> MazdaSpeed 3 - How-To's
 Old 07-09-2012, 10:57 AM   #1
Default Oil Spin On/ Sammich Plate How-to
So I know we have a spin on write up but I think some of the pictures got lost in the crash back in the day. So last week we decided we needed to get going on the shop car and install some gauges that have been laying around for a while.
First you want to drain your oil. After that remove the canister and as well as the let all the oil sensor pressure so you have greater access to the 4 bolts you have to remove.
This picture shows the oil pressure sensor removed.
After that remove the 4 bolts that hold the oil cooler on they are 10mm iirc
The biggest challenge you will have is getting off the drivers side top bolt but if you use a wobble extension on a 1/4 inch drive it will get to it will ease.
Once you have those out pull the the oil cooler down and take off the bolt that holds it in place. That will be a 15mm on the top of the cooler, here is a picture.
Once you take that out the cooler will be able to come off.
Next we got out sammich plate and spin on conversion ready with all the plugs. Leave the sensors off till last so they dont get in the way of putting everything back on. Make sure and use thread sealant liquid and not teflon tape on these fittings
After all that re-install in reverse order and this is what the final product should look like.
The Following 13 Users Say Thank You to EdgeAutosport.com For This Useful Post:
breakfstincluded (07-09-2012), Code Monkey (07-09-2012), Dahouse702 (07-09-2012), flappypaddles (09-05-2015), GAMISTAD (07-09-2012), Gibbo (11-03-2013), mazdafreak (07-30-2013), ms3blackmica (07-10-2012), Ms3_Miami (11-17-2012), Raider (07-09-2012), redmnsterut (07-09-2012), SKiZ0TT (07-09-2012), TiGraySpeed6 (07-09-2012)
 Old 07-09-2012, 11:44 AM   #2
TiGraySpeed6's Avatar
Posts: 3,981   (View Stats)
Thanks!
340hp / 371tq
codykemmet (07-09-2012), EdgeAutosport.com (07-09-2012)
 Old 07-09-2012, 11:57 AM   #3
breakfstincluded's Avatar
Posts: 3,588   (View Stats)
I think I might be blind but...
I didn't see it, do you guys sell the spin on oil conversion?
I definitely saw the sammich plate.
 Old 07-09-2012, 11:59 AM   #4
SKiZ0TT's Avatar
Posts: 542   (View Stats)
SKiZ0TT is the leader of the worldSKiZ0TT is the leader of the worldSKiZ0TT is the leader of the worldSKiZ0TT is the leader of the worldSKiZ0TT is the leader of the worldSKiZ0TT is the leader of the worldSKiZ0TT is the leader of the worldSKiZ0TT is the leader of the worldSKiZ0TT is the leader of the worldSKiZ0TT is the leader of the worldSKiZ0TT is the leader of the world
Groans: 33
Very cool and definitely on my shopping list to get.
2008.5 MAZDASPEED3 GT - SOLD
2004 MAZDASPEED Miata
SKiZ0TT is offline   Reply With Quote
The Following User Says Thank You to SKiZ0TT For This Useful Post:
 Old 07-09-2012, 12:05 PM   #5
Yeah we do they are just not on the site at the time
 Old 07-09-2012, 12:14 PM   #6
Must Have Teh 10's!
superskaterxes's Avatar
Posts: 10,442   (View Stats)
eric, what gauge is that?
First K04 in the 12's
First MS6 in the 11's
Certified RichTune E-Tuner
EdgeAutosport.com (07-10-2012)
 Old 07-09-2012, 12:19 PM   #7
Stack
Stack
Stack gauges.....
STACK World Class Instrumentation, Data-logging, TPMS & Video.
340hp / 371tq
 Old 07-09-2012, 12:20 PM   #8
They are stack gauges and iirc they are found in the lotus's of le world
 Old 07-09-2012, 12:36 PM   #9
Must Have Teh 10's!
fml teh $$$$$
 Old 07-09-2012, 12:38 PM   #10
sassyspeed3's Avatar
Posts: 1,054   (View Stats)
sassyspeed3 is the leader of the worldsassyspeed3 is the leader of the worldsassyspeed3 is the leader of the worldsassyspeed3 is the leader of the worldsassyspeed3 is the leader of the worldsassyspeed3 is the leader of the worldsassyspeed3 is the leader of the worldsassyspeed3 is the leader of the worldsassyspeed3 is the leader of the worldsassyspeed3 is the leader of the worldsassyspeed3 is the leader of the world
very nice, thank you for this. the one i ordered from you guys is sitting in my garage till the next oil change.
2013 Mitsubishi Lancer Evolution GSR
2008 Red MS3
BT & All
Eth Mix - 460hp/429tq
Pump - 411hp/403tq
**SOLD**
[02:58 PM] dturboman: and ZZB will happen one day, its just how long you can avoid it for
[09:15 PM] Erich: if you aren't notching your block, your turbo isn't big enough
sassyspeed3 is offline   Reply With Quote
The Following User Says Thank You to sassyspeed3 For This Useful Post:
 Old 07-09-2012, 01:02 PM   #11
Speeden6's Avatar
Posts: 598   (View Stats)
Speeden6 is the leader of the worldSpeeden6 is the leader of the worldSpeeden6 is the leader of the worldSpeeden6 is the leader of the worldSpeeden6 is the leader of the worldSpeeden6 is the leader of the worldSpeeden6 is the leader of the worldSpeeden6 is the leader of the worldSpeeden6 is the leader of the worldSpeeden6 is the leader of the worldSpeeden6 is the leader of the world
The only thing i would add, and this was only my personal experience with the MS6. when removing the oil cooling module on top the oil dongle, you can reach it from the top of the engine very front in between the block and radiator. just look for that 15mm bolt on top, it is VERY easily accessible this way and a extension on your socket wrench, loosen it before you take the bolts off the original oil "dongle". it was a PITA to try to loosen it after the original dongle was off, just couldn't get enough Torque to break it loose.
Also the Gasket that goes from the cooling system to the new spin on, make sure your gasket is seeded right, it has dots on it for the cooling system, if you dont get those lined up you will have a very very slow yet annoying leak between the spin on and cooling system.
2007 MS6 -
CPE TMIC, CS HPFP Internals, CS Stage 2 Intake and Inlet, Turbo Smart 50/50 BPV / BOV, Catless DP
2006 Acura TL Fully bolted and Running Nitrous! 330WHP SOLD
SOLD 1992 Corrado VR6
268 Cams, air intake, cat back, upgrade plugs and wires, coilovers.
SOLD
2001 Audi Allroad
SOLD
2006 MS6 -
CAI, TIP, ETS TMIC, AutoTech Internals, TBE catless, E85 30%,
19PSI, Cobb AP, RMM, K04, HKS SSQ4 VTA,
TUNED BY LEX FOR 330 AWHP / 380 TQ
Custom tune by
The habits we form today are the ones that Define us tomorrow
Speeden6 is offline   Reply With Quote
The Following 2 Users Say Thank You to Speeden6 For This Useful Post:
EdgeAutosport.com (07-09-2012), GAMISTAD (07-09-2012)
 Old 07-09-2012, 01:18 PM   #12
JP just told me ordered 20 units so let me know who wants spin on love
 Old 07-09-2012, 01:23 PM   #13
I assume its still 6qts with spin on filter?
Or is it still 6qts but theres even lesss risk of overfilling now
 Old 07-09-2012, 01:28 PM   #14
I <3 your mom
Dash08's Avatar
Posts: 7,166   (View Stats)
Groans: 293
I just want to clear a couple things up because I'm fucked up that way.
The aluminum part that bolts to the block is the housing. The black part attached to the top of the housing is the oil cooler.
Try to loosen that 15mm oil cooler bolt before you remove the housing. It's a bitch when it's off due to lack of leverage. Plus, it's on there pretty tight.
Also, if you are using teflon tape on the sandwich plate fittings, be sure to set it back about 3 or 4 threads from the tip to ensure it doesn't get into your oil.
this forum serves 2 purposes
The Following 2 Users Say Thank You to Dash08 For This Useful Post:
EdgeAutosport.com (07-10-2012), memin (08-26-2012)
 Old 07-09-2012, 02:05 PM   #15
Speeden6's Avatar
i like the word "Dongle" better than "housing" but that is just me. J/K! thanks for correcting my horrible part descriptions!
2007 MS6 -
SOLD
2001 Audi Allroad
SOLD
2006 MS6 -
Custom tune by
Dash08 (07-09-2012), EdgeAutosport.com (07-10-2012)
 Old 07-09-2012, 07:11 PM   #16
meicalnissyen's Avatar
Posts: 1,158   (View Stats)
Hmmmmm,.... Kostet Das ??
 Old 08-26-2012, 11:54 AM   #17
free_refil's Avatar
Posts: 349   (View Stats)
free_refil has a reputation beyond reputefree_refil has a reputation beyond reputefree_refil has a reputation beyond reputefree_refil has a reputation beyond reputefree_refil has a reputation beyond reputefree_refil has a reputation beyond reputefree_refil has a reputation beyond reputefree_refil has a reputation beyond reputefree_refil has a reputation beyond reputefree_refil has a reputation beyond reputefree_refil has a reputation beyond repute
Anybody do this and have their oil cooler gasket look like this??? If so, did ya reuse it and was it OK? I got into an accident and oil was leaking from my oil cooler, but I'm curious if it was just knocked loose as the bolt holding it on was not hard to get off at all, or if this is a no go and I need a new oil cooler
http://www.mazdaspeedforum.org/forum/foru...mg_7201-1-.jpg
'09 MS3 Sport, cp-e Xcel™ CAI w/Hydroshield, Cobb TIP, Forge BPV, TRZ RMM, JBaron SSP, MSD DH w/cp-e mount, Koni FSD's, Viper 5701 Remote Start/Alarm, AVIC-F700BT & JL 8W7 in Modified Stealthbox
free_refil is offline   Reply With Quote
 Old 08-26-2012, 11:57 AM   #18
There's a thread you can find by searching "spin on" i saw here.
A guy did his spin on and was leaking after, he took it off and looked at it and found the O-ring was severed in the outer right, it lookede like it fit just right otherwise.
But that tiny little thing caused the leak.
The Following 2 Users Say Thank You to breakfstincluded For This Useful Post:
free_refil (08-26-2012), TiGraySpeed6 (08-26-2012)
 Old 04-28-2018, 11:22 AM   #19
APEXistud's Avatar
Posts: 57   (View Stats)
APEXistud is a splendid one to beholdAPEXistud is a splendid one to beholdAPEXistud is a splendid one to beholdAPEXistud is a splendid one to beholdAPEXistud is a splendid one to beholdAPEXistud is a splendid one to beholdAPEXistud is a splendid one to behold
Necro Posting here, but could you possibly refresh this post so the pictures are viewable again. I bought this spin-on kit a month ago and about to attempt the install and would love to see the pics.
"off to youtube for a video"
APEXistud is offline   Reply With Quote
 Old 04-28-2018, 03:03 PM   #20
JSmith's Avatar
Posts: 707   (View Stats)
Groans: 106
@APEXistud;
Try this. The pics in this thread works for me. Someone else posted the link info on here, not my find
https://addons.mozilla.org/en-US/fir...d-fix/?src=api
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f33/oil-spin-sammich-plate-how-118433/
Change oil filter - Page 3 This thread Refback 11-23-2012 08:00 AM
How to do a spin on and sandwich plate conversion rodrigo MazdaSpeed 3 - How-To's 102 09-15-2011 09:58 PM
prosport sammich plate phillyb MazdaSpeed 3 - Engine, Transmission & Driveline 18 05-18-2009 11:21 AM
Page generated in 0.43571 seconds with 31 queries
