> MazdaSpeed 3 - How-To's
Like Tree21Likes
Closed Thread
 Old 06-21-2009, 11:25 AM   #1
bnoon's Avatar
Posts: 1,770   (View Stats)
Default Oil restrictor bolt install
PICS ARE GONE, SORRY!
First, remove the stock TMIC cover. 2 ten mm head bolts.
Next, remove the TMIC nuts (12mm head) and loosen the upper hose connection on the TMIC inlet from the turbo (10mm head). Then, pull the TMIC off of the mounting studs and push forward enough to let you reach the heatshield.
Remove the 5 heatshield bolts (8mm head).
Pull the heatshield out. It's tight, but it will fit past everything.
Now, you can remove the stock banjo bolt (can't really see it from this angle, but it's straight down from the driver's side rear of the TMIC, on top of the turbo. DO NOT FORGET TO REUSE THE 2 STOCK COPPER SEALING WASHERS! One on top of the banjo fitting and one below!!!
Better view of where the bolt will be as shown on my PTP SST.
UPDATE 9-4-2012
Originally Posted by broncojd78 View Post
ok, as a pubic service, i am adding pics to this thread so people can stop asking questions about how to do things. now everything is hosted on this site, you shouldn't have to worry about losing the pics.
@Raider do i get a cookie?
this is how you drill the bolt.
this is where you are working.
this is how to remove the heat shield.
this is the bolt you replace.
p057 likes this.
2008.5 MS3 GT - Sold!
2013 Ford Focus SE - Sold!
2002 BMW M3 - Sold!
bnoon is offline
The Following 16 Users Say Thank You to bnoon For This Useful Post:
Abilor (06-27-2011), ak_spray (06-14-2012), Constantin (05-10-2012), Dasleeper (02-28-2012), FreeFlyFreak (06-21-2009), hartungenator (03-17-2010), jack_hammer (11-01-2011), keychain12 (10-13-2013), labikesrcool (06-19-2011), Menace1 (04-14-2013), mike8748 (03-18-2010), p057 (01-09-2012), sjdannen (11-26-2017), SLOWHATCH (02-14-2012), TexasSpeed3 (11-26-2011), urbansurfer (08-18-2011)
 Old 06-21-2009, 11:43 AM   #2
bnoon's Avatar
This post will take you through how to make your own restrictor bolt from a regular M12x1.5 pitch bolt. Below shows the part number of the bolt you need. I got these from Advance Autoparts store. They had to order them in this length for me (30mm length).
This is the bit I used from True Value Hardware store. #52 is roughly .0635" in size.
Drill the small side hole first with the #52 bit. Center punch the bolt about 4 threads down from the head. You only need to drill about halfway though or so on this hole to meet the center hole you'll drill next. Do it this way first because if you don't, you run the risk of breaking the bit if you drill the center hole first (bits tend to break when they drill through the far side of the drilled material)
Drill the center hole last. I used a 15/64" bit for the center hole I believe.
That about it. I used a small deburring rasp made for making custom sized carb jets to take the side holes out to about .065", but just deburr the best you can with the bit itself and you'll be fine.
p057 and Prodigalson like this.
2002 BMW M3 - Sold!
bnoon is offline
The Following 17 Users Say Thank You to bnoon For This Useful Post:
Abilor (05-26-2011), ak_spray (06-14-2012), bioevolve (07-01-2009), Constantin (05-10-2012), Doc (03-02-2010), Fobio (07-13-2009), jack_hammer (11-01-2011), Jsn_Rob (08-17-2012), labikesrcool (06-19-2011), Menace1 (04-14-2013), p057 (01-09-2012), phillyb (07-01-2009), Prodigalson (02-14-2017), psychophyr (11-27-2011), rfinkle2 (05-23-2011), sjdannen (11-26-2017), urbansurfer (08-18-2011)
 Old 06-21-2009, 12:43 PM   #3
Addikted To Boost's Avatar
Posts: 1,837   (View Stats)
sweet nice write up man and good work on fixing this annoying problem its about damn time somebody figured it out. I will be getting one from you friday when i get payed to go along with my saikou michi catch can and hopefully that will stop my 09 from smoking and all i have is a test pipe.
09 MGM MS3
Addikted To Boost is offline
 Old 06-21-2009, 01:20 PM   #4
J-villa's Avatar
Posts: 354   (View Stats)
J-villa is the leader of the worldJ-villa is the leader of the worldJ-villa is the leader of the worldJ-villa is the leader of the worldJ-villa is the leader of the worldJ-villa is the leader of the worldJ-villa is the leader of the worldJ-villa is the leader of the worldJ-villa is the leader of the worldJ-villa is the leader of the worldJ-villa is the leader of the world
Groans: 46
In the last picture, it's the Top gold colored bolt, correct? A banjo bolt in the pball world looks like the one on the side that looks to be an allen head screw.
Om Nom Nom
[Flickr]
J-villa is offline
 Old 06-21-2009, 05:17 PM   #5
bnoon's Avatar
Yes, the zinc coated bolt. Here's a pic of the stock next to a restrictor (some are zinc coated, others are black oxide as hardware is scarce in this size). This is one of the bolts that ended up not working, but you get the idea.
EDIT: Here's what a banjo body looks like in the automotive world. Used at brake line connections, clutch connections, oil fittings, etc. Also used a lot in the hydraulic industry.
2002 BMW M3 - Sold!
bnoon is offline
The Following User Says Thank You to bnoon For This Useful Post:
phillyb (06-21-2009)
 Old 06-21-2009, 05:24 PM   #6
phillyb's Avatar
Posts: 14,702   (View Stats)
Groans: 1,940
elaborate please
phillyb is offline
 Old 06-21-2009, 05:26 PM   #7
bnoon's Avatar
Edited above post for you.
2002 BMW M3 - Sold!
bnoon is offline
 Old 06-21-2009, 05:32 PM   #8
phillyb's Avatar
Groans: 1,940
thanks, but i meant more like, what is this?
what am i reading about and what does this do...
pardon my ignorance
phillyb is offline
 Old 06-21-2009, 05:47 PM   #9
Race Roots's Avatar
Posts: 885   (View Stats)
Race Roots is the leader of the worldRace Roots is the leader of the worldRace Roots is the leader of the worldRace Roots is the leader of the worldRace Roots is the leader of the worldRace Roots is the leader of the worldRace Roots is the leader of the worldRace Roots is the leader of the worldRace Roots is the leader of the worldRace Roots is the leader of the worldRace Roots is the leader of the world
Groaned at 18 Times in 18 Posts
If I am not mistaken he is trying to reduce the amount of oil going into the CRHA. I think he is trying to reduce the amount of oil being burned. Hence his other thread but I could be wrong.
Race Roots is offline
 Old 06-21-2009, 08:28 PM   #10
J-villa's Avatar
Groans: 46
Click this Philly. IT explains it all
Om Nom Nom
[Flickr]
J-villa is offline
 Old 06-22-2009, 03:59 AM   #11
phillyb's Avatar
Groans: 1,940
ugh, i was trying to avoid that thread. thanks villa
phillyb is offline
 Old 06-26-2009, 12:18 PM   #12
bnoon's Avatar
Resistance is futile! :phillyb:
2002 BMW M3 - Sold!
bnoon is offline
 Old 07-01-2009, 05:24 PM   #13
bnoon's Avatar
Updated second post.
2002 BMW M3 - Sold!
bnoon is offline
 Old 07-01-2009, 05:54 PM   #14
mine should be here tomorrow thank god my car is smoking a lot lately. are you using grade 8 bolts?
09 MGM MS3
 Old 07-01-2009, 06:39 PM   #15
phillyb's Avatar
Groans: 1,940
shit is dope. thanks
phillyb is offline
 Old 07-02-2009, 02:15 PM   #16
Default No more smoke
Well i just got through installin my bnoon bolt (im claiming that term) and no more smoke. Just for good measure i let my car idle for about two minutes before i installed it and guess what, after two minutes blue smoke was pouring out the back, big surprise and i only have a test pipe. The install was pretty easy and once i fired her back up and let it sit for 8 minutes, not a puff of smoke at all. I am concerned though about one thing, the stock bolt has a small hole drilled all the way through it near the head, the bolt i got from bnoon only has a hole in one side of the bolt that doesnt go all the way through.... is everyone else's who got one of these like that? I hope i dont have to go uninstall all this shit because my bolt was fucked up.... but anyway if it was intentional good fucking job man im glad somebody finally figured this shit out. I also have a saikou michi catch can installed which seems to help in the process according to bnoon. Im glad i got one of these while they lasted...
09 MGM MS3
 Old 07-02-2009, 03:52 PM   #17
bnoon's Avatar
Yes, it's supposed to only be drilled on one side to restrict flow down to .065".
2002 BMW M3 - Sold!
bnoon is offline
Addikted To Boost (07-02-2009)
 Old 07-02-2009, 03:57 PM   #18
awesome man thanks a lot.
09 MGM MS3
 Old 07-04-2009, 08:48 PM   #19
MSF Punished Member
Shu_Hayate09's Avatar
Posts: 93   (View Stats)
Shu_Hayate09 will become famous soon enoughShu_Hayate09 will become famous soon enough
Groaned at 35 Times in 19 Posts
dude... love the pics
DarkAngel likes this.
Shu_Hayate09 is offline
 Old 07-06-2009, 07:26 PM   #20
kgb
kgb's Avatar
Posts: 808   (View Stats)
kgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the world
Groans: 88
I really appreciate you doing this....I now feel secure with my OCC, thicker oil, 900 idle and now bnoon-bolt.
FAST & FURIOUS... MazdaSpeed CBE - CNT Downpipe (diode trick) - Cp-e Nano - Autotech Internals - AMSOIL Signature Series 5W-30 Motor Oil - NGK 1-Step Colder Plugs
WHEEL HOP...........Cp-e RMM (75) - Cobb SS - TMW Shifter Brushings - Cobb Shifter Weight - H&R Springs - Hawk HPS Pads (Front) - CS Pads (Rear) - JBR Rear Cambers - JBR 5mm Wheel Spacers - JBR Rear Sway Bar - NATOR Clutch By-Pass - Nitto NT05s
AL GORE...............EGR Block, Valve Delete - JBR TB Coolant Bypass - NATOR Air Reroute to SRI
MMMM BRAINS.....Dashhawk (Mounted) - Hypertech Tune - SWAStika Oppression Defeated[SIGPIC][/SIGPIC] - DSC LED Reroute
JAM SESSION........US Amps (in Series w/ Stock Amp) using
OEM Speakers for Mids & Highs Only - Bazooka 8" Amplified (Got my trunk back)
RICE.................. NATOR Interior Red LEDs - NATOR Engine Blue LEDs - Advanced Film Solutions Tint - NATOR Gun Metal Stock Wheels - Ventshade Deflectors
- Acne Rear Bumper LED Reflectors
kgb is offline
 Old 07-06-2009, 07:54 PM   #21
Speedn3's Avatar
Posts: 642   (View Stats)
Speedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond repute
if anyone else takes this on i'd like to purchase one. don't have access to a drill press.
Speedn3 is offline
 Old 07-13-2009, 10:11 AM   #22
bnoon's Avatar
Updated my "Quest to cure..." thread in the turbo induction section. Making another batch.
Anyone else installed their bolt yet? Any troubles?
2002 BMW M3 - Sold!
bnoon is offline
 Old 07-13-2009, 10:59 AM   #23
Driver
Fobio's Avatar
Posts: 2,479   (View Stats)
Groans: 44
I'm interested in one of your bolts, but I hear you don't ship to Canada...lemme know if that changes.
-- Mario Andretti --
Fobio is offline
The Following User Says Thank You to Fobio For This Useful Post:
mazda-speed-3 (06-04-2014)
 Old 07-13-2009, 11:58 AM   #24
bnoon's Avatar
I will do it for actual shipping charges now. I talked to the UPS Store today and got setup so that it won't take me so long to ship international items.
lincam182 likes this.
2002 BMW M3 - Sold!
bnoon is offline
Fobio (07-13-2009)
 Old 12-03-2009, 01:23 PM   #25
shpankey's Avatar
Posts: 496   (View Stats)
shpankey is the leader of the worldshpankey is the leader of the worldshpankey is the leader of the worldshpankey is the leader of the worldshpankey is the leader of the worldshpankey is the leader of the worldshpankey is the leader of the worldshpankey is the leader of the worldshpankey is the leader of the worldshpankey is the leader of the worldshpankey is the leader of the world
Thank you for this. I'd love to buy one of your bolts as well. Email me: shpankey@gmail.com
Last edited by shpankey; 12-03-2009 at 02:00 PM. Reason: MSF Database - Automerged Doublepost
shpankey is offline
 Old 12-13-2009, 09:43 AM   #26
justang's Avatar
Posts: 19   (View Stats)
justang is an unknown quantity at this point
are these still being made? I may take one if you make another batch
2008.5 Mazdaspeed 3 AEM CAI, Forge BoV
justang is offline
 Old 12-14-2009, 07:23 AM   #27
bnoon's Avatar
Yes, I can still make these. I've had them on EBay from time to time too. Paypal is brad@bnmotorsports.com, just make sure to PM me if you send funds as I don't check that email account very often anymore.
2002 BMW M3 - Sold!
bnoon is offline
MarylandSpeed (05-08-2013)
 Old 12-15-2009, 10:00 PM   #28
keke's Avatar
Posts: 53   (View Stats)
keke is a glorious beacon of lightkeke is a glorious beacon of lightkeke is a glorious beacon of lightkeke is a glorious beacon of lightkeke is a glorious beacon of light
Could you e-mail me on how much it is shipped to Minnesota? xtreme_nickel@hotmail.com
keke is offline
 Old 12-15-2009, 10:47 PM   #29
flyrevs2's Avatar
Posts: 1,235   (View Stats)
looking for a bit of advise, my car has never smoked and I don't have the bnoon bolt currently installed, however I do have the PTP PVC restrictor on the car.
Now I have a DP and there is never any smoke. Should I install the bnoon bolt or just leave well enough alone ? THANKS
2013 Mazdaspeed3 Gen2
flyrevs2 is offline
 Old 01-07-2010, 08:27 PM   #30
Caldazar's Avatar
Posts: 293   (View Stats)
Caldazar has a reputation beyond reputeCaldazar has a reputation beyond reputeCaldazar has a reputation beyond reputeCaldazar has a reputation beyond reputeCaldazar has a reputation beyond reputeCaldazar has a reputation beyond reputeCaldazar has a reputation beyond reputeCaldazar has a reputation beyond reputeCaldazar has a reputation beyond reputeCaldazar has a reputation beyond reputeCaldazar has a reputation beyond repute
so, pls forgive the possible newbie question, but my take on this is that we have to restrict the oil flow to the CHRA of the stock turbo?
And we KNOW that 065 is the correct size? Is/was there any thought on UNDER oiling the turbo?
Also, does it have to be in the bolt itself or is it just anything in the oil feed line/bolt/banjo fitting itself?
Thanks for the great effort!
06 Speed6, camber balljoints and alignment, HankookV12 Evos, Konigs, Corksport full intake system, PTP pump internals, Cobb Ap, Forge BPV. Daily driver
91 Talon TSi, 5spd AWD, GT3076R, fmic, 3" exhaust, Jackal EMS, methanol injection, JIC C/O and more. Looking at 10's
Caldazar is offline
 Old 01-10-2010, 06:13 PM   #31
carfanatic101's Avatar
Posts: 25   (View Stats)
carfanatic101 has a spectacular aura aboutcarfanatic101 has a spectacular aura about
carfanatic101 is offline
 Old 01-11-2010, 04:44 PM   #32
cl45music's Avatar
Posts: 12   (View Stats)
cl45music is an unknown quantity at this point
I have already ordered the PTP Fix and hopefully it will be here soon.
Should I get one of your bolts as well (Bnoon)??
How do I order one of your bolts?
08.5 Mazdaspeed 3:CP-E Nano,CP-E Standback EMS w PNP,Custom DP w GHL Catback, Custom FMIC,H&R Sport Springs w SPC Rear Cambers,Turbosmart DP BOV
cl45music is offline
 Old 02-06-2010, 03:35 PM   #33
bnoon's Avatar
Sorry, I don't check this thread much anymore. I found out after much begging and pleading that .060" is recommended minimum size per 2 rebuild shops that specialize in rebuilt KKK turbos. I started at .090" size and worked my way down and got the best results at .065".
My trials are documented on this site as to what I did to get rid of the oil/smoke burning issue due to crankcase overpressurization. Thicker oil, catch can, second PCV... even the PTP pill works all of the time except on trailing throttle, which my bolt gets rid of, so I run both. I'm currently working with electric vacuum modules to increase vacuum on the crankcase, especially under boost. Also need to prove/disprove that the stock PCV valves don't seal under boost well enough. Stay tuned... eventually.
2002 BMW M3 - Sold!
bnoon is offline
Caldazar (02-06-2010)
 Old 02-06-2010, 06:04 PM   #34
Caldazar's Avatar
Thanx.
As well, I have done some research on this issue with other cars as I have been involved with turbo Talons for 8 years or so now. People who have upgraded thier turbos to certain kinds often end up with smoking issues due to over oiling. It turns out that, yes, too much inlet oil is a bad idea, but ALSO having adequate oil drainage is just as important.
I have not had a chance to look at the drain tube on the MZR yet. Is this adequate?
Caldazar is offline
 Old 03-02-2010, 07:41 AM   #35
bnoon's Avatar
Thanx.
Oil drain back is either 1/2" or 5/8", can't remember for sure. It will easily outflow the oil feed side, especially with the restrictor.
2002 BMW M3 - Sold!
bnoon is offline
 Old 03-02-2010, 05:35 PM   #36
Caldazar's Avatar
Cool, thanx for the info.
Caldazar is offline
 Old 03-03-2010, 07:09 PM   #37
azokaei's Avatar
Posts: 75   (View Stats)
azokaei is just really niceazokaei is just really niceazokaei is just really niceazokaei is just really nice
i sent you a pm bnoon about ordering one i just ordered my ptp pcv fix and im gonna change my oil to a thicker one any recommendations? How does 5w-40 sound and which brand should i use?
Thanks,
Alex
azokaei is offline
 Old 03-17-2010, 04:54 AM   #38
hartungenator's Avatar
hartungenator will become famous soon enoughhartungenator will become famous soon enough
HMMM... on ebay I found a similar bolt, the item number on ebay is 280479927007, but I'm not sure if the bolt is too long or too short. Anyone try the ebay one?
hartungenator is offline
 Old 03-18-2010, 05:36 AM   #39
gamma500's Avatar
Posts: 38   (View Stats)
gamma500 is a splendid one to beholdgamma500 is a splendid one to beholdgamma500 is a splendid one to beholdgamma500 is a splendid one to beholdgamma500 is a splendid one to beholdgamma500 is a splendid one to beholdgamma500 is a splendid one to behold
Anyone know what the stock bolt's orifice size is ?
gamma500 is offline
 Old 03-18-2010, 01:54 PM   #40
bnoon's Avatar
Thanks,
Alex
My favorite is Royal Purple 20w50 in summer and 5w40 in winter. I've tried just about everything else and seem to get the best results with RP. Amsoil is good too, but doesn't "smell" as good at oil changes, almost like the oil is breaking down a little bit.
That's not a restrictor bolt, it's an adapter to go to -4AN to feed an aftermarket turbo. Judging from what's pictured, the length looks correct at about 25-30mm. The feed hole is too large to be a proper restrictor though.
Two feed holes, about .090 or .095 on both holes if I remember right.
2002 BMW M3 - Sold!
bnoon is offline
The Following 2 Users Say Thank You to bnoon For This Useful Post:
Sebs6 (10-18-2013), sjdannen (11-26-2017)
Closed Thread
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f33/oil-restrictor-bolt-install-30577/
Mazdaspeed 3 White Smoke From Exhaust | DIY Reviews! This thread Refback 01-14-2016 07:17 PM
Banjo bolt - one size fits all ? ? Mazda MPS Owners Club This thread Refback 09-01-2015 02:42 AM
Mazdaspeed 3 white smoke from exhaust | Car Exhaust Emissions This thread Refback 01-12-2015 11:50 AM
US 'exhaust smoke fixes' - anyone tried them? ? Mazda MPS Owners Club This thread Refback 11-06-2014 12:00 PM
PCV Fix This thread Refback 08-26-2014 01:30 AM
How to make a bnoon bolt - 1Q5A This thread Refback 08-17-2014 10:14 PM
Oil Restrictor Bolt - ?????? - OPC ???? This thread Refback 08-05-2014 12:42 AM
Smokey Exhaust This thread Refback 07-23-2014 11:03 AM
Banjo bolt - one size fits all ? This thread Refback 06-02-2014 05:05 PM
Forum Mazda Performance Series - Zobacz temat - Bonjo Bolt This thread Refback 05-13-2014 01:55 PM
Oil banjo bolt - K04 - Page 2 This thread Refback 03-04-2014 06:05 PM
?????????? - ??????? (??????????, ???????, ??????) This thread Refback 02-28-2014 02:41 PM
US 'exhaust smoke fixes' - anyone tried them? This thread Refback 02-10-2014 04:03 PM
Banjo bolt - one size fits all ? ? Mazda MPS Owners Club This thread Refback 09-30-2013 01:29 AM
Restriktor wie von ptp - Seite 2 This thread Refback 04-03-2013 07:28 AM
PCV Fix ? Mazda MPS Owners Club This thread Refback 03-18-2013 09:49 AM
Banjo bolt - one size fits all ? ? Mazda MPS Owners Club This thread Refback 03-14-2013 04:17 PM
Lumpy idle following service and banjo bolt fitting - 6 MPS ? Mazda MPS Owners Club This thread Refback 03-14-2013 04:04 PM
Heller, leicht blauer Auspuff qualm... - Seite 6 This thread Refback 02-18-2013 03:40 AM
Heller, leicht blauer Auspuff qualm... - Seite 5 This thread Refback 02-17-2013 11:25 AM
Japanese version of the Bnoon bolt ? Mazda MPS Owners Club This thread Refback 02-07-2013 01:01 AM
PCV Fix ? Mazda MPS Owners Club This thread Refback 01-17-2013 01:06 PM
Smokey Exhaust ? Mazda MPS Owners Club This thread Refback 12-17-2012 12:45 PM
US 'exhaust smoke fixes' - anyone tried them? ? Mazda MPS Owners Club This thread Refback 12-16-2012 07:59 AM
bnoon/oil restrictor bolt This thread Pingback 11-15-2012 10:31 PM
Smoky exhaust • Mazda MPS Owners Club This thread Refback 10-30-2012 04:00 AM
PCV Fix • Mazda MPS Owners Club This thread Refback 10-28-2012 03:31 PM
Fixing "white smoke" problem (not in warranty) - in Melb - Page 5 This thread Refback 10-13-2012 12:43 AM
Mazda MPS Owners Club • View topic - US 'exhaust smoke fixes' - anyone tried them? This thread Refback 08-28-2012 10:48 PM
Turbo Focuzzz This thread Refback 07-14-2012 05:33 PM
Rauchentwicklung bei den L3K9/L3T Motoren - Seite 18 This thread Refback 06-24-2012 04:23 AM
MPS6: ????? TMIC Upgrade ????? ???. This thread Refback 04-16-2012 02:56 PM
Mazda MPS Owners Club • View topic - Japanese version of the Bnoon bolt This thread Refback 03-25-2012 08:40 AM
Oil Restrictor Bolt - OPC ???? This thread Refback 03-14-2012 03:38 PM
Quelques conseils pour aller en stg2 - Mazda 3 Quebec This thread Refback 01-14-2012 08:47 AM
Oil Restrictor Bolt - Opel Performance Center Club Russia This thread Refback 12-27-2011 02:26 PM
Mazda Owners Club SA • View topic - Smokey This thread Refback 09-07-2011 08:49 AM
Mazda MPS Owners Club • View topic - Smoky exhaust This thread Refback 06-03-2011 01:45 PM
Mazda MPS Owners Club • View topic - Japanese version of the Bnoon bolt This thread Refback 06-02-2011 06:17 AM
Mazda MPS Owners Club • View topic - US 'exhaust smoke fixes' - anyone tried them? This thread Refback 05-02-2011 11:59 AM
Mazda MPS Owners Club • View topic - PCV Fix This thread Refback 04-13-2011 11:36 AM
Modding the wifes car This thread Refback 04-02-2011 11:31 AM
Mps6 tyhjäkäyntisavutus This thread Refback 02-24-2011 01:28 PM
Mazda MPS Owners Club • View topic - Smokey Exhaust This thread Refback 02-10-2011 03:38 PM
Mazda MPS Owners Club • View topic - US 'exhaust smoke fixes' - anyone tried them? This thread Refback 01-09-2011 07:07 AM
Finally stops my smoking after DP installed This thread Refback 11-17-2010 12:28 AM
Oil banjo bolt - K04 This thread Pingback 06-21-2010 07:09 AM
Rauchentwicklung bei den L3K9/L3T Motoren This thread Refback 06-15-2010 07:55 AM
Fixing This thread Pingback 04-29-2010 10:31 PM
Oil Restrictor Bolt - Opel Performance Center ???? This thread Refback 02-27-2010 05:37 AM
Getting new intercooler bolt? iracer7 MazdaSpeed 3 - Engine, Transmission & Driveline 11 05-18-2009 04:28 PM
Broken Lug Bolt(s) MrBig MazdaSpeed 3/6 - Wheels & Tires 4 01-20-2009 11:47 AM
Full Bolt-On MS3 07cobaltss/sc Mazdaspeed3/6 General Discussion 20 12-24-2008 01:05 PM
2871 really bolt on? Speedie6 Mazdaspeed3/6 General Discussion 15 10-03-2008 01:03 PM
Page generated in 0.62341 seconds with 39 queries
