| MazdaSpeed 3 - How-To's MazdaSpeed 3 - How-To's - Want help out fellow owners? Post How-To's to simplify future installations for others. |
![]() Join Date: Oct 2018
Rep Power: 0 ![]() Thanks: 4
(Thread Starter) | Not Ranked : 0 score Sent from my iPhone using Tapatalk |
![]() Join Date: Nov 2014 Location: Chicago, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 105
| Not Ranked : 0 score In my expirence, 90% of the time is low coolant, 5% is air in the system because of a leak or recent cooling system repair, and 5% other. Start with checking coolant level and be sure the system is properly bled a d that you have no leaks. If it was a thermostat issue you would have poorish heat while driving. With most owners never exchanging coolant as they're supposed to, replacing the thermostat is good maintenance, but dont expect it to fix you're issue.
__________________ 2008 Metro Gray Mica Speed 3-SOLD Corksport SRI Corksport TIP JBR 80 duro RMM Cobb AP v3 Autotech internals CX Racing FMIC SPC rear camber arms Hawk HPS pads front and rear FREEKTUNE OTS+ 1998 Civic - SOLD2011 Speed3 200k+ miles Stock -Daily |
(Thread Starter) | Neutral : -1 score How would I bleed the system? And also the coolant reservoir is at the max amount Sent from my iPhone using Tapatalk |
| Not Ranked : 0 score Have you had to add any coolant to it? Bleeding is usually done by just letting the car run up to operating temp with the reservoir/radiator cap off. After it's up to operating temp let it run for a little while longer, revving it to 1500rpm during the warm up and running process helps circulate coolant. After letting it run I like to turn the car off and let it sit without the cap on it until it cools and then repeat the process. I have had air escape a lot during the cool down proccess. Some people like to jack the car up on just the side with the reservoir, but this is up to you.
| The Following User Says Thank You to 08mzr For This Useful Post: | raven4life (02-07-2019) |
Groans: 211
| Not Ranked : 0 score You may have a faulty thermostat that's sticking. Or like stated, low coolant. I would drain and fill with new coolant, bleed, and go. Do not open the cap when the engine is hot as the system is under positive pressure!
__________________ 2007 MS6- H&R Coilovers/ C-PE Catted DP/Corksport HPFP Internals/ AEM CAI/ ETS TMIC/ CPE Austenite Dual CBE/ CPE TIH/ Synapse Synchronic/ Freektuned/ AP Short Shifter/ AWR RMM and OEM TMM with CS Inserts/ Southbend Stage 2 Endurance/Stop Tech Slotted Rear and DBA T3 4000 Series Front with EBC Reds/CPE xFlex Rear Diff Mount/ Whiteline Rear Sway Bar/DSS Level 2.9 Rear Axles |
| The Following User Says Thank You to Thor Hammer For This Useful Post: | raven4life (02-07-2019) |
(Thread Starter) | Not Ranked : 0 score I haven’t added any coolant and never took the cap off. Just started to happen with it was -30 outside Sent from my iPhone using Tapatalk |
| Bob Ross Fanclub ![]() Join Date: Jan 2009 Location: SEFL
Rep Power: 4333 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,534
| Not Ranked : 0 score At -30F I am not sure the thermostat will ever open. You know how cold that is nigga? Fuuuuuu.
__________________ |
| The Following 3 Users Say Thank You to Tomas For This Useful Post: |
| Not Ranked : 0 score to bleed it, you can lift the front higher than the back while doing the above instruction to help the bubbles to get out. It can also be your heater core that is plugged with deposit when someone never replace the coolant. A flush with cleaning product may help but when it is too late, it means a core replacement.... Some leak fixing stuff is terrible at blocking heater core and some other part of the system...Never use that. In the other hand, you may monitor your coolant temp, it takes a lot more time to heat up a car with a -30deg C outside...And when the turbo is used, you quickly feel the heat generated.... Our thermostat are likely to bloc at some opening position a bit more than usual. If you monitor an unstable temperature, it may return a bad TH. During very cold days, it is likely to get up to temp and then drop a bit while slowing down 1 or 2 times but if it keep going up and down when the car is up to temp for a long while, your TH is bad..... I would start with a new TH, a coolant flush and new coolant perfectly bleeded. Then if it isn't better, i would investigate into a core replacement but it is usually a pita...
| The Following User Says Thank You to Jeff23spl For This Useful Post: | raven4life (02-07-2019) |
![]() Join Date: Jun 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,505
I just had to increase antifreeze to water concentration for winter. I was selling the car (my baby) to someone in a more frigid climate. I run a higher water ratio most of the year. I drained out about a gallon from the plastic plug in the bottom left side of the radiator and then began adding pure antifreeze and testing until I got the ratio to 50-50. I left the cap off the reservoir, it did a lot, I mean a lot of burping of air before I got it all out. Had to leave it running quite a while with the cap off until the coolant level normalized. Turned it off, let it sit, watched the reservoir and then restarted it and ran it some more. As more and more air escaped I slowly topped off with a 50-50 solution until it stabilized at the proper level. You may just have air in the system. Good time for a drain and flush if it's never been done, anyway. Good luck.
(Thread Starter) | Not Ranked : 0 score So I replaced the thermostat a couple days ago and the heat worked but my temps would go up on the high way and when I slow down/stop it goes down about 20 degrees. And just last night I got cold air at idle again Sent from my iPhone using Tapatalk |
| Not Ranked : 0 score have you bleeded it again after running for a while with the front leveled ? I bet your belt was spinning fine around the pump so if the air is gone and TH is new, the only part remaining is a plugged heater core... I would give few more try at bleeding it with enough temperature. I cost nothing while replacing the heater core is a pita...
(Thread Starter) | Not Ranked : 0 score It was good for a couple days after I bled it then again it happened today so I bled it and it’s good again. Also when my car is up in temp I see slight steam coming from the top of the rad could that be a hole? My coolant level hasn’t moved since Sent from my iPhone using Tapatalk |
| Not Ranked : 0 score sometimes you have some drops when filling the rad and it makes that but vanish after few days of driving. If it is dry outside and it keep smoking, yest you may have a leaking rad.
| My 2008 Speed 3 will not hold an idle and rides rough at low rpm and low idle | Dgms3 | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 17 | 11-23-2016 03:42 PM |
| MS6 no heat | mattymogue | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 10 | 01-02-2013 07:43 PM |
| NO HEAT? | avento | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 2 | 11-02-2012 09:45 PM |
