> MazdaSpeed 3 - How-To's
  • 1 Post By qtrmile beast
 Old 10-18-2012, 02:57 PM   #1
qtrmile beast's Avatar
Posts: 2,423   (View Stats)
Default Pulling the cams in the MZR
The HOW-TO is to show you how to pull your cams without pulling the head or timing cover.
Step one pull the valve cover. For those that have a TMIC pull that first.
At this point you will see the cams and the timing chain. Also while you are in there take a look on the underside of the valve cover above where the timing chain is to see if the chain has been hitting the valve cover. This is an indication that the chain may have been hitting and that is a sign of your chain or tensioner is going bad.
Next step is to pull the high pressure fuel pump housing:
Here are the bolts to the fuel pump housing.
Removed....
This line goes to the fuel rail..
Fuel pump harness and Feed and Return line:
Next install your blind plug.
Note i pulled one of the timing cover bolts and installed that in the BLIND PLUG hole. make sure you use the UPPER BLIND PLUG HOLE to do this. Also when installing it there is no need to TORQUE is down just go far enough til you feel a little tension. TIP: It might be best to use a 1/4in ratchet for this... This step is down so that when you loosen the exhaust cam sprocket to get the chain loose you will not loose tension on the tensioner because the timing chain guide will prevent that.
Next pull the EXHAUST CAM sprocket.
Next step is to pull the cam caps:
NOTE on the cam cap you will see numbers on each of them. Pay attention to the letters and the arrow that are inscribed on each of the caps. This pic shows the inscribed letter E 2 and also you see the arrow. The "E" is for exhaust and the "2" is for the second cap and the arrow is the direction the arrows should be pointing.
Now just lift your cam out of the head..
This is what it looks like with the cams out..
Roddiy likes this.
track weight 3220
street weight 3370
The Following 8 Users Say Thank You to qtrmile beast For This Useful Post:
aaron_-01 (10-18-2012), Alpha (10-18-2012), BobbleHead (10-18-2012), Neubreed (01-10-2014), Roddiy (10-18-2012), speed14 (10-18-2012), Speed3eak (10-18-2012), TiGraySpeed6 (10-18-2012)
 Old 10-18-2012, 03:24 PM   #2
Now putting it back together............
If you didn't already have the pistons at TDC this is how you can find it....
VIDEO (This video is without the timing cover on)
This is for those that have the cover still installed and want to see what the crank bolt is doing..
If you done have the proper SST (CRANK ALIGNMENT TOOL) don't worry you can use this..
when you have found TDC install this until you feel a little tension. You dont have to tighten down as there is a flat spot on the crank that this will rest on and will prevent the crank from turning. FYI this will not prevent the crank from turning if you are trying to loosen the CRANK BOLT only when tighting it. No need to do anything with the crank bolt for this how-to FYI...
Now that you have found and lock down TDC you can install your cams.
Again there is no need to pull the timing cover...
Make sure that when you install the cams that the first lobe on the passengerside of the motor(timing chain side) are almost pointing to each other (ie. The exhaust cam lobe is pointing toward the intake cam lobe. This is TDC for the cams. Make sure this is done BEFORE you install the cam caps. Now install your cam caps with the exhaust caps all are pointing in the same direction and in order by number. Do that same for the intake cam caps. FYI on the last cam cap nearest the CDFP make sure you use some permatex in the grooves located on the underside of the cap. If there is already some on there clean it out and install new permetex.
Here is the SST( cam alignment tool)
Also when tightening the caps you want to do them in sequence like when you do your head. I believe its 12in lbs for each bolt. Once you have done this now you can attach your timing chain to your exhaust sprocket BEFORE YOU BOLT IT YOUR CAM and then while your chain is attached attach the sprocket to the cam. Now with the cover still on the car you will not have a chance to use a torque wrench.
Will update more later....
track weight 3220
street weight 3370
The Following 10 Users Say Thank You to qtrmile beast For This Useful Post:
bcmurphy87 (11-12-2012), BobbleHead (10-18-2012), Kfunk (04-15-2013), Micha (12-15-2013), Neubreed (01-10-2014), rfinkle2 (12-04-2013), Roddiy (10-18-2012), sidekick (02-23-2014), Speed3eak (10-18-2012), TiGraySpeed6 (10-18-2012)
 Old 10-18-2012, 03:44 PM   #3
Roddiy's Avatar
Posts: 5,388   (View Stats)
Groans: 279
Now we just need a good set of Aftermarket cams...
2010 LSM Speed3
#BakeryTuned
The Following User Says Thank You to Roddiy For This Useful Post:
 Old 11-21-2014, 11:36 AM   #4
Bates5450's Avatar
Posts: 4   (View Stats)
Bates5450 can only hope to improve
Groaned at 6 Times in 2 Posts
Thanks for the post. It seems to me that it's easiest to just pull your motor out completely.
Bates5450 is offline   Reply With Quote
The Following 4 Users Say NO Thank You to Bates5450 For This Un-useful Post:
ArmanRus (11-21-2014), ASHMS3 (11-21-2014), JSmith (11-21-2014), mituc (11-21-2014)
 Old 11-21-2014, 12:23 PM   #5
ASHMS3's Avatar
Posts: 1,362   (View Stats)
Groans: 126
Thanks for bumping a 2 year old thread for a useless comment, twatknuckle.
 Old 08-17-2015, 02:27 PM   #6
Dropen's Avatar
Posts: 46   (View Stats)
Dropen will become famous soon enoughDropen will become famous soon enough
Hi,
I was reading your post and i have a question about the bolt of this picture:
It say that the bolt has to be 10x1,5 and the size with the measure tape say that has to be Øx2 3/8", whats the real size of the bolt that i have to use?
Tnx!
Dropen is offline   Reply With Quote
 Old 08-17-2015, 02:50 PM   #7
Originally Posted by Dropen View Post
Hi,
Tnx!
2 3/8" is a bit over 60mm.
In all reality, you can use a longer bolt than needed, provided you can maneuver it into the TDC blind plug hole.
 Old 08-17-2015, 03:02 PM   #8
Gr8Speed's Avatar
Posts: 5,702   (View Stats)
Hi,
Tnx!
M10x1.5 is a dia/thread pitch.
 Old 09-04-2015, 03:30 PM   #9
Jeff23spl's Avatar
Posts: 2,237   (View Stats)
^^^This lol
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
 Old 09-10-2015, 03:19 PM   #10
The length of the bolt doesn't really matter because you have to take the half shaft(AXLE) out to get to the hole anyway. You just want it long enough to reach the crank comfortably. I found that this length was ideal and left about 1/4' left once the bolt was flush against the crank.
http://vid206.photobucket.com/albums...P1010149-1.mp4
This is NOT the bolt in the picture. I think this a head bolt but i think the reason you see me use the wrench is because it was almost out of thread by the time it got snug enough to the crank. Hence the reason i went with the all thread bolt.
track weight 3220
street weight 3370
The Following User Says Thank You to qtrmile beast For This Useful Post:
impossible (01-12-2017)
PT-P regrind cams story -- need Web weld & regrind cams MazdaGaragePat MazdaSpeed 6 - Engine, Transmission & Driveline 30 08-10-2016 03:46 PM
Cams Cams Cams.... blkspeed6 MazdaSpeed 6 - Engine, Transmission & Driveline 11 12-17-2010 08:10 PM
PTP or other CAMS SpeedSixxx MazdaSpeed 6 - Engine, Transmission & Driveline 2 11-27-2009 05:52 PM
PTP Cams does anybody have them? RacingToaster MazdaSpeed 6 - Engine, Transmission & Driveline 12 10-10-2009 11:26 AM
ptp cams? Buildabong MazdaSpeed 3 - Engine, Transmission & Driveline 11 06-14-2009 11:02 PM
Page generated in 0.32817 seconds with 27 queries
