference the data with external measurements such as the phone's accelerometer or GPS. Generally this isn't a problem unless trying to match time stamps in conjunction with a track app, such as in the readout below:
09 CWP MS3 GT
 Old 05-28-2014, 11:38 PM   #58
sidekick's Avatar
That's what your tuner/tuning software is for. My laptop is hardwired when I'm datalogging. IMO, torque may work for logging, but I trust VT/AP more than I trust torque. Personally, I will only be using torque for live monitoring.
 Old 05-29-2014, 12:16 AM   #59
Design's Avatar
Not everyone is using a tuning solution with built-in datalogging. All I'm saying (as others familiar with the app will say) is that with the right hardware/configuration, Torque and DashCommand are airtight. I encourage you to share your own findings here or in a similar thread as you tinker with the BAFX module. In pairing mine with DC, it's been able to display/log up to 15 PIDs reliably on my '09.
BTW, I'd expect the Scantool you referenced to be in the 60-75 PID/sec range (similar to OBDKey). They both should use the same communication protocol with a slight variance in the proprietary firmware. It's likely anyone claiming 100 PID/sec is experiencing these results on a different platform. GL.
09 CWP MS3 GT
 Old 05-29-2014, 12:55 AM   #60
sidekick's Avatar
Does anyone know if torque updates all pids constantly, or does it only update the pids selected on the current screen?
 Old 05-29-2014, 07:54 AM   #61
Jeff23spl's Avatar
Min/max clamping values in another pages remain to 0 until you look at this page so it may let us know that it's only read pid of the page but it may try to read all of them and only update min/max when you open the page...I would also like to get results from this. The way to test it maybe to compare updating speed of the RPM alone in 1 page and have another page with every possible gauges including a 2th rpm and another setup with only rpm and comparing the reaction of the needle...
I have some PIDs that @Chron; sent me to try.
Knock retard:
PID - 1746
WGDC:
PID - 16E1
BAT:
PID - 1723
VVT Advance:
PID - 1724
nice find i will try it. BTW i only want torque for monitoring but if my engine is knocking 1sec and the pcm have to correct it to return to normal, i want to know it, right away! Actually i'm not sure if it is fast enough to catch all possible knock reading and this frighten me. For exemple i used to read some phantom KR while cruizing with Dashawk. After switching for torque, this kr seem to disapear but i run the same map only weather is warmer???
Wife drive 2010 CX7
Last edited by Jeff23spl; 05-29-2014 at 07:57 AM. Reason: MSF Database - Automerged Doublepost
 Old 05-29-2014, 08:50 AM   #62
Jtaylor's Avatar
Knock retard:
PID - 1746
WGDC:
PID - 16E1
BAT:
PID - 1723
VVT Advance:
PID - 1724
Thanks for this, I will try it tonight and get back with you.
08 MazdaSpeed3
 Old 05-29-2014, 09:58 AM   #63
Chron's Avatar
Posts: 800   (View Stats)
Chron is the leader of the worldChron is the leader of the worldChron is the leader of the worldChron is the leader of the worldChron is the leader of the worldChron is the leader of the worldChron is the leader of the worldChron is the leader of the worldChron is the leader of the worldChron is the leader of the worldChron is the leader of the world
We should be able to figure this out on Saturday. I can bring some recording equipment and monitor what is being transmitted between the vehicle and the phone.
sidekick likes this.
2012 Mazdaspeed 3 CWP
CorkSport: 3" Power Series Intake, TP, CBE, RMM, TMM Insert, RSB, Front Control Arm Bar, ECU Relocation Box, Short Shifter, Leather Shift Knob, Hood Struts, Exhaust Hangers, LED Fog Lights, Interior LEDs
Other: AutoTech HPFP, ETS TMIC, Cobb AP, Morimoto 3five 4500k HIDs
CorkSport Whore
Stratified Tuned
Chron is offline   Reply With Quote
 Old 05-29-2014, 10:16 AM   #64
I haven't had the time to identify the PID for MAP voltage that is used for larger sensors. However if you guys identify the PID you can use this to write the formula in Torque and have it read correctly for any MAP sensor.
 Old 05-29-2014, 10:43 AM   #65
Jeff23spl's Avatar
What would be the best way to identify that pids number ? I could try to add manny custom pid with successive binary coded numbers and see which one move when i try to change only that sensor value.
It would be great if there was an easy way to scan all adresses at once on a laptop computer or something else to see what is the resulting number displayed
Wife drive 2010 CX7
 Old 05-29-2014, 10:57 AM   #66
Chron's Avatar
The map voltage pid is HEX 0900. This is true for 06 and 07. I imagine it is the same for all gen1's but I haven't verified that.
CorkSport Whore
Stratified Tuned
 Old 05-29-2014, 11:02 AM   #67
What data are you getting from that PID? If you give me 2 data points I can probably let you know how to set it up so you get pressure readings instead of voltages.
The easiest data point is key on engine off.
 Old 05-29-2014, 11:26 AM   #68
Chron's Avatar
I have a gen2 so my data is irrelevant. The map pressure pid for the gen1's however is a straight conversion to kpa. MAP pressure pid is HEX 000B. This is the same for ms6 and gen1 ms3.
CorkSport Whore
Stratified Tuned
 Old 05-29-2014, 11:29 AM   #69
Design's Avatar
Current screen and any background logging.
Also, I'm not aware of anyone successfully pulling KR without the expansion pack in Pro.
09 CWP MS3 GT
 Old 05-29-2014, 11:48 PM   #70
sidekick's Avatar
So with the enhanced speed option check and without unchecking MPG calcs, I'm seeing 22pid/sec on average. I believe max was 25-26. I don't really see any lag that would be an issue and the min/max values are shown, so you would still catch KR events.
 Old 05-30-2014, 06:02 AM   #71
speedaholic's Avatar
Posts: 154   (View Stats)
speedaholic is the leader of the worldspeedaholic is the leader of the worldspeedaholic is the leader of the worldspeedaholic is the leader of the worldspeedaholic is the leader of the worldspeedaholic is the leader of the worldspeedaholic is the leader of the worldspeedaholic is the leader of the worldspeedaholic is the leader of the worldspeedaholic is the leader of the worldspeedaholic is the leader of the world
Oh it definitely catches KR events no problem, even with one of the eBay dongles. I've had a permanent setup for the past year, monitoring every single drive.
If you check out the theme I made in my other thread, you'll se that I setup KR to see the min/max value. I often register 0.1 or 0.4, then reset it. That's how I discovered that 95% of knock I'm getting is between shifts and the other 5% mechanical noise.
Torque is the cheapest "peace of mind" setup imo.
2015 Black Mustang GT
RIP 2015-06-27
2013 Liquid Silver MS3
speedaholic is offline   Reply With Quote
 Old 05-30-2014, 11:45 AM   #72
sidekick's Avatar
I agree. I've been running with no live monitoring setup for a while and torque is definitely a cheap solution that seems to work pretty damn well. Not to mention, the screens are 100% customizable. The next best solution would be an Aeroforce for $200+ventpod, etc.
 Old 06-04-2014, 02:30 PM   #73
Jeff23spl's Avatar
Knock retard:
PID - 1746
WGDC:
PID - 16E1
BAT:
PID - 1723
VVT Advance:
PID - 1724
none of then seem to work for me (2007 speed3)
Answer from scan tool representative about the speed of the OBlink LX:
Thank you for your interest in our products. OBDLink LX is one of the fastest devices in the market and it will be much faster than any ELM327 scan tool. The speed of a scan tool, however, also depends on the protocol of the vehicle. CAN and ISO 9141-2 are the fastest protocols and Mazda generally uses ISO 9141-2.
So it may worth a try for 69.99$ if it is 3-4x faster
Wife drive 2010 CX7
 Old 06-04-2014, 02:49 PM   #74
sidekick's Avatar
Yeah, I wasn't able to get any of them to work even after having a friend log the data being transferred from a the adapter to torque to see why it wasn't working. Still nothing. Lol. So I bought the plugin.
 Old 06-04-2014, 06:43 PM   #75
Jeff23spl's Avatar
for me isn't to save the pluging money but to get boost reading above 21-22 psi that bother me.
0900 or 000b doesn't work either and 010b is the pcm calculated map value limited to 255 kpa
correct but this absolute map pressure with limited range
0900 is the read result for sensor availibility of the 9th group and not map voltage.
still looking around for map voltage pid but couldn't figure it out
Wife drive 2010 CX7
 Old 06-29-2014, 09:19 PM   #76
MechE's Avatar
Posts: 18   (View Stats)
MechE has a spectacular aura aboutMechE has a spectacular aura aboutMechE has a spectacular aura about
Hey guys,
I bought a Bluetooth adapter, Torque Pro App, and the MS3 10-13 plug-in. I have been playing with it and found the oil temp data built into the Torque app does not work (and is not highlighted in green showing data is available). Has anyone resolved this issue?
I really wanted to be able to monitor oil pressure too, but it turns out that the sensor is really just a switch (ie, too low of pressure = signal to ECU to turn on oil dash light). I should have done better homework before pulling the trigger on this setup.
I've installed everything on my old HTC Thunderbolt with no issues, other than the phone is a small form factor for gauges and this old phone is slow. I side-loaded everything over to my Kindle but the MS3 2010-2013 plug-in is not working properly - it does not show up in the predefined set's list. It appears to install, and I have uninstalled, re-installed, and power-cycled and it doesn't come up. Anyone know how to get the plug-in to work on the Kindle?
Thanks!
P.S. For those who are curious about all the $10 plug-in includes for the Gen2 MS3, see attached screenshot.
MechE is offline   Reply With Quote
 Old 07-02-2014, 07:02 AM   #77
ajkulish's Avatar
Posts: 412   (View Stats)
ajkulish is the leader of the worldajkulish is the leader of the worldajkulish is the leader of the worldajkulish is the leader of the worldajkulish is the leader of the worldajkulish is the leader of the worldajkulish is the leader of the worldajkulish is the leader of the worldajkulish is the leader of the worldajkulish is the leader of the worldajkulish is the leader of the world
Groans: 40
Groaned at 15 Times in 12 Posts
I dont see why the PIDs from the add on wouldnt work.
But there is no resolving the oil temp or pressure "issues." The ECU does not monitor these values and therefore they do not display in Torque. Torque is just an app that turns the signals from sensors to the ECU into a displayed value on your screen.
All in all, its not meant to be some amazing thing that can tell you everything you want to know. But for less than 20 bucks, can you really complain? youre now able to monitor a bunch of values you couldnt before.
2006 Mazdaspeed 6 VRM
GTX3076r|Manley Pistons+Rods|AEM WMI|PnP Head|ACT 6 puck+Streetlite|COBB AP|Dramatuned|CorksportTBE|Autotech Internals|Forge v1|JBR Mounts|H&R Springs
RIP - 2007 Mazdaspeed3 GT 22V
COBB AP+SF+TIH|E30 tuned by Mark Gibson|H&R Springs|eBay Downpipe|CXRacing FMIC|KMD+Aviva|SU RMM|TurboXS Hybrid|TWM Base Bushings|Masonvi Knob
ajkulish is offline   Reply With Quote
 Old 08-20-2014, 01:21 AM   #78
DevinTheDood's Avatar
Posts: 118   (View Stats)
DevinTheDood is the leader of the worldDevinTheDood is the leader of the worldDevinTheDood is the leader of the worldDevinTheDood is the leader of the worldDevinTheDood is the leader of the worldDevinTheDood is the leader of the worldDevinTheDood is the leader of the worldDevinTheDood is the leader of the worldDevinTheDood is the leader of the worldDevinTheDood is the leader of the worldDevinTheDood is the leader of the world
I'm very interested in seeing the 3bar MAP issues resolved and wanna say a special thank you to everyone with the technical know how and willingness to dig into that.
I wish this would have magically given me oil temp or pressure monitoring but I knew it wasn't there long before I found Torque so that wasn't a letdown/surprise for me luckily.
To me oil monitoring is a must have and I'll go with the needed hardware solution but for now I'm just happy to have a visible coolant temp # for Jujiro's sake!
I'm loving Torque BTW and have decided to send back the cheap adapter I just bought that was already dropping BT intermittently:
CRAPCRAP
and buy the nice MX or LX edition from scantool which BTW now have their stuff on amazon for cheaper than the scantool site:
$59.46 for the ScanTool 427201 OBDLink LX Bluetooth
$85.77 for the ScanTool 426101 OBDLink MX Bluetooth (<---why not get all the locked GM and Ford codes too at this price so I might splurge)
CS SRI+TI+Racepipe+SSP+anchors+TMIC / CPE "stage 2" RMM / HKS SSQV recirc / Autotech internals / AP Stage 2 91 OTS / NGK's 1 step cold/ Knob
DevinTheDood is offline   Reply With Quote
 Old 08-20-2014, 09:15 AM   #79
Jeff23spl's Avatar
CRAP
No success for 3bars maps on my side but i would be interrested to know if you got your oblink and tried it yet ?
Wife drive 2010 CX7
 Old 09-01-2014, 02:15 PM   #80
Woot!
Snapped u a pic before I head out to hoon -
Will report back with results.
The Following User Says Thank You to DevinTheDood For This Useful Post:
speedaholic (09-01-2014)
COMPLETE HOW TO GUIDE MS3Axela703 MazdaSpeed 3 - How-To's 28 11-05-2014 03:47 PM
Abilor Guide Help for VT SpeedRebirth MazdaSpeed 3/6 - ECU Computer Tuning 10 04-08-2013 02:50 PM
My maintenance guide cham87 Gen2 MS3 General Discussion 8 10-31-2012 07:30 PM
Torque Wars: 2011 Ford Super Duty Now Tops GMC Sierra 2500 with 400 hp and 800 lb-ft of Torque Haltech Automotive News 0 08-03-2010 07:30 AM
FFS and LC in the new tuning guide twisted99
Cobb ATR Support
4 07-23-2009 12:25 AM
Page generated in 0.63521 seconds with 32 queries
