> MazdaSpeed 3 - How-To's
 Old 08-13-2018, 01:27 PM   #1
1gen_MSP3's Avatar
Posts: 3   (View Stats)
1gen_MSP3 is an unknown quantity at this point
Default Oil light and CEL on?
Hey guys, I’m new to this forum and I knew this is the best place to found out answers about my 2009 Mazdaspeed 3. The other I was driving and my oil light and CEL came on so I pulled over and checked the dipstick and there was little to no oil. So I waited about 10 minutes and checked again and there was oil to the max line. That morning I checked the oil and saw that I was low so I put 2 quarts of Mobil 1 10w30. I took it to the mechanic and they said that my camshaft seal had to be replaced with the timing belt. And when they did they said that they hear a light knocking and they said that the car had no oil. How could it be? The motor was rebuilt before I bought it and it is under warranty. It drove just fine before that this happened just a couple of days I got the car. And i didnt lose any power and it shifted just great. Please help me, thank you.
1gen_MSP3 is offline   Reply With Quote
 Old 08-13-2018, 02:57 PM   #2
Thor Hammer's Avatar
Posts: 1,847   (View Stats)
Groans: 211
Help you with what? Checking your oil? Solid first post. Go talk to your mechanic.
 Old 08-13-2018, 03:02 PM   #3
Db09ms3's Avatar
Posts: 536   (View Stats)
Change your oil and oil filter yourself. Save money. Then just think with your dipstick.
Stockish
 Old 08-13-2018, 03:06 PM   #4
1gen_MSP3's Avatar
Since I’m new here I didn’t know how to put it in a different category sorry guys
 Old 08-13-2018, 03:14 PM   #5
Db09ms3's Avatar
Check your email you received and navigate the forum from there.
Stockish
 Old 08-13-2018, 03:42 PM   #6
1gen_MSP3's Avatar
Okay thank you guys and the mechanic said it was the oil pump
 Old 08-14-2018, 06:19 AM   #7
MSMS3's Avatar
Posts: 2,826   (View Stats)
1. Get the CEL code reading and post the number here. Do that right now.
2. Get a different mechanic. Any mechanic that tells you that your engine has a timing belt is not to be trusted. Your cams are chain driven.
3. Is there a puddle of oil under your car where you park? Is there oil on the underside belly tray and dripping from it or the lowest suspension points? If its dry and no oil on the floor or ground, you are not leaking. 2 quart loss overnight would be obvious.
 Old 08-14-2018, 06:29 AM   #8
Jeff23spl's Avatar
Posts: 2,233   (View Stats)
first, the only way that i can imagine the oil level change without moving the car, it is because you don't check correctly the oil level. You need to remove the stick, dry it and put it back in and just after that you can read the level. If you check it at first time, it will always miss oil. It also need to be in a flat surface.
2 change mechanic guy because he know nothing about your type of car.
3 10w30 is a bit thick at cold for a speed. many use 5w40 and the oem spec is 5w30
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
e-brake light, abs light, dsc light, and traction control light DarrenMon MazdaSpeed 3/6 - Troubleshoot/Diagnostics 9 04-27-2016 08:44 PM
CES: Audi Traffic Light Assist helps you hit every green light Haltech Automotive News 0 01-09-2014 02:10 PM
Parker light trap in head light housing bcmps MazdaSpeed 6 - How-To's 4 11-26-2009 06:52 PM
Audi traffic light detection system gets the green-light Haltech Automotive News 1 09-21-2008 01:24 PM
All-in-One Black Studio Light Kit (includes Light Tent, 2 Lights, and Acrylic Table) $99.99 Haltech Hot Deals Section 0 03-26-2008 01:24 AM
Page generated in 0.27236 seconds with 24 queries
